  4. Probleme mit Zigbee und CC26X2R1 nach Neuinstallation
    6.5k
zigbeezigbee cc26x2r1gelöst
25 Beiträge 5 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • S Stefan_NK
    @thomas-braun Verstehe, dankeschön.
    Jetzt habe ich das Verbindungskabel zum CC26x2r1 getaucht - brauche in längeres, um es zentraler positionieren zu können, und der Adapter startet wieder nicht :-(
    Ich kann nicht jedes Mal die Datei löschen, was mache ich bei einem Stromausfall?
    2021-08-20 10:13:52.547 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-08-20 10:13:52.571 - info: zigbee.0 (4283) Got terminate signal TERMINATE_YOURSELF
    2021-08-20 10:13:52.572 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
    2021-08-20 10:13:52.573 - info: zigbee.0 (4283) cleaned everything up...
    2021-08-20 10:13:52.577 - info: zigbee.0 (4283) Zigbee: disabling joining new devices.
    2021-08-20 10:13:52.586 - warn: zigbee.0 (4283) Failed to stop zigbee during startup
    2021-08-20 10:13:52.587 - info: zigbee.0 (4283) terminating
    2021-08-20 10:13:52.589 - info: zigbee.0 (4283) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-08-20 10:13:53.142 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-08-20 10:13:55.650 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4548
    2021-08-20 10:13:58.184 - info: zigbee.0 (4548) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
    2021-08-20 10:13:58.283 - info: zigbee.0 (4548) Starting Zigbee npm ...
    2021-08-20 10:13:58.575 - info: zigbee.0 (4548) Installed Version: iobroker.zigbee@1.5.6
    2021-08-20 10:14:18.291 - error: zigbee.0 (4548) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2021-08-20 10:14:18.293 - error: zigbee.0 (4548) Failed to start Zigbee
    2021-08-20 10:14:18.294 - error: zigbee.0 (4548) Error herdsman start
    2021-08-20 10:14:28.296 - info: zigbee.0 (4548) Try to reconnect. 1 attempts left
    2021-08-20 10:14:28.299 - info: zigbee.0 (4548) Starting Zigbee npm ...
    2021-08-20 10:14:28.332 - info: zigbee.0 (4548) Installed Version: iobroker.zigbee@1.5.6
    2021-08-20 10:14:28.588 - error: zigbee.0 (4548) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2021-08-20 10:14:28.589 - error: zigbee.0 (4548) Failed to start Zigbee
    2021-08-20 10:14:28.589 - error: zigbee.0 (4548) Error herdsman start
    Was ich nicht verstehe, in der hardwaretechnischen Zusammenstellung hat vor der Neuinstallation alles funktioniert. Alle Adapter waren aktuell....
    arteckA Offline
    arteckA Offline
    arteck
    @stefan_nk zwischen dem stop und neustart liegen gerade mal 6 sekunden..
    • arteckA arteck
      Stefan_NK
      @arteck
      Ich habe jetzt...
      1. Das Log gelöscht.
      2. den Adapter pausiert
      3. Das Modul für mind. 10 Sekunden abgesteckt.
      4. Das Modul neu angesteckt
      5. Den Adapter wieder gestartet -> nicht grün
      Das muss doch einen Grund haben, dass das Ding nicht mehr funktioniert. Ich raff es einfach nicht.
      2021-08-20 11:01:31.449 - info: host.SmartHome "system.adapter.zigbee.0" disabled
      2021-08-20 11:01:31.463 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2021-08-20 11:01:31.492 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
      2021-08-20 11:01:31.490 - info: zigbee.0 (4548) Got terminate signal TERMINATE_YOURSELF
      2021-08-20 11:01:31.493 - info: zigbee.0 (4548) cleaned everything up...
      2021-08-20 11:01:31.502 - info: zigbee.0 (4548) Zigbee: disabling joining new devices.
      2021-08-20 11:01:31.505 - warn: zigbee.0 (4548) Failed to stop zigbee during startup
      2021-08-20 11:01:31.507 - info: zigbee.0 (4548) terminating
      2021-08-20 11:01:31.510 - info: zigbee.0 (4548) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-08-20 11:01:31.512 - error: zigbee.0 (4548) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-08-20 11:01:31.513 - error: zigbee.0 (4548) unhandled promise rejection: Cannot read property 'getEntries' of null
      2021-08-20 11:01:31.515 - error: zigbee.0 (4548) TypeError: Cannot read property 'getEntries' of null
      at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
      at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
      at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
      at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
      at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
      at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
      at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
      at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
      at runMicrotasks ()
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-08-20 11:01:31.516 - error: zigbee.0 (4548) Cannot read property 'getEntries' of null
      2021-08-20 11:01:32.062 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-08-20 11:02:41.592 - info: host.SmartHome "system.adapter.zigbee.0" enabled
      2021-08-20 11:02:41.678 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4627
      2021-08-20 11:02:44.091 - info: zigbee.0 (4627) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
      2021-08-20 11:02:44.194 - info: zigbee.0 (4627) Starting Zigbee npm ...
      2021-08-20 11:02:44.504 - info: zigbee.0 (4627) Installed Version: iobroker.zigbee@1.5.6
      2021-08-20 11:03:04.236 - error: zigbee.0 (4627) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      2021-08-20 11:03:04.238 - error: zigbee.0 (4627) Failed to start Zigbee
      2021-08-20 11:03:04.239 - error: zigbee.0 (4627) Error herdsman start
      2021-08-20 11:03:14.241 - info: zigbee.0 (4627) Try to reconnect. 1 attempts left
      2021-08-20 11:03:14.243 - info: zigbee.0 (4627) Starting Zigbee npm ...
      2021-08-20 11:03:14.274 - info: zigbee.0 (4627) Installed Version: iobroker.zigbee@1.5.6
      2021-08-20 11:03:14.523 - error: zigbee.0 (4627) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      2021-08-20 11:03:14.524 - error: zigbee.0 (4627) Failed to start Zigbee
      2021-08-20 11:03:14.525 - error: zigbee.0 (4627) Error herdsman start
      • S Stefan_NK
        @arteck
        Ich habe jetzt...
        at runMicrotasks ()
        @stefan_nk
        Zeig mal die Einstellungen im entsprechenden Reiter des Adapters.
          @stefan_nk
          Stefan_NK
          • S Stefan_NK
            arteckA Offline
            arteckA Offline
            arteck
            @stefan_nk der Adapter findet das TI Board nicht..
            weil :
            serialport gelockt
            oder
            es steckt in USB3
            oder
            hast du eine SSD noch im USB
            oder
            board hat sich verabschiedet
            oder
            kabel nicht OK
            oder
            USB HUB in Benutzung
            • arteckA arteck
              weil :
              serialport gelockt
              oder
              es steckt in USB3
              oder
              oder
              oder
              kabel nicht OK
              oder
              Stefan_NK
              @arteck hm....
              serialport gelockt... wie kann ich das überprüfen bzw. freigeben? Woher könnte der gelockt sein, nach einem Neustart?
              es steckt in USB3... ist bei USB 2 angesteckt
              hast du eine SSD noch im USB... Der Raspi läuft mit einem USB-Stick, wie das letzte Jahr auch
              board hat sich verabschiedet... hoffe ich nicht. kann ich auch nicht wirklich prüfen nur auf Verdacht ein Neues bestellen
              kabel nicht OK... hab es an dem bisherigen 30cm Kabel, aber auch an einem 3m Kabel probiert
              USB HUB in Benutzung... nein, es ist lediglich der Speicherstick und das Board angeschlossen.
              hydrotecH 1 Antwort Letzte Antwort
              • S Stefan_NK
                @arteck hm....
                hydrotecH Offline
                hydrotecH Offline
                hydrotec
                @stefan_nk
                Hallo Stefan,
                zwei Sachen sind mir aufgefallen.
                Zum einen ist bei deiner Konfiguration keine Sendeleistung ausgewählt.
                (Hat vermutlich nichts mit deinem aktuellen Problem zu tun, ist mir nur aufgefallen)
                Was eher auf dein Problem mit dem Adapter zu tun haben könnte,
                deine Firmeware des zigbee-sticks ist sehr neu
                "revision":20210708
                Vermutlich hat der zigbee-Adapter in der Version 1.5.6 damit Probleme.
                Versuche den Adapter auf 1.6.0 zu aktuallisieren.
                1.6.0 (2021-08-09)
                Hoffe das hat dir etwas weiter geholfen.
                Gruß, Karsten
                Ubuntu 22.04 LTS (LXD/LXC)
                admin: v6.3.5
                js-controller: v4.0.24
                node: v18.16.1
                npm: v9.5.1
                repository: stable
                • hydrotecH hydrotec
                  @stefan_nk
                  Hallo Stefan,
                  "revision":20210708
                  1.6.0 (2021-08-09)
                  Gruß, Karsten
                  Stefan_NK
                  Hallo Zusammen.... bin nun echt am Verzweifeln...
                  Ich habe den kompletten Raspi nochmals neu installiert. Es ist nichts außer der aktuellen Version von Raspberry Pi OS Lite und dem aktuellen iobroker wie hier beschrieben installiert.
                  Das Image des OS wurde auf den USB-Stick installiert, der in einem USB3 Anschluß steckt.
                  Die cc26x2r1 wurde (mit verschiedenen Kabeln getestet) an einen USB2 Anschluß gesteckt. Genau die gleiche Konstellation war bisher in Verwendung und hat vor der Neuinstallation einwandfrei funktioniert.
                  Aufgrund der Probleme habe ich lediglich die aktuelle FW des cc26x2r1 installiert
                  Adapterseitig ist vom admin, backitup, discovery, javascript und zigbee jeweils eine Instanz installiert.
                  Die zigbee-Adaptereinstellung wie folgt:
                  COM-Anschlußname: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100F8C-if00
                  Tpy: TI Z-Stack&CCxxxx Timer: 60
                  Erweiterte Pan ID: DDDDDDDDDDDDDDDD Pan ID: 6754
                  Kanal 11
                  Transportschlüssel: 01030507090B0D0F00020406080A0C0D
                  Sendeleistung: high
                  Ich bekomme den Adapter einfach nicht zum Laufen. Kann mir hier denn wirklich keiner helfen?
                  Anbeinochmals das gesamte Log, gefiltert auf zigbee.
                  2021-08-22 21:14:18.687 - error: zigbee.0 (1557) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                  2021-08-22 21:14:18.689 - error: zigbee.0 (1557) Failed to start Zigbee
                  2021-08-22 21:14:18.690 - error: zigbee.0 (1557) Error herdsman start
                  2021-08-22 21:14:18.951 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2021-08-22 21:14:18.959 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                  2021-08-22 21:14:18.959 - info: zigbee.0 (1557) Got terminate signal TERMINATE_YOURSELF
                  2021-08-22 21:14:18.962 - info: zigbee.0 (1557) cleaned everything up...
                  2021-08-22 21:14:18.970 - info: zigbee.0 (1557) Zigbee: disabling joining new devices.
                  2021-08-22 21:14:18.973 - warn: zigbee.0 (1557) Failed to stop zigbee during startup
                  2021-08-22 21:14:18.975 - info: zigbee.0 (1557) terminating
                  2021-08-22 21:14:18.977 - info: zigbee.0 (1557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2021-08-22 21:14:18.979 - error: zigbee.0 (1557) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2021-08-22 21:14:18.980 - error: zigbee.0 (1557) unhandled promise rejection: Cannot read property 'getEntries' of null
                  2021-08-22 21:14:18.983 - error: zigbee.0 (1557) TypeError: Cannot read property 'getEntries' of null
                  at processTicksAndRejections (node:internal/process/task_queues:96:5)
                  2021-08-22 21:14:18.984 - error: zigbee.0 (1557) Cannot read property 'getEntries' of null
                  2021-08-22 21:14:19.559 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2021-08-22 21:14:22.009 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1574
                  2021-08-22 21:14:24.650 - info: zigbee.0 (1574) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                  2021-08-22 21:14:24.700 - info: zigbee.0 (1574) Starting Zigbee npm ...
                  2021-08-22 21:14:25.031 - info: zigbee.0 (1574) Installed Version: iobroker.zigbee@1.5.6
                  2021-08-22 21:14:44.647 - error: zigbee.0 (1574) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                  2021-08-22 21:14:44.650 - error: zigbee.0 (1574) Failed to start Zigbee
                  2021-08-22 21:14:44.651 - error: zigbee.0 (1574) Error herdsman start
                  2021-08-22 21:14:54.654 - info: zigbee.0 (1574) Try to reconnect. 1 attempts left
                  2021-08-22 21:14:54.656 - info: zigbee.0 (1574) Starting Zigbee npm ...
                  2021-08-22 21:14:54.733 - info: zigbee.0 (1574) Installed Version: iobroker.zigbee@1.5.6
                  2021-08-22 21:14:54.920 - error: zigbee.0 (1574) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                  2021-08-22 21:14:54.921 - error: zigbee.0 (1574) Failed to start Zigbee
                  2021-08-22 21:14:54.922 - error: zigbee.0 (1574) Error herdsman start
                  2021-08-22 21:22:13.324 - error: zigbee.0 (1574) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                  2021-08-22 21:24:41.676 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2021-08-22 21:24:41.686 - info: zigbee.0 (1574) Got terminate signal TERMINATE_YOURSELF
                  2021-08-22 21:24:41.695 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                  2021-08-22 21:24:41.689 - info: zigbee.0 (1574) cleaned everything up...
                  2021-08-22 21:24:41.697 - info: zigbee.0 (1574) Zigbee: disabling joining new devices.
                  2021-08-22 21:24:41.702 - warn: zigbee.0 (1574) Failed to stop zigbee during startup
                  2021-08-22 21:24:41.704 - info: zigbee.0 (1574) terminating
                  2021-08-22 21:24:41.706 - info: zigbee.0 (1574) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2021-08-22 21:24:41.709 - error: zigbee.0 (1574) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2021-08-22 21:24:41.710 - error: zigbee.0 (1574) unhandled promise rejection: Cannot read property 'getEntries' of null
                  2021-08-22 21:24:41.714 - error: zigbee.0 (1574) TypeError: Cannot read property 'getEntries' of null
                  2021-08-22 21:24:41.715 - error: zigbee.0 (1574) Cannot read property 'getEntries' of null
                  2021-08-22 21:24:42.257 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2021-08-22 21:24:44.744 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1610
                  2021-08-22 21:24:47.397 - info: zigbee.0 (1610) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                  2021-08-22 21:24:47.443 - info: zigbee.0 (1610) Starting Zigbee npm ...
                  2021-08-22 21:24:47.826 - info: zigbee.0 (1610) Installed Version: iobroker.zigbee@1.5.6
                  2021-08-22 21:24:55.853 - error: zigbee.0 (1610) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                  2021-08-22 21:25:07.398 - error: zigbee.0 (1610) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                  2021-08-22 21:25:07.401 - error: zigbee.0 (1610) Failed to start Zigbee
                  2021-08-22 21:25:07.402 - error: zigbee.0 (1610) Error herdsman start
                  2021-08-22 21:25:17.409 - info: zigbee.0 (1610) Try to reconnect. 1 attempts left
                  2021-08-22 21:25:17.411 - info: zigbee.0 (1610) Starting Zigbee npm ...
                  2021-08-22 21:25:17.462 - info: zigbee.0 (1610) Installed Version: iobroker.zigbee@1.5.6
                  2021-08-22 21:25:17.668 - error: zigbee.0 (1610) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                  2021-08-22 21:25:17.668 - error: zigbee.0 (1610) Failed to start Zigbee
                  2021-08-22 21:25:17.669 - error: zigbee.0 (1610) Error herdsman start
                  • S Stefan_NK
                    Kanal 11
                    Sendeleistung: high
                    @stefan_nk
                    Ändere die.
                      @stefan_nk
                      Ändere die.
                      Stefan_NK
                      Geändert in
                      DCDDDDDADDDDDDDD
                      leider kein Erfolg
                      2021-08-22 21:45:03.266 - error: zigbee.0 (1826) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                      2021-08-22 21:45:03.268 - error: zigbee.0 (1826) Failed to start Zigbee
                      2021-08-22 21:45:03.269 - error: zigbee.0 (1826) Error herdsman start
                      2021-08-22 21:45:03.722 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2021-08-22 21:45:03.733 - info: zigbee.0 (1826) Got terminate signal TERMINATE_YOURSELF
                      2021-08-22 21:45:03.743 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                      2021-08-22 21:45:03.737 - info: zigbee.0 (1826) cleaned everything up...
                      2021-08-22 21:45:03.747 - info: zigbee.0 (1826) Zigbee: disabling joining new devices.
                      2021-08-22 21:45:03.750 - warn: zigbee.0 (1826) Failed to stop zigbee during startup
                      2021-08-22 21:45:03.751 - info: zigbee.0 (1826) terminating
                      2021-08-22 21:45:03.753 - info: zigbee.0 (1826) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2021-08-22 21:45:03.755 - error: zigbee.0 (1826) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2021-08-22 21:45:03.755 - error: zigbee.0 (1826) unhandled promise rejection: Cannot read property 'getEntries' of null
                      2021-08-22 21:45:03.757 - error: zigbee.0 (1826) TypeError: Cannot read property 'getEntries' of null
                      2021-08-22 21:45:03.758 - error: zigbee.0 (1826) Cannot read property 'getEntries' of null
                      2021-08-22 21:45:04.353 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2021-08-22 21:45:06.796 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1842
                      2021-08-22 21:45:09.395 - info: zigbee.0 (1842) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                      2021-08-22 21:45:09.441 - info: zigbee.0 (1842) Starting Zigbee npm ...
                      2021-08-22 21:45:09.776 - info: zigbee.0 (1842) Installed Version: iobroker.zigbee@1.5.6
                      2021-08-22 21:45:29.401 - error: zigbee.0 (1842) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                      2021-08-22 21:45:29.403 - error: zigbee.0 (1842) Failed to start Zigbee
                      2021-08-22 21:45:29.405 - error: zigbee.0 (1842) Error herdsman start
                      • S Stefan_NK
                        Geändert in
                        DCDDDDDADDDDDDDD
                        leider kein Erfolg
                        @stefan_nk
                        node: v16.7.0 zusammen mit npm@7 ?
                        Das ist ggf. dein Problem. Installier node12, maximal node14.
                          @stefan_nk
                          Stefan_NK
                          So... habe node 12 installiert, was übrigens auch zuerst installiert war. Das Update war nur ein Versuch.
                          Sobald ich das Modul eintrage, wird der Adapter nicht mehr grün.
                          2021-08-22 23:40:06.719 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                          2021-08-22 23:40:06.737 - info: zigbee.0 (1967) Got terminate signal TERMINATE_YOURSELF
                          2021-08-22 23:40:06.740 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                          2021-08-22 23:40:06.740 - info: zigbee.0 (1967) cleaned everything up...
                          2021-08-22 23:40:06.748 - info: zigbee.0 (1967) Zigbee: disabling joining new devices.
                          2021-08-22 23:40:06.752 - warn: zigbee.0 (1967) Failed to stop zigbee during startup
                          2021-08-22 23:40:06.754 - info: zigbee.0 (1967) terminating
                          2021-08-22 23:40:06.756 - info: zigbee.0 (1967) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-08-22 23:40:06.758 - error: zigbee.0 (1967) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2021-08-22 23:40:06.759 - error: zigbee.0 (1967) unhandled promise rejection: Cannot read property 'getEntries' of null
                          2021-08-22 23:40:06.760 - error: zigbee.0 (1967) TypeError: Cannot read property 'getEntries' of null
                          2021-08-22 23:40:06.761 - error: zigbee.0 (1967) Cannot read property 'getEntries' of null
                          2021-08-22 23:40:07.406 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2021-08-22 23:40:09.783 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1986
                          2021-08-22 23:40:12.284 - info: zigbee.0 (1986) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
                          2021-08-22 23:40:12.389 - info: zigbee.0 (1986) Starting Zigbee npm ...
                          2021-08-22 23:40:12.688 - info: zigbee.0 (1986) Installed Version: iobroker.zigbee@1.5.6
                          2021-08-22 23:40:14.465 - error: zigbee.0 (1986) Configuration is not consistent with adapter state/backup!
                          2021-08-22 23:40:14.465 - error: zigbee.0 (1986) - PAN ID: configured=6754, adapter=6754
                          2021-08-22 23:40:14.466 - error: zigbee.0 (1986) - Extended PAN ID: configured=dddddddddadddddc, adapter=00124b001caab81b
                          2021-08-22 23:40:14.466 - error: zigbee.0 (1986) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                          2021-08-22 23:40:14.467 - error: zigbee.0 (1986) - Channel List: configured=11, adapter=11
                          2021-08-22 23:40:14.468 - error: zigbee.0 (1986) Please update configuration to prevent further issues.
                          2021-08-22 23:40:14.468 - error: zigbee.0 (1986) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                          2021-08-22 23:40:14.468 - error: zigbee.0 (1986) Re-commissioning your network will require re-pairing of all devices!
                          2021-08-22 23:40:14.469 - error: zigbee.0 (1986) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                          2021-08-22 23:40:14.470 - error: zigbee.0 (1986) Failed to start Zigbee
                          2021-08-22 23:40:14.470 - error: zigbee.0 (1986) Error herdsman start
                          2021-08-22 23:40:24.472 - info: zigbee.0 (1986) Try to reconnect. 1 attempts left
                          2021-08-22 23:40:24.474 - info: zigbee.0 (1986) Starting Zigbee npm ...
                          2021-08-22 23:40:24.515 - info: zigbee.0 (1986) Installed Version: iobroker.zigbee@1.5.6
                          2021-08-22 23:40:24.738 - error: zigbee.0 (1986) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                          2021-08-22 23:40:24.738 - error: zigbee.0 (1986) Failed to start Zigbee
                          2021-08-22 23:40:24.739 - error: zigbee.0 (1986) Error herdsman start
                          • S Stefan_NK
                            @stefan_nk
                            Richtige IDs eintragen
                              @stefan_nk
                              Stefan_NK
                              @thomas-braun Welche IDs muss ich hier eintragen?
                              • S Stefan_NK
                                @stefan_nk
                                Steht doch da.
                                  @stefan_nk
                                  Steht doch da.
                                  Stefan_NK
                                  schrieb am zuletzt editiert von Stefan_NK
                                  @thomas-braun wenn ich es wissen und verstehen würde woran das Ding hakt, hätte ich nicht gefragt 🙄
                                  • S Stefan_NK
                                    @stefan_nk 1986) -
                                    In der config des Adapters steht das eine, der Stick erwartet das andere.
                                      @stefan_nk 1986) -
                                      Stefan_NK
                                      @thomas-braun sagte in Probleme mit Zigbee und CC26X2R1 nach Neuinstallation:
                                      00124b001caab81b
                                      Ok, ich habe jetzt die Adapter-ID 00124b001caab81b bei der erweiterten PAN-ID eingetragen. Die Konfig hatte ich bei der alten Installation nicht, aber der Adapter ist jetzt mal grün. Vielen, vielen, vielen Dank 👍 👍 👍 👍
