    @noah3112 Zeig mal die Ausgaben... In CodeTags.
    #4036
    ulf@iobroker:~$ iobroker update -i
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.2.1
    Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
    Adapter    "alias-manager" : 1.2.4    , installed 1.2.4
    Adapter    "backitup"      : 2.2.2    , installed 2.2.2
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "device-reminder": 1.2.9   , installed 1.2.9
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "echarts"       : 1.0.3    , installed 1.0.3
    Adapter    "feiertage"     : 1.0.23   , installed 1.0.23
    Adapter    "history"       : 1.9.13   , installed 1.9.14
    Adapter    "ical"          : 1.11.4   , installed 1.11.5
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "info"          : 1.9.8    , installed 1.9.16
    Adapter    "iot"           : 1.8.24   , installed 1.8.25
    Adapter    "jarvis"        : 2.2.1    , installed 2.2.5
    Adapter    "javascript"    : 5.2.13   , installed 5.2.16
    Controller "js-controller" : 3.3.21   , installed 3.3.21
    Adapter    "mihome-vacuum" : 3.3.1    , installed 3.3.1
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.1
    Adapter    "mqtt-client"   : 1.4.0    , installed 1.4.0
    Adapter    "node-red"      : 2.4.1    , installed 2.4.1
    Adapter    "nuki"          : 1.5.0    , installed 1.5.0
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"       : 1.3.4    , installed 1.3.4
    Adapter    "shelly"        : 4.0.7    , installed 4.1.2
    Adapter    "shuttercontrol": 1.2.1    , installed 1.2.1
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
    Adapter    "socketio"      : 3.1.4    , installed 3.1.5
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "text2command"  : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "trashschedule" : 1.2.0    , installed 1.3.6
    Adapter    "web"           : 3.4.9    , installed 3.4.16
    Adapter    "wled"          : 0.6.3    , installed 0.6.3
    Adapter    "yeelight-2"    : 1.1.2    , installed 1.1.2
    Adapter    "zigbee"        : 1.6.6    , installed 1.6.7
    ulf@iobroker:~$
      #4037
      @thomas-braun Ich hoffe das war so richtig!?
      Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
        #4038
        @noah3112 So ähnlich.
        Der Text gehört zwischen die Steuerzeichen.
        Ich würde dann jetzt auch auf stable bleiben.
          #4039
          @thomas-braun Eigentlich war ich der Meinung das wäre so... Okay es funktioniert wieder so wie vorher. Danke für deine Geduld. Ich bleib ab jetzt aber der sicheren Seite ;-)
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #4040
            @noah3112 sagte in Test Adapter shuttercontrol v1.4.x:
            habs dir passend formatiert :)
            ° Fixer ---> iob fix
            • NegaleinN Negalein
              #4041
              @negalein Danke 👍
                Ich wollte mir gerade wieder die Version 1.2.1 installieren. Leider geht das nicht mehr. Besteht die Möglichkeit an diese Version zu kommen? Bevor Fragen kommen warum. Einfach nur weil ich damit absolut keine Probleme hatte. Ich habe wieder nichts an der Einstellung geändert und trotzdem geht einiges nicht mehr. Einige Rollos fahren zum Beispiel seit einigen Tagen nicht mehr selbständig runter. Ich möchte nicht schon wieder anfangen mein System zu analysieren und Log aufzeichnen. Wie gesagt außer Updates wurde am System nichts geändert. Meine Einstellungen sind relativ simpel. Hatte ich hier ja schon vor kurzem gepostet als die Probleme mit den neuen Versionen losgingen. Brauche keinen Frostschutz oder Sonstiges. Daher noch einmal die Frage nach Version 1.2.1
                simatecS Offline
                simatecS Offline
                simatec
                #4042
                @noah3112
                Wenn du keine Beta Unterstützung hier im Forum oder auf Github leisten willst, kann ich aber absolut nicht verstehen, warum du deine Repo auf Beta stellst und hier dann meckerst.
                Konstruktiver wäre eindeutig hier deinen Debuglog zu posten und deinen Fehler zu beschreiben.
                Deine Aussage hat hier im Thread nun 2 Seiten, die nix mit dem Betatest zu tun haben verursacht.
                Da in der Version neue Funktionen für die Rollladenkonfiguration hinzugekommen sind, müssen die Einstellungen nach dem Update angepasst werden. speziell musst du pro Rollladen den Fensterstatus bei gekippten Fenster konfigurieren.
                Wenn du dass nicht machst, dann kann es zu deinen Problemen kommen.
                Aber auch später im Stable wirst du das Problem bekommen, wenn man stumpf ein Update fährt
                • Besuche meine Github Seite
                • HowTo Restore ioBroker
                • F Fortune95
                  @simatec
                  Es funktioniert leider immer noch nicht. :-(
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #4043
                  @fortune95 poste doch mal bitte deine Config als json.
                  Also um deinen Fehler mal zusammenzufassen.
                  Der Rollladen fährt zur eingestellten Zeit runter und das Fenster ist offen.
                  Dann schließt du später das Fenster und der Rollladen fährt wieder hoch
                  Richtig?
                  M F 2 Antworten Letzte Antwort
                  • simatecS simatec
                    Richtig?
                    MartyBr
                    #4044
                    @simatec
                    Hallo @simatec , hier mal eine positive Rückmeldung. Ich habe die 1.4.2 installiert, ansonsten fahre ich Stable. Der Weihnachtsmodus fährt wie gewünscht. Ich habe 40% eingetragen und der Rollo fährt Abends diese Position an. Bei dem Rollo ist auch eingestellt, dass er "Spät" komplett herunterfährt. Beides funktioniert ohne Probleme.
                    Herzlichen Dank für deine Arbeit und die intensive Betreuung hier im Forum 👍
                    Gruß und Dank und dir einen guten 2. Advent 🎄
                    Martin
                    Homematic und Homematic IP
                    • BanditFGB Offline
                      BanditFGB Offline
                      BanditFG
                      schrieb am zuletzt editiert von BanditFG
                      #4045
                      hallo
                      habe gerade die v1.4.2 installiert, der von mir gepostete Bug, welches den Wert für die AlarmFrostHöhe verschwinden lässt ist scheinbar gelöst. Super.
                      Mal sehen ob der Rollladen heute Abend 22:00 aus der Weihnachtshöhe von 70% in die Frostschutzhöhe von 15% fährt.
                      @simatec danke für die super Arbeit.!
                      ach und allen einen schönen zweiten Advent 🎄
                      • BanditFGB Offline
                        BanditFGB Offline
                        BanditFG
                        #4046
                        @simatec also die Weihnachtshöhe fahren meine Rollos heute nicht an. Sind irgendwie nur auf die Froststellung gefahren.
                        tercontrol.0
                        14142	2021-12-05 16:37:45.942	debug	outsidetemperature changed: viessmannapi.0.241772.0.features.heating.sensors.temperature.outside.properties.value.value Value: 1.7
                        shuttercontrol.0
                        14142	2021-12-05 16:35:00.006	debug	Sun Elevation: -5.2°
                        shuttercontrol.0
                        14142	2021-12-05 16:35:00.005	debug	Sun Azimut: 240.3°
                        shuttercontrol.0
                        14142	2021-12-05 16:35:00.005	debug	calculate astrodata ...
                        shuttercontrol.0
                        14142	2021-12-05 16:34:16.628	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d0002321724.temperature Value: 21.47
                        shuttercontrol.0
                        14142	2021-12-05 16:33:21.835	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d000247d478.temperature Value: 21.54
                        shuttercontrol.0
                        14142	2021-12-05 16:33:16.174	debug	save current height after State Check: 100% from Rollladen Küche Links.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:15.170	debug	last automatic Action for Rollladen Küche Links.LEVEL: Sunset_down
                        shuttercontrol.0
                        14142	2021-12-05 16:33:15.120	info	Sunset #12 Set ID: Rollladen Küche Links.LEVEL value: 15%
                        shuttercontrol.0
                        14142	2021-12-05 16:33:13.173	debug	save current height after State Check: 100% from Rollladen Küche Rechts.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:12.167	debug	last automatic Action for Rollladen Küche Rechts.LEVEL: Sunset_down
                        shuttercontrol.0
                        14142	2021-12-05 16:33:12.112	info	Sunset #12 Set ID: Rollladen Küche Rechts.LEVEL value: 15%
                        shuttercontrol.0
                        14142	2021-12-05 16:33:10.165	debug	save current height after State Check: 100% from Rollladen Terrassentür.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:09.155	debug	last automatic Action for Rollladen Terrassentür.LEVEL: Sunset_down
                        shuttercontrol.0
                        14142	2021-12-05 16:33:09.104	info	Sunset #12 Set ID: Rollladen Terrassentür.LEVEL value: 15%
                        shuttercontrol.0
                        14142	2021-12-05 16:33:01.237	debug	save current height after State Check: 100% from Rollladen Arbeitszimmer.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:01.168	debug	save current height after State Check: 0% from Rollladen Natalie klein.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.210	debug	last automatic Action for Rollladen Arbeitszimmer.LEVEL: Sunset_down
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.164	debug	shutterDownChildren #2 Rollladen Natalie klein.LEVEL old height: 0% new height: 30%
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.164	debug	last automatic Action for Rollladen Natalie klein.LEVEL: Down_ChildrenTime
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.115	debug	status frost alarm for hm-rpc.0.OEQ1300082.1.LEVEL: true
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.114	debug	start checking frost alarm
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.114	debug	status alarm pending for hm-rpc.0.OEQ1300082.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.114	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.114	debug	Rollladen Küche Links.LEVEL in xmas time down 70
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.113	debug	we are in period
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.113	debug	corrected End Thu Jan 06 2022
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.113	debug	End Wed Jan 06 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.113	debug	Start Mon Nov 22 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.113	debug	check in time 22.11. 06.01.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.113	debug	check xmas for Rollladen Küche Links.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.113	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.112	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.111	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.111	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.106	debug	status frost alarm for hm-rpc.0.OEQ1302808.1.LEVEL: true
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.105	debug	start checking frost alarm
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	status alarm pending for hm-rpc.0.OEQ1302808.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	Rollladen Küche Rechts.LEVEL in xmas time down 100
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	we are in period
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	corrected End Thu Jan 06 2022
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	End Wed Jan 06 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	Start Mon Nov 22 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.104	debug	check in time 22.11. 06.01.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.103	debug	check xmas for Rollladen Küche Rechts.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.103	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.103	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.103	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.103	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.098	debug	status frost alarm for hm-rpc.0.OEQ1302889.1.LEVEL: true
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.096	debug	start checking frost alarm
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.096	debug	status alarm pending for hm-rpc.0.OEQ1302889.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.096	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.096	debug	Rollladen Terrassentür.LEVEL in xmas time down 80
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.096	debug	we are in period
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.095	debug	corrected End Thu Jan 06 2022
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.095	debug	End Wed Jan 06 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.095	debug	Start Mon Nov 22 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.095	debug	check in time 22.11. 06.01.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.095	debug	check xmas for Rollladen Terrassentür.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.095	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.095	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.094	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.094	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.088	info	Sunset #12 Set ID: Rollladen Arbeitszimmer.LEVEL value: 15%
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.088	debug	check xmas for Rollladen Schlafzimmer.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.088	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.088	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.088	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.088	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.087	debug	check xmas for Rollladen Ecke Links.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.087	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.087	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.087	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.086	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.084	info	Children down #27 Set ID: Rollladen Natalie klein.LEVEL value: 30%
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.082	debug	check xmas for Rollladen Bad.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.082	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.082	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.082	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.081	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.081	debug	check xmas for Rollladen Ecke Rechts.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.081	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.081	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.081	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.080	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.078	debug	status frost alarm for hm-rpc.0.OEQ1299293.1.LEVEL: true
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.077	debug	check xmas for Rollladen Natalie.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.077	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.077	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.077	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.076	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.071	debug	start checking frost alarm
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.071	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.071	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.071	debug	Rollladen Arbeitszimmer.LEVEL in xmas time down 60
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.070	debug	we are in period
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.069	debug	corrected End Thu Jan 06 2022
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.069	debug	End Wed Jan 06 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.068	debug	Start Mon Nov 22 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.068	debug	check in time 22.11. 06.01.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.068	debug	check xmas for Rollladen Arbeitszimmer.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.068	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.068	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.068	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.067	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.058	debug	Rollladen Natalie klein.LEVEL in xmas time down 30
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.058	debug	we are in period
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.058	debug	corrected End Thu Jan 06 2022
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.058	debug	End Wed Jan 06 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.058	debug	Start Mon Nov 22 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.057	debug	check in time 22.11. 06.01.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.057	debug	check xmas for Rollladen Natalie klein.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.057	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.057	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.057	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.057	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.047	debug	check xmas for Rolladen Emilia.LEVEL
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.047	debug	we are not in period, after start Sat May 01 2021 and before end Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.046	debug	End Thu Sep 30 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.046	debug	Start Sat May 01 2021
                        shuttercontrol.0
                        14142	2021-12-05 16:33:00.046	debug	check in time 01.05. 30.09.
                        shuttercontrol.0
                        14142	2021-12-05 16:31:42.456	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d000224ce57.temperature Value: 15.97
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.264	debug	status alarm pending for hm-rpc.0.OEQ1300082.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.264	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.262	debug	status alarm pending for hm-rpc.0.OEQ1302808.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.262	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.216	debug	status alarm pending for hm-rpc.0.OEQ1302889.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.216	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.104	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.103	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.103	debug	start shutterAlarm
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.103	debug	Alarm Frost changed: true
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.005	debug	Sun Elevation: -4.5°
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.005	debug	Sun Azimut: 239.4°
                        shuttercontrol.0
                        14142	2021-12-05 16:30:00.004	debug	calculate astrodata ...
                        shuttercontrol.0
                        14142	2021-12-05 16:25:00.019	debug	Sun Elevation: -3.8°
                        shuttercontrol.0
                        14142	2021-12-05 16:25:00.019	debug	Sun Azimut: 238.4°
                        shuttercontrol.0
                        14142	2021-12-05 16:25:00.018	debug	calculate astrodata ...
                        shuttercontrol.0
                        14142	2021-12-05 16:20:16.979	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d0002288653.temperature Value: 23.25
                        shuttercontrol.0
                        14142	2021-12-05 16:20:00.014	debug	Sun Elevation: -3.1°
                        shuttercontrol.0
                        14142	2021-12-05 16:20:00.014	debug	Sun Azimut: 237.5°
                        shuttercontrol.0
                        14142	2021-12-05 16:20:00.014	debug	calculate astrodata ...
                        shuttercontrol.0
                        14142	2021-12-05 16:17:42.741	debug	outsidetemperature changed: viessmannapi.0.241772.0.features.heating.sensors.temperature.outside.properties.value.value Value: 1.8
                        shuttercontrol.0
                        14142	2021-12-05 16:15:00.323	debug	status alarm pending for hm-rpc.0.OEQ1300082.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:15:00.322	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:15:00.322	debug	status alarm pending for hm-rpc.0.OEQ1302808.1.LEVEL: false
                        shuttercontrol.0
                        14142	2021-12-05 16:15:00.321	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
                        shuttercontrol.0
                        14142	2021-12-05 16:15:00.278	debug	status alarm pending for hm-rpc.0.OEQ1302889.1.LEVEL: false
                        obwohl für Arbeitszimmer, Terrassentür, Küche links und Küche rechts speziellen Weihnachtshöhen eingestellt sind.
                        hat jemand ne Idee? ob ich was falsch habe
                        simatecS 2 Antworten Letzte Antwort
                          Tom Haase
                          #4047
                          Hallo @simatec ,
                          habe auf 1.4.2 aktualisiert und die Anpassungen der Rollos mit Fensterkontakten auf deinen Rat hin gemacht. Alles läuft jetzt wieder wie gehabt.
                          Jetzt wolllte ich auch mal die Weihnachtseinstellung bei 2 Rollos ausprobieren.... Das wird allerdings vollkommen ignoriert.
                          Grüße Tom
                          • T Tom Haase
                            Hallo @simatec ,
                            Grüße Tom
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #4048
                            @tom-haase Hast du bitte einen Debuglog für mich und am besten die Settings der betroffenen Rollläden als json Ausgabe
                            • BanditFGB BanditFG
                              tercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              shuttercontrol.0
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #4049
                              @banditfg Danke für dein Feedback. Ich denke es wird wohl daran liegen, dass die Alarme immer oberste Priorität haben ... Da muss ich mir den Code mal genauer anschauen, da die Alarme @FoxRo eingebaut hat.
                              Falls dem so ist, werde ich hier noch eine Abfrage für den Frostalarm einbauen, denn sicher ist die Weihnachtseinstellung so, dass hier der Frost dem Rollladen nicht schadet.
                              Werde mir das mal überlegen.
                              Kannst du mal zum testen den Frostalarm deaktivieren und schauen, ob dann die Weihnachtseinstellungen sauber angefahren werden?
                              • simatecS simatec
                                Richtig?
                                Fortune95
                                #4050
                                @simatec sagte in Test Adapter shuttercontrol v1.4.x:
                                Richtig?
                                Ja, genau das meine ich.
                                system.adapter.shuttercontrol.0.json
                                • simatecS simatec
                                  Tom Haase
                                  #4051
                                  Gerne, kann aber ein paar Tage dauern....leider
                                  • BanditFGB Offline
                                    BanditFGB Offline
                                    BanditFG
                                    #4052
                                    @simatec ich haben bei meinen 4 Rollos wo erst einmal auf Weihnachtshöhe gefahren werden soll den Frost Alarm deaktiviert. mal sehen ob die morgen Abend sauber fahren.
                                    werde natürlich gern berichten..
                                    danke für deine Arbeit..
                                    • simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #4053
                                      Ab sofort steht die Version 1.4.3 auf Github und in kürze auch im latest zur Verfügung.
                                      Changelog
                                      1.4.3 (2021-12-05)
                                      • (simatec) Bugfix Trigger after shutter close
                                      • (simatec) Bugfix XMas Level by frost
                                      • (simatec) XMas Level for GoldenHour added
                                      • (simatec) Summertime for Goldenhour added
                                      • (simatec) small Bugfixes
                                        tercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #4054
                                        @banditfg Bitte teste mal die 1.4.3 ... dein Problem sollte gefixt sein.
                                        • T Tom Haase
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #4055
                                          @tom-haase Bitte teste mal die 1.4.3 ... dein Problem sollte gefixt sein.
