  4. Probleme mit Zigbee und CC26X2R1 nach Neuinstallation
    6.5k
zigbeezigbee cc26x2r1gelöst
25 Beiträge 5 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • AsgothianA Asgothian
    @stefan_nk sagte in Probleme mit Zigbee und CC26X2R1 nach Neuinstallation:
    zigbee.0 2021-08-19 16:01:50.487 error - PAN ID: configured=6755, adapter=6754
    Da steht doch die Lösung. Deine panID stimmt nicht,
    A.
    Stefan_NK
    schrieb am zuletzt editiert von Stefan_NK
    @asgothian Die ID habe ich schon geändert, leider hat das nicht wirklich etwas gebracht :-(
    2021-08-19 22:01:55.162 - info: zigbee.0 (2755) Try to reconnect. 1 attempts left
    2021-08-19 22:01:55.163 - info: zigbee.0 (2755) Starting Zigbee npm ...
    2021-08-19 22:01:55.189 - info: zigbee.0 (2755) Installed Version: iobroker.zigbee@1.5.6
    2021-08-19 22:01:55.415 - error: zigbee.0 (2755) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2021-08-19 22:01:55.416 - error: zigbee.0 (2755) Failed to start Zigbee
    2021-08-19 22:01:55.418 - error: zigbee.0 (2755) Error herdsman start
    2021-08-19 22:01:56.261 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-08-19 22:01:56.272 - info: zigbee.0 (2755) Got terminate signal TERMINATE_YOURSELF
    2021-08-19 22:01:56.272 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
    2021-08-19 22:01:56.276 - info: zigbee.0 (2755) cleaned everything up...
    2021-08-19 22:01:56.284 - info: zigbee.0 (2755) Zigbee: disabling joining new devices.
    2021-08-19 22:01:56.288 - warn: zigbee.0 (2755) Failed to stop zigbee during startup
    2021-08-19 22:01:56.290 - info: zigbee.0 (2755) terminating
    2021-08-19 22:01:56.292 - info: zigbee.0 (2755) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-08-19 22:01:56.294 - error: zigbee.0 (2755) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-08-19 22:01:56.294 - error: zigbee.0 (2755) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-08-19 22:01:56.296 - error: zigbee.0 (2755) TypeError: Cannot read property 'getEntries' of null
    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
    at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
    at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-08-19 22:01:56.297 - error: zigbee.0 (2755) Cannot read property 'getEntries' of null
    2021-08-19 22:01:56.866 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-08-19 22:01:59.315 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 2773
    2021-08-19 22:02:01.781 - info: zigbee.0 (2773) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
    2021-08-19 22:02:01.879 - info: zigbee.0 (2773) Starting Zigbee npm ...
    2021-08-19 22:02:02.168 - info: zigbee.0 (2773) Installed Version: iobroker.zigbee@1.5.6
    2021-08-19 22:02:03.958 - error: zigbee.0 (2773) Configuration is not consistent with adapter state/backup!
    2021-08-19 22:02:03.958 - error: zigbee.0 (2773) - PAN ID: configured=6755, adapter=6754
    2021-08-19 22:02:03.959 - error: zigbee.0 (2773) - Extended PAN ID: configured=1bb8ac1c004a1200, adapter=00124b001caab81b
    2021-08-19 22:02:03.960 - error: zigbee.0 (2773) - Network Key: configured=01030507090b0d0f0ff20406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    2021-08-19 22:02:03.960 - error: zigbee.0 (2773) - Channel List: configured=11, adapter=11
    2021-08-19 22:02:03.961 - error: zigbee.0 (2773) Please update configuration to prevent further issues.
    2021-08-19 22:02:03.961 - error: zigbee.0 (2773) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    2021-08-19 22:02:03.962 - error: zigbee.0 (2773) Re-commissioning your network will require re-pairing of all devices!
    2021-08-19 22:02:03.962 - error: zigbee.0 (2773) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2021-08-19 22:02:03.963 - error: zigbee.0 (2773) Failed to start Zigbee
    2021-08-19 22:02:03.963 - error: zigbee.0 (2773) Error herdsman start
    2021-08-19 22:02:13.965 - info: zigbee.0 (2773) Try to reconnect. 1 attempts left
    2021-08-19 22:02:13.967 - info: zigbee.0 (2773) Starting Zigbee npm ...
    2021-08-19 22:02:14.006 - info: zigbee.0 (2773) Installed Version: iobroker.zigbee@1.5.6
    2021-08-19 22:02:14.232 - error: zigbee.0 (2773) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2021-08-19 22:02:14.232 - error: zigbee.0 (2773) Failed to start Zigbee
    2021-08-19 22:02:14.233 - error: zigbee.0 (2773) Error herdsman start
    • S Stefan_NK
      arteckA Offline
      arteckA Offline
      arteck
      @stefan_nk lösche mal die nvbackup.json aus
      /opt/iobroker/iobroker-data/zugbee_0
      und starte adapter neu
      • arteckA arteck
        Stefan_NK
        @arteck Der Adapter ist jetzt grün, vielen Dank. Eine Warnung gibt es schon wieder wegen der PAN ID. Soll ich da was ändern? Werde am Wochenende dann mal die Sensoren anlernen.
        2021-08-20 07:48:44.501 - info: host.SmartHome "system.adapter.zigbee.0" disabled
        2021-08-20 07:48:44.503 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2021-08-20 07:48:44.515 - info: zigbee.0 (4259) Got terminate signal TERMINATE_YOURSELF
        2021-08-20 07:48:44.521 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
        2021-08-20 07:48:44.517 - info: zigbee.0 (4259) cleaned everything up...
        2021-08-20 07:48:44.523 - info: zigbee.0 (4259) Zigbee: disabling joining new devices.
        2021-08-20 07:48:45.020 - info: zigbee.0 (4259) terminating
        2021-08-20 07:48:45.021 - info: zigbee.0 (4259) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-08-20 07:48:45.524 - info: host.SmartHome stopInstance system.adapter.zigbee.0 killing pid 4259
        2021-08-20 07:48:45.590 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-08-20 07:51:22.577 - info: host.SmartHome "system.adapter.zigbee.0" enabled
        2021-08-20 07:51:22.638 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4283
        2021-08-20 07:51:25.076 - info: zigbee.0 (4283) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
        2021-08-20 07:51:25.176 - info: zigbee.0 (4283) Starting Zigbee npm ...
        2021-08-20 07:51:25.465 - info: zigbee.0 (4283) Installed Version: iobroker.zigbee@1.5.6
        2021-08-20 07:51:27.196 - warn: zigbee.0 (4283) Extended PAN ID is reversed (expected=1bb8aa1c004b1200, actual=00124b001caab81b)
        2021-08-20 07:51:34.832 - info: zigbee.0 (4283) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
        2021-08-20 07:51:34.844 - info: zigbee.0 (4283) --> transmitPower : normal
        2021-08-20 07:51:34.851 - info: zigbee.0 (4283) Currently no devices.
        2021-08-20 07:51:34.852 - info: zigbee.0 (4283) Zigbee started
        Von wo kommt das, nach einer sauberen Neuinstallation? Sind die Fehlermeldungen beim Installieren des Adapters normal? Auch, dass das so lang dauert?
        • S Stefan_NK
          @stefan_nk
          Da sind keine Fehlermeldungen.
          Das sind die Meldungen, wenn ein Modul kompiliert wird. Das dauert dann auch schon mal etwas länger.
            @stefan_nk
            Stefan_NK
            @thomas-braun Verstehe, dankeschön.
            Jetzt habe ich das Verbindungskabel zum CC26x2r1 getaucht - brauche in längeres, um es zentraler positionieren zu können, und der Adapter startet wieder nicht :-(
            Ich kann nicht jedes Mal die Datei löschen, was mache ich bei einem Stromausfall?
            2021-08-20 10:13:52.547 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2021-08-20 10:13:52.571 - info: zigbee.0 (4283) Got terminate signal TERMINATE_YOURSELF
            2021-08-20 10:13:52.572 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
            2021-08-20 10:13:52.573 - info: zigbee.0 (4283) cleaned everything up...
            2021-08-20 10:13:52.577 - info: zigbee.0 (4283) Zigbee: disabling joining new devices.
            2021-08-20 10:13:52.586 - warn: zigbee.0 (4283) Failed to stop zigbee during startup
            2021-08-20 10:13:52.587 - info: zigbee.0 (4283) terminating
            2021-08-20 10:13:52.589 - info: zigbee.0 (4283) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-08-20 10:13:53.142 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-08-20 10:13:55.650 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4548
            2021-08-20 10:13:58.184 - info: zigbee.0 (4548) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
            2021-08-20 10:13:58.283 - info: zigbee.0 (4548) Starting Zigbee npm ...
            2021-08-20 10:13:58.575 - info: zigbee.0 (4548) Installed Version: iobroker.zigbee@1.5.6
            2021-08-20 10:14:18.291 - error: zigbee.0 (4548) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            2021-08-20 10:14:18.293 - error: zigbee.0 (4548) Failed to start Zigbee
            2021-08-20 10:14:18.294 - error: zigbee.0 (4548) Error herdsman start
            2021-08-20 10:14:28.296 - info: zigbee.0 (4548) Try to reconnect. 1 attempts left
            2021-08-20 10:14:28.299 - info: zigbee.0 (4548) Starting Zigbee npm ...
            2021-08-20 10:14:28.332 - info: zigbee.0 (4548) Installed Version: iobroker.zigbee@1.5.6
            2021-08-20 10:14:28.588 - error: zigbee.0 (4548) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            2021-08-20 10:14:28.589 - error: zigbee.0 (4548) Failed to start Zigbee
            2021-08-20 10:14:28.589 - error: zigbee.0 (4548) Error herdsman start
            Was ich nicht verstehe, in der hardwaretechnischen Zusammenstellung hat vor der Neuinstallation alles funktioniert. Alle Adapter waren aktuell....
            • S Stefan_NK
              arteckA Offline
              arteckA Offline
              arteck
              @stefan_nk zwischen dem stop und neustart liegen gerade mal 6 sekunden..
              • arteckA arteck
                Stefan_NK
                @arteck
                Ich habe jetzt...
                1. Das Log gelöscht.
                2. den Adapter pausiert
                3. Das Modul für mind. 10 Sekunden abgesteckt.
                4. Das Modul neu angesteckt
                5. Den Adapter wieder gestartet -> nicht grün
                Das muss doch einen Grund haben, dass das Ding nicht mehr funktioniert. Ich raff es einfach nicht.
                2021-08-20 11:01:31.449 - info: host.SmartHome "system.adapter.zigbee.0" disabled
                2021-08-20 11:01:31.463 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                2021-08-20 11:01:31.492 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                2021-08-20 11:01:31.490 - info: zigbee.0 (4548) Got terminate signal TERMINATE_YOURSELF
                2021-08-20 11:01:31.493 - info: zigbee.0 (4548) cleaned everything up...
                2021-08-20 11:01:31.502 - info: zigbee.0 (4548) Zigbee: disabling joining new devices.
                2021-08-20 11:01:31.505 - warn: zigbee.0 (4548) Failed to stop zigbee during startup
                2021-08-20 11:01:31.507 - info: zigbee.0 (4548) terminating
                2021-08-20 11:01:31.510 - info: zigbee.0 (4548) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-08-20 11:01:31.512 - error: zigbee.0 (4548) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-08-20 11:01:31.513 - error: zigbee.0 (4548) unhandled promise rejection: Cannot read property 'getEntries' of null
                2021-08-20 11:01:31.515 - error: zigbee.0 (4548) TypeError: Cannot read property 'getEntries' of null
                at runMicrotasks ()
                2021-08-20 11:01:31.516 - error: zigbee.0 (4548) Cannot read property 'getEntries' of null
                2021-08-20 11:01:32.062 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-08-20 11:02:41.592 - info: host.SmartHome "system.adapter.zigbee.0" enabled
                2021-08-20 11:02:41.678 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4627
                2021-08-20 11:02:44.091 - info: zigbee.0 (4627) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
                2021-08-20 11:02:44.194 - info: zigbee.0 (4627) Starting Zigbee npm ...
                2021-08-20 11:02:44.504 - info: zigbee.0 (4627) Installed Version: iobroker.zigbee@1.5.6
                2021-08-20 11:03:04.236 - error: zigbee.0 (4627) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                2021-08-20 11:03:04.238 - error: zigbee.0 (4627) Failed to start Zigbee
                2021-08-20 11:03:04.239 - error: zigbee.0 (4627) Error herdsman start
                2021-08-20 11:03:14.241 - info: zigbee.0 (4627) Try to reconnect. 1 attempts left
                2021-08-20 11:03:14.243 - info: zigbee.0 (4627) Starting Zigbee npm ...
                2021-08-20 11:03:14.274 - info: zigbee.0 (4627) Installed Version: iobroker.zigbee@1.5.6
                2021-08-20 11:03:14.523 - error: zigbee.0 (4627) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                2021-08-20 11:03:14.524 - error: zigbee.0 (4627) Failed to start Zigbee
                2021-08-20 11:03:14.525 - error: zigbee.0 (4627) Error herdsman start
                • S Stefan_NK
                  @arteck
                  Ich habe jetzt...
                  at runMicrotasks ()
                  @stefan_nk
                  Zeig mal die Einstellungen im entsprechenden Reiter des Adapters.
                    @stefan_nk
                    Stefan_NK
                    • S Stefan_NK
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @stefan_nk der Adapter findet das TI Board nicht..
                      weil :
                      serialport gelockt
                      oder
                      es steckt in USB3
                      oder
                      hast du eine SSD noch im USB
                      oder
                      board hat sich verabschiedet
                      oder
                      kabel nicht OK
                      oder
                      USB HUB in Benutzung
                      • arteckA arteck
                        weil :
                        serialport gelockt
                        oder
                        es steckt in USB3
                        oder
                        oder
                        oder
                        kabel nicht OK
                        oder
                        Stefan_NK
                        @arteck hm....
                        serialport gelockt... wie kann ich das überprüfen bzw. freigeben? Woher könnte der gelockt sein, nach einem Neustart?
                        es steckt in USB3... ist bei USB 2 angesteckt
                        hast du eine SSD noch im USB... Der Raspi läuft mit einem USB-Stick, wie das letzte Jahr auch
                        board hat sich verabschiedet... hoffe ich nicht. kann ich auch nicht wirklich prüfen nur auf Verdacht ein Neues bestellen
                        kabel nicht OK... hab es an dem bisherigen 30cm Kabel, aber auch an einem 3m Kabel probiert
                        USB HUB in Benutzung... nein, es ist lediglich der Speicherstick und das Board angeschlossen.
                        hydrotecH 1 Antwort Letzte Antwort
                        • S Stefan_NK
                          @arteck hm....
                          hydrotecH Offline
                          hydrotecH Offline
                          hydrotec
                          @stefan_nk
                          Hallo Stefan,
                          zwei Sachen sind mir aufgefallen.
                          Zum einen ist bei deiner Konfiguration keine Sendeleistung ausgewählt.
                          (Hat vermutlich nichts mit deinem aktuellen Problem zu tun, ist mir nur aufgefallen)
                          Was eher auf dein Problem mit dem Adapter zu tun haben könnte,
                          deine Firmeware des zigbee-sticks ist sehr neu
                          "revision":20210708
                          Vermutlich hat der zigbee-Adapter in der Version 1.5.6 damit Probleme.
                          Versuche den Adapter auf 1.6.0 zu aktuallisieren.
                          1.6.0 (2021-08-09)
                          Hoffe das hat dir etwas weiter geholfen.
                          Gruß, Karsten
                          Ubuntu 22.04 LTS (LXD/LXC)
                          admin: v6.3.5
                          js-controller: v4.0.24
                          node: v18.16.1
                          npm: v9.5.1
                          repository: stable
                          • hydrotecH hydrotec
                            @stefan_nk
                            Hallo Stefan,
                            "revision":20210708
                            1.6.0 (2021-08-09)
                            Gruß, Karsten
                            Stefan_NK
                            Hallo Zusammen.... bin nun echt am Verzweifeln...
                            Ich habe den kompletten Raspi nochmals neu installiert. Es ist nichts außer der aktuellen Version von Raspberry Pi OS Lite und dem aktuellen iobroker wie hier beschrieben installiert.
                            Das Image des OS wurde auf den USB-Stick installiert, der in einem USB3 Anschluß steckt.
                            Die cc26x2r1 wurde (mit verschiedenen Kabeln getestet) an einen USB2 Anschluß gesteckt. Genau die gleiche Konstellation war bisher in Verwendung und hat vor der Neuinstallation einwandfrei funktioniert.
                            Aufgrund der Probleme habe ich lediglich die aktuelle FW des cc26x2r1 installiert
                            Adapterseitig ist vom admin, backitup, discovery, javascript und zigbee jeweils eine Instanz installiert.
                            Die zigbee-Adaptereinstellung wie folgt:
                            COM-Anschlußname: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100F8C-if00
                            Tpy: TI Z-Stack&CCxxxx Timer: 60
                            Erweiterte Pan ID: DDDDDDDDDDDDDDDD Pan ID: 6754
                            Kanal 11
                            Transportschlüssel: 01030507090B0D0F00020406080A0C0D
                            Sendeleistung: high
                            Ich bekomme den Adapter einfach nicht zum Laufen. Kann mir hier denn wirklich keiner helfen?
                            Anbeinochmals das gesamte Log, gefiltert auf zigbee.
                            2021-08-22 21:14:18.687 - error: zigbee.0 (1557) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2021-08-22 21:14:18.689 - error: zigbee.0 (1557) Failed to start Zigbee
                            2021-08-22 21:14:18.690 - error: zigbee.0 (1557) Error herdsman start
                            2021-08-22 21:14:18.951 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2021-08-22 21:14:18.959 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                            2021-08-22 21:14:18.959 - info: zigbee.0 (1557) Got terminate signal TERMINATE_YOURSELF
                            2021-08-22 21:14:18.962 - info: zigbee.0 (1557) cleaned everything up...
                            2021-08-22 21:14:18.970 - info: zigbee.0 (1557) Zigbee: disabling joining new devices.
                            2021-08-22 21:14:18.973 - warn: zigbee.0 (1557) Failed to stop zigbee during startup
                            2021-08-22 21:14:18.975 - info: zigbee.0 (1557) terminating
                            2021-08-22 21:14:18.977 - info: zigbee.0 (1557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2021-08-22 21:14:18.979 - error: zigbee.0 (1557) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2021-08-22 21:14:18.980 - error: zigbee.0 (1557) unhandled promise rejection: Cannot read property 'getEntries' of null
                            2021-08-22 21:14:18.983 - error: zigbee.0 (1557) TypeError: Cannot read property 'getEntries' of null
                            at processTicksAndRejections (node:internal/process/task_queues:96:5)
                            2021-08-22 21:14:18.984 - error: zigbee.0 (1557) Cannot read property 'getEntries' of null
                            2021-08-22 21:14:19.559 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2021-08-22 21:14:22.009 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1574
                            2021-08-22 21:14:24.650 - info: zigbee.0 (1574) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                            2021-08-22 21:14:24.700 - info: zigbee.0 (1574) Starting Zigbee npm ...
                            2021-08-22 21:14:25.031 - info: zigbee.0 (1574) Installed Version: iobroker.zigbee@1.5.6
                            2021-08-22 21:14:44.647 - error: zigbee.0 (1574) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2021-08-22 21:14:44.650 - error: zigbee.0 (1574) Failed to start Zigbee
                            2021-08-22 21:14:44.651 - error: zigbee.0 (1574) Error herdsman start
                            2021-08-22 21:14:54.654 - info: zigbee.0 (1574) Try to reconnect. 1 attempts left
                            2021-08-22 21:14:54.656 - info: zigbee.0 (1574) Starting Zigbee npm ...
                            2021-08-22 21:14:54.733 - info: zigbee.0 (1574) Installed Version: iobroker.zigbee@1.5.6
                            2021-08-22 21:14:54.920 - error: zigbee.0 (1574) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            2021-08-22 21:14:54.921 - error: zigbee.0 (1574) Failed to start Zigbee
                            2021-08-22 21:14:54.922 - error: zigbee.0 (1574) Error herdsman start
                            2021-08-22 21:22:13.324 - error: zigbee.0 (1574) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            2021-08-22 21:24:41.676 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2021-08-22 21:24:41.686 - info: zigbee.0 (1574) Got terminate signal TERMINATE_YOURSELF
                            2021-08-22 21:24:41.695 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                            2021-08-22 21:24:41.689 - info: zigbee.0 (1574) cleaned everything up...
                            2021-08-22 21:24:41.697 - info: zigbee.0 (1574) Zigbee: disabling joining new devices.
                            2021-08-22 21:24:41.702 - warn: zigbee.0 (1574) Failed to stop zigbee during startup
                            2021-08-22 21:24:41.704 - info: zigbee.0 (1574) terminating
                            2021-08-22 21:24:41.706 - info: zigbee.0 (1574) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2021-08-22 21:24:41.709 - error: zigbee.0 (1574) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2021-08-22 21:24:41.710 - error: zigbee.0 (1574) unhandled promise rejection: Cannot read property 'getEntries' of null
                            2021-08-22 21:24:41.714 - error: zigbee.0 (1574) TypeError: Cannot read property 'getEntries' of null
                            2021-08-22 21:24:41.715 - error: zigbee.0 (1574) Cannot read property 'getEntries' of null
                            2021-08-22 21:24:42.257 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2021-08-22 21:24:44.744 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1610
                            2021-08-22 21:24:47.397 - info: zigbee.0 (1610) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                            2021-08-22 21:24:47.443 - info: zigbee.0 (1610) Starting Zigbee npm ...
                            2021-08-22 21:24:47.826 - info: zigbee.0 (1610) Installed Version: iobroker.zigbee@1.5.6
                            2021-08-22 21:24:55.853 - error: zigbee.0 (1610) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            2021-08-22 21:25:07.398 - error: zigbee.0 (1610) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2021-08-22 21:25:07.401 - error: zigbee.0 (1610) Failed to start Zigbee
                            2021-08-22 21:25:07.402 - error: zigbee.0 (1610) Error herdsman start
                            2021-08-22 21:25:17.409 - info: zigbee.0 (1610) Try to reconnect. 1 attempts left
                            2021-08-22 21:25:17.411 - info: zigbee.0 (1610) Starting Zigbee npm ...
                            2021-08-22 21:25:17.462 - info: zigbee.0 (1610) Installed Version: iobroker.zigbee@1.5.6
                            2021-08-22 21:25:17.668 - error: zigbee.0 (1610) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            2021-08-22 21:25:17.668 - error: zigbee.0 (1610) Failed to start Zigbee
                            2021-08-22 21:25:17.669 - error: zigbee.0 (1610) Error herdsman start
                            • S Stefan_NK
                              Kanal 11
                              Sendeleistung: high
                              @stefan_nk
                              Ändere die.
                                @stefan_nk
                                Ändere die.
                                Stefan_NK
                                Geändert in
                                DCDDDDDADDDDDDDD
                                leider kein Erfolg
                                2021-08-22 21:45:03.266 - error: zigbee.0 (1826) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                2021-08-22 21:45:03.268 - error: zigbee.0 (1826) Failed to start Zigbee
                                2021-08-22 21:45:03.269 - error: zigbee.0 (1826) Error herdsman start
                                2021-08-22 21:45:03.722 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                2021-08-22 21:45:03.733 - info: zigbee.0 (1826) Got terminate signal TERMINATE_YOURSELF
                                2021-08-22 21:45:03.743 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                                2021-08-22 21:45:03.737 - info: zigbee.0 (1826) cleaned everything up...
                                2021-08-22 21:45:03.747 - info: zigbee.0 (1826) Zigbee: disabling joining new devices.
                                2021-08-22 21:45:03.750 - warn: zigbee.0 (1826) Failed to stop zigbee during startup
                                2021-08-22 21:45:03.751 - info: zigbee.0 (1826) terminating
                                2021-08-22 21:45:03.753 - info: zigbee.0 (1826) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-08-22 21:45:03.755 - error: zigbee.0 (1826) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-08-22 21:45:03.755 - error: zigbee.0 (1826) unhandled promise rejection: Cannot read property 'getEntries' of null
                                2021-08-22 21:45:03.757 - error: zigbee.0 (1826) TypeError: Cannot read property 'getEntries' of null
                                2021-08-22 21:45:03.758 - error: zigbee.0 (1826) Cannot read property 'getEntries' of null
                                2021-08-22 21:45:04.353 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-08-22 21:45:06.796 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1842
                                2021-08-22 21:45:09.395 - info: zigbee.0 (1842) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                                2021-08-22 21:45:09.441 - info: zigbee.0 (1842) Starting Zigbee npm ...
                                2021-08-22 21:45:09.776 - info: zigbee.0 (1842) Installed Version: iobroker.zigbee@1.5.6
                                2021-08-22 21:45:29.401 - error: zigbee.0 (1842) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                2021-08-22 21:45:29.403 - error: zigbee.0 (1842) Failed to start Zigbee
                                2021-08-22 21:45:29.405 - error: zigbee.0 (1842) Error herdsman start
                                • S Stefan_NK
                                  Geändert in
                                  DCDDDDDADDDDDDDD
                                  leider kein Erfolg
                                  @stefan_nk
                                  node: v16.7.0 zusammen mit npm@7 ?
                                  Das ist ggf. dein Problem. Installier node12, maximal node14.
                                    @stefan_nk
                                    Stefan_NK
                                    So... habe node 12 installiert, was übrigens auch zuerst installiert war. Das Update war nur ein Versuch.
                                    Sobald ich das Modul eintrage, wird der Adapter nicht mehr grün.
                                    2021-08-22 23:40:06.719 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                    2021-08-22 23:40:06.737 - info: zigbee.0 (1967) Got terminate signal TERMINATE_YOURSELF
                                    2021-08-22 23:40:06.740 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                                    2021-08-22 23:40:06.740 - info: zigbee.0 (1967) cleaned everything up...
                                    2021-08-22 23:40:06.748 - info: zigbee.0 (1967) Zigbee: disabling joining new devices.
                                    2021-08-22 23:40:06.752 - warn: zigbee.0 (1967) Failed to stop zigbee during startup
                                    2021-08-22 23:40:06.754 - info: zigbee.0 (1967) terminating
                                    2021-08-22 23:40:06.756 - info: zigbee.0 (1967) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-08-22 23:40:06.758 - error: zigbee.0 (1967) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2021-08-22 23:40:06.759 - error: zigbee.0 (1967) unhandled promise rejection: Cannot read property 'getEntries' of null
                                    2021-08-22 23:40:06.760 - error: zigbee.0 (1967) TypeError: Cannot read property 'getEntries' of null
                                    2021-08-22 23:40:06.761 - error: zigbee.0 (1967) Cannot read property 'getEntries' of null
                                    2021-08-22 23:40:07.406 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-08-22 23:40:09.783 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1986
                                    2021-08-22 23:40:12.284 - info: zigbee.0 (1986) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
                                    2021-08-22 23:40:12.389 - info: zigbee.0 (1986) Starting Zigbee npm ...
                                    2021-08-22 23:40:12.688 - info: zigbee.0 (1986) Installed Version: iobroker.zigbee@1.5.6
                                    2021-08-22 23:40:14.465 - error: zigbee.0 (1986) Configuration is not consistent with adapter state/backup!
                                    2021-08-22 23:40:14.465 - error: zigbee.0 (1986) - PAN ID: configured=6754, adapter=6754
                                    2021-08-22 23:40:14.466 - error: zigbee.0 (1986) - Extended PAN ID: configured=dddddddddadddddc, adapter=00124b001caab81b
                                    2021-08-22 23:40:14.466 - error: zigbee.0 (1986) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                    2021-08-22 23:40:14.467 - error: zigbee.0 (1986) - Channel List: configured=11, adapter=11
                                    2021-08-22 23:40:14.468 - error: zigbee.0 (1986) Please update configuration to prevent further issues.
                                    2021-08-22 23:40:14.468 - error: zigbee.0 (1986) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                    2021-08-22 23:40:14.468 - error: zigbee.0 (1986) Re-commissioning your network will require re-pairing of all devices!
                                    2021-08-22 23:40:14.469 - error: zigbee.0 (1986) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                    2021-08-22 23:40:14.470 - error: zigbee.0 (1986) Failed to start Zigbee
                                    2021-08-22 23:40:14.470 - error: zigbee.0 (1986) Error herdsman start
                                    2021-08-22 23:40:24.472 - info: zigbee.0 (1986) Try to reconnect. 1 attempts left
                                    2021-08-22 23:40:24.474 - info: zigbee.0 (1986) Starting Zigbee npm ...
                                    2021-08-22 23:40:24.515 - info: zigbee.0 (1986) Installed Version: iobroker.zigbee@1.5.6
                                    2021-08-22 23:40:24.738 - error: zigbee.0 (1986) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    2021-08-22 23:40:24.738 - error: zigbee.0 (1986) Failed to start Zigbee
                                    2021-08-22 23:40:24.739 - error: zigbee.0 (1986) Error herdsman start
                                    • S Stefan_NK
                                      @stefan_nk
                                      Richtige IDs eintragen
                                        @stefan_nk
                                        Stefan_NK
                                        @thomas-braun Welche IDs muss ich hier eintragen?
                                        • S Stefan_NK
                                          @stefan_nk
                                          Steht doch da.
