Iobroker Admin lässt sich nicht öffnen
internal/modules/cjs/loader.js:905 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15) at Function.Module._load (internal/modules/cjs/loader.js:746:27) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12) at internal/main/run_main_module.js:17:47 { code: 'MODULE_NOT_FOUND', requireStack: [] }internal/modules/cjs/loader.js:905 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15) at Function.Module._load (internal/modules/cjs/loader.js:746:27) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12) at internal/main/run_main_module.js:17:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } -
cd /opt/iobroker iobroker stop sudo -H -u iobroker npm install iobroker.js-controller iobroker restart@glasfaser vielen Dank, es läuft wieder!
@horido und jetzt verrätst du uns bitte, was du als letztes gemacht hattest bevor es zu dem Problem kam
Also das who bringt folgende Meldung:
iobroker [command] Commands: iobroker setup Setup ioBroker iobroker start Starts the js-con troller iobroker stop stops the js-cont roller iobroker restart Restarts js-contr oller iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance iobroker info Shows the host in fo iobroker logs [<adapter>] Monitor log iobroker add <adapter> [desiredNumber] Add instance of a dapter iobroker install <adapter> Installs a specif ied adapter iobroker rebuild <adapter>|self Rebuilds a specif ied adapter iobroker url <url> [<name>] Install adapter f rom specified url, e.g. GitHub iobroker del <adapter> Remove adapter fr om system iobroker del <adapter>.<instance> Remove adapter in stance iobroker update [<repositoryUrl>] Update repository and list adapters iobroker upgrade Upgrade managemen t iobroker upload Upload management iobroker object Object management iobroker state State management iobroker message <adapter>[.instance] <command> [<message>] Send message to a dapter instance/s iobroker list <type> [<filter>] List all entries, like objects iobroker chmod <mode> <file> Change file right s iobroker chown <user> <group> <file> Change file owner ship iobroker touch <file> Touch file iobroker rm <file> Remove file iobroker file File management iobroker user User commands iobroker group group management iobroker host <hostname> Set host to given hostname iobroker set <adapter>.<instance> Change settings o f adapter config iobroker license <license.file or license.text> Update license by given file iobroker cert Certificate manag ement iobroker clean <yes> Clears all object s and states iobroker backup Create backup iobroker restore <backup name or path> Restore a specifi ed backup iobroker validate <backup name or path> Validate a specif ied backup iobroker status [all|<adapter>.<instance>] Status of ioBroke r or adapter instance iobroker repo [<name>] Show repo informa tion iobroker uuid Show uuid of the installation iobroker unsetup Reset license, in stallation secret and language iobroker fix Execute the insta llation fixer script, this updates your ioBroker installation iobroker multihost Multihost managem ent iobroker compact compact group man agement iobroker plugin Plugin management iobroker version [<adapter>] Show version of j s-controller or specified adapter Options: --help Show help [boolean] -v, --version Show version [boolean]@Homoran : Ich habe eigentlich nichts weiter gemacht, wollte eigentlich eben mal reinschauen und das System warten und kam leider nicht mehr drauf, daraufhin hatte ich das erst versucht den Admin-Adapter neu zu insatllieren/ wollte eine neue Instanz erstellt und das funktionierte nicht.
@horido sagte in Iobroker Admin lässt sich nicht öffnen:
das sieht so aus als ob du
iobroker whoeingegeben hättest.Daher bitte immer die gesamte Ein- und Ausgaben posten
@glasfaser nur who ergibt pi pts/0 2021-12-25 19:27 (192.168.178.99)
@homoran sagte in Iobroker Admin lässt sich nicht öffnen:
Daher bitte immer die gesamte Ein- und Ausgaben postenNur so am Rande ...
es hilft uns , das du hier alles zeigst und nicht nur eine Teil.Da du nicht alles zeigen willst , wollte ich schauen ob du als root unterwegs bist .
@glasfaser laut Post (um 20:46) war die Uhrzeit 19:27, daher schrieb ich ja, das die Uhrzeit nicht stimmt
Der Befehl who zeigt doch local time -
Der Befehl who zeigt doch local timewho zeigt den Zeitpunkt des letzten Login des betreffenden Users an. Das aber in lokaler Zeit, stimmt.
@thomas-braun also, glaube nicht das er ne Stunde gewartet hat, es hier zu posten, bzw ging ja zeitlich gar nicht, somit müsste die Zeit falsch sein auf seinem Pi
Den Gedanken kann ich jetzt nicht nachvollziehen. Man kann doch seit Stunden oder Tagen mit einem User angemeldet sein?
@thomas-braun sagte in Iobroker Admin lässt sich nicht öffnen:
https://forum.iobroker.net/post/726523
dieser Post war um dreiviertel neun -
dieser Post war um dreiviertel neunUnd? Der User Pi kann dann doch seit 19:27 lokaler Zeit angemeldet sein?
Last login: Sat Dec 25 22:20:56 2021 from 100.75.198.95 pi@chet:~ $ who pi pts/0 2021-12-25 22:21 (1xx.x5.1xx.x5) pi@chet:~ $ who pi pts/0 2021-12-25 22:21 (1xx.x5.1xx.x5) pi@chet:~ $ date Sat 25 Dec 22:36:46 CET 2021 pi@chet:~ $ -
Last login: Sat Dec 25 22:20:56 2021 from 100.75.198.95 pi@chet:~ $ who pi pts/0 2021-12-25 22:21 (1xx.x5.1xx.x5) pi@chet:~ $ who pi pts/0 2021-12-25 22:21 (1xx.x5.1xx.x5) pi@chet:~ $ date Sat 25 Dec 22:36:46 CET 2021 pi@chet:~ $@thomas-braun ja, jetzt stand ich auf dem Schlauch, Anmeldung überlesen, ich war gedanklich bei Aufruf
OT
wahnsinn das man da auch gleich negativ bewertet wird, wer auch immer das war
