  4. Easee Wallbox mit iobroker
easeewallboxadapter
534 Beiträge 62 Kommentatoren 203.1k Aufrufe 55 Beobachtet
  • NewanN Newan
    @scotty89 Nur cloud
    S
    S
    stonemaan
    #243
    @newan ich habe heute morgen signalR angeschaltet. leider ist der adapter nach einiger Zeit wieder auf gelb gesprungen. Ich habe heute allerdings auch den JS controller geupdated und NodeJS auch..
    2021-08-06 11:34:42.697 - error: easee.0 (1381) Error: Request failed with status code 503
    2021-08-06 11:34:42.698 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
    2021-08-06 11:34:42.704 - error: easee.0 (1381) Error: Request failed with status code 503
    2021-08-06 11:34:42.705 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
    2021-08-06 11:34:53.251 - error: easee.0 (1381) SignalR Verbindung beendet!!!- restart
    2021-08-06 11:34:53.379 - error: easee.0 (1381) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-08-06 11:34:53.380 - error: easee.0 (1381) unhandled promise rejection: Service Temporarily Unavailable
    2021-08-06 11:34:53.381 - error: easee.0 (1381) Error: Service Temporarily Unavailable
    at new HttpError (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/Errors.js:27:24)
    at FetchHttpClient. (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:154:35)
    at step (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:52:23)
    at Object.next (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:33:53)
    at fulfilled (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:24:58)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-08-06 11:34:53.381 - error: easee.0 (1381) Service Temporarily Unavailable
    2021-08-06 11:34:53.384 - info: easee.0 (1381) Adaptor easee cleaned up everything...
    2021-08-06 11:34:53.384 - info: easee.0 (1381) terminating
    2021-08-06 11:34:53.385 - warn: easee.0 (1381) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-08-06 11:35:02.486 - info: easee.0 (7331) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.easee, node: v12.22.4, js-controller: 3.3.15
    2021-08-06 11:35:02.742 - error: easee.0 (7331) Api login error - check Username and password
    Ich beobachte mal weiter
    NewanN 1 Antwort Letzte Antwort
    • S stonemaan
      at runMicrotasks ()
      NewanN
      NewanN
      Newan
      #244
      @stonemaan ok ist aber 1.0.3?
      Schau mir das nochmal an
      S 2 Antworten Letzte Antwort
      • NewanN Newan
        S
        S
        stonemaan
        #245
        @newan jo... 1.0.3
        • S stonemaan
          @newan jo... 1.0.3
          A
          A
          Aiouh
          #246
          @Newan
          Ich bekomme seit Heute mit der 1.0.3 folg. Fehler
          easee.0	2021-08-06 23:14:23.569	error	(8630) Api login error - check Username and password
          Es wurde aber an user & passwort nichts geändert :(
          • A Aiouh
            @Newan
            NewanN
            NewanN
            Newan
            #247
            @aiouh mal aus der App abmelden und versuchen da wieder anzumelden. Die erros kommen ja direkt von der api
            • NewanN Newan
              A
              A
              Aiouh
              #248
              @newan said in Easee Wallbox mit iobroker:
              abmelden aus der App hat leider nichts gebracht, nach Neustart des ioBroker ist aber wieder alles im Lot.
              Ist 1.0.3 eigentlich die aktuelle?
              • NewanN Newan
                S
                S
                stonemaan
                #249
                @newan heute wieder der gleiche Fehler... ohne erkennbaren Grund. liegt wohl an SignalR. schalte es vorerst wieder aus ^^
                • The SpiritT
                  The SpiritT
                  The Spirit
                  #250
                  ich habe gerade noch das hier gefunden
                  https://github.com/fondberg/pyeasee/issues/35#issuecomment-760378451
                  von daher wäre es schon gut, wenn man auch die circuit dynamic currents schreiben könnte.
                  für mich ist dies relevant, da ich pv Überschuss laden will. so kann ich am Anfang nur mit einer Phase laden und dann einfach auf drei umschalten wenn genügend ström da ist ohne den Phasenmodus "echt" wechseln zu müssen (der Phasenmodus soll ja auch nicht zu oft umgeschalten werden, da dieser auch in den Flash geschrieben wird).
                  Danke für deine Tolle Arbeit
                  • The SpiritT The Spirit
                    A
                    A
                    Aiouh
                    #251
                    @newan
                    Mittlerweile läuft mein Überschussladen mit der Easee recht gut, nochmal vielen Dank für den Adapter, habe damit bisher 663kWh in den e-Soul geschoben.
                    Ich frage bisher nur alle 10 Minuten den Überschuss ab und regle dann nach, denn erstens braucht das Fahrzeug ja auch ne ganze Weile bis es nachregelt UND...jetzt komme ich wieder zum Punkt - ich will das flash der Easee home nicht vorzeitig zerstören. DynamicCircuitCurrent läuft ja noch nicht :(
                    Du hattest mal geschrieben dass die dynamiCircuitCurrent objekte nur "read only" sind und somit auch nicht an die API gesendet werden. Mir ist völlig klar, dass die Arbeit hier vermutlich eh schon zu viel Deiner Zeit frisst und ich kann ja leider selbst nicht programmieren, trotzdem frage ich mal gaaanz vorsichtig ob Du das mit dem DynamicCircuitCurrent vielleicht schon auf dem Plan hast ;) ?
                    • A Aiouh
                      @newan
                      S
                      S
                      stonemaan
                      #252
                      Hi @aiouh warum nutzt du nicht die DynamicChargerCurrent? Damit regle ich meine Easee auf den Pv Überschuss und die soll nicht „abnutzen“ ;)
                      • S stonemaan
                        A
                        A
                        Aiouh
                        schrieb am zuletzt editiert von Aiouh
                        #253
                        @stonemaan Hmm, das hört sich ja sehr gut an. Wird damit dann der Strom gleichmässig auf die genutzten Phasen verteilt ?
                        Also z. bei 20A einphasig =20A, zweiphasig je Phase 10A?
                        • A Aiouh
                          S
                          S
                          stonemaan
                          #254
                          @aiouh oh, das kann ich dir nicht genau sagen, da ich nur nen Plugin Hybriden habe, der maximal mit unfassbaren 2.9kw an einer Phase lädt. Ich meine in Erinnerung zu haben, dass an einem anderen Auto alle Phasen gleichmäßig runtergeregelt wurden. Probiers doch mal aus :)
                          • S stonemaan
                            A
                            A
                            Aiouh
                            #255
                            @stonemaan Ich habe das gerade mal mit dem dem einphasigen getestet, klappts schon prima. Werde das mit dem zweiphasigen dann später testen. Dann stelle ich mal noch mein Script um.
                            DANKE
                            NewanN Uli977U 2 Antworten Letzte Antwort
                            • A Aiouh
                              DANKE
                              NewanN
                              NewanN
                              Newan
                              #256
                              @aiouh DynamicCircuitCurrent bin ich dran, meine Kinder haben aber derzeit Vorrang. Sobald Zeit kommt ein Update
                              A S 2 Antworten Letzte Antwort
                              • NewanN Newan
                                A
                                A
                                Aiouh
                                #257
                                @newan Keine Eile, mit dem Tip von Stoneman komm ich ja schon gut weiter.
                                • S stonemaan
                                  Ich hab das per blockly Script gemacht. Ich berechne über den KOSTAL Adapter den PV Überschuss und setze dann entsprechend die dynamicchargercurrent auf den Wert, den ich brauche. Abfrage läuft minütlich. War ein ziemliches gefummel bis dahin, aber es funktioniert einwandfrei. Jetzt fehlt nur noch die Sonne ;)
                                  Uli977U
                                  Uli977U
                                  Uli977
                                  schrieb am zuletzt editiert von Uli977
                                  #258
                                  kann mir jemand sagen warum ich regelmäßig diese Meldung bekomme?
                                  Danke Euch!
                                  • A Aiouh
                                    DANKE
                                    Uli977U
                                    Uli977U
                                    Uli977
                                    #259
                                    @aiouh Hast du dein Skript nochmal umgestellt. Aktuell ist es bei mir so, dass wenn er z.B. auf 10A regelt, jede Phase mit 10A geregelt wird und somit zu viel Leistung herausgegeben wird.
                                    • NewanN Newan
                                      S
                                      S
                                      schweiger2
                                      #260
                                      @newan
                                      ich erhalte seit einigen Tagen folgende Fehlermeldung(en). Weder Adapter-Restart noch ioBroker-Restart schaffen Abhilfe. Woran liegt das ? haben andere auch damit zu tun ?
                                      2021-10-13 15:22:14.266 - error: easee.0 (4558) Error: Request failed with status code 403
                                      2021-10-13 15:22:14.267 - warn: easee.0 (4558) No Chargers found!
                                      2021-10-13 15:23:14.376 - error: easee.0 (4558) Error: Request failed with status code 403
                                      2021-10-13 15:23:14.377 - warn: easee.0 (4558) No Chargers found!
                                      Beste Grüße
                                      • Uli977U Uli977
                                        Danke Euch!
                                        NewanN
                                        NewanN
                                        Newan
                                        #261
                                        @uli977 Das sollte behoben sei in der 1.0.4, teste mal bitte
                                        • S schweiger2
                                          @newan
                                          Beste Grüße
                                          NewanN
                                          NewanN
                                          Newan
                                          #262
                                          @schweiger2 https://github.com/Newan/ioBroker.easee/issues/25
                                          Großer Mist!
                                          Uli977U NewanN 2 Antworten Letzte Antwort
