  4. Iobroker Admin lässt sich nicht öffnen
    6.3k
46 Beiträge 8 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • H horido
    @glasfaser vielen Dank, es läuft wieder!
    @horido und jetzt verrätst du uns bitte, was du als letztes gemacht hattest bevor es zu dem Problem kam
    • H Offline
      horido
      Also das who bringt folgende Meldung:
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start                                               Starts the js-con troller
        iobroker stop                                                stops the js-cont roller
        iobroker restart                                             Restarts js-contr oller
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js  debugging session for the adapter instance
        iobroker info                                                Shows the host in fo
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of a dapter
        iobroker install <adapter>                                   Installs a specif ied adapter
        iobroker rebuild <adapter>|self                              Rebuilds a specif ied adapter
        iobroker url <url> [<name>]                                  Install adapter f rom specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter fr om system
        iobroker del <adapter>.<instance>                            Remove adapter in stance
        iobroker update [<repositoryUrl>]                            Update repository  and list adapters
        iobroker upgrade                                             Upgrade managemen t
        iobroker upload                                              Upload management
        iobroker object                                              Object management
        iobroker state                                               State management
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to a dapter instance/s
        iobroker list <type> [<filter>]                              List all entries,  like objects
        iobroker chmod <mode> <file>                                 Change file right s
        iobroker chown <user> <group> <file>                         Change file owner ship
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given  hostname
        iobroker set <adapter>.<instance>                            Change settings o f adapter config
        iobroker license <license.file or license.text>              Update license by  given file
        iobroker cert                                                Certificate manag ement
        iobroker clean <yes>                                         Clears all object s and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specifi ed backup
        iobroker validate <backup name or path>                      Validate a specif ied backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroke r or adapter instance
        iobroker repo [<name>]                                       Show repo informa tion
        iobroker uuid                                                Show uuid of the  installation
        iobroker unsetup                                             Reset license, in stallation secret and language
        iobroker fix                                                 Execute the insta llation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost managem ent
        iobroker compact                                             compact group man agement
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of j s-controller or specified adapter
      Options:
            --help     Show help  [boolean]
        -v, --version  Show version  [boolean]
      @Homoran : Ich habe eigentlich nichts weiter gemacht, wollte eigentlich eben mal reinschauen und das System warten und kam leider nicht mehr drauf, daraufhin hatte ich das erst versucht den Admin-Adapter neu zu insatllieren/ wollte eine neue Instanz erstellt und das funktionierte nicht.
      • H horido
        iobroker [command]
        Commands:
        Options:
        @horido sagte in Iobroker Admin lässt sich nicht öffnen:
        das sieht so aus als ob du iobroker who eingegeben hättest.
        Daher bitte immer die gesamte Ein- und Ausgaben posten
        H GlasfaserG 2 Antworten Letzte Antwort
          horido
          @homoran ja iob who
          • H horido
            @homoran ja iob who
            GlasfaserG Offline
            GlasfaserG Offline
            @horido
            nur :
            who
            H 1 Antwort Letzte Antwort
            • GlasfaserG Glasfaser
              @horido
              nur :
              who
              horido
              @glasfaser nur who ergibt pi pts/0 2021-12-25 19:27 (192.168.178.99)
              • H horido
                crunchipC Abwesend
                crunchipC Abwesend
                19:27
                da stimmt deine zeit aber nicht
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @horido
                  @homoran sagte in Iobroker Admin lässt sich nicht öffnen:
                  Nur so am Rande ...
                  es hilft uns , das du hier alles zeigst und nicht nur eine Teil.
                  Da du nicht alles zeigen willst , wollte ich schauen ob du als root unterwegs bist .
                  H crunchipC 2 Antworten Letzte Antwort
                    @horido
                    Nur so am Rande ...
                    horido
                    Ach so, nein ich bin als user pi unterwegs, wie du ja siehst.
                    Nächstes Mal werde ich die Befehlsblöcke mitsenden
                      @horido
                      Nur so am Rande ...
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @glasfaser laut Post (um 20:46) war die Uhrzeit 19:27, daher schrieb ich ja, das die Uhrzeit nicht stimmt
                      Der Befehl who zeigt doch local time
                        @crunchip
                        who zeigt den Zeitpunkt des letzten Login des betreffenden Users an. Das aber in lokaler Zeit, stimmt.
                          @crunchip
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @thomas-braun also, glaube nicht das er ne Stunde gewartet hat, es hier zu posten, bzw ging ja zeitlich gar nicht, somit müsste die Zeit falsch sein auf seinem Pi
                            @crunchip
                            Den Gedanken kann ich jetzt nicht nachvollziehen. Man kann doch seit Stunden oder Tagen mit einem User angemeldet sein?
                              @crunchip
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @thomas-braun sagte in Iobroker Admin lässt sich nicht öffnen:
                              https://forum.iobroker.net/post/726523
                              dieser Post war um dreiviertel neun
                                @crunchip
                                Und? Der User Pi kann dann doch seit 19:27 lokaler Zeit angemeldet sein?
                                Last login: Sat Dec 25 22:20:56 2021 from 100.75.198.95
                                pi@chet:~ $ who
                                pi       pts/0        2021-12-25 22:21 (1xx.x5.1xx.x5)
                                pi@chet:~ $ who
                                pi@chet:~ $ date
                                Sat 25 Dec 22:36:46 CET 2021
                                pi@chet:~ $
                                  @crunchip
                                  pi@chet:~ $ who
                                  pi@chet:~ $ who
                                  pi@chet:~ $ date
                                  pi@chet:~ $
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @thomas-braun ja, jetzt stand ich auf dem Schlauch, Anmeldung überlesen, ich war gedanklich bei Aufruf
                                  OT
                                  wahnsinn das man da auch gleich negativ bewertet wird, wer auch immer das war
