Adapter "smartmeter"
jetzt habe ich probleme:
host.minime 2017-02-08 20:28:41.731 error instance system.adapter.smartmeter.0 terminated with code 0 (OK) smartmeter.0 2017-02-08 20:28:41.698 info terminating smartmeter.0 2017-02-08 20:28:41.191 warn Exception: Error: Error while parsing SML message: Error: Wrong TL-Field 0x3b for Choice!: Message: 1b1b1b1b0101010176090109521b010900010162003b01012e620001234201770701003307007f01017e535844010000016 smartmeter.0 2017-02-08 20:28:41.186 error at FSReqWrap.wrapper [as oncomplete] (fs.js:576:17) smartmeter.0 2017-02-08 20:28:41.186 error at SerialPort. (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:306:7) smartmeter.0 2017-02-08 20:28:41.186 error at SerialPort. (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:293:14) smartmeter.0 2017-02-08 20:28:41.186 error at SerialPort._emitData (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:313:18) smartmeter.0 2017-02-08 20:28:41.186 error at SerialPort.module.exports.raw (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/parsers.js:7:13) smartmeter.0 2017-02-08 20:28:41.186 error at SerialPort.emit (events.js:169:7) smartmeter.0 2017-02-08 20:28:41.186 error at emitOne (events.js:77:13) smartmeter.0 2017-02-08 20:28:41.186 error at SerialPort. (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:52:41) smartmeter.0 2017-02-08 20:28:41.186 error at SmlProtocol.handleMessage (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/protocols/SmlProtocol.js:48:15) smartmeter.0 2017-02-08 20:28:41.186 error Error: Error while parsing SML message: Error: Wrong TL-Field 0x3b for Choice!: Message: 1b1b1b1b0101010176090109521b010900010162003b01012e620001234201770701003307007f01017e53584401000001622152620952 smartmeter.0 2017-02-08 20:28:41.177 error uncaught exception: Error while parsing SML message: Error: Wrong TL-Field 0x3b for Choice!: Message: 1b1b1b1b0101010176090109521b010900010162003b01012e620001234201770701003307007f01017e5358440100000 smartmeter.0 2017-02-08 20:27:14.519 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.3Error while parsing SML message: Error: Wrong TL-Field 0x3b for Choice!:
was ist das für ein Feld?
Das sieht einerseits irgendwie nach unvollständigen Messages aus weil die viel zu kurz sind und auch das Ende nicht passt, andererseits ist genau die Stelle die er anmeckert immer gleich. Lass mal im Debug-Loglevel laufen dann schreibt er noch einiges mehr und poste das mal …
Ging es vorher schonmal? Was für ein gerät? Oder hat das Problem mit der 0.2.5 angefangen?
Aso dann wirds gehen sorry. Muss nochmal warten weil ich drin rumgespielt habe.
Danke dann war es nur ein Denkfehler. :?
Hab mir einen zweiten Sensor bestellt, hoffe ihr helft mir bei der Einrichtung.
Könnte man noch einen Vortageswert machen? Also Verbrauch die vorletzten 24h.
mein script ermittelt auch die Tageswerte. wenn du dann in einem History adapter speicherst, dann kannst du den Verbrauch von von gestern, vorgstern und und und. allerdings erst ab dann, ab wann du deine werte speicherst.Danke stimmt so geht das.
Melde mich wenn es Probleme gibt aber im Moment ist alles gut.
Ging es vorher schonmal? Was für ein gerät? Oder hat das Problem mit der 0.2.5 angefangen? `
Im Log wird nicht die komplette Message angezeigt. Nur wenn man mit der Maus drüber geht. Da ist sie viel länger.Auf der Umgebung raspi + rückseitige Schnittstelle eines Hagers habe ich meinen Script laufen und die Werte sind korrekt. Die Umgebung die Konstellation sind neu.
Irgendwie kommt er mit der Message nicht klar.
! ` > minime 2017-02-08 20:52:45.309 info host.minime Restart adapter system.adapter.smartmeter.0 because enabled
minime 2017-02-08 20:52:45.309 error host.minime instance system.adapter.smartmeter.0 terminated with code 0 (OK)
smartmeter.0 2017-02-08 20:52:44.793 debug smartmeter.0 SERIALPORT CLOSE
smartmeter.0 2017-02-08 20:52:44.793 warn smartmeter.0 Exception: Error: No answer from Serial Device after last request.
smartmeter.0 2017-02-08 20:52:44.793 error smartmeter.0 Error: No answer from Serial Device after last request. at SerialRequestResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-o
smartmeter.0 2017-02-08 20:52:44.792 error smartmeter.0 uncaught exception: No answer from Serial Device after last request.
smartmeter.0 2017-02-08 20:52:44.791 debug smartmeter.0 MESSAGE TIMEOUT TRIGGERED
smartmeter.0 2017-02-08 20:52:43.611 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:39.957 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:39.955 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:39.952 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:39.948 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:37.375 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:37.115 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:37.110 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:37.104 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:37.096 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:36.854 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:36.594 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:34.647 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:30.944 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:30.939 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:30.931 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:30.927 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:28.454 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:28.235 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:28.132 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:28.128 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:28.069 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.827 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.820 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.817 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.815 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.809 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.802 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.796 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.634 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.632 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.629 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.627 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.624 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.618 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.578 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:25.573 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:22.688 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:22.686 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:22.669 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:22.617 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:22.496 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:22.315 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:21.912 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:21.647 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:19.795 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:19.609 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:16.774 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:16.582 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:16.573 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:16.566 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:16.494 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:16.042 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:15.807 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:13.448 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:13.437 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:13.433 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:13.426 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:12.880 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:12.877 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:12.872 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:12.672 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:12.668 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:12.658 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:10.238 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:10.236 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:10.229 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:07.614 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607010060
smartmeter.0 2017-02-08 20:52:07.609 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e6070100"
smartmeter.0 2017-02-08 20:52:07.605 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e607" -> n
smartmeter.0 2017-02-08 20:52:07.532 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45e6" -> nul
smartmeter.0 2017-02-08 20:52:07.524 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b4faf6fb64b41640e45" -> null
smartmeter.0 2017-02-08 20:52:07.475 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff010b" -> null
smartmeter.0 2017-02-08 20:52:07.405 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff01" -> null
smartmeter.0 2017-02-08 20:52:07.338 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165ff" -> null
smartmeter.0 2017-02-08 20:52:06.820 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab010165" -> null
smartmeter.0 2017-02-08 20:52:06.801 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab0101" -> null
smartmeter.0 2017-02-08 20:52:04.744 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab01" -> null
smartmeter.0 2017-02-08 20:52:04.581 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183ab" -> null
smartmeter.0 2017-02-08 20:52:04.496 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501010183" -> null
smartmeter.0 2017-02-08 20:52:04.492 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff0701015305010101" -> null
smartmeter.0 2017-02-08 20:52:04.489 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff07010153050101" -> null
smartmeter.0 2017-02-08 20:52:04.486 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101530501" -> null
smartmeter.0 2017-02-08 20:52:04.479 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff0701015305" -> null
smartmeter.0 2017-02-08 20:52:04.383 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff07010153" -> null
smartmeter.0 2017-02-08 20:52:04.375 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff070101" -> null
smartmeter.0 2017-02-08 20:52:04.372 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff0701" -> null
smartmeter.0 2017-02-08 20:52:04.365 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff07" -> null
smartmeter.0 2017-02-08 20:52:03.896 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6ebff" -> null
smartmeter.0 2017-02-08 20:52:03.732 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6eb" -> null
smartmeter.0 2017-02-08 20:52:03.709 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002c6" -> null
smartmeter.0 2017-02-08 20:52:03.704 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201760101090000000002" -> null
smartmeter.0 2017-02-08 20:52:03.686 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b064841030110770101320176" -> null
smartmeter.0 2017-02-08 20:52:03.646 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701013201" -> null
smartmeter.0 2017-02-08 20:52:01.573 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b06484103011077010132" -> null
smartmeter.0 2017-02-08 20:52:01.037 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b064841030110770101" -> null
smartmeter.0 2017-02-08 20:52:01.022 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301107701" -> null
smartmeter.0 2017-02-08 20:52:01.018 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b06484103011077" -> null
smartmeter.0 2017-02-08 20:52:01.015 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b064841030110" -> null
smartmeter.0 2017-02-08 20:52:00.956 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b0648410301" -> null
smartmeter.0 2017-02-08 20:52:00.797 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b06484103" -> null
smartmeter.0 2017-02-08 20:52:00.758 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177010b064841" -> null
smartmeter.0 2017-02-08 20:52:00.749 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b0177" -> null
smartmeter.0 2017-02-08 20:52:00.746 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b01" -> null
smartmeter.0 2017-02-08 20:52:00.599 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893361b" -> null
smartmeter.0 2017-02-08 20:51:58.523 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f489336" -> null
smartmeter.0 2017-02-08 20:51:58.518 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f4893" -> null
smartmeter.0 2017-02-08 20:51:58.512 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202269f" -> null
smartmeter.0 2017-02-08 20:51:58.504 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a282320003010162095200520226" -> null
smartmeter.0 2017-02-08 20:51:58.498 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2823200030101620952005202" -> null
smartmeter.0 2017-02-08 20:51:55.664 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a28232000301016209520052" -> null
smartmeter.0 2017-02-08 20:51:55.504 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a282" -> null
smartmeter.0 2017-02-08 20:51:55.497 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47a2" -> null
smartmeter.0 2017-02-08 20:51:55.329 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b47" -> null
smartmeter.0 2017-02-08 20:51:55.193 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e011b" -> null
smartmeter.0 2017-02-08 20:51:55.149 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e01" -> null
smartmeter.0 2017-02-08 20:51:54.924 debug smartmeter.0 MATCH-RESULT MESSAGE: "01621e" -> null
smartmeter.0 2017-02-08 20:51:54.921 debug smartmeter.0 MATCH-RESULT MESSAGE: "01" -> null
smartmeter.0 2017-02-08 20:51:44.761 debug smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000
smartmeter.0 2017-02-08 20:51:44.760 debug smartmeter.0 INITIAL MESSAGES TO SEND: 0
smartmeter.0 2017-02-08 20:51:44.760 debug smartmeter.0 SERIALPORT RESET BAUDRATE TO 9600
smartmeter.0 2017-02-08 20:51:44.760 debug smartmeter.0 SERIALPORT OPEN
smartmeter.0 2017-02-08 20:51:44.760 debug smartmeter.0 CREATE SERIALPORT: 9600 8 1 none
smartmeter.0 2017-02-08 20:51:44.759 debug smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialRequestResponseTransport","requestInterval":"60","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudra
smartmeter.0 2017-02-08 20:51:44.757 info smartmeter.0 starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.3 `
Wenn da hinten wirklich SML rauskommt dann ist die "Seriell bidirektional" falsch. Stell mal auf Readonly. Wenn Bidirektional sollte es D0 als protokoll sein und kein SMl … oder ?! `
readonly war das erste, was ich probiert habe. und es ist sicher sml das lese ich mit meinem script:
root@miniyou:/opt/iobroker# more /tmp/HAGER.raw 1B1B1B1B0101010176090000000006727A86620162007263010176010109 00000000022628D90B0 64841470109A8EB2F5C0101639660007609000000 0006727A87620162007263070177010B064841 470109A8EB2F5C07010062 0AFFFF72620165038B8450F17677078181C78203FF010101010448414 701 77070100000009FF010101010B064841470109A8EB2F5C01770701000108 00FF628201621E5 2FF55033C0D420177070100010801FF0101621E52FF55 033BE6320177070100010802FF0101621E 52FF5327100177070100100700 FF0101621B52005300E70177070100240700FF0101621B52FF530 6240177 0701001F0700FF0101622152FE53005A0177070100200700FF0101622352 FE5359CE017 7070100380700FF0101621B52FF5300DC0177070100330700 FF0101622152FE5300280177070100 340700FF0101622352FE535A3A0177 0701004C0700FF0101621B52FF53020F0177070100470700F F0101622152 FE53002A0177070100480700FF0101622352FE535A900177070100603200 0201016 20952FF5300F40177078181C78205FF0101010183028DAC263C22 0B9F1D489336B5C0A793A28262 73774FAF6FB64B41640E45732704E6D59F C08E96016D9DABEC88EA55E9800177070100603203030 10162235200628D 01770701006032030401016223520062EF01770701006032000301016209 520 0520A017707010060320004010162095200521D017707010060320005 0101620952005209010101 63186F0076090000000006727A886201620072 630201710163FFCC00001B1B1B1B1A011C7F1B1B1 B1B0101010176090000 000006727A8C62016200726301017601010900000000022628DB0B064841 470109A8EB2F5C01016332A000760900000000host.miniyou 2017-02-08 23:09:52.661 info Restart adapter system.adapter.smartmeter.0 because enabled host.miniyou 2017-02-08 23:09:52.660 error instance system.adapter.smartmeter.0 terminated with code 0 (OK) smartmeter.0 2017-02-08 23:09:52.645 info terminating smartmeter.0 2017-02-08 23:09:52.141 warn Exception: Error: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 1b1b1b1b0101010176090000000006727ada62016200726301017601010900000000022628f50b smartmeter.0 2017-02-08 23:09:52.137 error at FSReqWrap.wrapper [as oncomplete] (fs.js:576:17) smartmeter.0 2017-02-08 23:09:52.137 error at SerialPort. (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:306:7) smartmeter.0 2017-02-08 23:09:52.137 error at SerialPort. (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:293:14) smartmeter.0 2017-02-08 23:09:52.137 error at SerialPort._emitData (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:313:18) smartmeter.0 2017-02-08 23:09:52.137 error at SerialPort.module.exports.raw (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/parsers.js:7:13) smartmeter.0 2017-02-08 23:09:52.137 error at SerialPort.emit (events.js:169:7) smartmeter.0 2017-02-08 23:09:52.137 error at emitOne (events.js:77:13) smartmeter.0 2017-02-08 23:09:52.137 error at SerialPort. (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:45:46) smartmeter.0 2017-02-08 23:09:52.137 error at SmlProtocol.handleMessage (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/protocols/SmlProtocol.js:48:15) smartmeter.0 2017-02-08 23:09:52.137 error Error: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 1b1b1b1b0101010176090000000006727ada62016200726301017601010900000000022628f50b06484147010 smartmeter.0 2017-02-08 23:09:52.129 error uncaught exception: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 1b1b1b1b0101010176090000000006727ada62016200726301017601010900000000022628f5 -
Hurra, der Adapter läuft bei mir :D
Ich habe zwei USB-Volkszähler-Leseköpfe an einem RasPi2 der als Multihost-Slave in ioBroker läuft. Der Adapter hat auf Anhieb funktioniert. Super Arbeit @apollon77!!
Allerdings habe ich es nicht hinbekommen eigene Namen für die USB-Devices zu vergeben. Habe hier die Anleitung ein paar Posts weiter oben und auch die vom Volkszähler-Projekt dazugenommen - aber da bin ich wohl noch zu viel Linux-Noob. Ist aber auch nicht weiter schlimm, ich habe ja nicht vor, an dem RasPi die USB-Geräte ständig umzustecken…
@a200: Readonly und SML ist schonmal korrekt. Das Raw der SML Datei war genau das was ich nutzen kann um mal in die Nachricht reinzuschauen.
Weisst DU ob das SML 1.0.3 sein soll oder welche Protokollversion? Ich suche mal.
Kommt immer die gleiche Meldung. Mal schauen welches Datenfeld Ihm da nicht gefällt :-) Weiter oben war noch was mit nem "3b"-Fehler … das war auch von dir. kann ich so eine nachricht bitte auch vollständig haben :-) Danke
Ingo F
Hier habe ich aus dem Logfile
! ` > 2017-02-08 23:12:12.696 - info: host.miniyou instance system.adapter.smartmeter.0 started with pid 3638
2017-02-08 23:12:14.942 - info: smartmeter.0 starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.2
2017-02-08 23:12:18.133 - error: smartmeter.0 uncaught exception: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 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
2017-02-08 23:12:18.143 - error: smartmeter.0 Error: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 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
at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:45:46)
at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:293:14)
at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:306:7)
2017-02-08 23:12:18.146 - warn: smartmeter.0 Exception: Error: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 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
2017-02-08 23:12:18.659 - info: smartmeter.0 terminating
2017-02-08 23:12:18.674 - error: host.miniyou instance system.adapter.smartmeter.0 terminated with code 0 (OK)
2017-02-08 23:12:18.674 - info: host.miniyou Restart adapter system.adapter.smartmeter.0 because enabled
2017-02-08 23:12:23.739 - info: host.miniyou object change system.adapter.smartmeter.0
2017-02-08 23:12:50.922 - error: host.miniyou instance system.adapter.smartmeter.0 terminated with code 3 (Adapter disabled or invalid config)
2017-02-08 23:12:50.923 - info: host.miniyou Do not restart adapter system.adapter.smartmeter.0 because disabled or deleted</anonymous></anonymous></anonymous> `
Vielleicht bringt das was?!
@a200: Also dein 0x77er Fehler ist gefunden … Die Daten behaupten das 21 Listen-Datensätze kommen ... es sind aber 22 drin. Der Parser machts halt genau und fliegt damit auf die schnauze weil halt was anderes drin ist als erwartet.
Ich überlege mal und rede mit dem Entwickler der SML-Library ... ich würde was einbauen was das trotzdem liesst ... melde mich, kann aber paar Tage dauern weil der das akzeptieren muss und so!
Super, hast Du auch noch ein log als er wegen dem 0x3b gemeckert hatte? `
Kann ich dir erst heute Abend liefern.Ansonsten vielen Dank für die tolle Arbeit!
Das kann aber nach einem reboot auch passieren… Morgen kriegen wir das hin. `
Ja, hast schon Recht mit dem Reboot. Allerdings wird ja von manchen Leuten suggeriert dass Linux stabiler wäre als Windows ;)
Nein - Spaß beiseite. Wenn Du uns helfen kannst das noch korrekt hinzubekommen bin ich natürlich auch gerne dabei was dazuzulernen.
bei läuft der Adapter seit gestern Nachmittag. Strombezug passt. Ich bekomme jedoch keine Daten vom Solarertrag. Ich hab den Lesekopf von Volkszähler.
Gibt es hier irgendetwas zum umstellen?
1342_bildschirmfoto_2017-02-09_um_08.39.03.png -
Nein - Spaß beiseite. Wenn Du uns helfen kannst das noch korrekt hinzubekommen bin ich natürlich auch gerne dabei was dazuzulernen. `
Also bei mir hat die Anleitung von der Volkszähler-Seite funktioniert … aber Achtung da sind Unterschiede zwischen Debian und Ubuntu ... Also vorher lesen und das "richtige" machen :-)
@ein-bayer: Wenns nicht aus Datenpunkt drin ist kommt es nicht als Daten. Hatten wir glaube weiter oben schon ... da wäre die einzig Sinnvolle Option per Javascript differenzen der Zählerstände zu nehmen
Heute Nacht hat sich der Adapter verabschiedet und lief seit 2:20 bis heute Morgen nicht mehr [emoji53]
Mit ist dann aufgefallen das zwei gleiche Prozesse liefen! Denn im log wurde angezeigt das der serial Port nicht geöffnet werden kann
Ich habe einen Prozess abgeschossen! Den anderen konnte ich erst beenden als iobroker gestoppt wurde!
Als ich dann iobroker gestartet habe lief alles wieder wunderbar
Muss ich mal beobachten, woran das schon wieder lag
Adrian
