  4. Test Adapter KNX v2.x
421 Beiträge 70 Kommentatoren 165.5k Aufrufe 62 Beobachtet
  • M mpl1338
    habe seit dem Update massig Warnungen im LOG
    knx.0
    2022-01-03 16:27:53.809	warn	Read-only state "knx.0.schalten_status.EG.licht_dali_wc_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 16:27:50.778	warn	Read-only state "knx.0.heizung.wärmepumpe.Wärmepumpe_vorlauf" has been written without ack-flag with value "50.88"
    knx.0
    2022-01-03 16:27:04.329	warn	Read-only state "knx.0.schalten_status.EG.licht_dali_wc_schalten_status" has been written without ack-flag with value "true"
    knx.0
    2022-01-03 16:26:35.801	warn	Read-only state "knx.0.schalten_status.EG.licht_dali_wc_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 16:26:05.559	warn	Read-only state "knx.0.schalten_status.EG.licht_dali_wc_schalten_status" has been written without ack-flag with value "true"
    knx.0
    2022-01-03 16:25:35.448	warn	Read-only state "knx.0.schalten_status.KG.licht_technik_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 16:25:35.397	warn	Read-only state "knx.0.schalten_status.KG.licht_flur_keller_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 16:25:35.344	warn	Read-only state "knx.0.schalten_status.EG.licht_bis_hwr_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 16:18:50.342	warn	Read-only state "knx.0.heizung.wärmepumpe.warmwasser_ist" has been written without ack-flag with value "46.2"
    knx.0
    2022-01-03 16:18:15.332	warn	Read-only state "knx.0.heizung.wärmepumpe.Temperatur_aussen" has been written without ack-flag with value "12.4"
    knx.0
    2022-01-03 16:18:07.896	warn	Read-only state "knx.0.heizung.wärmepumpe.Wärmemenge_Heizen_1-4" has been written without ack-flag with value "3331"
    knx.0
    2022-01-03 16:17:01.705	warn	Read-only state "knx.0.heizung.wärmepumpe.Betriebsstunden_Primärpumpe" has been written without ack-flag with value "3318"
    knx.0
    2022-01-03 15:39:55.683	warn	Read-only state "knx.0.schalten_status.KG.licht_technik_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 15:39:55.632	warn	Read-only state "knx.0.schalten_status.KG.licht_flur_keller_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 15:39:55.579	warn	Read-only state "knx.0.schalten_status.EG.licht_bis_hwr_schalten_status" has been written without ack-flag with value "false"
    knx.0
    2022-01-03 15:34:05.436	warn	Read-only state "knx.0.schalten_status.KG.licht_technik_schalten_status" has been written without ack-flag with value "true"
    knx.0
    2022-01-03 15:34:05.365	warn	Read-only state "knx.0.schalten_status.KG.licht_flur_keller_schalten_status" has been written without ack-flag with value "true"
    knx.0
    2022-01-03 15:34:05.313	warn	Read-only state "knx.0.schalten_status.EG.licht_bis_hwr_schalten_status" has been written without ack-flag with value "true"
    knx.0
    2022-01-03 15:31:17.990	warn	Read-only state "knx.0.heizung.wärmepumpe.Temperatur_aussen" has been written without ack-flag with value "12.700000000000001"
    knx.0
    2022-01-03 15:24:42.497	warn	Read-only state "knx.0.heizung.wärmepumpe.warmwasser_ist" has been written without ack-flag with value "46.4"
    knx.0
    2022-01-03 15:23:13.893	warn	Read-only state "knx.0.heizung.wärmepumpe.Wärmemenge_Heizen_1-4" has been written without ack-flag with value "3330"
    knx.0
    2022-01-03 15:17:01.797	warn	Read-only state "knx.0.heizung.wärmepumpe.Betriebsstunden_Primärpumpe" has been written without ack-flag with value "3317"
    knx.0
    2022-01-03 15:15:10.893	warn	Read-only state "knx.0.heizung.wärmepumpe.Temperatur_aussen" has been written without ack-flag with value "12.8"
    lässt sich das schnell in den griff bekommen?
    chefkoch009C
    chefkoch009C
    chefkoch009
    #197
    @mpl1338 update ist online V2.0.8
    Merlin123M 1 Antwort Letzte Antwort
    • chefkoch009C chefkoch009
      Merlin123M
      Merlin123M
      Merlin123
      #198
      @chefkoch009 Vielen Dank! Scheint zu funktionieren. Sachen lassen sich schalten und Log ist bis jetzt leer.
      Beta-Tester
      • chefkoch009C
        chefkoch009C
        chefkoch009
        #199
        @merlin123 Klasse. Danke für die Rückmeldung. Hast Du schon directLink probiert?
        Wenn die Funktion oder das wie und warum unklar sind, dann erkläre ich es gern einmal, denn offensichtlich ist die Doku dann nicht gut.
        chefkoch009
          chefkoch009
          M
          M
          marlan99
          #200
          @chefkoch009 habe soeben auf 2.0.8 updated und bisher (30 min.) keine Probleme entdeckt.
          directLink bei einem Objekt ebenfalls getestet und funktionierte auf Anhieb.
          Dachte zuerst, dass man damit ein bereits bestehendes Objekt auf ein KNX Objekt bindet, aber es ist ja umgekehrt.
          Der Wert des KNX Objekt wird auf ein ioBroker Objekt gebunden.
          L 1 Antwort Letzte Antwort
          • M marlan99
            L
            L
            loverz
            #201
            @marlan99 was heisst das denn ganz genau, was bewirkt es und bei welchen Fällen braucht man das?
            Hast du ein Beispiel für diese Bindung?
            • L loverz
              M
              M
              marlan99
              #202
              @loverz angenommen du willst dass ein KNX Objekt bei einer Aktualisierung des Wert ein anderes Objekt (Bsp.: 0_userdata.0.example_state) mit diesem Wert beschreibt, dann trägst du bei directLink das Objekt 0_userdata.0.example_state ein.
              Tatsächlich benötige ich den entgegengesetzten Fall.
              Ich messe Temperaturen mit 1wire und beschreibe bei einer Änderung des Wertes ein bestimmtes KNX Objekt für die Heizungssteuerung.
              Aber ich kann mir vorstellen, dass auch der nun verfügbare directLink von nutzen sein kann.
              In meinem Fall nutze ich aktuell weiterhin die javascript blockly Option mit dem Baustein "binde object"
              chefkoch009C 1 Antwort Letzte Antwort
              • M
                M
                mpl1338
                #203
                @chefkoch009 said in Test Adapter KNX v2.x:
                danke funzt.
                Ich hab nun ein anderes Problem wahr genommen. Der Adapter verschluckt den ein oder anderen Befehl. Am meisten merke ich es bei Routinen welche mehrere GAs ansprechen.
                on({id: 'alexa2.0.Echo-Devices.123', change: "any"}, async function (obj) {
                  var value = obj.state.val;
                  if (getState("alexa2.0.Echo-Devices.123").val == true) {
                    setStateDelayed("alias.0.Bad.Deckenlicht.SET"/*Bad Deckenlicht schalten*/, false, 15000, false);
                    setStateDelayed("knx.0.zentral.Szenen.haus_verlassen"/*haus_verlassen*/, 64, 10000, false);
                    if (getState("alias.0.Wetter.Dämmerungsschalter.ACTUAL").val) {
                      setState("alias.0.Bad.Rollladen_Bad.SET"/*Rollladen Bad SET*/, 100);
                    setState("alias.0.Bad.Duschlicht.SET"/*Duschlicht schalten*/, true);
                    setState("alias.0.Bad.Duschablage.ON_SET"/*Duschablage schalten*/, true);
                    setState("alexa2.0.Echo-Devices.123.Player.radioStationId"/*radioStationId*/, 's96355');
                    setState("alexa2.0.Echo-Devices.123.Player.controlPlay"/*controlPlay*/, true);
                    setState("alexa2.0.Echo-Devices.123"/*fertig*/, false);
                // "alexa duschen"
                    setState("alias.0.Bad.Deckenlicht.SET"/*Bad Deckenlicht schalten*/, false);
                    setState("alias.0.Bad.Spiegellicht.SET"/*Bad Spiegellicht schalten*/, false);
                      setState("alias.0.Bad.Rollladen_Bad.SET"/*Rollladen Bad SET*/, 0);
                    setState("alias.0.Bad.Duschlicht.SET"/*Duschlicht schalten*/, false);
                    setState("alias.0.Bad.Duschablage.ON_SET"/*Duschablage schalten*/, false);
                    setState("alexa2.0.Echo-Devices.123.Player.controlPause"/*controlPause*/, true);
                    setState("alexa2.0.Echo-Devices.123"/*Duschen*/, false);
                on({id: 'alias.0.Garage.Garage_verlassen.SET', change: "ne"}, async function (obj) {
                  if (getState("alias.0.Garage.Garage_verlassen.SET").val == true) {
                    console.log('Garage verlassen');
                    setState("alexa2.0.Echo-Devices123.Player.controlPause"/*controlPause*/, true);
                    setState("alias.0.Garage.Steckdose_Kompressor.SET"/*Steckdose Kompressor schalten*/, false);
                    setState("alias.0.Garage.Licht_Garage_hinten.SET"/*Licht Garage hinten schalten*/, false);
                    setState("alias.0.Garage.Garage_Licht.SET"/*Garage Licht schalten*/, false);
                    setStateDelayed("alias.0.Garage.Licht_Garagentorstripes.ON_SET"/*Licht Garagentorstripes schalten*/, false, 2000, false);
                    setState("alias.0.Garage.Garagentor_fahren.SET"/*Garagentor fahren schalten*/, true);
                    if (getState("knx.0.schalten_status.bewaesserung.magnetventil_trafo_schalten_status").val == false) {
                      setState("alias.0.Garage.Steckdose_Brunnen.SET"/*Steckdose Brunnen schalten*/, false);
                    console.log('alles aus');
                      setState("alias.0.Garage.Licht_Torsturz.ON_SET"/*Licht Torsturz schalten*/, true);
                      setState("alias.0.Außen.Licht_Hauswand_Garage.SET"/*Licht Hauswand Garage schalten*/, true);
                      setState("alias.0.Außen.Licht_Hauswand_vorne.SET"/*Licht Hauswand vorne schalten*/, true);
                      setStateDelayed("alias.0.Garage.Licht_Torsturz.ON_SET"/*Licht Torsturz schalten*/, false, 18000, false);
                      setStateDelayed("alias.0.Außen.Licht_Hauswand_Garage.SET"/*Licht Hauswand Garage schalten*/, false, 19000, false);
                      setStateDelayed("alias.0.Außen.Licht_Hauswand_vorne.SET"/*Licht Hauswand vorne schalten*/, false, 20000, false);
                      console.log('alles aus bei dämmerung ');
                    } else {
                      setStateDelayed("alias.0.Garage.Licht_Torsturz.ON_SET"/*Licht Torsturz schalten*/, false, 5000, false);
                    setStateDelayed("alias.0.Garage.Garage_verlassen.SET"/*Garage verlassen schalten*/, false, 1000, false);
                on({id: 'alias.0.Garage.Garagentor_fahren.SET', change: "ne"}, async function (obj) {
                  if (getState("alias.0.Garage.Garagentor_fahren.SET").val == false) {
                    console.log('Garagentor öffnen');
                      setStateDelayed("alias.0.Außen.Licht_Hauswand_Garage.SET"/*Licht Hauswand Garage schalten*/, true, 5000, false);
                      setStateDelayed("alias.0.Garage.Garage_Licht.SET"/*Garage Licht schalten*/, true, 8000, false);
                      setStateDelayed("alias.0.Garage.Licht_Torsturz.ON_SET"/*Licht Torsturz schalten*/, false, 180000, false);
                      setStateDelayed("alias.0.Außen.Licht_Hauswand_Garage.SET"/*Licht Hauswand Garage schalten*/, false, 100000, false);
                anbei 2 Blocklys welche bis vor kurzem ganz durchliefen. Jetzt kommt es vor dass die Scripte nicht mehr alle befehle abarbeiten
                • M marlan99
                  chefkoch009C
                  chefkoch009C
                  chefkoch009
                  #204
                  Ich gebe einfach mal folgendes Szenaren:
                  1. Es gibt einen Sonosplayer und einen KNX-Tastsensor. Nun soll die Taste 1 vom Tastsensor "play" machen und im Display vom Tastsensor soll der Interpret und die Lautstärke angezeigt werden.
                    Dazu lege ich eine GA Bsp 5/0/1 "Sonos-play-stopp", eine GA 5/0/2 "Interpret" und eine GA 5/0/3 "Lautstärke" an.
                  Nun verknüpfe ich über directLink die 5/0/1 mit Sonos-simpleState, die 5/0/2 mit Sonos-Interpret und die 5/0/3 mit Sonos-Volume.
                  Somit werden diese Sachen im KNX abgebildet und umgekehrt, das heisst, wenn ich die Lautstärke über meine Sonos-HandyApp ändere, wird sofort die 5/0/3 aktualisiert und umkehrt, wenn ich einen Wert für Volume in die 5/0/3 schreibe, dann werden die Sonos-States aktualisiert.
                  Ich kann nun auch über ein GroupValueRead den verknüpften State abfragen.
                  1. mein iobroker soll als Zeitserver für KNX dienen. Dann verknüpfe ich das iobroker object, welches mir die Zeit liefert direkt mit der KNX GA. Wenn sich nun das Object aktualisiert, dann tut es das auch auf dem KNX Bus.
                  Ich hoffe das bringt etwas Licht ins Dunkel ;-)
                  chefkoch009
                  M V 2 Antworten Letzte Antwort
                  • M mpl1338
                    danke funzt.
                    // "alexa duschen"
                        } else {
                    chefkoch009C
                    chefkoch009C
                    chefkoch009
                    #205
                    @mpl1338 Ich glaube ich verstehe das Problem nicht....du machst doch nur ein einziges setState mit einem object aus KNX?
                    chefkoch009
                    • A
                      A
                      andreas99
                      schrieb am zuletzt editiert von andreas99
                      #206
                      @chefkoch009
                      es scheint so. als ob bei Version 2.0.8. die GA Properties nicht gespeichert werden. Wenn ich von lesen/aktualisieren auf schreiben wechsle und schließe ist beim nächsten öffnen der zustand wieder der alte. DPT Änderung wird gespeichert. Rollback auf 2.0.5. hat das Problem behoben.
                        chefkoch009
                        M
                        M
                        mpl1338
                        #207
                        @chefkoch009 geht alles per alias weiter ans KNX, hatte für die eine GA nur kein Alias eingerichtet
                          chefkoch009
                          M
                          M
                          marlan99
                          #208
                          @chefkoch009 wenn ich dich richtig verstehe, dann wird beim direct Link ein veränderter Wert in beide Richtungen aktualisiert?
                          In diesem Fall funktioniert es bei mir nicht.
                          Wenn ich ein Objekt verknüpfe, dann wird der Wert nur auf das Datenobjekt geschrieben, wenn ich vom KNX Bus einen Wert empfange.
                          Wenn sich jedoch ein Datenobjekt im ioBroker ändert, dann wird dies nicht auf das verknüpfte KNX Objekt geschrieben.
                          • K
                            K
                            Klamm 0
                            #209
                            Hallo!
                            Ich habe das schon mal geschrieben aber ich denke es ist untergegangen.
                            Wenn ich die Gruppenadressen importiere steht da ja immer Erfolgreich importierte GAs: XXX. Wäre es wohl möglich im gleichen Fenstern noch die Anzahl der neu angelegten GA anzuzeigen.
                            Ich bin mit der KNX Installation nicht fertig und erweitere immer wieder. Es hätte mir in einigen Fällen schon die Fehlersuche verkürzt.
                            • K Klamm 0
                              Hallo!
                              chefkoch009C
                              chefkoch009C
                              chefkoch009
                              #210
                              @klamm-0 Ähm...stimmt...ist untergegangen, sorry. Kannst Du dazu auf Github bitte einen Feature request anlegen?
                              chefkoch009
                              • M mpl1338
                                chefkoch009C
                                chefkoch009C
                                chefkoch009
                                #211
                                @mpl1338 Danke für das Feedback.
                                chefkoch009
                                • M
                                  M
                                  mpl1338
                                  #212
                                  schau mal hier ein beispiel, hier hat der Adapter den befehl knx.0./knx.0.schalten.Garage.garagentor_fahren und knx.0./knx.0.schalten.Garage.licht_garage_hinten_schalten verschluckt.
                                  Busmonitor:
                                  #	Zeit	Dienst	Flags 	Prio	Quelladresse	Quellname	Zieladresse	Zielname	Hop Count	Typ	DPT	Info
                                  10	07.01.2022 18:05:29,397	zum Bus		Niedrig	1.0.2	Tunnelling Kanal 2	7/1/10	Garage verlassen	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  9	07.01.2022 18:05:29,394	vom Bus		Niedrig	1.1.100	-	1/4/3	steckdose_kompressor_schalten	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  11	07.01.2022 18:05:29,620	vom Bus		Niedrig	1.1.100	-	1/4/0	licht_garage_schalten	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  12	07.01.2022 18:05:29,845	vom Bus		Niedrig	1.1.100	-	1/4/4	steckdose_brunnen_schalten	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  13	07.01.2022 18:05:30,070	vom Bus		Niedrig	1.1.100	-	1/4/1	licht_torlicht_schalten	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  15	07.01.2022 18:05:30,171	vom Bus		Niedrig	1.1.100	-	1/3/3	licht_hauswand_garage_schalten	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  17	07.01.2022 18:05:30,294	vom Bus		Niedrig	1.1.100	-	1/3/7	licht_hauswand_schalten	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  19	07.01.2022 18:05:30,396	vom Bus		Niedrig	1.1.100	-	7/1/11	Bett taster blinken	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  21	07.01.2022 18:05:30,519	vom Bus		Niedrig	1.1.100	-	7/1/11	Bett taster blinken	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  22	07.01.2022 18:05:30,621	vom Bus		Niedrig	1.1.100	-	7/1/10	Garage verlassen	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  23	07.01.2022 18:05:31,388	vom Bus		Niedrig	1.1.100	-	1/4/7	licht_garage_ledstripe_schalten	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  40	07.01.2022 18:05:47,388	vom Bus		Niedrig	1.1.100	-	1/4/1	licht_torlicht_schalten	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  42	07.01.2022 18:05:47,537	vom Bus		Niedrig	1.1.100	-	7/1/11	Bett taster blinken	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  44	07.01.2022 18:05:48,389	vom Bus		Niedrig	1.1.100	-	1/3/3	licht_hauswand_garage_schalten	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  46	07.01.2022 18:05:48,589	vom Bus		Niedrig	1.1.100	-	7/1/11	Bett taster blinken	6	GroupValueWrite	  1.001 Schalten	$01 | Ein
                                  47	07.01.2022 18:05:49,389	vom Bus		Niedrig	1.1.100	-	1/3/7	licht_hauswand_schalten	6	GroupValueWrite	  1.001 Schalten	$00 | Aus
                                  Javascript:
                                  18:05:27.974	info	javascript.0 (397) script.js.Garage.garage_verlassen: Garage verlassen
                                  18:05:27.974	info	javascript.0 (397) script.js.Garage.garage_verlassen: alles aus
                                  18:05:27.975	info	javascript.0 (397) script.js.Garage.garage_verlassen: alles aus bei dämmerung
                                  18:05:27.982	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.steckdose_kompressor_schalten:{"val":false,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1640994645124}
                                  18:05:27.984	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.licht_garage_hinten_schalten:{"val":false,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1638987354871}
                                  18:05:27.985	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.licht_garage_schalten:{"val":false,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641574670278}
                                  18:05:27.986	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.garagentor_fahren:{"val":true,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641574670278}
                                  18:05:27.987	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.steckdose_brunnen_schalten:{"val":false,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641150805828}
                                  18:05:27.988	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.licht_torlicht_schalten:{"val":true,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641575127980}
                                  18:05:27.990	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Außen.licht_hauswand_garage_schalten:{"val":true,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641575127980}
                                  18:05:27.996	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Außen.licht_hauswand_schalten:{"val":true,"ack":false,"ts":1641575127980,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641575127980}
                                  18:05:28.976	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.Logic.IOB_befehle.Garage_verlassen:{"val":false,"ack":false,"ts":1641575128975,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641575128975}
                                  18:05:29.976	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.licht_garage_ledstripe_schalten:{"val":false,"ack":false,"ts":1641575129975,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641150807833}
                                  18:05:45.977	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Garage.licht_torlicht_schalten:{"val":false,"ack":false,"ts":1641575145976,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641575145976}
                                  18:05:46.978	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Außen.licht_hauswand_garage_schalten:{"val":false,"ack":false,"ts":1641575146977,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641575146977}
                                  18:05:47.978	silly	knx.0 (1034) States user redis pmessage knx.0.*/knx.0.schalten.Außen.licht_hauswand_schalten:{"val":false,"ack":false,"ts":1641575147977,"q":0,"c":"script.js.Garage.garage_verlassen","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1641575147977}
                                    chefkoch009
                                    V
                                    V
                                    Videonisse
                                    #213
                                    @chefkoch009 sagte in Test Adapter KNX v2.x:
                                    chefkoch009
                                    Ich versuche den "DirectLink" funktion zu konfigurieren aber kann nicht die ioBroker Objekte wählen beim Verlinken. Warum kann ich nur andere KNX GAs wählen?
                                    Adapter version ist 2.0.8
                                    2022-01-09 16_45_48-instances - iobrokerv3 och 17 sidor till - Privat – Microsoft​ Edge.png
                                    ioBroker v3.3.18, Debian 10 Buster 64-bit (Vmware 6.5 VM), Node.js: v12.22.6, NPM: 6.14.15
                                    Most important Device Adapters: KNX, Trådfri, Homekit/Yahka
                                    • V Videonisse
                                      chefkoch009
                                      chefkoch009C
                                      chefkoch009C
                                      chefkoch009
                                      #214
                                      @videonisse Rechts unten in Deinem Screenshot fehlt "directLink". Hast Du mal "iobroker u knx" gemacht?
                                      chefkoch009
                                      V 1 Antwort Letzte Antwort
                                        chefkoch009
                                        V
                                        V
                                        Videonisse
                                        #215
                                        iobroker u knx
                                        It actually works. The issue was that the button "ADD" for Direct Links was not visible on my screen. I'm using Full HD resolution and the GA-TOOLS GUI lacks a scroll bar so I didn't understand there was another button below "Add new relation".
                                        • V
                                          V
                                          Videonisse
                                          #216
                                          How can I create an Object where Direct Link is connected with the current Time/Date? Or has ioBroker such Object in the Object Tree already available?
                                          It should be used to send the actual Time/date to the KNX bus as a response to a GroupValueRead.
                                          84.1k
