  4. Probleme mit Zigbee und CC26X2R1 nach Neuinstallation
    6.5k
zigbeezigbee cc26x2r1gelöst
25 Beiträge 5 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • arteckA arteck
    @stefan_nk lösche mal die nvbackup.json aus
    /opt/iobroker/iobroker-data/zugbee_0
    und starte adapter neu
    Stefan_NK
    schrieb am zuletzt editiert von Stefan_NK
    @arteck Der Adapter ist jetzt grün, vielen Dank. Eine Warnung gibt es schon wieder wegen der PAN ID. Soll ich da was ändern? Werde am Wochenende dann mal die Sensoren anlernen.
    2021-08-20 07:48:44.501 - info: host.SmartHome "system.adapter.zigbee.0" disabled
    2021-08-20 07:48:44.503 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-08-20 07:48:44.515 - info: zigbee.0 (4259) Got terminate signal TERMINATE_YOURSELF
    2021-08-20 07:48:44.521 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
    2021-08-20 07:48:44.517 - info: zigbee.0 (4259) cleaned everything up...
    2021-08-20 07:48:44.523 - info: zigbee.0 (4259) Zigbee: disabling joining new devices.
    2021-08-20 07:48:45.020 - info: zigbee.0 (4259) terminating
    2021-08-20 07:48:45.021 - info: zigbee.0 (4259) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-08-20 07:48:45.524 - info: host.SmartHome stopInstance system.adapter.zigbee.0 killing pid 4259
    2021-08-20 07:48:45.590 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-08-20 07:51:22.577 - info: host.SmartHome "system.adapter.zigbee.0" enabled
    2021-08-20 07:51:22.638 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4283
    2021-08-20 07:51:25.076 - info: zigbee.0 (4283) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
    2021-08-20 07:51:25.176 - info: zigbee.0 (4283) Starting Zigbee npm ...
    2021-08-20 07:51:25.465 - info: zigbee.0 (4283) Installed Version: iobroker.zigbee@1.5.6
    2021-08-20 07:51:27.196 - warn: zigbee.0 (4283) Extended PAN ID is reversed (expected=1bb8aa1c004b1200, actual=00124b001caab81b)
    2021-08-20 07:51:34.832 - info: zigbee.0 (4283) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
    2021-08-20 07:51:34.844 - info: zigbee.0 (4283) --> transmitPower : normal
    2021-08-20 07:51:34.851 - info: zigbee.0 (4283) Currently no devices.
    2021-08-20 07:51:34.852 - info: zigbee.0 (4283) Zigbee started
    Von wo kommt das, nach einer sauberen Neuinstallation? Sind die Fehlermeldungen beim Installieren des Adapters normal? Auch, dass das so lang dauert?
    • S Stefan_NK
      @stefan_nk
      Da sind keine Fehlermeldungen.
      Das sind die Meldungen, wenn ein Modul kompiliert wird. Das dauert dann auch schon mal etwas länger.
        @stefan_nk
        Stefan_NK
        @thomas-braun Verstehe, dankeschön.
        Jetzt habe ich das Verbindungskabel zum CC26x2r1 getaucht - brauche in längeres, um es zentraler positionieren zu können, und der Adapter startet wieder nicht :-(
        Ich kann nicht jedes Mal die Datei löschen, was mache ich bei einem Stromausfall?
        2021-08-20 10:13:52.547 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2021-08-20 10:13:52.571 - info: zigbee.0 (4283) Got terminate signal TERMINATE_YOURSELF
        2021-08-20 10:13:52.572 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
        2021-08-20 10:13:52.573 - info: zigbee.0 (4283) cleaned everything up...
        2021-08-20 10:13:52.577 - info: zigbee.0 (4283) Zigbee: disabling joining new devices.
        2021-08-20 10:13:52.586 - warn: zigbee.0 (4283) Failed to stop zigbee during startup
        2021-08-20 10:13:52.587 - info: zigbee.0 (4283) terminating
        2021-08-20 10:13:52.589 - info: zigbee.0 (4283) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-08-20 10:13:53.142 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-08-20 10:13:55.650 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4548
        2021-08-20 10:13:58.184 - info: zigbee.0 (4548) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
        2021-08-20 10:13:58.283 - info: zigbee.0 (4548) Starting Zigbee npm ...
        2021-08-20 10:13:58.575 - info: zigbee.0 (4548) Installed Version: iobroker.zigbee@1.5.6
        2021-08-20 10:14:18.291 - error: zigbee.0 (4548) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        2021-08-20 10:14:18.293 - error: zigbee.0 (4548) Failed to start Zigbee
        2021-08-20 10:14:18.294 - error: zigbee.0 (4548) Error herdsman start
        2021-08-20 10:14:28.296 - info: zigbee.0 (4548) Try to reconnect. 1 attempts left
        2021-08-20 10:14:28.299 - info: zigbee.0 (4548) Starting Zigbee npm ...
        2021-08-20 10:14:28.332 - info: zigbee.0 (4548) Installed Version: iobroker.zigbee@1.5.6
        2021-08-20 10:14:28.588 - error: zigbee.0 (4548) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2021-08-20 10:14:28.589 - error: zigbee.0 (4548) Failed to start Zigbee
        2021-08-20 10:14:28.589 - error: zigbee.0 (4548) Error herdsman start
        Was ich nicht verstehe, in der hardwaretechnischen Zusammenstellung hat vor der Neuinstallation alles funktioniert. Alle Adapter waren aktuell....
        • S Stefan_NK
          arteckA Offline
          arteckA Offline
          arteck
          @stefan_nk zwischen dem stop und neustart liegen gerade mal 6 sekunden..
          • arteckA arteck
            Stefan_NK
            @arteck
            Ich habe jetzt...
            1. Das Log gelöscht.
            2. den Adapter pausiert
            3. Das Modul für mind. 10 Sekunden abgesteckt.
            4. Das Modul neu angesteckt
            5. Den Adapter wieder gestartet -> nicht grün
            Das muss doch einen Grund haben, dass das Ding nicht mehr funktioniert. Ich raff es einfach nicht.
            2021-08-20 11:01:31.449 - info: host.SmartHome "system.adapter.zigbee.0" disabled
            2021-08-20 11:01:31.463 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2021-08-20 11:01:31.492 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
            2021-08-20 11:01:31.490 - info: zigbee.0 (4548) Got terminate signal TERMINATE_YOURSELF
            2021-08-20 11:01:31.493 - info: zigbee.0 (4548) cleaned everything up...
            2021-08-20 11:01:31.502 - info: zigbee.0 (4548) Zigbee: disabling joining new devices.
            2021-08-20 11:01:31.505 - warn: zigbee.0 (4548) Failed to stop zigbee during startup
            2021-08-20 11:01:31.507 - info: zigbee.0 (4548) terminating
            2021-08-20 11:01:31.510 - info: zigbee.0 (4548) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-08-20 11:01:31.512 - error: zigbee.0 (4548) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2021-08-20 11:01:31.513 - error: zigbee.0 (4548) unhandled promise rejection: Cannot read property 'getEntries' of null
            2021-08-20 11:01:31.515 - error: zigbee.0 (4548) TypeError: Cannot read property 'getEntries' of null
            at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
            at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
            at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
            at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
            at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
            at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
            at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
            at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
            at runMicrotasks ()
            at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2021-08-20 11:01:31.516 - error: zigbee.0 (4548) Cannot read property 'getEntries' of null
            2021-08-20 11:01:32.062 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-08-20 11:02:41.592 - info: host.SmartHome "system.adapter.zigbee.0" enabled
            2021-08-20 11:02:41.678 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 4627
            2021-08-20 11:02:44.091 - info: zigbee.0 (4627) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
            2021-08-20 11:02:44.194 - info: zigbee.0 (4627) Starting Zigbee npm ...
            2021-08-20 11:02:44.504 - info: zigbee.0 (4627) Installed Version: iobroker.zigbee@1.5.6
            2021-08-20 11:03:04.236 - error: zigbee.0 (4627) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            2021-08-20 11:03:04.238 - error: zigbee.0 (4627) Failed to start Zigbee
            2021-08-20 11:03:04.239 - error: zigbee.0 (4627) Error herdsman start
            2021-08-20 11:03:14.241 - info: zigbee.0 (4627) Try to reconnect. 1 attempts left
            2021-08-20 11:03:14.243 - info: zigbee.0 (4627) Starting Zigbee npm ...
            2021-08-20 11:03:14.274 - info: zigbee.0 (4627) Installed Version: iobroker.zigbee@1.5.6
            2021-08-20 11:03:14.523 - error: zigbee.0 (4627) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            2021-08-20 11:03:14.524 - error: zigbee.0 (4627) Failed to start Zigbee
            2021-08-20 11:03:14.525 - error: zigbee.0 (4627) Error herdsman start
            • S Stefan_NK
              @arteck
              Ich habe jetzt...
              at runMicrotasks ()
              @stefan_nk
              Zeig mal die Einstellungen im entsprechenden Reiter des Adapters.
                @stefan_nk
                Stefan_NK
                • S Stefan_NK
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @stefan_nk der Adapter findet das TI Board nicht..
                  weil :
                  serialport gelockt
                  oder
                  es steckt in USB3
                  oder
                  hast du eine SSD noch im USB
                  oder
                  board hat sich verabschiedet
                  oder
                  kabel nicht OK
                  oder
                  USB HUB in Benutzung
                  • arteckA arteck
                    weil :
                    serialport gelockt
                    oder
                    es steckt in USB3
                    oder
                    oder
                    oder
                    kabel nicht OK
                    oder
                    Stefan_NK
                    @arteck hm....
                    serialport gelockt... wie kann ich das überprüfen bzw. freigeben? Woher könnte der gelockt sein, nach einem Neustart?
                    es steckt in USB3... ist bei USB 2 angesteckt
                    hast du eine SSD noch im USB... Der Raspi läuft mit einem USB-Stick, wie das letzte Jahr auch
                    board hat sich verabschiedet... hoffe ich nicht. kann ich auch nicht wirklich prüfen nur auf Verdacht ein Neues bestellen
                    kabel nicht OK... hab es an dem bisherigen 30cm Kabel, aber auch an einem 3m Kabel probiert
                    USB HUB in Benutzung... nein, es ist lediglich der Speicherstick und das Board angeschlossen.
                    hydrotecH 1 Antwort Letzte Antwort
                    • S Stefan_NK
                      @arteck hm....
                      hydrotecH Offline
                      hydrotecH Offline
                      hydrotec
                      @stefan_nk
                      Hallo Stefan,
                      zwei Sachen sind mir aufgefallen.
                      Zum einen ist bei deiner Konfiguration keine Sendeleistung ausgewählt.
                      (Hat vermutlich nichts mit deinem aktuellen Problem zu tun, ist mir nur aufgefallen)
                      Was eher auf dein Problem mit dem Adapter zu tun haben könnte,
                      deine Firmeware des zigbee-sticks ist sehr neu
                      "revision":20210708
                      Vermutlich hat der zigbee-Adapter in der Version 1.5.6 damit Probleme.
                      Versuche den Adapter auf 1.6.0 zu aktuallisieren.
                      1.6.0 (2021-08-09)
                      Hoffe das hat dir etwas weiter geholfen.
                      Gruß, Karsten
                      Ubuntu 22.04 LTS (LXD/LXC)
                      admin: v6.3.5
                      js-controller: v4.0.24
                      node: v18.16.1
                      npm: v9.5.1
                      repository: stable
                      • hydrotecH hydrotec
                        @stefan_nk
                        Hallo Stefan,
                        "revision":20210708
                        1.6.0 (2021-08-09)
                        Gruß, Karsten
                        Stefan_NK
                        Hallo Zusammen.... bin nun echt am Verzweifeln...
                        Ich habe den kompletten Raspi nochmals neu installiert. Es ist nichts außer der aktuellen Version von Raspberry Pi OS Lite und dem aktuellen iobroker wie hier beschrieben installiert.
                        Das Image des OS wurde auf den USB-Stick installiert, der in einem USB3 Anschluß steckt.
                        Die cc26x2r1 wurde (mit verschiedenen Kabeln getestet) an einen USB2 Anschluß gesteckt. Genau die gleiche Konstellation war bisher in Verwendung und hat vor der Neuinstallation einwandfrei funktioniert.
                        Aufgrund der Probleme habe ich lediglich die aktuelle FW des cc26x2r1 installiert
                        Adapterseitig ist vom admin, backitup, discovery, javascript und zigbee jeweils eine Instanz installiert.
                        Die zigbee-Adaptereinstellung wie folgt:
                        COM-Anschlußname: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.16__Embed_with_CMSIS-DAP_L1100F8C-if00
                        Tpy: TI Z-Stack&CCxxxx Timer: 60
                        Erweiterte Pan ID: DDDDDDDDDDDDDDDD Pan ID: 6754
                        Kanal 11
                        Transportschlüssel: 01030507090B0D0F00020406080A0C0D
                        Sendeleistung: high
                        Ich bekomme den Adapter einfach nicht zum Laufen. Kann mir hier denn wirklich keiner helfen?
                        Anbeinochmals das gesamte Log, gefiltert auf zigbee.
                        2021-08-22 21:14:18.687 - error: zigbee.0 (1557) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                        2021-08-22 21:14:18.689 - error: zigbee.0 (1557) Failed to start Zigbee
                        2021-08-22 21:14:18.690 - error: zigbee.0 (1557) Error herdsman start
                        2021-08-22 21:14:18.951 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                        2021-08-22 21:14:18.959 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                        2021-08-22 21:14:18.959 - info: zigbee.0 (1557) Got terminate signal TERMINATE_YOURSELF
                        2021-08-22 21:14:18.962 - info: zigbee.0 (1557) cleaned everything up...
                        2021-08-22 21:14:18.970 - info: zigbee.0 (1557) Zigbee: disabling joining new devices.
                        2021-08-22 21:14:18.973 - warn: zigbee.0 (1557) Failed to stop zigbee during startup
                        2021-08-22 21:14:18.975 - info: zigbee.0 (1557) terminating
                        2021-08-22 21:14:18.977 - info: zigbee.0 (1557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2021-08-22 21:14:18.979 - error: zigbee.0 (1557) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-08-22 21:14:18.980 - error: zigbee.0 (1557) unhandled promise rejection: Cannot read property 'getEntries' of null
                        2021-08-22 21:14:18.983 - error: zigbee.0 (1557) TypeError: Cannot read property 'getEntries' of null
                        at processTicksAndRejections (node:internal/process/task_queues:96:5)
                        2021-08-22 21:14:18.984 - error: zigbee.0 (1557) Cannot read property 'getEntries' of null
                        2021-08-22 21:14:19.559 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2021-08-22 21:14:22.009 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1574
                        2021-08-22 21:14:24.650 - info: zigbee.0 (1574) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                        2021-08-22 21:14:24.700 - info: zigbee.0 (1574) Starting Zigbee npm ...
                        2021-08-22 21:14:25.031 - info: zigbee.0 (1574) Installed Version: iobroker.zigbee@1.5.6
                        2021-08-22 21:14:44.647 - error: zigbee.0 (1574) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                        2021-08-22 21:14:44.650 - error: zigbee.0 (1574) Failed to start Zigbee
                        2021-08-22 21:14:44.651 - error: zigbee.0 (1574) Error herdsman start
                        2021-08-22 21:14:54.654 - info: zigbee.0 (1574) Try to reconnect. 1 attempts left
                        2021-08-22 21:14:54.656 - info: zigbee.0 (1574) Starting Zigbee npm ...
                        2021-08-22 21:14:54.733 - info: zigbee.0 (1574) Installed Version: iobroker.zigbee@1.5.6
                        2021-08-22 21:14:54.920 - error: zigbee.0 (1574) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                        2021-08-22 21:14:54.921 - error: zigbee.0 (1574) Failed to start Zigbee
                        2021-08-22 21:14:54.922 - error: zigbee.0 (1574) Error herdsman start
                        2021-08-22 21:22:13.324 - error: zigbee.0 (1574) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                        2021-08-22 21:24:41.676 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                        2021-08-22 21:24:41.686 - info: zigbee.0 (1574) Got terminate signal TERMINATE_YOURSELF
                        2021-08-22 21:24:41.695 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                        2021-08-22 21:24:41.689 - info: zigbee.0 (1574) cleaned everything up...
                        2021-08-22 21:24:41.697 - info: zigbee.0 (1574) Zigbee: disabling joining new devices.
                        2021-08-22 21:24:41.702 - warn: zigbee.0 (1574) Failed to stop zigbee during startup
                        2021-08-22 21:24:41.704 - info: zigbee.0 (1574) terminating
                        2021-08-22 21:24:41.706 - info: zigbee.0 (1574) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2021-08-22 21:24:41.709 - error: zigbee.0 (1574) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2021-08-22 21:24:41.710 - error: zigbee.0 (1574) unhandled promise rejection: Cannot read property 'getEntries' of null
                        2021-08-22 21:24:41.714 - error: zigbee.0 (1574) TypeError: Cannot read property 'getEntries' of null
                        2021-08-22 21:24:41.715 - error: zigbee.0 (1574) Cannot read property 'getEntries' of null
                        2021-08-22 21:24:42.257 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2021-08-22 21:24:44.744 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1610
                        2021-08-22 21:24:47.397 - info: zigbee.0 (1610) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                        2021-08-22 21:24:47.443 - info: zigbee.0 (1610) Starting Zigbee npm ...
                        2021-08-22 21:24:47.826 - info: zigbee.0 (1610) Installed Version: iobroker.zigbee@1.5.6
                        2021-08-22 21:24:55.853 - error: zigbee.0 (1610) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                        2021-08-22 21:25:07.398 - error: zigbee.0 (1610) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                        2021-08-22 21:25:07.401 - error: zigbee.0 (1610) Failed to start Zigbee
                        2021-08-22 21:25:07.402 - error: zigbee.0 (1610) Error herdsman start
                        2021-08-22 21:25:17.409 - info: zigbee.0 (1610) Try to reconnect. 1 attempts left
                        2021-08-22 21:25:17.411 - info: zigbee.0 (1610) Starting Zigbee npm ...
                        2021-08-22 21:25:17.462 - info: zigbee.0 (1610) Installed Version: iobroker.zigbee@1.5.6
                        2021-08-22 21:25:17.668 - error: zigbee.0 (1610) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                        2021-08-22 21:25:17.668 - error: zigbee.0 (1610) Failed to start Zigbee
                        2021-08-22 21:25:17.669 - error: zigbee.0 (1610) Error herdsman start
                        • S Stefan_NK
                          Kanal 11
                          Sendeleistung: high
                          @stefan_nk
                          Ändere die.
                            @stefan_nk
                            Ändere die.
                            Stefan_NK
                            Geändert in
                            DCDDDDDADDDDDDDD
                            leider kein Erfolg
                            2021-08-22 21:45:03.266 - error: zigbee.0 (1826) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2021-08-22 21:45:03.268 - error: zigbee.0 (1826) Failed to start Zigbee
                            2021-08-22 21:45:03.269 - error: zigbee.0 (1826) Error herdsman start
                            2021-08-22 21:45:03.722 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2021-08-22 21:45:03.733 - info: zigbee.0 (1826) Got terminate signal TERMINATE_YOURSELF
                            2021-08-22 21:45:03.743 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                            2021-08-22 21:45:03.737 - info: zigbee.0 (1826) cleaned everything up...
                            2021-08-22 21:45:03.747 - info: zigbee.0 (1826) Zigbee: disabling joining new devices.
                            2021-08-22 21:45:03.750 - warn: zigbee.0 (1826) Failed to stop zigbee during startup
                            2021-08-22 21:45:03.751 - info: zigbee.0 (1826) terminating
                            2021-08-22 21:45:03.753 - info: zigbee.0 (1826) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2021-08-22 21:45:03.755 - error: zigbee.0 (1826) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2021-08-22 21:45:03.755 - error: zigbee.0 (1826) unhandled promise rejection: Cannot read property 'getEntries' of null
                            2021-08-22 21:45:03.757 - error: zigbee.0 (1826) TypeError: Cannot read property 'getEntries' of null
                            2021-08-22 21:45:03.758 - error: zigbee.0 (1826) Cannot read property 'getEntries' of null
                            2021-08-22 21:45:04.353 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2021-08-22 21:45:06.796 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1842
                            2021-08-22 21:45:09.395 - info: zigbee.0 (1842) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.7.0, js-controller: 3.3.15
                            2021-08-22 21:45:09.441 - info: zigbee.0 (1842) Starting Zigbee npm ...
                            2021-08-22 21:45:09.776 - info: zigbee.0 (1842) Installed Version: iobroker.zigbee@1.5.6
                            2021-08-22 21:45:29.401 - error: zigbee.0 (1842) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                            2021-08-22 21:45:29.403 - error: zigbee.0 (1842) Failed to start Zigbee
                            2021-08-22 21:45:29.405 - error: zigbee.0 (1842) Error herdsman start
                            • S Stefan_NK
                              Geändert in
                              DCDDDDDADDDDDDDD
                              leider kein Erfolg
                              @stefan_nk
                              node: v16.7.0 zusammen mit npm@7 ?
                              Das ist ggf. dein Problem. Installier node12, maximal node14.
                                @stefan_nk
                                Stefan_NK
                                So... habe node 12 installiert, was übrigens auch zuerst installiert war. Das Update war nur ein Versuch.
                                Sobald ich das Modul eintrage, wird der Adapter nicht mehr grün.
                                2021-08-22 23:40:06.719 - info: host.SmartHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                2021-08-22 23:40:06.737 - info: zigbee.0 (1967) Got terminate signal TERMINATE_YOURSELF
                                2021-08-22 23:40:06.740 - info: host.SmartHome stopInstance system.adapter.zigbee.0 send kill signal
                                2021-08-22 23:40:06.740 - info: zigbee.0 (1967) cleaned everything up...
                                2021-08-22 23:40:06.748 - info: zigbee.0 (1967) Zigbee: disabling joining new devices.
                                2021-08-22 23:40:06.752 - warn: zigbee.0 (1967) Failed to stop zigbee during startup
                                2021-08-22 23:40:06.754 - info: zigbee.0 (1967) terminating
                                2021-08-22 23:40:06.756 - info: zigbee.0 (1967) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-08-22 23:40:06.758 - error: zigbee.0 (1967) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-08-22 23:40:06.759 - error: zigbee.0 (1967) unhandled promise rejection: Cannot read property 'getEntries' of null
                                2021-08-22 23:40:06.760 - error: zigbee.0 (1967) TypeError: Cannot read property 'getEntries' of null
                                2021-08-22 23:40:06.761 - error: zigbee.0 (1967) Cannot read property 'getEntries' of null
                                2021-08-22 23:40:07.406 - info: host.SmartHome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-08-22 23:40:09.783 - info: host.SmartHome instance system.adapter.zigbee.0 started with pid 1986
                                2021-08-22 23:40:12.284 - info: zigbee.0 (1986) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.5, js-controller: 3.3.15
                                2021-08-22 23:40:12.389 - info: zigbee.0 (1986) Starting Zigbee npm ...
                                2021-08-22 23:40:12.688 - info: zigbee.0 (1986) Installed Version: iobroker.zigbee@1.5.6
                                2021-08-22 23:40:14.465 - error: zigbee.0 (1986) Configuration is not consistent with adapter state/backup!
                                2021-08-22 23:40:14.465 - error: zigbee.0 (1986) - PAN ID: configured=6754, adapter=6754
                                2021-08-22 23:40:14.466 - error: zigbee.0 (1986) - Extended PAN ID: configured=dddddddddadddddc, adapter=00124b001caab81b
                                2021-08-22 23:40:14.466 - error: zigbee.0 (1986) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                2021-08-22 23:40:14.467 - error: zigbee.0 (1986) - Channel List: configured=11, adapter=11
                                2021-08-22 23:40:14.468 - error: zigbee.0 (1986) Please update configuration to prevent further issues.
                                2021-08-22 23:40:14.468 - error: zigbee.0 (1986) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                2021-08-22 23:40:14.468 - error: zigbee.0 (1986) Re-commissioning your network will require re-pairing of all devices!
                                2021-08-22 23:40:14.469 - error: zigbee.0 (1986) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                2021-08-22 23:40:14.470 - error: zigbee.0 (1986) Failed to start Zigbee
                                2021-08-22 23:40:14.470 - error: zigbee.0 (1986) Error herdsman start
                                2021-08-22 23:40:24.472 - info: zigbee.0 (1986) Try to reconnect. 1 attempts left
                                2021-08-22 23:40:24.474 - info: zigbee.0 (1986) Starting Zigbee npm ...
                                2021-08-22 23:40:24.515 - info: zigbee.0 (1986) Installed Version: iobroker.zigbee@1.5.6
                                2021-08-22 23:40:24.738 - error: zigbee.0 (1986) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                2021-08-22 23:40:24.738 - error: zigbee.0 (1986) Failed to start Zigbee
                                2021-08-22 23:40:24.739 - error: zigbee.0 (1986) Error herdsman start
                                • S Stefan_NK
                                  @stefan_nk
                                  Richtige IDs eintragen
                                    @stefan_nk
                                    Stefan_NK
                                    @thomas-braun Welche IDs muss ich hier eintragen?
                                    • S Stefan_NK
                                      @stefan_nk
                                      Steht doch da.
                                        @stefan_nk
                                        Steht doch da.
                                        Stefan_NK
                                        @thomas-braun wenn ich es wissen und verstehen würde woran das Ding hakt, hätte ich nicht gefragt 🙄
                                        • S Stefan_NK
                                          @stefan_nk 1986) -
                                          In der config des Adapters steht das eine, der Stick erwartet das andere.
