  2. English
  3. ioBroker general
  4. [Gelöst] Adapters show invalid mode
    6.4k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
invalid mode
23 Beiträge 7 Kommentatoren 4.4k Aufrufe 6 Beobachtet
    DBh
    Klar ;-)
    pi@pi04:/opt/iobroker $ iobroker status
    Objects type: file
    States  type: file
    pi@pi04:/opt/iobroker $ iobroker update -i
    Used repository: default
    hash changed or no sources cached => force download of new sources
    update done
    Adapter    "admin"         : 5.1.23   , installed 5.1.23
    Adapter    "backitup"      : 2.1.17   , installed 2.1.17
    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
    Adapter    "heos"          : 1.8.6    , installed 1.8.6
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.8    , installed 5.2.8
    Controller "js-controller" : 3.3.15   , installed 3.3.15
    Adapter    "node-red"      : 2.4.0    , installed 2.4.0
    Adapter    "shelly"        : 4.0.7    , installed 4.0.7
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "vis"           : 1.4.3    , installed 1.4.3
    Adapter    "web"           : 3.4.7    , installed 3.4.7
    pi@pi04:/opt/iobroker $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.1.23
    system.adapter.backitup                : backitup       - v2.1.17
    system.adapter.discovery               : discovery      - v2.7.0
    system.adapter.heos                    : heos           - v1.8.6
    system.adapter.info                    : info           - v1.9.8
    system.adapter.javascript              : javascript     - v5.2.8
    system.adapter.node-red                : node-red       - v2.4.0
    system.adapter.shelly                  : shelly         - v4.0.7
    system.adapter.web                     : web            - v3.4.7
    pi@pi04:/opt/iobroker $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : pi04                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : pi04                                     -  enabled
    + system.adapter.discovery.0              : discovery             : pi04                                     -  enabled
      system.adapter.heos.0                   : heos                  : pi04                                     -  enabled
      system.adapter.info.0                   : info                  : pi04                                     -  enabled
    + system.adapter.javascript.0             : javascript            : pi04                                     -  enabled
    + system.adapter.node-red.0               : node-red              : pi04                                     -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.shelly.0                 : shelly                : pi04                                     -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.web.0                    : web                   : pi04                                     -  enabled
    + system.adapter.web.1                    : web                   : pi04                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    Thomas BraunT paul53P 2 Antworten Letzte Antwort
    • D DBh
      Klar ;-)
      Objects type: file
      States  type: file
      update done
      + instance is alive
      @dbh
      iobroker start info
      Und warum zwei Instanzen von web?
        @dbh
        iobroker start info
        DBh
        Habe ich, nachdem das Problem aufgetreten ist, nochmals installiert.
        • D DBh
          @dbh
          Widerspricht dem KISS-Prinzip. Schmeiß den raus.
          • D DBh
            Klar ;-)
            Objects type: file
            States  type: file
            update done
            + instance is alive
            @dbh
            Was steht in den drei Objekten
            • system.adapter.heos.0
            • system.adapter.info.0
            • system.adapter.web.0
            unter "OBJEKTDATEN" hinter common.mode? Expertenmodus aktivieren!
              "_id": "system.adapter.web.0",
              "type": "instance",
              "common": {
                "name": "web",
                "version": "3.4.7",
                "title": "WEB server",
                "titleLang": {
                  "en": "WEB server",
                  "de": "WEB-Server",
                  "ru": "Веб сервер",
                  "pt": "Servidor web",
                  "nl": "Web Server",
                  "fr": "Serveur Web",
                  "it": "Server web",
                  "es": "Servidor web",
                  "pl": "Serwer internetowy",
                  "zh-cn": "Web服务器"
                "desc": {
                  "en": "opens a webserver for other adapters",
                  "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung",
                  "ru": "Запускает веб сервер для 'ioBroker драйверов'",
                  "pt": "abre um servidor web para outros adaptadores",
                  "nl": "opent een webserver voor andere adapters",
                  "fr": "ouvre un serveur web pour d'autres adaptateurs",
                  "it": "apre un server web per altri adattatori",
                  "es": "abre un servidor web para otros adaptadores",
                  "pl": "otwiera serwer internetowy dla innych kart",
                  "zh-cn": "为其他适配器服务的web服务器"
                "mode": "daemon",
              @dbh
                "type": "instance",
                "common": {
                  "name": "web",
                  "version": "3.4.7",
                  "titleLang": {
                    "en": "WEB server",
                    "de": "WEB-Server",
                    "ru": "Веб сервер",
                    "nl": "Web Server",
                    "it": "Server web",
                    "zh-cn": "Web服务器"
                  "desc": {
                  "mode": "daemon",
              DBh
              Bin leider noch nicht so fit, du hast wahrscheinlich eine Konsolenkommando gemein. In der Weboberfläche sehe ich die Objekte nicht.
              • D DBh
                @dbh sagte: In der Weboberfläche sehe ich die Objekte nicht.
                Unter "system" (rot).
                Dann die Eigenschaften (Bleistift rechts).
                  DBh
                  Danke für die Unterstützung!
                    "type": "instance",
                    "protectedNative": [],
                    "encryptedNative": [],
                    "notifications": [],
                    "instanceObjects": [],
                    "objects": [],
                    "common": {
                      "name": "web",
                      "title": "ioBroker web Adapter",
                      "logLevel": "info",
                      "host": "pi04",
                      "enabled": true
                    "native": {},
                    "user": "system.user.admin",
                    "ts": 1631008143484
                    "type": "instance",
                    "objects": [],
                    "_id": "system.adapter.info.0",
                    "common": {
                      "name": "info",
                      "title": "Information page",
                      "logLevel": "info",
                      "host": "pi04",
                      "enabled": true
                    "native": {},
                    "ts": 1631009504485
                    "type": "meta",
                    "common": {
                      "name": "admin",
                      "type": "admin"
                    "from": "system.host.pi04.cli",
                    "ts": 1631003881490,
                    "native": {},
                    "_id": "heos.admin"
                  • D DBh
                      "type": "instance",
                      "objects": [],
                      "common": {
                        "name": "web",
                        "logLevel": "info",
                        "host": "pi04",
                        "enabled": true
                      "native": {},
                      "ts": 1631008143484
                      "type": "instance",
                      "objects": [],
                      "common": {
                        "name": "info",
                        "logLevel": "info",
                        "host": "pi04",
                        "enabled": true
                      "native": {},
                      "ts": 1631009504485
                      "type": "meta",
                      "common": {
                        "name": "admin",
                        "type": "admin"
                      "native": {},
                      "_id": "heos.admin"
                    @dbh
                    Da ist wohl beim Erstellen der Instanzen einiges schief gelaufen.
                    Lösche die Instanzen und erstelle sie neu. Falls es dann immer noch so aussieht, lösche die Adapter und installiere sie neu.
                    D 2 Antworten Letzte Antwort
                      @dbh
                      DBh
                      @paul53 Danke, mache ich
                        @dbh
                        DBh
                        @paul53 Das Löschen und Neuanlegen der Instanzen hat gereicht. Läuft, besten Dank!
                        • D DBh
                          @dbh sagte: Löschen und Neuanlegen der Instanzen hat gereicht.
                          Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [Gelöst].
                          • apollon77A Offline
                            Seeehr interessant ... Kann mir das gerade nicht erklären so recht. Falls der nächste das Problem hat wäre interessnt bo auch ein "upload" des betroffenen Adapters das fixt und falls der Adapter neu installiert war das Install log.
                            Bzw Frage an die bisher betroffenen: Waren es neu installierte Adapter oder ist es "plötzlich aus heiteremHimmel" aufgetreten? Oder nach einem Update?
                            SchloS 1 Antwort Letzte Antwort
                            • apollon77A apollon77
                              SchloS Offline
                              SchloS Offline
                              Schlo
                              @apollon77
                              Ich hatte ein ähnliches Problem. Ich nutze das aktuelle Docker-Image von ioBroker und bei mir waren alle Instanzen außer Admin, Backup und Discovery fehlerhaft oder sind nicht (richtig) gestartet.
                              Löschen und über Adapter neu installieren hat es dann auch gefixt.
                              Die Fehler treten nur (aber immer nachvollziehbar) auf, wenn ich die Installation per Geräte und Dienste finden -> Letzten Scan verwenden -> Instanz auswählen und "Instanzen erstellen" starte. Was ich als Newbie natürlich erst mal so gemacht hatte.
                              Vielleicht hilft ja dieser Hinweis.
                              OstfrieseUnterwegsO 1 Antwort Letzte Antwort
                              • SchloS Schlo
                                @apollon77
                                OstfrieseUnterwegsO Offline
                                OstfrieseUnterwegs
                                @apollon77
                                Ebenso: Komplett neu aufgesetzt. Erstkonfiguration mit dem Assistenten.
                                Es gab drei Instanzen, die nicht gestartet sind: javascript, proxmox, lgtv. Der Fehler war invalid mode
                                Weitere Instanzen konnten nicht konfiguriert werden. (tr-064, web, net-tools, ping) Fehlermeldung: File index.html not found
                                'Upload' hat das Problem gelöst. Löschen der Instanz oder des Adapters war nicht nötig
                                • OstfrieseUnterwegsO OstfrieseUnterwegs
                                  @apollon77
                                  @ostfrieseunterwegs Legt bitte mal jemand im discovery adapter ein issue an? Danke!
                                    OstfrieseUnterwegs
                                    @apollon77
                                    schon da
                                    https://github.com/ioBroker/ioBroker.discovery/issues/176
