  2. English
  3. ioBroker general
  4. [Gelöst] Adapters show invalid mode
    6.4k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
invalid mode
23 Beiträge 7 Kommentatoren 4.4k Aufrufe 6 Beobachtet
  • D DBh
    After installing iobroker on a Raspi from scratch some of the adapters show "invalid mode":
    The instances themselves show no version number (although when updating they show the most recent one):
    Any ideas what went wrong?
    fastfoot
    @dbh sagte in Adapters show invalid mode:
    from scratch
    how exactly did you install?
    • F fastfoot
      from scratch
      DBh
      @fastfoot :
      sudo curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
      sudo apt install -y nodejs
      sudo reboot now
      sudo curl -sL https://iobroker.net/install.sh | bash -
      sudo reboot now
      Raspbian was installed with the Raspi_Imager_1.6.2
      • D DBh
        @fastfoot :
        sudo reboot now
        sudo reboot now
        is the only line that is necessary for a clean installation.
        What does your system reply to
        iobroker status
        iobroker update -i
        iobroker list adapters
        iobroker list instances
          iobroker status
          iobroker update -i
          DBh
          Hi Thomas,
          here the response to the commands:
          pi@pi04:/opt/iobroker $ iobroker status
          Objects type: file
          States type: file
          pi@pi04:/opt/iobroker $ iobroker update -i
          Used repository: default
          hash changed or no sources cached => force download of new sources
          update done
          Adapter "admin" : 5.1.23 , installed 5.1.23
          Adapter "backitup" : 2.1.17 , installed 2.1.17
          Adapter "discovery" : 2.7.0 , installed 2.7.0
          Adapter "heos" : 1.8.6 , installed 1.8.6
          Adapter "info" : 1.9.8 , installed 1.9.8
          Adapter "javascript" : 5.2.8 , installed 5.2.8
          Controller "js-controller" : 3.3.15 , installed 3.3.15
          Adapter "node-red" : 2.4.0 , installed 2.4.0
          Adapter "shelly" : 4.0.7 , installed 4.0.7
          Adapter "simple-api" : 2.6.1 , installed 2.6.1
          Adapter "socketio" : 3.1.4 , installed 3.1.4
          Adapter "vis" : 1.4.3 , installed 1.4.3
          Adapter "web" : 3.4.7 , installed 3.4.7
          pi@pi04:/opt/iobroker $ iobroker list adapters
          system.adapter.admin : admin - v5.1.23
          system.adapter.backitup : backitup - v2.1.17
          system.adapter.discovery : discovery - v2.7.0
          system.adapter.heos : heos - v1.8.6
          system.adapter.info : info - v1.9.8
          system.adapter.javascript : javascript - v5.2.8
          system.adapter.node-red : node-red - v2.4.0
          system.adapter.shelly : shelly - v4.0.7
          system.adapter.web : web - v3.4.7
          pi@pi04:/opt/iobroker $ iobroker list instances
          • system.adapter.admin.0 : admin : pi04 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          • system.adapter.backitup.0 : backitup : pi04 - enabled
          • system.adapter.discovery.0 : discovery : pi04 - enabled
            system.adapter.heos.0 : heos : pi04 - enabled
            system.adapter.info.0 : info : pi04 - enabled
          • system.adapter.javascript.0 : javascript : pi04 - enabled
          • system.adapter.node-red.0 : node-red : pi04 - enabled, port: 1880, bind: 0.0.0.0
          • system.adapter.shelly.0 : shelly : pi04 - enabled, port: 1882, bind: 0.0.0.0
            system.adapter.web.0 : web : pi04 - enabled
          • system.adapter.web.1 : web : pi04 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          • instance is alive
          Cheers
          Dieter
          • D DBh
            Hi Thomas,
            Objects type: file
            States type: file
            update done
            • instance is alive
            Cheers
            Dieter
            @dbh
            Ich denke einem Dieter kann man auch deutsch antworten.
            Bitte Ausgaben aus der Konsole in CodeTags einbetten.
              DBh
              Klar ;-)
              Objects type: file
              States  type: file
              update done
              + system.adapter.admin.0                  : admin                 : pi04                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : pi04                                     -  enabled
              + system.adapter.discovery.0              : discovery             : pi04                                     -  enabled
              + system.adapter.javascript.0             : javascript            : pi04                                     -  enabled
              + system.adapter.node-red.0               : node-red              : pi04                                     -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.shelly.0                 : shelly                : pi04                                     -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.web.1                    : web                   : pi04                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              Thomas BraunT paul53P 2 Antworten Letzte Antwort
              • D DBh
                Klar ;-)
                Objects type: file
                States  type: file
                update done
                + instance is alive
                @dbh
                iobroker start info
                Und warum zwei Instanzen von web?
                  @dbh
                  iobroker start info
                  DBh
                  Habe ich, nachdem das Problem aufgetreten ist, nochmals installiert.
                  • D DBh
                    @dbh
                    Widerspricht dem KISS-Prinzip. Schmeiß den raus.
                    • D DBh
                      Klar ;-)
                      Objects type: file
                      States  type: file
                      update done
                      + instance is alive
                      @dbh
                      Was steht in den drei Objekten
                      • system.adapter.heos.0
                      • system.adapter.info.0
                      • system.adapter.web.0
                      unter "OBJEKTDATEN" hinter common.mode? Expertenmodus aktivieren!
                        "_id": "system.adapter.web.0",
                        "type": "instance",
                        "common": {
                          "name": "web",
                          "version": "3.4.7",
                          "title": "WEB server",
                          "titleLang": {
                            "en": "WEB server",
                            "de": "WEB-Server",
                            "ru": "Веб сервер",
                            "pt": "Servidor web",
                            "nl": "Web Server",
                            "fr": "Serveur Web",
                            "it": "Server web",
                            "es": "Servidor web",
                            "pl": "Serwer internetowy",
                            "zh-cn": "Web服务器"
                          "desc": {
                            "en": "opens a webserver for other adapters",
                            "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung",
                            "ru": "Запускает веб сервер для 'ioBroker драйверов'",
                            "pt": "abre um servidor web para outros adaptadores",
                            "nl": "opent een webserver voor andere adapters",
                            "fr": "ouvre un serveur web pour d'autres adaptateurs",
                            "it": "apre un server web per altri adattatori",
                            "es": "abre un servidor web para otros adaptadores",
                            "pl": "otwiera serwer internetowy dla innych kart",
                            "zh-cn": "为其他适配器服务的web服务器"
                          "mode": "daemon",
                        @dbh
                          "type": "instance",
                          "common": {
                            "name": "web",
                            "version": "3.4.7",
                            "titleLang": {
                              "en": "WEB server",
                              "de": "WEB-Server",
                              "ru": "Веб сервер",
                              "nl": "Web Server",
                              "it": "Server web",
                              "zh-cn": "Web服务器"
                            "desc": {
                            "mode": "daemon",
                        DBh
                        Bin leider noch nicht so fit, du hast wahrscheinlich eine Konsolenkommando gemein. In der Weboberfläche sehe ich die Objekte nicht.
                        • D DBh
                          @dbh sagte: In der Weboberfläche sehe ich die Objekte nicht.
                          Unter "system" (rot).
                          Dann die Eigenschaften (Bleistift rechts).
                            DBh
                            Danke für die Unterstützung!
                              "type": "instance",
                              "protectedNative": [],
                              "encryptedNative": [],
                              "notifications": [],
                              "instanceObjects": [],
                              "objects": [],
                              "common": {
                                "name": "web",
                                "title": "ioBroker web Adapter",
                                "logLevel": "info",
                                "host": "pi04",
                                "enabled": true
                              "native": {},
                              "user": "system.user.admin",
                              "ts": 1631008143484
                              "type": "instance",
                              "objects": [],
                              "_id": "system.adapter.info.0",
                              "common": {
                                "name": "info",
                                "title": "Information page",
                                "logLevel": "info",
                                "host": "pi04",
                                "enabled": true
                              "native": {},
                              "ts": 1631009504485
                              "type": "meta",
                              "common": {
                                "name": "admin",
                                "type": "admin"
                              "from": "system.host.pi04.cli",
                              "ts": 1631003881490,
                              "native": {},
                              "_id": "heos.admin"
                            • D DBh
                                "type": "instance",
                                "objects": [],
                                "common": {
                                  "name": "web",
                                  "logLevel": "info",
                                  "host": "pi04",
                                  "enabled": true
                                "native": {},
                                "ts": 1631008143484
                                "type": "instance",
                                "objects": [],
                                "common": {
                                  "name": "info",
                                  "logLevel": "info",
                                  "host": "pi04",
                                  "enabled": true
                                "native": {},
                                "ts": 1631009504485
                                "type": "meta",
                                "common": {
                                  "name": "admin",
                                  "type": "admin"
                                "native": {},
                                "_id": "heos.admin"
                              @dbh
                              Da ist wohl beim Erstellen der Instanzen einiges schief gelaufen.
                              Lösche die Instanzen und erstelle sie neu. Falls es dann immer noch so aussieht, lösche die Adapter und installiere sie neu.
                              D 2 Antworten Letzte Antwort
                                @dbh
                                DBh
                                @paul53 Danke, mache ich
                                  @dbh
                                  DBh
                                  @paul53 Das Löschen und Neuanlegen der Instanzen hat gereicht. Läuft, besten Dank!
                                  • D DBh
                                    @dbh sagte: Löschen und Neuanlegen der Instanzen hat gereicht.
                                    Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [Gelöst].
                                    • apollon77A Offline
                                      Seeehr interessant ... Kann mir das gerade nicht erklären so recht. Falls der nächste das Problem hat wäre interessnt bo auch ein "upload" des betroffenen Adapters das fixt und falls der Adapter neu installiert war das Install log.
                                      Bzw Frage an die bisher betroffenen: Waren es neu installierte Adapter oder ist es "plötzlich aus heiteremHimmel" aufgetreten? Oder nach einem Update?
                                      SchloS 1 Antwort Letzte Antwort
                                      • apollon77A apollon77
                                        SchloS Offline
                                        SchloS Offline
                                        Schlo
                                        @apollon77
                                        Ich hatte ein ähnliches Problem. Ich nutze das aktuelle Docker-Image von ioBroker und bei mir waren alle Instanzen außer Admin, Backup und Discovery fehlerhaft oder sind nicht (richtig) gestartet.
                                        Löschen und über Adapter neu installieren hat es dann auch gefixt.
                                        Die Fehler treten nur (aber immer nachvollziehbar) auf, wenn ich die Installation per Geräte und Dienste finden -> Letzten Scan verwenden -> Instanz auswählen und "Instanzen erstellen" starte. Was ich als Newbie natürlich erst mal so gemacht hatte.
                                        Vielleicht hilft ja dieser Hinweis.
                                        OstfrieseUnterwegsO 1 Antwort Letzte Antwort
                                        • SchloS Schlo
                                          @apollon77
                                          OstfrieseUnterwegsO Offline
                                          OstfrieseUnterwegs
                                          @apollon77
                                          Ebenso: Komplett neu aufgesetzt. Erstkonfiguration mit dem Assistenten.
                                          Es gab drei Instanzen, die nicht gestartet sind: javascript, proxmox, lgtv. Der Fehler war invalid mode
                                          Weitere Instanzen konnten nicht konfiguriert werden. (tr-064, web, net-tools, ping) Fehlermeldung: File index.html not found
                                          'Upload' hat das Problem gelöst. Löschen der Instanz oder des Adapters war nicht nötig
