  4. [Gelöst]Proxm-backup Abbruch bei 20GB nur ca.5GB vorhanden
    6.5k
34 Beiträge 5 Kommentatoren 4.7k Aufrufe 3 Beobachtet
  • G GOETSCHHOFER
    @crunchip said in [Gelöst]Proxm-backup Abbruch bei 20GB nur ca.5GB vorhanden:
    sudo apt-get install lshw
    Nachinstalliert und dies ist das Ergebnis mit sudo lshw, wegen Fehlermeldung: Partition 2 does not start on physical sector boundary.
    login as: karl
    karl@192.168.1.140's password:
    Linux NUC 5.4.124-1-pve #1 SMP PVE 5.4.124-1 (Wed, 23 Jun 2021 13:47:09 +0200) x        86_64
    permitted by applicable law.
    Last login: Sun Aug 29 13:09:10 2021 from 192.168.1.3
    karl@NUC:~$ sudo lshw
    [sudo] password for karl:
    nuc
        description: Mini PC
        product: NUC8i3BEK (BOXNUC8i3BEK)
        vendor: Intel(R) Client Systems
        version: J72748-308
        serial: G6BE05100A7W
        width: 64 bits
        capabilities: smbios-3.2.1 dmi-3.2.1 smp vsyscall32
        configuration: boot=normal chassis=mini family=BE sku=BOXNUC8i3BEK uuid=3214        261F-3EE2-1169-841C-1C697AA1241B
      *-core
           description: Motherboard
           product: NUC8BEB
           vendor: Intel Corporation
           physical id: 0
           version: J72693-309
           serial: GEBE048005F0
           slot: Default string
         *-firmware
              description: BIOS
              vendor: Intel Corp.
              physical id: 0
              version: BECFL357.86A.0081.2020.0504.1834
              date: 05/04/2020
              capacity: 16MiB
              capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd        int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17        printer acpi usb biosbootspecification uefi
         *-memory
              description: System Memory
              physical id: 3b
              slot: System board or motherboard
            *-bank:0
                 description: SODIMM DDR4 Synchronous 2400 MHz (0.4 ns)
                 product: CT16G4SFD824A.C16FE
                 vendor: 859B
                 physical id: 0
                 serial: E5223447
                 slot: SODIMM1
                 width: 64 bits
                 clock: 2400MHz (0.4ns)
            *-bank:1
                 description: [empty]
                 physical id: 1
                 slot: SODIMM2
         *-cache:0
              description: L1 cache
              physical id: 45
              slot: L1 Cache
              capacity: 128KiB
              capabilities: synchronous internal write-back unified
              configuration: level=1
         *-cache:1
              description: L2 cache
              physical id: 46
              slot: L2 Cache
              capacity: 512KiB
              configuration: level=2
         *-cache:2
              description: L3 cache
              physical id: 47
              slot: L3 Cache
              capacity: 4MiB
              configuration: level=3
         *-cpu
              description: CPU
              product: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
              vendor: Intel Corp.
              physical id: 48
              bus info: cpu@0
              version: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
              serial: To Be Filled By O.E.M.
              slot: U3E1
              width: 64 bits
              clock: 100MHz
              capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 a        pic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm        pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_        good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds        _cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe p        opcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpu        id_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriorit        y ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdsee        d adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pl        n pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d cpufreq
              configuration: cores=2 enabledcores=2 threads=4
         *-pci
              description: Host bridge
              product: Intel Corporation
              physical id: 100
              bus info: pci@0000:00:00.0
              version: 08
              width: 32 bits
              clock: 33MHz
              configuration: driver=skl_uncore
              resources: irq:0
            *-display
                 description: VGA compatible controller
                 physical id: 2
                 bus info: pci@0000:00:02.0
                 version: 01
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pciexpress msi pm vga_controller bus_master cap_list        rom
                 configuration: driver=i915 latency=0
                 resources: irq:142 memory:a7000000-a7ffffff memory:80000000-8ffffff        f ioport:4000(size=64) memory:c0000-dffff
            *-generic:0
                 description: System peripheral
                 product: Skylake Gaussian Mixture Model
                 physical id: 8
                 bus info: pci@0000:00:08.0
                 logical name: /dev/fb0
                 version: 00
                 width: 64 bits
                 clock: 33MHz
                 capabilities: msi pm cap_list fb
                 configuration: depth=32 latency=0 mode=1920x1080 visual=truecolor x        res=1920 yres=1080
                 resources: iomemory:400-3ff memory:4022c1a000-4022c1afff
            *-generic:1
                 description: Signal processing controller
                 physical id: 12
                 bus info: pci@0000:00:12.0
                 version: 30
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm msi cap_list
                 configuration: driver=intel_pch_thermal latency=0
                 resources: iomemory:400-3ff irq:16 memory:4022c19000-4022c19fff
            *-usb
                 description: USB controller
                 physical id: 14
                 bus info: pci@0000:00:14.0
                 version: 30
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm msi xhci bus_master cap_list
                 configuration: driver=xhci_hcd latency=0
                 resources: iomemory:400-3ff irq:133 memory:4022c00000-4022c0ffff
               *-usbhost:0
                    product: xHCI Host Controller
                    vendor: Linux 5.4.124-1-pve xhci-hcd
                    physical id: 0
                    bus info: usb@1
                    logical name: usb1
                    version: 5.04
                    capabilities: usb-2.00
                    configuration: driver=hub slots=12 speed=480Mbit/s
                  *-usb
                       description: Bluetooth wireless interface
                       vendor: Intel Corp.
                       physical id: a
                       bus info: usb@1:a
                       version: 0.02
                       capabilities: bluetooth usb-2.00
                       configuration: driver=btusb maxpower=100mA speed=12Mbit/s
               *-usbhost:1
                    physical id: 1
                    bus info: usb@2
                    logical name: usb2
                    version: 5.04
                    capabilities: usb-3.10
                    configuration: driver=hub slots=6 speed=10000Mbit/s
                  *-usb
                       description: Mass storage device
                       product: SanDisk 3.2Gen1
                       vendor: USB
                       physical id: 1
                       bus info: usb@2:1
                       logical name: scsi3
                       version: 1.00
                       serial: 09012f2628e4c2ae279e230673d5c0e627351182b22493c32e6e4        d1e7fe6d0701a77000000000000
                       capabilities: usb-3.00 scsi emulated scsi-host
                       configuration: driver=usb-storage maxpower=896mA speed=5000Mb        it/s
                     *-disk
                          description: SCSI Disk
                          vendor: USB
                          physical id: 0.0.0
                          bus info: scsi@3:0.0.0
                          logical name: /dev/sda
                          version: 1.00
                          capabilities: removable
                          configuration: ansiversion=6 logicalsectorsize=512 sectors        ize=512
                        *-medium
                             physical id: 0
                             capabilities: partitioned partitioned:dos
                             configuration: signature=fe0e14e2
                           *-volume
                                description: EXT4 volume
                                vendor: Linux
                                physical id: 1
                                logical name: /dev/sda1
                                logical name: /media/USB-NUC-NAS
                                version: 1.0
                                serial: 424d08e7-6f86-47bf-b555-9db175a8b480
                                capacity: 14GiB
                                capabilities: primary journaled extended_attributes        large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                                configuration: created=2021-05-17 12:17:26 filesyste        m=ext4 lastmountpoint=/media/USB-NUC-NAS modified=2021-08-26 08:52:38 mount.fsty        pe=ext4 mount.options=rw,sync,nosuid,nodev,noexec,relatime mounted=2021-08-26 08        :52:38 state=mounted
            *-memory UNCLAIMED
                 description: RAM memory
                 physical id: 14.2
                 bus info: pci@0000:00:14.2
                 version: 30
                 width: 64 bits
                 clock: 33MHz (30.3ns)
                 capabilities: pm cap_list
                 configuration: latency=0
                 resources: iomemory:400-3ff iomemory:400-3ff memory:4022c14000-4022        c15fff memory:4022c18000-4022c18fff
            *-network:0 DISABLED
                 description: Wireless interface
                 physical id: 14.3
                 bus info: pci@0000:00:14.3
                 logical name: wlp0s20f3
                 version: 30
                 serial: 54:8d:5a:64:5f:c8
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm msi pciexpress msix bus_master cap_list ethernet p        hysical wireless
                 configuration: broadcast=yes driver=iwlwifi driverversion=5.4.124-1        -pve firmware=46.6b541b68.0 latency=0 link=no multicast=yes wireless=IEEE 802.11
                 resources: iomemory:400-3ff irq:16 memory:4022c10000-4022c13fff
            *-communication
                 description: Communication controller
                 physical id: 16
                 bus info: pci@0000:00:16.0
                 version: 30
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm msi bus_master cap_list
                 configuration: driver=mei_me latency=0
                 resources: iomemory:400-3ff irq:135 memory:4022c17000-4022c17fff
            *-sata
                 description: SATA controller
                 physical id: 17
                 bus info: pci@0000:00:17.0
                 version: 30
                 width: 32 bits
                 clock: 66MHz
                 capabilities: sata msi pm ahci_1.0 bus_master cap_list
                 configuration: driver=ahci latency=0
                 resources: irq:131 memory:a8b24000-a8b25fff memory:a8b27000-a8b270f        f ioport:4090(size=8) ioport:4080(size=4) ioport:4060(size=32) memory:a8b26000-a        8b267ff
            *-pci:0
                 description: PCI bridge
                 physical id: 1c
                 bus info: pci@0000:00:1c.0
                 version: f0
                 width: 32 bits
                 clock: 33MHz
                 capabilities: pci pciexpress msi pm normal_decode bus_master cap_li        st
                 configuration: driver=pcieport
                 resources: irq:122
            *-pci:1
                 physical id: 1c.4
                 bus info: pci@0000:00:1c.4
                 version: f0
                 width: 32 bits
                 clock: 33MHz
                 resources: irq:123 ioport:5000(size=4096) memory:90000000-a60fffff        ioport:4000000000(size=570425344)
            *-pci:2
                 physical id: 1d
                 bus info: pci@0000:00:1d.0
                 version: f0
                 width: 32 bits
                 clock: 33MHz
                 resources: irq:124 memory:a8a00000-a8afffff
               *-storage
                    description: Non-Volatile memory controller
                    product: Kingston Technologies
                    vendor: Kingston Technologies
                    physical id: 0
                    bus info: pci@0000:3b:00.0
                    version: 03
                    width: 64 bits
                    clock: 33MHz
                    capabilities: storage pm msi pciexpress msix nvm_express bus_mas        ter cap_list
                    configuration: driver=nvme latency=0
                    resources: irq:16 memory:a8a00000-a8a03fff
            *-pci:3
                 physical id: 1d.6
                 bus info: pci@0000:00:1d.6
                 version: f0
                 width: 32 bits
                 clock: 33MHz
                 resources: irq:125 ioport:3000(size=4096) memory:a8000000-a89fffff        ioport:4022100000(size=10485760)
               *-generic
                    description: Unassigned class
                    product: RTS522A PCI Express Card Reader
                    vendor: Realtek Semiconductor Co., Ltd.
                    physical id: 0
                    bus info: pci@0000:3c:00.0
                    version: 01
                    width: 32 bits
                    clock: 33MHz
                    capabilities: pm msi pciexpress bus_master cap_list
                    configuration: driver=rtsx_pci latency=0
                    resources: irq:132 memory:a8000000-a8000fff
            *-isa
                 description: ISA bridge
                 physical id: 1f
                 bus info: pci@0000:00:1f.0
                 version: 30
                 width: 32 bits
                 clock: 33MHz
                 capabilities: isa bus_master
            *-multimedia
                 description: Audio device
                 physical id: 1f.3
                 bus info: pci@0000:00:1f.3
                 version: 30
                 width: 64 bits
                 clock: 33MHz
                 configuration: driver=snd_hda_intel latency=32
                 resources: iomemory:400-3ff irq:143 memory:a8b20000-a8b23fff memory        :4022b00000-4022bfffff
            *-serial:0
                 description: SMBus
                 physical id: 1f.4
                 bus info: pci@0000:00:1f.4
                 version: 30
                 width: 64 bits
                 clock: 33MHz
                 configuration: driver=i801_smbus latency=0
                 resources: iomemory:400-3ff irq:16 memory:4022c16000-4022c160ff iop        ort:efa0(size=32)
            *-serial:1 UNCLAIMED
                 description: Serial bus controller
                 physical id: 1f.5
                 bus info: pci@0000:00:1f.5
                 version: 30
                 width: 32 bits
                 clock: 33MHz
                 resources: memory:fe010000-fe010fff
            *-network:1
                 description: Ethernet interface
                 physical id: 1f.6
                 bus info: pci@0000:00:1f.6
                 logical name: eno1
                 version: 30
                 serial: 1c:69:7a:a1:24:1b
                 capacity: 1Gbit/s
                 width: 32 bits
                 clock: 33MHz
                 capabilities: pm msi bus_master cap_list ethernet physical tp 10bt        10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
                 configuration: autonegotiation=on broadcast=yes driver=e1000e drive        rversion=3.2.6-k duplex=full firmware=0.4-4 latency=0 link=yes multicast=yes por        t=twisted pair speed=1Gbit/s
                 resources: irq:134 memory:a8b00000-a8b1ffff
         *-pnp00:00
              product: PnP device PNP0c02
              physical id: 1
              capabilities: pnp
              configuration: driver=system
         *-pnp00:01
              physical id: 2
              capabilities: pnp
         *-pnp00:02
              physical id: 3
              capabilities: pnp
         *-pnp00:03
              product: PnP device INT3f0d
              physical id: 4
              capabilities: pnp
         *-pnp00:04
              physical id: 5
              capabilities: pnp
         *-pnp00:05
              physical id: 6
              capabilities: pnp
         *-pnp00:06
              physical id: 7
              capabilities: pnp
         *-pnp00:07
              physical id: 8
              capabilities: pnp
      *-power UNCLAIMED
           description: To Be Filled By O.E.M.
           product: To Be Filled By O.E.M.
           vendor: To Be Filled By O.E.M.
           physical id: 1
           version: To Be Filled By O.E.M.
           capacity: 32768mWh
      *-network:0
           physical id: 2
           logical name: fwln100i0
           serial: 06:ef:85:fc:a2:c7
           capabilities: ethernet physical
           configuration: autonegotiation=off broadcast=yes driver=veth driverversio        n=1.0 duplex=full link=yes multicast=yes port=twisted pair speed=10Gbit/s
      *-network:1
           physical id: 3
           logical name: fwbr210i0
           serial: 0e:7a:56:a4:4c:21
           configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A        link=yes multicast=yes
      *-network:2
           physical id: 4
           logical name: veth210i0
           serial: fe:9d:55:05:33:e4
      *-network:3
           physical id: 5
           logical name: veth200i0
           serial: fe:79:00:c3:96:f0
      *-network:4
           physical id: 6
           logical name: vmbr0
           configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A        ip=192.168.1.140 link=yes multicast=yes
      *-network:5
           physical id: 7
           logical name: fwln210i0
      *-network:6
           physical id: 8
           logical name: fwpr200p0
           serial: 6a:ca:d6:e0:9a:8d
      *-network:7
           physical id: 9
           logical name: fwln200i0
           serial: 9a:a1:2b:ad:7d:53
      *-network:8
           physical id: a
           logical name: fwpr100p0
           serial: 1a:3d:b2:73:f9:08
      *-network:9
           physical id: b
           logical name: fwbr200i0
      *-network:10
           physical id: c
           logical name: fwbr100i0
      *-network:11
           physical id: d
           logical name: fwpr210p0
           serial: 96:bd:b5:ab:db:6f
      *-network:12
           physical id: e
           logical name: tap100i0
           serial: a6:83:ed:6a:8d:9f
           configuration: autonegotiation=off broadcast=yes driver=tun driverversion        =1.6 duplex=full link=yes multicast=yes port=twisted pair promiscuous=yes speed=        10Mbit/s
    crunchipC Abwesend
    crunchipC Abwesend
    @goetschhofer ich finde da nichts zu deiner Platte, nur deinen Stick ,bei
    *-disk
    G 1 Antwort Letzte Antwort
      *-disk
      GOETSCHHOFER
      schrieb am zuletzt editiert von GOETSCHHOFER
      @crunchip
      Dann ignoriere ich einfach mal diese Fehlermeldung.
      • G GOETSCHHOFER
        @crunchip
        crunchipC Abwesend
        crunchipC Abwesend
        @goetschhofer ?
          @goetschhofer ?
          GOETSCHHOFER
          @goetschhofer ?
          Melde mich gleich, bezüglich mounten Stick-2 bei vorhandenem stick-1.
          • G GOETSCHHOFER
            @goetschhofer ?
            GOETSCHHOFER
            @crunchip
            Habe den USB-Stick auf ext4 formatiert und eingesteckt.
            Mein aktueller USB-Stick-12 GB ist im Verzeichnis media/USB-Stick/NAS unter sda1 gemountet.
            Kann ich für meinen USB-Stick-2-120GB das gleiche Verzeichnis verwenden oder muss ich hier ein eigenes Verzeichnis anlegen ?
            Mit sudo fdisk -l bekomme ich den aktuellen USB-Stick mit 16 GB Bezeichnung sda1.
            Disk /dev/sda: 14.6 GiB, 15682240512 bytes, 30629376 sectors
            Disk model:  SanDisk 3.2Gen1
            Units: sectors of 1 * 512 = 512 bytes
            Sector size (logical/physical): 512 bytes / 512 bytes
            I/O size (minimum/optimal): 512 bytes / 512 bytes
            Disklabel type: dos
            Disk identifier: 0xfe0e14e2
            Device     Boot Start      End  Sectors  Size Id Type
            /dev/sda1        2048 30627839 30625792 14.6G  7 HPFS/NTFS/exFAT
            karl@NUC:~$
            Danke für die Hilfe.
            G crunchipC 2 Antworten Letzte Antwort
            • G GOETSCHHOFER
              @crunchip
              Disklabel type: dos
              karl@NUC:~$
              GOETSCHHOFER
              @crunchip
              Habe den USB-Stick-120 GB jetzt gefunden, dieser ist unter sdb1 angezeigt.
              Beim einhängen mit sudo mount /dev/sdb1 /media/USB-NUC-NAS bekomme ich aber eine Fehlermeldung:
              /dev/sdb1       32768 250085375 250052608 119.2G 83 Linux
              karl@NUC:~$ ^C
              karl@NUC:~$ sudo mount /dev/sdb1 /media/USB-NUC-NAS
              mount: /dev/sdb1 /media/USB-NUC-NAS: can't find in /etc/fstab.
              karl@NUC:~$
              Disklabel type: dos
              Disk /dev/sdb: 119.3 GiB, 128043712512 bytes, 250085376 sectors
              Disk model: Extreme Pro
              Disklabel type: dos
              Disk identifier: 0x01343268
              karl@NUC:~$
              • G GOETSCHHOFER
                @crunchip
                Disklabel type: dos
                karl@NUC:~$
                crunchipC Abwesend
                crunchipC Abwesend
                @goetschhofer sagte in [Gelöst]Proxm-backup Abbruch bei 20GB nur ca.5GB vorhanden:
                im Verzeichnis "media" ja, jedoch nicht von Vorteil, den gleichen Namen zu vergeben
                du machst z.b.
                sudo mkdir /media/usb_backup
                sudo mount /dev/sdb1 /media/usb_backup
                testen kannst du mit
                mount -l
                wie du siehst, kommt der Fehler, das der Eintrag in der fstab fehlt, daher brauchst du noch die UUID mittels
                blkid
                sudo nano /etc/fstab
                trägst du dann ein
                UUID=die-uuid-deines-neuen-sticks /media/usb_backup  ext4   auto,defaults   0   2
                  du machst z.b.
                  mount -l
                  blkid
                  trägst du dann ein
                  GOETSCHHOFER
                  @crunchip
                  Ich habe alles schon mit den Schritten, welche du beschrieben hast anhand eines Videos vorher schon durchgeführt, aber das Einbinden hat anschließend nicht funktioniert, Fehlermeldung.
                  Ich glaube der wesentliche Fehler war der gleiche Ordner, mit der Anlage eines neuen Ordners hat es jetzt auf Anhieb funktioniert.
                  Backup fehlerfrei durchgelaufen. 😀
                  Vielen Dank für deine Hilfe und vor allem die Geduld. 👍
                  • G GOETSCHHOFER
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    freut mich, backup müsste dann auch etwas zügiger durchgelaufen sein, als vorher mit deinem alten Stick
                    und nicht vergessen, deine Automatisierten Backups auf den neuen Stick zu ändern
                      GOETSCHHOFER
                      Ja, dies ist jetzt für VM-iobroker mit 12 GB in 2 - 3 Minuten durchgelaufen, die restlichen 2 LXC waren in 1 Minute erledigt.
                      Der Hinweis von dir, bezüglich Lese/Schreibegeschwindigkeit 400 MB/s beim Kauf des USB-Stick war sehr wertvoll.
