  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.4k Aufrufe 82 Beobachtet
  • S saeft_2003
    Hat noch jemand von euch das Problem, dass sich gelegentlich der Adapter nach dem Befehl für eine Raumreinigung aufhängt?
    Hier die Errors im log:
    host.iobroker
    	2021-12-25 19:33:32.973	error	instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    	2021-12-25 19:33:32.973	error	Caught by controller[1]: MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    host.iobroker
    	2021-12-25 19:33:32.971	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    mihome-vacuum.0
    	2021-12-25 19:33:32.368	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0
    	2021-12-25 19:33:32.367	error	Socket Close
    mihome-vacuum.0
    	2021-12-25 19:33:32.314	error	undefined
    mihome-vacuum.0
    	2021-12-25 19:33:32.314	error	unhandled promise rejection: undefined
    mihome-vacuum.0
    	2021-12-25 19:33:32.313	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    mihome-vacuum.0
    	2021-12-25 19:33:32.308	warn	Cant send command please try again "water_box_mode"
    mihome-vacuum.0
    	2021-12-25 19:33:32.298	warn	Cant send command please try again "fan_power"
    haselchenH Offline
    haselchenH Offline
    haselchen
    #429
    @Meistertr
    Ändert sich was über den Jahreswechsel an der URL?
    Das kommt vom Adapter und in Skripten habe ich die Meldungen auch.
    mihome-vacuum.0	2021-12-31 14:19:38.738	warn	(2591) Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #430
      bekomme aktuell Fehlermeldungen im log:
      mihome-vacuum.0
      2021-12-31 13:48:02.330	warn	Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
      mihome-vacuum.0
      2021-12-31 13:47:41.187	warn	Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
      mihome-vacuum.0
      2021-12-31 13:47:19.752	warn	Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
      mihome-vacuum.0
      2021-12-31 13:46:58.608	warn	Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
      mihome-vacuum.0
      2021-12-31 13:46:37.468	warn	Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
      mihome-vacuum.0
      2021-12-31 13:46:16.228	warn	Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
      mihome-vacuum.0
      2021-12-31 13:45:54.893	warn	Get Error when receiving map url: Error: getaddrinfo ENOTFOUND de.api.io.mi.com
      mihome-vacuum.0
      2021-12-31 13:45:46.234	warn	Get Error when receiving map url: Error: Client network socket disconnected before secure TLS connection was established
      mihome-vacuum.0
      2021-12-31 13:45:23.387	warn	Get Error when receiving map url: Error: Client network socket disconnected before secure TLS connection was established
      mihome-vacuum.0
      2021-12-31 13:45:01.174	warn	Get Error when receiving map url: Error: Client network socket disconnected before secure TLS connection was established
      mihome-vacuum.0
      2021-12-31 13:44:45.123	warn	Get Error when receiving map url: Error: connect ECONNREFUSED 18.196.173.163:443
      mihome-vacuum.0
      2021-12-31 13:44:24.415	warn	Get Error when receiving map url: Error: Client network socket disconnected before secure TLS connection was established
      mihome-vacuum.0
      2021-12-31 13:43:55.327	warn	Get Error when receiving map url: Error: read ECONNRESET
      mihome-vacuum.0
      2021-12-31 13:43:26.110	warn	Get Error when receiving map url: Error: connect ECONNREFUSED 18.196.173.163:443
      mihome-vacuum.0
      2021-12-31 13:43:24.010	warn	Get Error when receiving map url: Error: Client network socket disconnected before secure TLS connection was established
      mihome-vacuum.0
      2021-12-31 13:42:47.030	warn	Get Error when receiving map url: Error: read ECONNRESET
      mihome-vacuum.0
      2021-12-31 13:42:36.765	warn	Get Error when receiving map url: Error: Client network socket disconnected before secure TLS connection was established
      Habt ihr das auch ?
      Danke.
      • bahnuhrB bahnuhr
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        Habt ihr das auch ?
        da_WoodyD Offline
        da_WoodyD Offline
        #431
        @bahnuhr nein, weil ich seit einiger zeit sowieso keine map64, noch eine mapURL bekomme. die DP werden nicht mehr befüllt.
        • da_WoodyD da_Woody
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          #432
          @da_woody sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
          map64
          Hat heute morgen noch funktioniert, jetzt nicht mehr.
          Vielleicht ein Problem mit der Server in China.
          Danke.
          Siggi0904S da_WoodyD 2 Antworten Letzte Antwort
          • haselchenH haselchen
            @Meistertr
            Strobelix
            #433
            @haselchen in der Xiaomi App wird die Karte auch nicht erzeugt. Denke ein Serverfehler bei Xiaomi
            Raspberrymatic, Homematic & Homematic IP Aktoren, ioBroker auf NUC i3, Nuki, Harmony Hub, Digitalstrom, Diverse Sonoff (Tasmota) und Shellies
            • S Strobelix
              haselchenH Offline
              haselchenH Offline
              haselchen
              #434
              @strobelix
              Hab den Adapter erstmal abgestellt.
              Wie du schon sagst, in der App kommt auch Netzwerkfehler.
                @strobelix
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #435
                @haselchen sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                ich auch.
                Mal abwarten.
                Handy app geht bei mir auch nicht.
                Danke.
                • bahnuhrB bahnuhr
                  map64
                  Siggi0904S Offline
                  Siggi0904S Offline
                  Siggi0904
                  #436
                  @bahnuhr Ich denke, das enspricht dem Gleichen wie hier.
                  https://forum.iobroker.net/post/730524
                  Wir schauen ja alle auf die gleichen Server.
                  • bahnuhrB bahnuhr
                    map64
                    da_WoodyD Offline
                    da_WoodyD Offline
                    #437
                    @bahnuhr die map64 ist mir eigentlich tögal. mapURL wäre es bei mir.
                    aber eigentlich schau ich auf den german server. dürfte aber wirklich ein prob sein. musste mich gerade in der APP neu anmelden. mein roborocks6pure wird zwar gefunden, aber beim map laden seh ich nur kringel mit "netzwerk langsam. bitt warten."
                    • MeistertrM Offline
                      MeistertrM Offline
                      Meistertr
                      schrieb am zuletzt editiert von Meistertr
                      #438
                      app geht wieder, adapter noch nicht, ich befürchte die haben was am server geändert.... wobei der govee adapter auch fehler schmeißt, also schätze ich eher auf Netzwerkprobleme im land der aufgehenden sonne....
                      bahnuhrB 2 Antworten Letzte Antwort
                      • MeistertrM Meistertr
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #439
                        @meistertr
                        app geht wieder, bekomme auch gleich ein Update angeboten: 4.1.5_1398
                        Instanz wird auch grün.
                        Karte weiß ich noch nicht.
                        Danke.
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #440
                          @meistertr
                          beim start der Instanz kommt sowas:
                          mihome-vacuum.0
                          2021-12-31 17:27:06.759	warn	{"statusCode":401,"body":"{\"code\":0,\"message\":\"auth err\"}","headers":{"server":"Tengine","date":"Fri, 31 Dec 2021 16:27:06 GMT","content-type":"text/plain; charset=utf-8","content-length":"31","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"de.api.io.mi.com","port":443,"hostname":"de.api.io.mi.com","hash":null,"search":null,"query":null,"pathname":"/app/home/getmapfileurl","path":"/app/home/getmapfileurl","href":"https://de.api.io.mi.com/app/home/getmapfileurl"},"method":"POST","headers":{"Content-Type":"application/x-www-form-urlencoded","x-xiaomi-protocal-flag-cli":"PROTOCAL-HTTP2","User-Agent":"Android-7.1.1-1.0.0-ONEPLUS A3010-136-9D28921C354D7 APP/xiaomi.smarthome APPV/62830","Cookie":"userId=1859580730; yetAnotherServiceToken=2jLptLTZl7Nib6yuI/b1+UavFv5+fTOMjdVL37UnxpvkV8RbwV9Cl9G8JDh+ISJWCrmHH1MH4RrOcUQ9rlQ1FiYv80gC4/VcNOs/tQYscg6lCCg=; serviceToken=2jLptLTZl7Nib6yuI/vtJPaXNiw51djOdZYAZO38Yd7qV137UnxpvkV8RbwV9Cl9G8JDh+ISJWCrmHH1MH4RrOcUQ9rlQ1FiYv80gC4/VcNOs/tQYscg6lCCg=; locale=de_DE; timezone=GMT%2B01%3A00; is_daylight=1; dst_offset=3600000; channel=MI_APP_STORE","accept-encoding":"gzip, deflate","content-length":148}}}
                          (habe die token etwas gekürzt)
                          Danke.
                          • bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #441
                            habe die Instanz erst einmal wieder ausgeschaltet.
                            Danke.
                            da_WoodyD MeistertrM 2 Antworten Letzte Antwort
                              denjo
                              schrieb am zuletzt editiert von denjo
                              #442
                              Hallo, der mihome server war down aber jetzt läuft wieder alles übers handy. leider nicht über den mihome vacuum adapter. ist das normal oder muss da was nachgebessert werden??
                              • bahnuhrB bahnuhr
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #443
                                @bahnuhr autsch. bei mir auch. aber heftig auch noch...
                                aber App tutet wieder...
                                • bahnuhrB bahnuhr
                                  MeistertrM Offline
                                  MeistertrM Offline
                                  Meistertr
                                  #444
                                  @bahnuhr kannst auch einfach in der konfig map über cloud deaktivieren.
                                    MeistertrM Offline
                                    Meistertr
                                    #445
                                    werde noch bis morgen abwarten und schauen ob es wieder geht, falls nicht muss ich mal schauen ob ich herausfinde was sie geändert haben...
                                    da_WoodyD haselchenH Christian WöhrleC 3 Antworten Letzte Antwort
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #446
                                      @meistertr ich denk mal, die sind sauer, weil viele roborocks bei denen drauf sind. oder gehören die zusammen?
                                        saeft_2003
                                        schrieb am zuletzt editiert von saeft_2003
                                        #447
                                        Ich bin logischerweise auch betroffen. App geht wieder, beim Adapter geht die map nicht mehr. Diese Warnung im log kommt alle paar Sekunden…
                                        	{"statusCode":401,"body":"{\"code\":0,\"message\":\"auth err\"}","headers":{"server":"Tengine","date":"Fri, 31 Dec 2021 17:11:16 GMT","content-type":"text/plain; charset=utf-8","content-length":"31","connection":"close"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"de.api.io.mi.com","port":443,"hostname":"de.api.io.mi.com","hash":null,"search":null,"query":null,"pathname":"/app/home/getmapfileurl","path":"/app/home/getmapfileurl","href":"https://de.api.io.mi.com/app/home/getmapfileurl"},"method":"POST","headers":{"Content-Type":"application/x-www-form-urlencoded","x-xiaomi-protocal-flag-cli":"PROTOCAL-HTTP2","User-Agent":"Android-7.1.1-1.0.0-ONEPLUS A3010-136-9D28921C354D7 APP/xiaomi.smarthome APPV/62830","Cookie":"userId=1777607180; yetAnotherServiceToken/qnWzpOzCefijLqk0533HLH4U9U3YGxTnq1A5fpbZMSqza5DD649IKmyc7SdZ8Msg+c13EnUbGHInYzbQ+I1IJdY=; serviceToken=q9rKEhEI8ekLzRO10CxdUVlYF4tr+c13EnUbGHInYzbQ+I1IJdY=; locale=de_DE; timezone=GMT%2B01%3A00; is_daylight=1; dst_offset=3600000; channel=MI_APP_STORE","accept-encoding":"gzip, deflate","content-length":148}}}
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #448
                                          @meistertr
                                          Hier ebenso
                                          mihome-vacuum.0	2021-12-31 19:40:34.356	warn	(10259) {"statusCode":401,"body":"{\"code\":2,\"message\":\"auth err\"}","headers":{"server":"Tengine","date":"Fri, 31 Dec 2021 18:40:34 GMT","content-type":"text/plain; charset=utf-8","content-length
                                          HTTP Error beim Drücken auf GetDevices
                                          mihome-vacuum.0	2021-12-31 19:42:03.479	info	(10259) discover HTTP ERROR
                                          mihome-vacuum.0	2021-12-31 19:42:03.478	error	(10259) null
