  4. Test Adapter KNX v2.x
421 Beiträge 70 Kommentatoren 146.9k Aufrufe 62 Beobachtet
    schmid_no1
    #129
      schmid_no1
      #130
      Habe beim Import Probleme.
      Kann mir da jemand helfen, bzw. sagen was ich hier falsch mache?
      • S schmid_no1
        GlasfaserG Offline
        GlasfaserG Offline
        #131
        @schmid_no1
        Bitte keine Screenshot´s
        Log Ausgaben komplett in Code-Tags </> setzen
          schmid_no1
          #132
          host.raspberrypi
          	2021-12-18 15:43:45.443	error	instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.raspberrypi
          	2021-12-18 15:43:45.442	error	Caught by controller[0]: at processTimers (internal/timers.js:500:7)
          host.raspberrypi
          	2021-12-18 15:43:45.442	error	Caught by controller[0]: at listOnTimeout (internal/timers.js:559:11)
          host.raspberrypi
          	2021-12-18 15:43:45.441	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:267377)
          host.raspberrypi
          	2021-12-18 15:43:45.441	error	Caught by controller[0]: at _0x1239e8 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:258738)
          host.raspberrypi
          	2021-12-18 15:43:45.440	error	Caught by controller[0]: at Function.each (/opt/iobroker/node_modules/iobroker.knx/node_modules/underscore/underscore-node-f-pre.js:1316:7)
          host.raspberrypi
          	2021-12-18 15:43:45.439	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:259948
          host.raspberrypi
          	2021-12-18 15:43:45.428	error	Caught by controller[0]: ReferenceError: actGAcomObjectInstanceRefId_GARefId is not defined
          knx.0
          	2021-12-18 15:43:44.745	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          knx.0
          	2021-12-18 15:43:44.743	info	terminating
          knx.0
          	2021-12-18 15:43:44.724	error	actGAcomObjectInstanceRefId_GARefId is not defined
          knx.0
          	2021-12-18 15:43:44.723	error	ReferenceError: actGAcomObjectInstanceRefId_GARefId is not defined at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:259948 at Function.each (/opt/iobroker/node_modules/iobroker.knx/node_modules/underscore/underscore-node-f-pre.js:1316:7) at _0x1239e8 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:258738) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:267377) at listOnTimeout (internal/timers.js:559:11) at processTimers (internal/timers.js:500:7)
          knx.0
          	2021-12-18 15:43:44.718	error	uncaught exception: actGAcomObjectInstanceRefId_GARefId is not defined
          • GlasfaserG Glasfaser
            @schmid_no1
            schmid_no1
            #133
            @glasfaser so richtig?
            • S schmid_no1
              GlasfaserG Offline
              GlasfaserG Offline
              #134
              @schmid_no1 sagte in Test Adapter KNX v2.x:
              JA ,
              denn Screenshot´s kann man schlecht lesen , bzw . Fehler sind abgeschnitten und man kann daraus nicht Zitieren .......
                schmid_no1
                #135
                Habe ich ein Problem mit meiner .knxproj Datei
                chefkoch009C 1 Antwort Letzte Antwort
                • S schmid_no1
                  chefkoch009C Offline
                  chefkoch009
                  #136
                  @schmid_no1 Was ist das für eine ETS Version, welche Version haben Dein
                  1. Admin
                  2. nodejs
                  3. js-controller
                  4. knx-adapter
                  chefkoch009
                  • chefkoch009C chefkoch009
                    @yellowflash Da war ich mit den Requirements leider etwas unaufmerksam.
                    iobroker-horst:~# cd /opt/iobroker
                    iobroker-horst:/opt/iobroker# npm i iobroker.admin@5.1.28
                    iobroker-horst:/opt/iobroker# iobroker u admin
                    Damit sollte es laufen.
                    chefkoch009
                    Y Offline
                    Y Offline
                    YellowFlash
                    #137
                    @chefkoch009 said in Test Adapter KNX v2.x:
                    chefkoch009
                    Danke, nun startet der Adapter wieder und nimmt Verbindung auf.
                      1. Admin
                      2. nodejs
                      3. js-controller
                      4. knx-adapter
                      chefkoch009
                      schmid_no1
                      #138
                      @chefkoch009
                      Hallo Chefkoch009 Versionen wie folgt:
                      ETS 5.5.2
                      Admin 5.1.25
                      nodejs v14.17.2
                      js-controller 3.3.21
                      KNX-adapter2.0.5
                      alles sauber installiert.
                      Ich bin hergegangen und löschte alles was mit dem KNX adapter (1.0.45) zu tun hatte. Ich wollte alles mit dem neuen Adapter einlesen. Hier kam die Fehlermeldung, die ich oben einstellte.
                      Habe ein downgrade des KNX-Adapters gemacht, mein projekt eingelesen und bin dann wieder auf 2.0.5. Jetzt geht es, aber der Upload ging bei mir nicht mit dem neuen.
                      • U Offline
                        U Offline
                        urs77
                        #139
                        Hallo, ich habe aktuell 510 GA. Lohnt sich im moment noch nicht, eine Lizenz zu kaufen. Das werde ich erst nach der nächsten Erweiterung im Haus machen.
                        Was passiert aber jetzt bei einem Update (ohne Lizenz): geht der Adapter gar nicht mehr? Oder fallen 10 Objekte weg? Wenn ich in ETS 10 Objekte lösche: reicht es, die knxproj neu einzulesen und iobroker erkennt, dass GA fehlen oder muss ich alles entfernen und komplett neu einrichten?
                        Danke und vg
                        • U urs77
                          Danke und vg
                          chefkoch009
                          #140
                          @urs77
                          Klar läuft er, aber er kommuniziert nicht mehr mit dem KNX Bus.
                          Nein, da fällt nichts weg.
                          Es werden nur neue hinzugefügt, bestehende bleiben vorhanden.
                          chefkoch009
                          U 1 Antwort Letzte Antwort
                            @urs77
                            chefkoch009
                            U Offline
                            U Offline
                            urs77
                            #141
                            @chefkoch009 ok danke
                            "Es werden nur neue hinzugefügt, bestehende bleiben vorhanden." bedeutet dann: in ETS auf unter 500 GA reduzieren und im iobroker erst alle Objekte unterhalb von knx löschen und knxproj vollständig neu laden und gegebenfalls alles neu einrichten?
                            • U urs77
                              chefkoch009
                              #142
                              @urs77 du brauchst im iobroker nur die löschen, die in deinem neuen Projekt auch wegfallen.
                              chefkoch009
                              • L Offline
                                loverz
                                schrieb am zuletzt editiert von loverz
                                #143
                                Ohne den Tag vor dem Abend zu loben:
                                Bin gerade von 1.0.20 auf 2.0.5 hoch und es scheint auf Anhieb zu laufen.
                                Hatte bisher mit allen v1.x höher als 1.0.20 das Problem, dass meine Rollläden nicht die aktuelle Position rückgemeldet haben, daher bin ich auf 1.0.20 geblieben.
                                Habe nun in der 2.0.5 direkt über die "GA-Tools" die Zuordnung von Aktor und Status gemacht.
                                -Denkt ihr, dass das Problem damit weg ist?
                                -Muss ich diese Zuordnung nur bei den Rollos machen, oder auch bei Lampen etc.?
                                -Was bewirkt diese Zuordnung denn genau?
                                -Ist die Zuordnung wieder weg, wenn ich ein neues KNX Projekt einlese?
                                ->Ggf. Nur wenn ich diesen Haken weglasse:
                                Danke erstmal für die Weiterentwicklung, ich bin begeistert!
                                Edit: Hab wohl doch zu früh gelobt: Es gibt wieder Probleme, die mit 1.0.20 einwandfrei gelaufen sind:
                                Mir ist aufgefallen, dass die Rollladen-Positionen wieder nicht richtig rückgemeldet werden, obwohl ich die Status-GA und die Aktor-GA verknüpft habe:
                                Außerdem ist mir aufgefallen, dass der Adapter es nicht gebacken bekommt, wenn ich in der ETS Software eine Gruppenadresse anlege, die nicht mit einem Aktor, sondern nur mit einem Wandtaster (z.B. MDT Glastaster) verknüpft ist.
                                Dies wird z.B. benötigt, wenn man eine Indikator-LED am Taster steuern möchte, oder wenn man einen Knopf von diesen Wandtastern in iobroker auswerten möchte
                                Wenn ich nun einen Wert von iobroker über diese Gruppenadresse an den Glastaster senden möchte, dann kommt dieser Befehl nicht an.
                                Hier so ein Objekt:
                                  "_id": "knx.0.OG.Jalousie.Bad_Indikator",
                                  "type": "state",
                                  "common": {
                                    "name": "Bad Indikator",
                                    "type": "boolean",
                                    "read": false,
                                    "write": true,
                                    "role": "switch",
                                    "min": false,
                                    "max": true
                                  "native": {
                                    "dpt": "DPT1.001",
                                    "address": "2/3/13",
                                    "addressRefId": "P-039B-0_GA-327",
                                    "statusGARefId": "",
                                    "actGARefId": ""
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                    "owner": "system.user.admin",
                                  "user": "system.user.admin",
                                  "ts": 1640167746052
                                Ich weiß nicht, was da los ist! Wieso geht bis 1.0.20 alles einwandfrei und danach kommt es immer wieder zu diesen massiven Problemen??
                                • L loverz
                                  Hier so ein Objekt:
                                    "type": "state",
                                    "common": {
                                      "type": "boolean",
                                      "read": false,
                                      "write": true,
                                      "role": "switch",
                                      "min": false,
                                      "max": true
                                    "native": {
                                      "dpt": "DPT1.001",
                                      "actGARefId": ""
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                    "ts": 1640167746052
                                  tombox
                                  #144
                                  @lover
                                  vielleicht gibst du auch mal dem openKNX Adapter eine Chance (läuft auch parallel zu knx adapter), der kann von jedem verbessert werden vielleicht funktioniert der besser. Wir nehmen gerne Verbesserungswünsche entgegen.
                                  https://forum.iobroker.net/topic/50352/test-adapter-openknx-0-1-x
                                  L 1 Antwort Letzte Antwort
                                  • Hant0rH Offline
                                    Hant0rH Offline
                                    Hant0r
                                    #145
                                    @andreask sagte in Test Adapter KNX v2.x:
                                    Das bedeutet, wenn ich in der ETS den Bereich Reports -> Projektstatistik öffne, ist die Anzahl der gezeigten Gruppenadressen ausschlaggebend. Richtig? Danach staffelt sich dann die Kosten.
                                    Na super!
                                    Habe 693 Gruppenadressen ... und ich habe nur mein privates Haus das ich hier betreibe.
                                    Dabei ist der Garten noch nicht mal fertig ausgebaut :(
                                    Heißt entweder greife ich tief in die Tasche oder ich muss mit der Version 1 weiter vorlieb nehmen?
                                    Und die ETS Version darf ich auch nicht auf >5.7.5 udpaten?
                                    • T tombox
                                      @lover
                                      loverz
                                      #146
                                      @tombox wenn das mit dem Umzug der Scripte klappt, dann werde ich umziehen, sieht sehr vielversprechend aus der openknx Adapter. Danke!
                                      Gott sei dank habe ich ein SD Image gemacht, bevor ich auf 2.x hier hoch bin.
                                      Hab nun mein Image mit 1.0.20 eingespielt und alles funktioniert wieder!
                                      • L loverz
                                        chefkoch009
                                        #147
                                        @loverz
                                        komisch....warum nur?
                                        Ich möchte an dieser Stelle darauf hinweisen, das das hier der Thread vom KNX Adapter ist und nicht der von openknx.
                                        chefkoch009
                                        L T 2 Antworten Letzte Antwort
                                          @loverz
                                          chefkoch009
                                          loverz
                                          #148
                                          @chefkoch009 das ist mir auch klar.
                                          Ich würde auch bei deinem Adapter bleiben, das wäre ja das einfachste, wenn du mal auf meine Probleme eingehen würdest und Hilfestellung geben könntest wäre das echt super!
                                          Ich frage nochmal explizit: Was hat sich an ALLEN Versionen nach 1.0.20 geändert, dass ich plötzlich diese massiven Probleme habe?
                                          Ich habe hier im Forum auch von anderen gelesen, die auch mit diesem Problem kämpfen.
                                          M chefkoch009C 2 Antworten Letzte Antwort
