  2. English
  3. ioBroker general
  4. [Gelöst] Adapters show invalid mode
    6.4k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
invalid mode
23 Beiträge 7 Kommentatoren 4.4k Aufrufe 6 Beobachtet
    DBh
    schrieb am zuletzt editiert von DBh
    After installing iobroker on a Raspi from scratch some of the adapters show "invalid mode":
    The instances themselves show no version number (although when updating they show the most recent one):
    Any ideas what went wrong?
    F 1 Antwort Letzte Antwort
    • D DBh
      F Online
      F Online
      fastfoot
      @dbh sagte in Adapters show invalid mode:
      from scratch
      how exactly did you install?
      • F fastfoot
        from scratch
        DBh
        @fastfoot :
        sudo curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
        sudo apt install -y nodejs
        sudo reboot now
        sudo curl -sL https://iobroker.net/install.sh | bash -
        sudo reboot now
        Raspbian was installed with the Raspi_Imager_1.6.2
        • D DBh
          @fastfoot :
          sudo reboot now
          sudo reboot now
          is the only line that is necessary for a clean installation.
          What does your system reply to
          iobroker status
          iobroker update -i
          iobroker list adapters
          iobroker list instances
            iobroker status
            iobroker update -i
            DBh
            Hi Thomas,
            here the response to the commands:
            pi@pi04:/opt/iobroker $ iobroker status
            Objects type: file
            States type: file
            pi@pi04:/opt/iobroker $ iobroker update -i
            Used repository: default
            hash changed or no sources cached => force download of new sources
            update done
            Adapter "admin" : 5.1.23 , installed 5.1.23
            Adapter "backitup" : 2.1.17 , installed 2.1.17
            Adapter "discovery" : 2.7.0 , installed 2.7.0
            Adapter "heos" : 1.8.6 , installed 1.8.6
            Adapter "info" : 1.9.8 , installed 1.9.8
            Adapter "javascript" : 5.2.8 , installed 5.2.8
            Controller "js-controller" : 3.3.15 , installed 3.3.15
            Adapter "node-red" : 2.4.0 , installed 2.4.0
            Adapter "shelly" : 4.0.7 , installed 4.0.7
            Adapter "simple-api" : 2.6.1 , installed 2.6.1
            Adapter "socketio" : 3.1.4 , installed 3.1.4
            Adapter "vis" : 1.4.3 , installed 1.4.3
            Adapter "web" : 3.4.7 , installed 3.4.7
            pi@pi04:/opt/iobroker $ iobroker list adapters
            system.adapter.admin : admin - v5.1.23
            system.adapter.backitup : backitup - v2.1.17
            system.adapter.discovery : discovery - v2.7.0
            system.adapter.heos : heos - v1.8.6
            system.adapter.info : info - v1.9.8
            system.adapter.javascript : javascript - v5.2.8
            system.adapter.node-red : node-red - v2.4.0
            system.adapter.shelly : shelly - v4.0.7
            system.adapter.web : web - v3.4.7
            pi@pi04:/opt/iobroker $ iobroker list instances
            • system.adapter.admin.0 : admin : pi04 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
            • system.adapter.backitup.0 : backitup : pi04 - enabled
            • system.adapter.discovery.0 : discovery : pi04 - enabled
              system.adapter.heos.0 : heos : pi04 - enabled
              system.adapter.info.0 : info : pi04 - enabled
            • system.adapter.javascript.0 : javascript : pi04 - enabled
            • system.adapter.node-red.0 : node-red : pi04 - enabled, port: 1880, bind: 0.0.0.0
            • system.adapter.shelly.0 : shelly : pi04 - enabled, port: 1882, bind: 0.0.0.0
              system.adapter.web.0 : web : pi04 - enabled
            • system.adapter.web.1 : web : pi04 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
            • instance is alive
            Cheers
            Dieter
            • D DBh
              Hi Thomas,
              Objects type: file
              States type: file
              update done
              • instance is alive
              Cheers
              Dieter
              @dbh
              Ich denke einem Dieter kann man auch deutsch antworten.
              Bitte Ausgaben aus der Konsole in CodeTags einbetten.
                DBh
                Klar ;-)
                Objects type: file
                States  type: file
                update done
                + system.adapter.admin.0                  : admin                 : pi04                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.backitup.0               : backitup              : pi04                                     -  enabled
                + system.adapter.discovery.0              : discovery             : pi04                                     -  enabled
                + system.adapter.javascript.0             : javascript            : pi04                                     -  enabled
                + system.adapter.node-red.0               : node-red              : pi04                                     -  enabled, port: 1880, bind: 0.0.0.0
                + system.adapter.shelly.0                 : shelly                : pi04                                     -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.web.1                    : web                   : pi04                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                Thomas BraunT paul53P 2 Antworten Letzte Antwort
                • D DBh
                  Klar ;-)
                  Objects type: file
                  States  type: file
                  update done
                  + instance is alive
                  @dbh
                  iobroker start info
                  Und warum zwei Instanzen von web?
                    @dbh
                    iobroker start info
                    DBh
                    Habe ich, nachdem das Problem aufgetreten ist, nochmals installiert.
                    • D DBh
                      @dbh
                      Widerspricht dem KISS-Prinzip. Schmeiß den raus.
                      • D DBh
                        Klar ;-)
                        Objects type: file
                        States  type: file
                        update done
                        + instance is alive
                        @dbh
                        Was steht in den drei Objekten
                        • system.adapter.heos.0
                        • system.adapter.info.0
                        • system.adapter.web.0
                        unter "OBJEKTDATEN" hinter common.mode? Expertenmodus aktivieren!
                          "_id": "system.adapter.web.0",
                          "type": "instance",
                          "common": {
                            "name": "web",
                            "version": "3.4.7",
                            "title": "WEB server",
                            "titleLang": {
                              "en": "WEB server",
                              "de": "WEB-Server",
                              "ru": "Веб сервер",
                              "pt": "Servidor web",
                              "nl": "Web Server",
                              "fr": "Serveur Web",
                              "it": "Server web",
                              "es": "Servidor web",
                              "pl": "Serwer internetowy",
                              "zh-cn": "Web服务器"
                            "desc": {
                              "en": "opens a webserver for other adapters",
                              "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung",
                              "ru": "Запускает веб сервер для 'ioBroker драйверов'",
                              "pt": "abre um servidor web para outros adaptadores",
                              "nl": "opent een webserver voor andere adapters",
                              "fr": "ouvre un serveur web pour d'autres adaptateurs",
                              "it": "apre un server web per altri adattatori",
                              "es": "abre un servidor web para otros adaptadores",
                              "pl": "otwiera serwer internetowy dla innych kart",
                              "zh-cn": "为其他适配器服务的web服务器"
                            "mode": "daemon",
                          @dbh
                            "type": "instance",
                            "common": {
                              "name": "web",
                              "version": "3.4.7",
                              "titleLang": {
                                "en": "WEB server",
                                "de": "WEB-Server",
                                "ru": "Веб сервер",
                                "nl": "Web Server",
                                "it": "Server web",
                                "zh-cn": "Web服务器"
                              "desc": {
                              "mode": "daemon",
                          DBh
                          Bin leider noch nicht so fit, du hast wahrscheinlich eine Konsolenkommando gemein. In der Weboberfläche sehe ich die Objekte nicht.
                          • D DBh
                            @dbh sagte: In der Weboberfläche sehe ich die Objekte nicht.
                            Unter "system" (rot).
                            Dann die Eigenschaften (Bleistift rechts).
                              DBh
                              Danke für die Unterstützung!
                                "type": "instance",
                                "protectedNative": [],
                                "encryptedNative": [],
                                "notifications": [],
                                "instanceObjects": [],
                                "objects": [],
                                "common": {
                                  "name": "web",
                                  "title": "ioBroker web Adapter",
                                  "logLevel": "info",
                                  "host": "pi04",
                                  "enabled": true
                                "native": {},
                                "user": "system.user.admin",
                                "ts": 1631008143484
                                "type": "instance",
                                "objects": [],
                                "_id": "system.adapter.info.0",
                                "common": {
                                  "name": "info",
                                  "title": "Information page",
                                  "logLevel": "info",
                                  "host": "pi04",
                                  "enabled": true
                                "native": {},
                                "ts": 1631009504485
                                "type": "meta",
                                "common": {
                                  "name": "admin",
                                  "type": "admin"
                                "from": "system.host.pi04.cli",
                                "ts": 1631003881490,
                                "native": {},
                                "_id": "heos.admin"
                              • D DBh
                                  "type": "instance",
                                  "objects": [],
                                  "common": {
                                    "name": "web",
                                    "logLevel": "info",
                                    "host": "pi04",
                                    "enabled": true
                                  "native": {},
                                  "ts": 1631008143484
                                  "type": "instance",
                                  "objects": [],
                                  "common": {
                                    "name": "info",
                                    "logLevel": "info",
                                    "host": "pi04",
                                    "enabled": true
                                  "native": {},
                                  "ts": 1631009504485
                                  "type": "meta",
                                  "common": {
                                    "name": "admin",
                                    "type": "admin"
                                  "native": {},
                                  "_id": "heos.admin"
                                @dbh
                                Da ist wohl beim Erstellen der Instanzen einiges schief gelaufen.
                                Lösche die Instanzen und erstelle sie neu. Falls es dann immer noch so aussieht, lösche die Adapter und installiere sie neu.
                                D 2 Antworten Letzte Antwort
                                  @dbh
                                  DBh
                                  @paul53 Danke, mache ich
                                    @dbh
                                    DBh
                                    @paul53 Das Löschen und Neuanlegen der Instanzen hat gereicht. Läuft, besten Dank!
                                    • D DBh
                                      @dbh sagte: Löschen und Neuanlegen der Instanzen hat gereicht.
                                      Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [Gelöst].
                                      • apollon77A Offline
                                        Seeehr interessant ... Kann mir das gerade nicht erklären so recht. Falls der nächste das Problem hat wäre interessnt bo auch ein "upload" des betroffenen Adapters das fixt und falls der Adapter neu installiert war das Install log.
                                        Bzw Frage an die bisher betroffenen: Waren es neu installierte Adapter oder ist es "plötzlich aus heiteremHimmel" aufgetreten? Oder nach einem Update?
                                        SchloS 1 Antwort Letzte Antwort
                                        • apollon77A apollon77
                                          SchloS Offline
                                          SchloS Offline
                                          Schlo
                                          @apollon77
                                          Ich hatte ein ähnliches Problem. Ich nutze das aktuelle Docker-Image von ioBroker und bei mir waren alle Instanzen außer Admin, Backup und Discovery fehlerhaft oder sind nicht (richtig) gestartet.
                                          Löschen und über Adapter neu installieren hat es dann auch gefixt.
                                          Die Fehler treten nur (aber immer nachvollziehbar) auf, wenn ich die Installation per Geräte und Dienste finden -> Letzten Scan verwenden -> Instanz auswählen und "Instanzen erstellen" starte. Was ich als Newbie natürlich erst mal so gemacht hatte.
                                          Vielleicht hilft ja dieser Hinweis.
                                          OstfrieseUnterwegsO 1 Antwort Letzte Antwort
