Test Adapter TrashSchedule
trashschedule.0 2021-09-03 11:01:58.931 info State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:01:58.931 info State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:01:58.926 warn no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule! trashschedule.0 2021-09-03 11:00:05.013 info State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:00:05.011 info State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:00:05.004 warn no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule! trashschedule.0 2021-09-03 11:00:03.043 info State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:00:03.041 info State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:00:03.037 warn no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule!Ich glaube das ist nachdem ich das ganze System geupdated habe.
trashschedule.0 2021-09-03 11:17:43.027 info State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:17:43.025 info State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number" trashschedule.0 2021-09-03 11:17:42.856 debug (5) filling "nextAfter" event with data: {"minDays":13,"minDate":"2021-09-15T22:00:00.000Z","minTypes":["Gelbe Tonne"]} trashschedule.0 2021-09-03 11:17:42.855 debug (5) filling "next" event with data: {"minDays":6,"minDate":"2021-09-08T22:00:00.000Z","minTypes":["Schwarze Tonne"]} trashschedule.0 2021-09-03 11:17:42.853 warn no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule! trashschedule.0 2021-09-03 11:17:42.853 debug (3) event match: "Restmüll" matches type "Schwarze Tonne" with pattern "Restmüll" trashschedule.0 2021-09-03 11:17:42.852 debug (2) processing: Restmüll (1632348000000) // dayDiff: 20 // current hour (date): 11 (1630620000000) // skipsamedayathour (config): 18 trashschedule.0 2021-09-03 11:17:42.852 debug (1) parsing next event {"date":"23.09.2021 07:00","event":"Restmüll","_class":"ical_Muell ","_date":"2021-09-23T05:00:00.000Z","_end":"2021-09-23T05:00:00.000Z","_section":"Restmüll","_IDID":"5e09c2ce-cbd6-450d-bf19-f43c629e3c66","_allDay":false,"_private":false,"_rule":" ","location":"Glück-Auf-Straße 105, Dorsten","_calName":"Muell","_calColor":"#000000"} // originalDate: 2021-09-23T05:00:00.000Z // calculated date (with offset): Thu Sep 23 2021 00:00:00 GMT+0200 (GMT+02:00) trashschedule.0 2021-09-03 11:17:42.851 debug (4) filled type: "Gelbe Tonne" trashschedule.0 2021-09-03 11:17:42.850 debug (3) event match: "Wertstofftonne" matches type "Gelbe Tonne" with pattern "Wertstofftonne" trashschedule.0 2021-09-03 11:17:42.850 debug (2) processing: Wertstofftonne (1631743200000) // dayDiff: 13 // current hour (date): 11 (1630620000000) // skipsamedayathour (config): 18 trashschedule.0 2021-09-03 11:17:42.849 debug (1) parsing next event {"date":"16.09.2021 07:00","event":"Wertstofftonne","_class":"ical_Muell ","_date":"2021-09-16T05:00:00.000Z","_end":"2021-09-16T05:00:00.000Z","_section":"Wertstofftonne","_IDID":"32354b51-a34e-4f78-8a35-57afe049dfcc","_allDay":false,"_private":false,"_rule":" ","location":"Glück-Auf-Straße 105, Dorsten","_calName":"Muell","_calColor":"#000000"} // originalDate: 2021-09-16T05:00:00.000Z // calculated date (with offset): Thu Sep 16 2021 00:00:00 GMT+0200 (GMT+02:00) trashschedule.0 2021-09-03 11:17:42.849 debug (4) filled type: "Schwarze Tonne" trashschedule.0 2021-09-03 11:17:42.846 debug (3) event match: "Restmüll" matches type "Schwarze Tonne" with pattern "Restmüll" trashschedule.0 2021-09-03 11:17:42.846 debug (2) processing: Restmüll (1631138400000) // dayDiff: 6 // current hour (date): 11 (1630620000000) // skipsamedayathour (config): 18 trashschedule.0 2021-09-03 11:17:42.845 debug (1) parsing next event {"date":"In 6 Tagen 07:00","event":"Restmüll","_class":"ical_Muell ical_6days","_date":"2021-09-09T05:00:00.000Z","_end":"2021-09-09T05:00:00.000Z","_section":"Restmüll","_IDID":"affeac37-c472-4f20-b1ef-953500435a0a","_allDay":false,"_private":false,"_rule":" ","location":"Glück-Auf-Straße 105, Dorsten","_calName":"Muell","_calColor":"#000000"} // originalDate: 2021-09-09T05:00:00.000Z // calculated date (with offset): Thu Sep 09 2021 00:00:00 GMT+0200 (GMT+02:00) trashschedule.0 2021-09-03 11:17:42.844 debug (0) offset (config): 0 trashschedule.0 2021-09-03 11:17:42.843 debug Start processing 3 iCal events trashschedule.0 2021-09-03 11:17:42.840 debug updating data trashschedule.0 2021-09-03 11:17:42.836 debug re-creating refresh timeout in 2542164ms (00:42:22) trashschedule.0 2021-09-03 11:17:42.760 debug Trash type found: "Papiertonne" trashschedule.0 2021-09-03 11:17:42.730 debug Trash type found: "Schwarze Tonne" trashschedule.0 2021-09-03 11:17:42.712 debug Trash type found: "Gelbe Tonne" trashschedule.0 2021-09-03 11:17:42.634 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.5, js-controller: 3.3.15 trashschedule.0 2021-09-03 11:17:42.273 debug Plugin sentry Initialize Plugin (enabled=true) trashschedule.0 2021-09-03 11:17:41.000 debug statesDB connected trashschedule.0 2021-09-03 11:17:40.999 debug States connected to redis: 127.0.0.1:9000 trashschedule.0 2021-09-03 11:17:40.985 debug States create User PubSub Client trashschedule.0 2021-09-03 11:17:40.984 debug States create System PubSub Client trashschedule.0 2021-09-03 11:17:40.972 debug Redis States: Use Redis connection: 127.0.0.1:9000 trashschedule.0 2021-09-03 11:17:40.970 debug objectDB connected trashschedule.0 2021-09-03 11:17:40.956 debug Objects connected to redis: 127.0.0.1:9001 trashschedule.0 2021-09-03 11:17:40.936 debug Objects client initialize lua scripts trashschedule.0 2021-09-03 11:17:40.935 debug Objects create User PubSub Client trashschedule.0 2021-09-03 11:17:40.933 debug Objects create System PubSub Client trashschedule.0 2021-09-03 11:17:40.931 debug Objects client ready ... initialize now trashschedule.0 2021-09-03 11:17:40.894 debug Redis Objects: Use Redis connection: 127.0.0.1:9001@cino sagte in Test Adapter TrashSchedule v1.1.x:
steht weiter oben , was zu machen ist
https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v1-1-x/814
ich habe die Eigenschaft "leuchtet wenn fällig" angehakt und nun leuchtet der Kreis um die Zahl rot.
Dies ist mir aber nicht auffällig genug und hätte gerne das, am liebsten die ganze Tonne leuchtet / blinkt.Kann man das irgendwie einstellen?
Gruß Nu
Gruß Nu
Gruß Nu
@nu_81 sorry, aber irgendwie kann man alles übertreiben... :(
noch dazu, das du nicht mal schreibst, welche visualisierung du verwendest...@da_woody
Ich weiß jetzt nicht genau wie ich dir auf den Schlips getreten bin, falls ich etwas falsch gemacht haben sollte möchte ich mich aber natürlich entschuldigen.Ich habe niemanden kritisiert und auch wollte mich auch nur informieren,
wie ich eine bereits gute Lösung für mich noch weiter individualisieren kann.Habe nun letztlich einen Rahmen um alle Tonnen gelegt, der pulsiert wenn NextDays <= 1 ist.
@da_woody
@nu_81 oi, du bist mir nicht wo draufgetreten! :)
ist aber schwer, wenn du nicht sagst, welche visu du verwendest.
as i c, verwendest du vis. gibt aber auch noch andere. z.b. iQontrol u.s.w.
so gesehn, ists halt unterschiedlich wie man vorgehn kann. :) -
so gesehn, ists halt unterschiedlich wie man vorgehn kann. :)Hallo zusammen,
weiß vielleicht schon jemand wie man den Rahmen um die Mülltonnen verkleinern kann um das Widget ganz in die Ecke der Vis zu schieben?
Hab es bis jetzt noch nicht rausgefunden.
https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v1-1-x/758MfG Patrick
ich bin ganz neu im Thema ioBroker, und finde diese Adapter total super.
Auch das Widget lässt sich einfach ins vis einbinden.Was ich allerdings nicht gefunden habe ist die Möglichkeit das Widget im vis in der Größe zu ändern.
Geht dies nicht, oder wie muss ich das machen, damit auch alle (bei mir) 4 Tonnen angezeigt werden.Gruß
Christian -
Christian@c-radi
@sigi234 Schade, dass beim verkleinern auch die Schrift sehr klein wird. Das Datum ist fast nicht zu lesen, wenn man die Tonnen kleiner macht.
@bergjet sagte in Test Adapter TrashSchedule v1.1.x:
Abhilfe eventuell:
Beim Widget Haken weg bei Datum anzeigen
@bergjet
Vielleicht kann ich dir bisschen helfen.
Kennst du dich aus mit dieser CSS Sache?(bin auch noch am lernen)
Versuch mal das:
Damit wird die Schrift wieder grösser. du kannst statt large auch diverse andere Werte eingeben:
/* <absolute-size>-Werte */ font-size: xx-small; font-size: x-small; font-size: small; font-size: medium; font-size: large; font-size: x-large; font-size: xx-large; /* <relative-size>-Werte */ font-size: smaller; font-size: larger; /* <length>-Werte */ font-size: 12px; font-size: 0.8em; /* <percentage>-Werte */ font-size: 80%;Hoffe ich konnte auch mal was sinnvolle beitragen.
MfG
Patrick -
@bergjet
Versuch mal das:
MfG
Patrick@marsmännchen Danke, ob die Welt am Mars auch so einfach ist?
@bergjet
Leider nicht, ich schaffe es mittlerweile nicht mal mehr mit blockly einen state auf true zu schalten.
Kann mir jemand helfen und erklären warum der Adapter ein völlig falsches Datum angibt.
Ich stehe da gerade komplett auf`m Schlauch
@aachen1305
Wann sollte die nächste Abholung sein? Was steht im Kalender? -
@aachen1305
Wann sollte die nächste Abholung sein? Was steht im Kalender?@marsmännchen
Heute wäre die nächste Abholung.(Hausmüll)
Bei Ical ist auch alles richtig von den Daten her. -
@marsmännchen
Bei Ical ist auch alles richtig von den Daten her.@aachen1305
Vielleicht ein Screenshot von den beiden Konfigseiten?? -
@aachen1305
