  4. Test Adapter renault v0.0.x für myRenault und myDacia
387 Beiträge 59 Kommentatoren 100.1k Aufrufe 56 Beobachtet
  • T tombox
    @guergen Lösche mal die states und installiere via github neu
    guergen
    @tombox Jetzt kommen folgende Meldungen:
    renault.0
    	2021-10-09 15:39:28.275	error	{"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"}
    renault.0
    	2021-10-09 15:39:28.275	error	Error: Request failed with status code 403
    renault.0
    	2021-10-09 15:39:28.274	error	https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-e2eb-4ce4-866f-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/FIN/charge-history?type=day&start=1970-01-01&end=2021-10-09&country=de
    renault.0
    	2021-10-09 15:39:27.679	error	{"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"}
    renault.0
    	2021-10-09 15:39:27.678	error	Error: Request failed with status code 403
    renault.0
    	2021-10-09 15:39:27.677	error	https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-e2eb-4ce4-866f-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/FIN/charges?start=1970-01-01&end=2021-10-09&country=de
    • G guergen
      renault.0
      renault.0
      renault.0
      renault.0
      renault.0
      renault.0
      tombox
      @guergen hast du ein e Auto waren die charges und charge history vorher gefüllt ?
      G 1 Antwort Letzte Antwort
      • T tombox
        guergen
        @tombox Kein E-Auto, Benzin und LPG
        Der Chargemode ist leer.
        • G guergen
          tombox
          @guergen In der aktuellen version werden die Abfragen gestoppt wenn so ein Fehler kommt
          • T tombox
            guergen
            @tombox Also es kommt echt drauf an, wo ich genau parke... mal mit komma, mal ohne
            Oder es kommt darauf an, was Renault mir für eine Location sendet....
            Heute Nachmittag hatte ich wahrshceinlich ein kurze (8-stellige logitude), da hagelte es Fehler, jetzt habe ich wieder eine lange und alles ist schick ;-)
            • G guergen
              tombox
              @guergen eigentlich sollten kein fehler kommen kannst du den ordner location löschen und den adapter neustarten
              • T tombox
                guergen
                @tombox Erledigt, mal sehen was morgen passiert....
                • G guergen
                  Tudo
                  ich habe die Version 0.0.3 installiert. Die Daten scheinen zuverlässig zu kommen. Jedoch funktioniert die remote Funktion nicht.
                  Wenn ich z.B. die Heizung einschalten will und den Wert auf true setze, tut sich nichts.
                  So sieht der Log aus:
                  Ich habe einen Renault Twingo Electric Intense.
                  Grüße und Danke für die Arbeit,
                  Udo
                  T 2 Antworten Letzte Antwort
                  • T Tudo
                    Udo
                    tombox
                    @tudo geht es denn über die App
                    • T tombox
                      Tudo
                      @tombox Ja, es geht über die App und auch, wenn ich statt des Renault, den zoe2 Adapter starte.
                      • T Tudo
                        Udo
                        tombox
                        @tudo installier nochmal neu und probier nochmal kannst auch den debug log mir via privat nachricht schicken
                        G SunkHDS 2 Antworten Letzte Antwort
                        • T tombox
                          guergen
                          @tombox Bei mir erscheint jetzt schon wieder:
                          renault.0
                          	2021-10-14 15:26:47.675	info	State value to set for "renault.0.FIN.location.gpsLatitude" has to be type "string" but received type "number"
                          • G guergen
                            renault.0
                            tombox
                            @guergen
                            hast du wirklich den adapter Neuinstalliert
                            Location Ordner gelöscht
                            und dann den adapter Neustarten
                            • T tombox
                              @guergen
                              guergen
                              @tombox Ja, habe ich ,.... schon mehrfach; grade soar mein System neu installiert und dennoch bekomme ich den Fehler!
                              • G guergen
                                tombox
                                @guergen Ich hab in der github version nochmal die typen für die gps location angepasst.
                                Die Objekte nochmal löschen, neuinstallieren und dann sollte der type mixed sein.
                                • T tombox
                                  guergen
                                  @tombox OK, grade installiert, Typ ist mixed.
                                  Ich sage Bescheid, wenn was nicht ganz rund läuft.
                                  Version ist jetzt 0.0.5
                                  • H Offline
                                    heinzie
                                    ich verwende den Adapter (0.0.5) für eine zeo und läuft eigentlich auch einwandfrei. Das einzige Problem ist, dass der Adapter immer nach 1-2 Tagen keine neuen Werte holt. Wenn ich dann händisch einen Reset des Adaptzers vornehme läuft we weider ~1-2Tage.
                                    Ist der Fehler ggf. schon bekannt?
                                    2021-12-07 13:41:40.393	info	{"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                                    renault.0
                                    	30078	2021-12-07 13:41:40.392	info	Error: Request failed with status code 502
                                    renault.0
                                    	30078	2021-12-07 13:41:40.391	info	Feature not found. Ignore lock-status for updates.
                                    renault.0
                                    	30078	2021-12-07 13:41:40.120	info	{"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"}
                                    renault.0
                                    	30078	2021-12-07 13:41:40.120	info	Error: Request failed with status code 403
                                    renault.0
                                    	30078	2021-12-07 13:41:40.118	info	Feature not found. Ignore res-state for updates.
                                    renault.0
                                    	30078	2021-12-07 13:41:38.199	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.renault, node: v14.15.4, js-controller: 3.3.20
                                    • H heinzie
                                      renault.0
                                      renault.0
                                      renault.0
                                      renault.0
                                      renault.0
                                      renault.0
                                      guergen
                                      #66
                                      @heinzie Kann ich bestätigen, dachte es läeg an meinem System...
                                      Bekomme aber nur den Fehler 402
                                      • G guergen
                                        #67
                                        @guergen
                                        @heinzie
                                        Auch der zoe2-Adapter hat immer mal wieder keine Verbindung zu myRenault.
                                        Das liegt an der immer wieder kritisierten Renault Cloud
                                        Der Zoe2 kommt dann aber beim nächsten mal wieder.
                                        ggf. liegt es auch daran, wenn man parallel die App nutzt und (vielleicht) zu viele Zugriffe generiert
                                          @guergen
                                          @heinzie
                                          guergen
                                          #68
                                          @homoran Zu viele Zugriffe kann nicht sein, ich nutze die App sonst gar nicht. Nur wenn der Adapter mal wieder nicht wollte, gucke ich nach dem Kilometerstand und prüfe es zeitgleich in der App und dem Adapter
