  4. Pi Überlastet ** geschlossen mit neuinstall **
    5.6k
43 Beiträge 5 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • Horst BöttcherH Horst Böttcher
    @crunchip sagte in Pi Überlastet:
    @horst-böttcher
    dazu fehlen ein paar Info's z.b. was da alles darauf läuft, welcher Pi, etc...
    ja, theoretisch könnte ma es aufteilen, Stichwort Multihost
    processor       : 0
    model name      : ARMv7 Processor rev 3 (v7l)
    BogoMIPS        : 270.00
    Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xd08
    CPU revision    : 3
    processor       : 1
    BogoMIPS        : 270.00
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xd08
    CPU revision    : 3
    processor       : 2
    BogoMIPS        : 270.00
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xd08
    CPU revision    : 3
    processor       : 3
    BogoMIPS        : 270.00
    CPU architecture: 7
    CPU variant     : 0x0
    CPU part        : 0xd08
    CPU revision    : 3
    Hardware        : BCM2711
    Revision        : c03111
    Serial          : 100000002e4dc7ac
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "alias-manager" : 1.2.3    , installed 1.2.3
    Adapter    "backitup"      : 2.1.17   , installed 2.1.17
    Adapter    "ble"           : 0.12.0   , installed 0.12.0
    Adapter    "bring"         : 1.7.8    , installed 1.7.8
    Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
    Adapter    "deconz"        : 1.3.19   , installed 1.3.19
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "discovergy"    : 0.5.4    , installed 0.5.4
    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "fb-checkpresence": 1.1.8   , installed 1.1.8
    Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
    Adapter    "flot"          : 1.10.6   , installed 1.10.6
    Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.8
    Adapter    "history"       : 1.9.13   , installed 1.9.13
    Adapter    "hmip"          : 1.13.1   , installed 1.13.1
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "iot"           : 1.8.22   , installed 1.8.22
    Adapter    "javascript"    : 5.2.8    , installed 5.2.8
    Controller "js-controller" : 3.3.18   , installed 3.3.15 [Updateable]
    Adapter    "linux-control" : 1.1.2    , installed 1.1.2
    Adapter    "nuki-extended" : 2.3.1    , installed 2.3.1
    Adapter    "openligadb"    : 1.1.0    , installed 1.2.0
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
    Adapter    "sayit"         : 1.12.3   , installed 1.12.3
    Adapter    "shelly"        : 4.0.7    , installed 4.0.7
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
    Adapter    "tuya"          : 3.6.9    , installed 3.6.9
    Adapter    "tvprogram"     : 1.1.0    , installed 1.1.0
    Adapter    "tvspielfilm"   : 1.0.4    , installed 1.0.4
    Adapter    "upnp"          : 1.0.19   , installed 1.0.19
    Adapter    "vis"           : 1.4.3    , installed 1.4.3
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-icontwo"   : 0.80.0   , installed 0.80.0
    Adapter    "vis-inventwo"  : 3.1.3    , installed 3.1.3
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
    Adapter    "web"           : 3.4.7    , installed 3.4.7
    Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
    Adapter    "windows-control": 0.1.5   , installed 0.1.5
    Adapter    "youtube"       : 1.1.1    , installed 1.1.1
    Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
    crunchipC Abwesend
    crunchipC Abwesend
    @horst-böttcher sagte in Pi Überlastet:
    den kannste z.b. stoppen, unnötiger Ballast
    ansonsten wie schon geschrieben wurde, Pi mit 4GB Ram ist dann etwas knapp bemessen
    Horst BöttcherH 1 Antwort Letzte Antwort
      Hallo ich habe 1 Pi 4
      und habe dort meine ganze Wohnung drauf laufen
      Jetzt habe ich festgestellt das er hoffnungslos überlastet ist
      Was kann ich tun damit er es nicht mehr ist
      • Kann man einen 2 anklemmen und die Arbeit aufteilen (wenn ja bitte idioten sicher erklären )
      woran hast du das festgemacht?
      ich habe etwa 70 Instanzen und auch 2.7GB genutzten RAM - aber deswegen noch lange keinen überlasteten Server.
      jegliche weitere Vermutung kann ohne weitere Fakten nur in die falsche Richtung losgehen.
        @horst-böttcher
        Um 2:00 gleichzeitig in RL 3 und 5 gebootet? Das kann nicht sein.
        Du besuchst mehr RAM, weniger laufende Instanzen und einen Server in RunLevel 3. Oder wird da auch noch unmittelbar ein Display für die vis über den Raspberry befeuert?
        Horst BöttcherH Offline
        Horst Böttcher
        @thomas-braun sagte in Pi Überlastet:
        @horst-böttcher
        Hab ihn später umgestellt auf booten ohne Display Treiber weil also auf Level 3
        ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
          Horst Böttcher
          Ok werde ich machen
            Horst Böttcher
            @homoran sagte in Pi Überlastet:
            Ich hab es mit bekommen als der pi beim Arbeiten fast eingeschlafen ist
            Schalten über vis dauer immer so 30 sekunden bis sich was tut genauso über Google
              und was für Fakten hast du aus dieser Zeit?
              60% RAM-Nutzung bremsen ihn nicht aus.
              immer?
              Dann braucht es tatsächlich jede weitere Menge Infos um die mögliche Ursache einzugrenzen.
                immer?
                Horst Böttcher
                @homoran ich denke hier kann mann das problem sehen was ich habe
                https://youtu.be/-8YKwhNzOwA
                  bitte keine externen Links
                    Horst Böttcher
                    @homoran videos kann man hier nicht hochladen oder
                      @horst-böttcher
                      Wozu ein Video? Mit einem kreisenden Logo kann hier auch keiner weiterhelfen.
                      Log Files?
                      htop
                      z.B.?
                      Wobei die Diagnose da eigentlich einfach ist:
                      Da läuft zu viel Zeug.
                      Horst BöttcherH HomoranH 2 Antworten Letzte Antwort
                        @horst-böttcher
                        Log Files?
                        htop
                        z.B.?
                        Horst Böttcher
                        @horst-böttcher
                        Log Files?
                        htop
                        z.B.?
                        ok kann mmit jemand erklärren wie auf eine bestehenden Systerm ein multi host machte oder nuss ich alles neu machen
                          @horst-böttcher
                          Log Files?
                          htop
                          z.B.?
                          sehe ich anders.
                            sehe ich anders.
                            Horst Böttcher
                            mein logs sind leider zu gross
                              @horst-böttcher
                              Was zur Hölle ist denn da bei dir los?
                              ein controller-Prozess mit 112% eines CPU-Kerns. nicht schön, aber eigentlich nicht tödlich (Load average liegt ja nur bei etwa 2 von max 4)
                              RAM voll und SWAP verbraucht (letzteres wird viel I/O verursachen)
                              Da scheint etwas grundsätzlich im Argen zu liegen
                                @horst-böttcher
                                Horst Böttcher
                                @homoran also ab besten alles neu machen
                                  solange du nicht weisst was du falsch hast, wird es sehr wahrscheinlich auch bei einer Neuanlage wieder so sein
                                    Horst Böttcher
                                    @homoran das problem hab ich erst seid dem ich auf Admin 5 umgestellt hab
                                      @horst-böttcher iobroker update -i
                                        Horst Böttcher
                                        iobroker update -i
                                        pi@raspberrypi:/opt/iobroker $ iobroker update -i
                                        hash changed or no sources cached => force download of new sources
                                        update done
                                        Controller "js-controller" : 3.3.18   , installed 3.3.18
                                          iobroker update -i
                                          update done
                                          @horst-böttcher
                                          Da sind ja schon einige nahezu identische Adapter am Werk.
                                          Ich kenne auch nicht alle, kann daher nicht sagen, welche möglicherweise dein System asubremsen
                                          Auch ob die ganzen China-Adapter sich ggf. mit den Ports in die Quere kommen
                                          Vielleicht weiß da jemand anderes mehr
