  2. English
  3. ioBroker general
  4. [Gelöst] Adapters show invalid mode
    6.4k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
invalid mode
23 Beiträge 7 Kommentatoren 4.4k Aufrufe 6 Beobachtet
  • F fastfoot
    @dbh sagte in Adapters show invalid mode:
    from scratch
    how exactly did you install?
    DBh
    @fastfoot :
    sudo curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
    sudo apt install -y nodejs
    sudo reboot now
    sudo curl -sL https://iobroker.net/install.sh | bash -
    sudo reboot now
    Raspbian was installed with the Raspi_Imager_1.6.2
    • D DBh
      @fastfoot :
      sudo reboot now
      sudo reboot now
      is the only line that is necessary for a clean installation.
      What does your system reply to
      iobroker status
      iobroker update -i
      iobroker list adapters
      iobroker list instances
        iobroker status
        iobroker update -i
        DBh
        Hi Thomas,
        here the response to the commands:
        pi@pi04:/opt/iobroker $ iobroker status
        Objects type: file
        States type: file
        pi@pi04:/opt/iobroker $ iobroker update -i
        Used repository: default
        hash changed or no sources cached => force download of new sources
        update done
        Adapter "admin" : 5.1.23 , installed 5.1.23
        Adapter "backitup" : 2.1.17 , installed 2.1.17
        Adapter "discovery" : 2.7.0 , installed 2.7.0
        Adapter "heos" : 1.8.6 , installed 1.8.6
        Adapter "info" : 1.9.8 , installed 1.9.8
        Adapter "javascript" : 5.2.8 , installed 5.2.8
        Controller "js-controller" : 3.3.15 , installed 3.3.15
        Adapter "node-red" : 2.4.0 , installed 2.4.0
        Adapter "shelly" : 4.0.7 , installed 4.0.7
        Adapter "simple-api" : 2.6.1 , installed 2.6.1
        Adapter "socketio" : 3.1.4 , installed 3.1.4
        Adapter "vis" : 1.4.3 , installed 1.4.3
        Adapter "web" : 3.4.7 , installed 3.4.7
        pi@pi04:/opt/iobroker $ iobroker list adapters
        system.adapter.admin : admin - v5.1.23
        system.adapter.backitup : backitup - v2.1.17
        system.adapter.discovery : discovery - v2.7.0
        system.adapter.heos : heos - v1.8.6
        system.adapter.info : info - v1.9.8
        system.adapter.javascript : javascript - v5.2.8
        system.adapter.node-red : node-red - v2.4.0
        system.adapter.shelly : shelly - v4.0.7
        system.adapter.web : web - v3.4.7
        pi@pi04:/opt/iobroker $ iobroker list instances
        • system.adapter.admin.0 : admin : pi04 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        • system.adapter.backitup.0 : backitup : pi04 - enabled
        • system.adapter.discovery.0 : discovery : pi04 - enabled
          system.adapter.heos.0 : heos : pi04 - enabled
          system.adapter.info.0 : info : pi04 - enabled
        • system.adapter.javascript.0 : javascript : pi04 - enabled
        • system.adapter.node-red.0 : node-red : pi04 - enabled, port: 1880, bind: 0.0.0.0
        • system.adapter.shelly.0 : shelly : pi04 - enabled, port: 1882, bind: 0.0.0.0
          system.adapter.web.0 : web : pi04 - enabled
        • system.adapter.web.1 : web : pi04 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        • instance is alive
        Cheers
        Dieter
        • D DBh
          Hi Thomas,
          Objects type: file
          States type: file
          update done
          • instance is alive
          Cheers
          Dieter
          @dbh
          Ich denke einem Dieter kann man auch deutsch antworten.
          Bitte Ausgaben aus der Konsole in CodeTags einbetten.
            DBh
            Klar ;-)
            Objects type: file
            States  type: file
            update done
            + system.adapter.admin.0                  : admin                 : pi04                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : pi04                                     -  enabled
            + system.adapter.discovery.0              : discovery             : pi04                                     -  enabled
            + system.adapter.javascript.0             : javascript            : pi04                                     -  enabled
            + system.adapter.node-red.0               : node-red              : pi04                                     -  enabled, port: 1880, bind: 0.0.0.0
            + system.adapter.shelly.0                 : shelly                : pi04                                     -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.web.1                    : web                   : pi04                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            Thomas BraunT paul53P 2 Antworten Letzte Antwort
            • D DBh
              Klar ;-)
              Objects type: file
              States  type: file
              update done
              + instance is alive
              @dbh
              iobroker start info
              Und warum zwei Instanzen von web?
                @dbh
                iobroker start info
                DBh
                Habe ich, nachdem das Problem aufgetreten ist, nochmals installiert.
                • D DBh
                  @dbh
                  Widerspricht dem KISS-Prinzip. Schmeiß den raus.
                  • D DBh
                    Klar ;-)
                    Objects type: file
                    States  type: file
                    update done
                    + instance is alive
                    @dbh
                    Was steht in den drei Objekten
                    • system.adapter.heos.0
                    • system.adapter.info.0
                    • system.adapter.web.0
                    unter "OBJEKTDATEN" hinter common.mode? Expertenmodus aktivieren!
                      "_id": "system.adapter.web.0",
                      "type": "instance",
                      "common": {
                        "name": "web",
                        "version": "3.4.7",
                        "title": "WEB server",
                        "titleLang": {
                          "en": "WEB server",
                          "de": "WEB-Server",
                          "ru": "Веб сервер",
                          "pt": "Servidor web",
                          "nl": "Web Server",
                          "fr": "Serveur Web",
                          "it": "Server web",
                          "es": "Servidor web",
                          "pl": "Serwer internetowy",
                          "zh-cn": "Web服务器"
                        "desc": {
                          "en": "opens a webserver for other adapters",
                          "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung",
                          "ru": "Запускает веб сервер для 'ioBroker драйверов'",
                          "pt": "abre um servidor web para outros adaptadores",
                          "nl": "opent een webserver voor andere adapters",
                          "fr": "ouvre un serveur web pour d'autres adaptateurs",
                          "it": "apre un server web per altri adattatori",
                          "es": "abre un servidor web para otros adaptadores",
                          "pl": "otwiera serwer internetowy dla innych kart",
                          "zh-cn": "为其他适配器服务的web服务器"
                        "mode": "daemon",
                      @dbh
                        "type": "instance",
                        "common": {
                          "name": "web",
                          "version": "3.4.7",
                          "titleLang": {
                            "en": "WEB server",
                            "de": "WEB-Server",
                            "ru": "Веб сервер",
                            "nl": "Web Server",
                            "it": "Server web",
                            "zh-cn": "Web服务器"
                          "desc": {
                          "mode": "daemon",
                      DBh
                      Bin leider noch nicht so fit, du hast wahrscheinlich eine Konsolenkommando gemein. In der Weboberfläche sehe ich die Objekte nicht.
                      • D DBh
                        @dbh sagte: In der Weboberfläche sehe ich die Objekte nicht.
                        Unter "system" (rot).
                        Dann die Eigenschaften (Bleistift rechts).
                          DBh
                          Danke für die Unterstützung!
                            "type": "instance",
                            "protectedNative": [],
                            "encryptedNative": [],
                            "notifications": [],
                            "instanceObjects": [],
                            "objects": [],
                            "common": {
                              "name": "web",
                              "title": "ioBroker web Adapter",
                              "logLevel": "info",
                              "host": "pi04",
                              "enabled": true
                            "native": {},
                            "user": "system.user.admin",
                            "ts": 1631008143484
                            "type": "instance",
                            "objects": [],
                            "_id": "system.adapter.info.0",
                            "common": {
                              "name": "info",
                              "title": "Information page",
                              "logLevel": "info",
                              "host": "pi04",
                              "enabled": true
                            "native": {},
                            "ts": 1631009504485
                            "type": "meta",
                            "common": {
                              "name": "admin",
                              "type": "admin"
                            "from": "system.host.pi04.cli",
                            "ts": 1631003881490,
                            "native": {},
                            "_id": "heos.admin"
                          • D DBh
                              "type": "instance",
                              "objects": [],
                              "common": {
                                "name": "web",
                                "logLevel": "info",
                                "host": "pi04",
                                "enabled": true
                              "native": {},
                              "ts": 1631008143484
                              "type": "instance",
                              "objects": [],
                              "common": {
                                "name": "info",
                                "logLevel": "info",
                                "host": "pi04",
                                "enabled": true
                              "native": {},
                              "ts": 1631009504485
                              "type": "meta",
                              "common": {
                                "name": "admin",
                                "type": "admin"
                              "native": {},
                              "_id": "heos.admin"
                            @dbh
                            Da ist wohl beim Erstellen der Instanzen einiges schief gelaufen.
                            Lösche die Instanzen und erstelle sie neu. Falls es dann immer noch so aussieht, lösche die Adapter und installiere sie neu.
                            D 2 Antworten Letzte Antwort
                              @dbh
                              DBh
                              @paul53 Danke, mache ich
                                @dbh
                                DBh
                                @paul53 Das Löschen und Neuanlegen der Instanzen hat gereicht. Läuft, besten Dank!
                                • D DBh
                                  @dbh sagte: Löschen und Neuanlegen der Instanzen hat gereicht.
                                  Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [Gelöst].
                                  • apollon77A Offline
                                    Seeehr interessant ... Kann mir das gerade nicht erklären so recht. Falls der nächste das Problem hat wäre interessnt bo auch ein "upload" des betroffenen Adapters das fixt und falls der Adapter neu installiert war das Install log.
                                    Bzw Frage an die bisher betroffenen: Waren es neu installierte Adapter oder ist es "plötzlich aus heiteremHimmel" aufgetreten? Oder nach einem Update?
                                    SchloS 1 Antwort Letzte Antwort
                                    • apollon77A apollon77
                                      SchloS Offline
                                      SchloS Offline
                                      Schlo
                                      @apollon77
                                      Ich hatte ein ähnliches Problem. Ich nutze das aktuelle Docker-Image von ioBroker und bei mir waren alle Instanzen außer Admin, Backup und Discovery fehlerhaft oder sind nicht (richtig) gestartet.
                                      Löschen und über Adapter neu installieren hat es dann auch gefixt.
                                      Die Fehler treten nur (aber immer nachvollziehbar) auf, wenn ich die Installation per Geräte und Dienste finden -> Letzten Scan verwenden -> Instanz auswählen und "Instanzen erstellen" starte. Was ich als Newbie natürlich erst mal so gemacht hatte.
                                      Vielleicht hilft ja dieser Hinweis.
                                      OstfrieseUnterwegsO 1 Antwort Letzte Antwort
                                      • SchloS Schlo
                                        @apollon77
                                        OstfrieseUnterwegsO Offline
                                        OstfrieseUnterwegs
                                        @apollon77
                                        Ebenso: Komplett neu aufgesetzt. Erstkonfiguration mit dem Assistenten.
                                        Es gab drei Instanzen, die nicht gestartet sind: javascript, proxmox, lgtv. Der Fehler war invalid mode
                                        Weitere Instanzen konnten nicht konfiguriert werden. (tr-064, web, net-tools, ping) Fehlermeldung: File index.html not found
                                        'Upload' hat das Problem gelöst. Löschen der Instanz oder des Adapters war nicht nötig
                                        • OstfrieseUnterwegsO OstfrieseUnterwegs
                                          @apollon77
                                          @ostfrieseunterwegs Legt bitte mal jemand im discovery adapter ein issue an? Danke!
