  4. [influxDB] nach Rechnerumzug immer wieder ECONNREFUSED
    6.3k
64 Beiträge 6 Kommentatoren 8.2k Aufrufe 6 Beobachtet
  • L lukas8519
    Fur influx ist das falsche Repo aktiv. Stretch ist falsch
    Erstmal deine Installationsquellen korrigieren.
    klingt gut! Leider weiß ich nicht wie ...
    @lukas8519
    https://repos.influxdata.com/debian stretch/stable
    Da muss buster statt stretch rein.
    Dürfte in der /etc/apt/sources.list.d/influxdb.list drin stehen.
    L 1 Antwort Letzte Antwort
      @lukas8519
      lukas8519
      pi@raspberrypi:~ $ https://repos.influxdata.com/debian stretch/stable
      -bash: https://repos.influxdata.com/debian: No such file or directory
      • L lukas8519
        crunchipC Offline
        crunchipC Offline
        @lukas8519 deine sources.list anpassen
        machs so
        wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
        source /etc/os-release
        echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
          machs so
          lukas8519
          @crunchip
          pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
          OK
          pi@raspberrypi:~ $ source /etc/os-release
          pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/buster $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
          deb https://repos.influxdata.com/buster buster stable
          • L lukas8519
            @crunchip
            OK
            @lukas8519
            sudo apt update
            sudo apt install --reinstall influxdb
              @lukas8519
              sudo apt update
              lukas8519
              habe ich:
              pi@raspberrypi:~ $ sudo apt update
              Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
              Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
              Get:3 https://packages.grafana.com/oss/deb stable InRelease [12.1 kB]
              Get:4 https://deb.nodesource.com/node_12.x buster InRelease [4,584 B]
              Ign:5 https://repos.influxdata.com/buster buster InRelease
              Get:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
              Err:7 https://repos.influxdata.com/buster buster Release
                404  Not Found [IP: 2600:9000:224a:fa00:7:7790:e740:93a1 443]
              Get:8 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
              Get:9 https://packages.grafana.com/oss/deb stable/main armhf Packages [29.8 kB]
              Get:10 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.8 kB]
              Get:11 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
              Get:12 https://deb.nodesource.com/node_12.x buster/main armhf Packages [777 B]
              Reading package lists... Done
              E: The repository 'https://repos.influxdata.com/buster buster Release' does not have a Release file.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
              N: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
              pi@raspberrypi:~ $ sudo apt install --reinstall influxdb
              Building dependency tree
              Reinstallation of influxdb is not possible, it cannot be downloaded.
              0 upgraded, 0 newly installed, 0 to remove and 88 not upgraded.
              pi@raspberrypi:~ $
              • L lukas8519
                habe ich:
                pi@raspberrypi:~ $
                @lukas8519
                Die /etc/apt/sources.list.d/influxdb.list ist noch falsch.
                Zeig mal was da jetzt drin steht.
                cat /etc/apt/sources.list.d/influxdb.list
                • L Offline
                  lukas8519
                  pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influxdb.list
                  • L lukas8519
                    @lukas8519
                    Ersetze das erste buster durch debian
                      @lukas8519
                      lukas8519
                      ehm... so war das nicht gemeint oder?
                      pi@raspberrypi:~ $ deb https://repos.influxdata.com/debian
                      -bash: deb: command not found
                      • L lukas8519
                        @lukas8519
                        Mit einem Editor wie z.B. nano macht man das
                        nano /etc/apt/sources.list.d/influxdb.list
                        L crunchipC 2 Antworten Letzte Antwort
                          @lukas8519
                          lukas8519
                          sorry ich kenne mich wirklich kaum aus und bin sehr dankbar für eure Hilfe!
                          File Name to Write: /etc/apt/sources.list.d/influxdb.list
                          ^G Get Help         M-D DOS Format      M-A Append          M-B Backup File
                          ^C Cancel           M-M Mac Format      M-P Prepend         ^T To Files
                          habe es geändet. Speiche ich das?
                          • L lukas8519
                            @lukas8519
                            Mit Strg-X, dann noch bestätigen.
                              @lukas8519
                              lukas8519
                              Error writing /etc/apt/sources.list.d/influxdb.listcode_text: Permission denied
                              ^G Get Help  ^O Write Out ^W Where Is  ^K Cut Text  ^J Justify   ^C Cur Pos
                              ^X Exit      ^R Read File ^\ Replace   ^U Uncut Text^T To Spell  ^_ Go To Line
                                @lukas8519
                                crunchipC Offline
                                crunchipC Offline
                                @thomas-braun hatt vorhin einen Denkfehler, mein Fehler, daher das Buster zuviel, habs oben korrigiert
                                @lukas8519 wenn ausgebessert dann nochmal
                                sudo apt update
                                sudo systemctl unmask influxdb.service
                                sudo systemctl start influxdb.service
                                sudo systemctl enable influxdb.service
                                • L lukas8519
                                  crunchipC Offline
                                  crunchipC Offline
                                  @lukas8519 du musst mit sudo davor
                                  sudo nano /etc/apt/sources.list.d/influxdb.list
                                    lukas8519
                                    @crunchip @Thomas-Braun
                                    ok. ich bin jetzt wieder hier habe buster in debian geändert:
                                    und jetzt?
                                    deb https://repos.influxdata.com/debian buster stable
                                    Thomas BraunT crunchipC 3 Antworten Letzte Antwort
                                    • L lukas8519
                                      und jetzt?
                                      @lukas8519
                                      Sorry, mit sudo vorweg, natürlich.
                                      • L lukas8519
                                        und jetzt?
                                        crunchipC Offline
                                        crunchipC Offline
                                        @lukas8519 strg und o speichert, strg und x wird geschlossen
                                          lukas8519
                                          @crunchip sagte in [influxDB] nach Rechnerumzug immer wieder ECONNREFUSED:
                                          bei beiden Kombinationen passiert nicht...
