  4. ZigBee neue Version 1.6.x
    6.3k
509 Beiträge 61 Kommentatoren 150.2k Aufrufe 62 Beobachtet
  • H hukio
    @arteck Ich habe inzwischen mein iobroker backup mit 1.5.6 eingespielt und alles läuft wie vorher. Habe jetzt nochmals das zigbee adapter update gemacht, vorher die Instanz angehalten. Das Ergebnis ist sehr ähnlich.
    2021-08-16 14:31:56.533 - info: host.raspi-3 Restart adapter system.adapter.zigbee.0 because enabled
    2021-08-16 14:32:26.624 - info: host.raspi-3 instance system.adapter.zigbee.0 started with pid 11648
    2021-08-16 14:32:27.441 - error: host.raspi-3 Caught by controller[0]: internal/modules/cjs/loader.js:818
    2021-08-16 14:32:27.442 - error: host.raspi-3 Caught by controller[0]: throw err;
    2021-08-16 14:32:27.442 - error: host.raspi-3 Caught by controller[0]: ^
    2021-08-16 14:32:27.442 - error: host.raspi-3 Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/dist/adapter/serialPortUtils'
    2021-08-16 14:32:27.443 - error: host.raspi-3 Caught by controller[0]: Require stack:
    2021-08-16 14:32:27.443 - error: host.raspi-3 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js
    2021-08-16 14:32:27.443 - error: host.raspi-3 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
    2021-08-16 14:32:27.443 - error: host.raspi-3 Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    2021-08-16 14:32:27.444 - error: host.raspi-3 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    2021-08-16 14:32:27.444 - error: host.raspi-3 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-08-16 14:32:27.444 - error: host.raspi-3 Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    2021-08-16 14:32:27.444 - error: host.raspi-3 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js:3:25)
    2021-08-16 14:32:27.445 - error: host.raspi-3 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-08-16 14:32:27.445 - error: host.raspi-3 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-08-16 14:32:27.445 - error: host.raspi-3 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-08-16 14:32:27.445 - error: host.raspi-3 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-08-16 14:32:27.446 - error: host.raspi-3 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) {
    2021-08-16 14:32:27.446 - error: host.raspi-3 Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2021-08-16 14:32:27.446 - error: host.raspi-3 Caught by controller[0]: requireStack: [
    2021-08-16 14:32:27.446 - error: host.raspi-3 Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js',
    2021-08-16 14:32:27.446 - error: host.raspi-3 Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
    2021-08-16 14:32:27.447 - error: host.raspi-3 Caught by controller[0]: ]
    2021-08-16 14:32:27.447 - error: host.raspi-3 Caught by controller[0]: }
    2021-08-16 14:32:27.447 - error: host.raspi-3 instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Wenn etwas nicht installiert ist, wird es unter 1.5.6 nicht gebraucht.
    Eine Idee, was ich testen soll?
    @hukio
    iobroker repo list
    cd /opt/iobroker
    npm cache clean --force
    iobroker update
    iobroker upgrade zigbee@1.6.0
    Komplette Ein- und Ausgaben zeigen.
    Davon abgesehen ist 1.5.6 die derzeitige stable.
    • H Offline
      hukio
      pi@raspi-3:~ $ iobroker repo list
      stable      : http://download.iobroker.net/sources-dist.json
      beta        : http://download.iobroker.net/sources-dist-latest.json
      Active repo: beta
      pi@raspi-3:~ $ cd /opt/iobroker
      pi@raspi-3:/opt/iobroker $ npm cache clean --force
      npm WARN using --force Recommended protections disabled.
      pi@raspi-3:/opt/iobroker $ iobroker update
      Used repository: beta
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
      Adapter    "backitup"      : 2.1.17   , installed 2.1.17
      Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
      Adapter    "daikin"        : 1.3.3    , installed 1.3.3
      Adapter    "discovery"     : 2.7.0    , installed 2.7.0
      Adapter    "doorbird"      : 0.1.5    , installed 0.1.5
      Adapter    "email"         : 1.0.10   , installed 1.0.10
      Adapter    "flot"          : 1.10.6   , installed 1.10.6
      Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
      Adapter    "history"       : 1.9.13   , installed 1.9.13
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iot"           : 1.8.22   , installed 1.8.22
      Adapter    "iqontrol"      : 1.9.1    , installed 1.8.2 [Updateable]
      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
      Controller "js-controller" : 3.3.15   , installed 3.3.15
      Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
      Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
      Adapter    "netatmo"       : 1.4.4    , installed 1.4.4
      Adapter    "nuki-extended" : 2.3.1    , installed 2.3.1
      Adapter    "onkyo"         : 2.1.0    , installed 2.1.0
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "scenes"        : 2.3.6    , installed 2.3.6
      Adapter    "shelly"        : 4.0.8    , installed 4.0.8
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "text2command"  : 2.1.1    , installed 2.1.1
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Adapter    "zigbee"        : 1.6.0    , installed 1.6.0
      pi@raspi-3:/opt/iobroker $ iobroker upgrade zigbee@1.6.0
      Would you like to reinstall version 1.6.0 of zigbee now? [(y)es, (n)o]: y
      Update zigbee from @1.6.0 to @1.6.0
      NPM version: 7.5.4
      npm install iobroker.zigbee@1.6.0 --loglevel error --prefix "/opt/iobroker" (System call)
      npm install scheint nicht zu gehen, bleibt jedenfalls hängen.
      Was jetzt?
      • H hukio
        Active repo: beta
        update done
        NPM version: 7.5.4
        Was jetzt?
        @hukio
        Falsche npm Version.
        Nimm npm@6 her. Die 7 funktioniert nicht vollständig mit iobroker.
        npm@6 ist auch die Version die mit den empfohlenen nodeJS Versionen im Paket mitkommt.
        Installier sauber node12 oder node14.
        H 1 Antwort Letzte Antwort
          @hukio
          hukio
          @thomas-braun Ich habe zu früh das Handtuch geworfen. Das install für den zigbee adapter ist doch durchgelaufen. Hier ist der Rest:
          NPM version: 7.5.4
          upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
          upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
          upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/paulmann_rgbw_globe.png img/paulmann_rgbw_globe.png image/png
          upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lamp_01.png img/lamp_01.png image/png
          upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_6.png img/group_6.png image/png
          upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_gu10.png img/gledopto_gu10.png image/png
          upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e14_candle.png img/flair_viyu_e14_candle.png image/png
          upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/diy.png img/diy.png image/png
          upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/crts0111.PNG img/crts0111.PNG image/png
          upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
          upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
          upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
          upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
          upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
          upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
          upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
          upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
          upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
          upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
          upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
          upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
          upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
          upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
          upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
          upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
          upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
          upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
          upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
          upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
          upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
          upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
          upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
          upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
          Adapter "zigbee" updated
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:~ $ iobroker repo list
          -bash: pi@raspi-3:~: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ stable      : http://download.iobroker.net/sources-dist.json
          -bash: stable: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ beta        : http://download.iobroker.net/sources-dist-latest.json
          -bash: beta: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ Active repo: beta
          -bash: Active: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:~ $ cd /opt/iobroker
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ npm cache clean --force
          -bash: pi@raspi-3:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
          pi@raspi-3:/opt/iobroker $ npm WARN using --force Recommended protections disabled.
          Top hits for "WARN" "using" "Recommended" "protections" "disabled."
          npm help config          Recommended:2 WARN:8 disabled.:1 protections:1 using:15
          npm help package-json                                            WARN:4 using:21
          npm help install                                          Recommended:1 using:11
          npm help doctor                                            Recommended:1 using:4
          npm help scripts                                                  WARN:1 using:4
          npm help exec                                              Recommended:1 using:3
          npm help npx                                               Recommended:1 using:2
          npm help unpublish                                                WARN:1 using:2
          npm help deprecate                                                WARN:1 using:1
          npm help run-script                                               WARN:1 using:1
          (run with -l or --long to see more context)
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ iobroker update
          pi@raspi-3:/opt/iobroker $ Used repository: beta
          -bash: Used: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ hash unchanged, use cached sources
          -bash: hash: unchanged,: Nicht gefunden.
          -bash: hash: use: Nicht gefunden.
          -bash: hash: cached: Nicht gefunden.
          -bash: hash: sources: Nicht gefunden.
          pi@raspi-3:/opt/iobroker $ update done
          -bash: update: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ Adapter    "admin"         : 5.1.25   , installed 5.1.25
          -bash: Adapter: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
          pi@raspi-3:/opt/iobroker $ Adapter    "backitup"      : 2.1.17   , installed 2.1.17
          pi@raspi-3:/opt/iobroker $ Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
          pi@raspi-3:/opt/iobroker $ Adapter    "daikin"        : 1.3.3    , installed 1.3.3
          pi@raspi-3:/opt/iobroker $ Adapter    "discovery"     : 2.7.0    , installed 2.7.0
          pi@raspi-3:/opt/iobroker $ Adapter    "doorbird"      : 0.1.5    , installed 0.1.5
          pi@raspi-3:/opt/iobroker $ Adapter    "email"         : 1.0.10   , installed 1.0.10
          pi@raspi-3:/opt/iobroker $ Adapter    "flot"          : 1.10.6   , installed 1.10.6
          pi@raspi-3:/opt/iobroker $ Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
          pi@raspi-3:/opt/iobroker $ Adapter    "history"       : 1.9.13   , installed 1.9.13
          pi@raspi-3:/opt/iobroker $ Adapter    "info"          : 1.9.8    , installed 1.9.8
          pi@raspi-3:/opt/iobroker $ Adapter    "iot"           : 1.8.22   , installed 1.8.22
          pi@raspi-3:/opt/iobroker $ Adapter    "iqontrol"      : 1.9.1    , installed 1.8.2 [Updateable]
          pi@raspi-3:/opt/iobroker $ Adapter    "javascript"    : 5.2.8    , installed 5.2.8
          pi@raspi-3:/opt/iobroker $ Controller "js-controller" : 3.3.15   , installed 3.3.15
          -bash: Controller: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
          pi@raspi-3:/opt/iobroker $ Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
          pi@raspi-3:/opt/iobroker $ Adapter    "netatmo"       : 1.4.4    , installed 1.4.4
          pi@raspi-3:/opt/iobroker $ Adapter    "nuki-extended" : 2.3.1    , installed 2.3.1
          pi@raspi-3:/opt/iobroker $ Adapter    "onkyo"         : 2.1.0    , installed 2.1.0
          pi@raspi-3:/opt/iobroker $ Adapter    "ping"          : 1.5.0    , installed 1.5.0
          pi@raspi-3:/opt/iobroker $ Adapter    "scenes"        : 2.3.6    , installed 2.3.6
          pi@raspi-3:/opt/iobroker $ Adapter    "shelly"        : 4.0.8    , installed 4.0.8
          pi@raspi-3:/opt/iobroker $ Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          pi@raspi-3:/opt/iobroker $ Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
          pi@raspi-3:/opt/iobroker $ Adapter    "socketio"      : 3.1.4    , installed 3.1.4
          pi@raspi-3:/opt/iobroker $ Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
          pi@raspi-3:/opt/iobroker $ Adapter    "telegram"      : 1.10.0   , installed 1.10.0
          pi@raspi-3:/opt/iobroker $ Adapter    "text2command"  : 2.1.1    , installed 2.1.1
          pi@raspi-3:/opt/iobroker $ Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
          pi@raspi-3:/opt/iobroker $ Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
          pi@raspi-3:/opt/iobroker $ Adapter    "web"           : 3.4.9    , installed 3.4.9
          pi@raspi-3:/opt/iobroker $ Adapter    "zigbee"        : 1.6.0    , installed 1.6.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ iobroker upgrade zigbee@1.6.0
          pi@raspi-3:/opt/iobroker $ Would you like to reinstall version 1.6.0 of zigbee now? [(y)es, (n)o]: y
          -bash: Syntaxfehler beim unerwarteten Wort `('
          pi@raspi-3:/opt/iobroker $ Update zigbee from @1.6.0 to @1.6.0
          -bash: Update: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ NPM version: 7.5.4
          -bash: NPM: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ npm install iobroker.zigbee@1.6.0 --loglevel error --prefix "/opt/iobroker" (System call)
          upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067-bash: Syntaxfehler beim unerwarteten Wort `('
          .png image/png
          pi@raspi-3:/opt/iobroker $ upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
          upload [5] zigbee.admin -bash: upload: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobrokepi@raspi-3:/opt/iobroker $ upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
          pi@raspi-3:/opt/iobroker $ upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/paulmann_rgbw_globe.png img/paulmann_rgbw_globe.png image/png
          pi@raspi-3:/opt/iobroker $ upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lamp_01.png img/lamp_01.png image/png
          pi@raspi-3:/opt/iobroker $ upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_6.png img/group_6.png image/png
          pi@raspi-3:/opt/iobroker $ upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_gu10.png img/gledopto_gu10.png image/png
          pi@raspi-3:/opt/iobroker $ upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e14_candle.png img/flair_viyu_e14_candle.png image/png
          pi@raspi-3:/opt/iobroker $ upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/diy.png img/diy.png image/png
          pi@raspi-3:/opt/iobroker $ upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/crts0111.PNG img/crts0111.PNG image/png
          pi@raspi-3:/opt/iobroker $ upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
          pi@raspi-3:/opt/iobroker $ upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
          pi@raspi-3:/opt/iobroker $ upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
          pi@raspi-3:/opt/iobroker $ upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
          pi@raspi-3:/opt/iobroker $ upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
          pi@raspi-3:/opt/iobroker $ upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
          pi@raspi-3:/opt/iobroker $ upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
          pi@raspi-3:/opt/iobroker $ upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
          pi@raspi-3:/opt/iobroker $ upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
          pi@raspi-3:/opt/iobroker $ upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
          pi@raspi-3:/opt/iobroker $ upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
          pi@raspi-3:/opt/iobroker $ upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
          pi@raspi-3:/opt/iobroker $ upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
          pi@raspi-3:/opt/iobroker $ upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
          pi@raspi-3:/opt/iobroker $ upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
          pi@raspi-3:/opt/iobroker $ upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
          pi@raspi-3:/opt/iobroker $ upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
          pi@raspi-3:/opt/iobroker $ upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
          pi@raspi-3:/opt/iobroker $ upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
          pi@raspi-3:/opt/iobroker $ upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
          pi@raspi-3:/opt/iobroker $ upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
          pi@raspi-3:/opt/iobroker $ upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
          pi@raspi-3:/opt/iobroker $ upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
          pi@raspi-3:/opt/iobroker $ upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
          pi@raspi-3:/opt/iobroker $ Adapter "zigbee" updated
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ pi@raspi-3:~ $ iobroker repo list
          pi@raspi-3:/opt/iobroker $ -bash: pi@raspi-3:~: Kommando nicht gefunden.
          -bash: -bash:: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ stable      : http://download.iobroker.net/sources-dist.json
          pi@raspi-3:/opt/iobroker $ -bash: stable: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ beta        : http://download.iobroker.net/sources-dist-latest.json
          pi@raspi-3:/opt/iobroker $ -bash: beta: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Active repo: beta
          pi@raspi-3:/opt/iobroker $ -bash: Active: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ pi@raspi-3:~ $ cd /opt/iobroker
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ npm cache clean --force
          pi@raspi-3:/opt/iobroker $ -bash: pi@raspi-3:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ npm WARN using --force Recommended protections disabled.
          pi@raspi-3:/opt/iobroker $ Top hits for "WARN" "using" "Recommended" "protections" "disabled."
          -bash: Top: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ ————————————————————————————————————————————————————————————————————————————————
          -bash: ————————————————————————————————————————————————————————————————————————————————: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ npm help config          Recommended:2 WARN:8 disabled.:1 protections:1 using:15
          Top hits for "config" "Recommended:2" "WARN:8" "disabled.:1" "protections:1" "using:15"
          npm help config                                                        config:60
          npm help config                                                        config:31
          npm help npm                                                           config:31
          npm help npmrc                                                         config:29
          npm help package-json                                                  config:27
          npm help install                                                       config:24
          npm help registry                                                      config:16
          npm help scripts                                                       config:15
          npm help folders                                                       config:12
          npm help adduser                                                       config:11
          Did you mean this?
              config
          pi@raspi-3:/opt/iobroker $ npm help package-json                                            WARN:4 using:21
          Top hits for "package-json" "WARN:4" "using:21"
          npm help install                                                  package-json:4
          npm help init                                                     package-json:3
          npm help publish                                                  package-json:2
          npm help npm                                                      package-json:2
          npm help developers                                               package-json:2
          npm help workspaces                                               package-json:2
          npm help scripts                                                  package-json:2
          npm help config                                                   package-json:2
          npm help config                                                   package-json:1
          npm help help                                                     package-json:1
          pi@raspi-3:/opt/iobroker $ npm help install                                          Recommended:1 using:11
          Top hits for "install" "Recommended:1" "using:11"
          npm help install                                                     install:122
          npm help config                                                       install:64
          npm help package-json                                                 install:46
          npm help scripts                                                      install:44
          npm help folders                                                      install:42
          npm help install                                                      install:33
          npm help npm                                                          install:25
          npm help removal                                                      install:16
          npm help scope                                                        install:16
          npm help package-lock-json                                            install:15
          Did you mean one of these?
              install
              uninstall
          pi@raspi-3:/opt/iobroker $ npm help doctor                                            Recommended:1 using:4
          Top hits for "doctor" "Recommended:1" "using:4"
          npm help doctor                                                         doctor:8
          npm help ping                                                           doctor:2
          Did you mean this?
              doctor
          pi@raspi-3:/opt/iobroker $ npm help scripts                                                  WARN:1 using:4
          Top hits for "scripts" "WARN:1" "using:4"
          npm help scripts                                                      scripts:37
          npm help config                                                       scripts:17
          npm help run-script                                                   scripts:15
          npm help package-json                                                 scripts:12
          npm help version                                                       scripts:8
          npm help developers                                                    scripts:7
          npm help start                                                         scripts:6
          npm help install                                                       scripts:6
          npm help restart                                                       scripts:5
          npm help stop                                                          scripts:4
          pi@raspi-3:/opt/iobroker $ npm help exec                                              Recommended:1 using:3
          Top hits for "exec" "Recommended:1" "using:3"
          npm help exec                                                            exec:24
          npm help npx                                                             exec:24
          npm help scripts                                                         exec:11
          npm help config                                                           exec:9
          npm help package-json                                                     exec:6
          npm help run-script                                                       exec:5
          npm help init                                                             exec:3
          npm help folders                                                          exec:3
          npm help install                                                          exec:2
          npm help removal                                                          exec:2
          Did you mean this?
              exec
          pi@raspi-3:/opt/iobroker $ npm help npx                                               Recommended:1 using:2
          Top hits for "npx" "Recommended:1" "using:2"
          npm help exec                                                             npx:22
          npm help npx                                                              npx:22
          npm help init                                                              npx:9
          npm help publish                                                           npx:1
          npm help config                                                            npx:1
          pi@raspi-3:/opt/iobroker $ npm help unpublish                                                WARN:1 using:2
          Top hits for "unpublish" "WARN:1" "using:2"
          npm help unpublish                                                   unpublish:9
          npm help publish                                                     unpublish:2
          npm help package-json                                                unpublish:1
          npm help config                                                      unpublish:1
              publish
              unpublish
          pi@raspi-3:/opt/iobroker $ npm help deprecate                                                WARN:1 using:1
          Top hits for "deprecate" "WARN:1" "using:1"
          npm help deprecate                                                   deprecate:6
          npm help config                                                      deprecate:5
          npm help unpublish                                                   deprecate:4
          npm help npx                                                         deprecate:2
          npm help exec                                                        deprecate:2
          npm help publish                                                     deprecate:2
          npm help package-json                                                deprecate:1
          npm help scripts                                                     deprecate:1
          Did you mean this?
              deprecate
          pi@raspi-3:/opt/iobroker $ npm help run-script                                               WARN:1 using:1
          Top hits for "run-script" "WARN:1" "using:1"
          npm help start                                                      run-script:4
          npm help restart                                                    run-script:3
          npm help scripts                                                    run-script:3
          npm help set-script                                                 run-script:2
          npm help shrinkwrap                                                 run-script:2
          npm help stop                                                       run-script:2
          npm help test                                                       run-script:2
          npm help version                                                    run-script:2
          npm help npx                                                        run-script:2
          npm help exec                                                       run-script:2
              run-script
              set-script
          pi@raspi-3:/opt/iobroker $ (run with -l or --long to see more context)
          -bash: run: Kommando nicht gefunden.
          .pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ iobroker update
          er-bash: pi@raspi-3:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Used repository: beta
          obr-bash: pi@raspi-3:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
          pi@raspi-3:/opt/iobroker $ -bash: Used: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ hash unchanged, use cached sources
          pi@raspi-3:/opt/iobroker $ -bash: hash: unchanged,: Nicht gefunden.
          pi@raspi-3:/opt/iobroker $ -bash: hash: use: Nicht gefunden.
          pi@raspi-3:/opt/iobroker $ -bash: hash: cached: Nicht gefunden.
          pi@raspi-3:/opt/iobroker $ -bash: hash: sources: Nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ update done
          pi@raspi-3:/opt/iobroker $ -bash: update: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "admin"         : 5.1.25   , installed 5.1.25
          pi@raspi-3:/opt/iobroker $ -bash: Adapter: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "backitup"      : 2.1.17   , installed 2.1.17
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "daikin"        : 1.3.3    , installed 1.3.3
          : NPM: Kommand-bash: -bash:: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "discovery"     : 2.7.0    , installed 2.7.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "doorbird"      : 0.1.5    , installed 0.1.5
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "email"         : 1.0.10   , installed 1.0.10
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "flot"          : 1.10.6   , installed 1.10.6
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "history"       : 1.9.13   , installed 1.9.13
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "info"          : 1.9.8    , installed 1.9.8
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "iot"           : 1.8.22   , installed 1.8.22
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "iqontrol"      : 1.9.1    , installed 1.8.2 [Updateable]
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "javascript"    : 5.2.8    , installed 5.2.8
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Controller "js-controller" : 3.3.15   , installed 3.3.15
          pi@raspi-3:/opt/iobroker $ -bash: Controller: Kommando nicht gefunden.
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "lgtv"          : 1.1.10   , installed 1.1.10
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "netatmo"       : 1.4.4    , installed 1.4.4
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "nuki-extended" : 2.3.1    , installed 2.3.1
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "onkyo"         : 2.1.0    , installed 2.1.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "ping"          : 1.5.0    , installed 1.5.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "scenes"        : 2.3.6    , installed 2.3.6
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "shelly"        : 4.0.8    , installed 4.0.8
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "socketio"      : 3.1.4    , installed 3.1.4
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "telegram"      : 1.10.0   , installed 1.10.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "text2command"  : 2.1.1    , installed 2.1.1
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "web"           : 3.4.9    , installed 3.4.9
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Adapter    "zigbee"        : 1.6.0    , installed 1.6.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ iobroker upgrade zigbee@1.6.0
          pi@raspi-3:/opt/iobroker $ pi@raspi-3:/opt/iobroker $ Would you like to reinstall version 1.6.0 of zigbee now? [(y)es, (n)o]: y
          pi@raspi-3:/opt/iobroker $ -bash: Syntaxfehler beim unerwarteten Wort `('
          Mir scheint, da ist etwas durcheindergelaufen. Aber der Adapter 1.6.0 läuft jetzt!!!!!!!!!!!!!
          Werde npm 6 installieren.
          Vielen Dank!
          • H hukio
            NPM version: 7.5.4
            .png image/png
            Did you mean this?
                config
                install
                uninstall
            Did you mean this?
                doctor
            Did you mean this?
                exec
            npm help npx                                                              npx:22
            npm help init                                                              npx:9
                publish
                unpublish
            Did you mean this?
                deprecate
                run-script
                set-script
            Vielen Dank!
            @hukio sagte in ZigBee neue Version 1.6.0:
            Das glaube ich auch...
            Wie ist denn nodeJS jetzt überhaupt installiert?
            which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
            • H Offline
              hukio
              pi@raspi-3:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.20.0
              v12.20.0
              7.5.4
              nodejs:
                Installiert:           12.20.0-1nodesource1
                Installationskandidat: 12.22.5-1nodesource1
                Versionstabelle:
                   12.22.5-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               *** 12.20.0-1nodesource1 100
                   10.24.0~dfsg-1~deb10u1 500
              Hier die Antwort. Habe mein Durcheinander verstanden. Wenn ich die Zeilen aus dem Terminal kopiert habe. Habe ich leider Ctrl C gedrückt und mit der Kopie Befehle gestartet. Linux ist gewöhnungsbedürftig.
              Ist an meiner Installation etwas auszusetzen?
              • H hukio
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.20.0
                v12.20.0
                7.5.4
                nodejs:
                  Versionstabelle:
                @hukio
                sudo apt update
                iobroker stop
                sudo apt dist-upgrade
                sudo reboot
                sollte alles wieder geraderücken.
                Und lass die Finger von npm-Updates außerhalb von apt.
                  @hukio
                  sudo apt update
                  iobroker stop
                  sudo reboot
                  hukio
                  Nochmals vielen Dank!
                  Ich wünschte, ich wüßte was ich tue.
                  HUK
                    Marsx79
                    Hallo.
                    Ich habe ein merkwürdiges Verhalten bei einem Tuya Smart Socket (TS0121_plug).
                    https://www.zigbee2mqtt.io/devices/TS0121_plug.html
                    Er lässt sich ohne Probleme einbinden. Allerdings lässt er sich nur direkt über die Weboberfläche das Zigbee Adapters ein/aus schalten. Wenn ich den Datenpunkt direkt in den Objekten zigbee.0.xxxxx.state schalte passiert nichts. Den Datenpunkt kann man zwar auf true/false setzen er schaltet aber nicht.
                    Irgendwelche Ideen dazu?
                    IdleBitI 1 Antwort Letzte Antwort
                    • M Marsx79
                      Hallo.
                      IdleBitI Offline
                      IdleBitI Offline
                      IdleBit
                      @marsx79 das Bestätigt darf nicht gesetzt sein, hast Du das beachtet?
                      • IdleBitI IdleBit
                        Marsx79
                        @idlebit Nein habe ich nicht beachtet! Funktioniert! Danke für die Hilfe.
                        Warum ist das so? Ist mir vorher irgendwie nie aufgefallen.
                        • IdleBitI Offline
                          IdleBitI Offline
                          IdleBit
                          @marsx79 Bestätigt = ack -> https://forum.iobroker.net/topic/46771/wozu-ist-der-ack-flag-da/16
                          • arteckA arteck
                            wit haben gestern abend eine neue Version des Adapter publiziert..
                            in der latest die ihr im Admin sieht ist die allgemeine Version die wir normalerweise auch preferieren.. hier sind alle Geräte auch gepflegt bzw. der converter immer akuell
                            ABER
                            sollte diese Version nicht funktionieren bitte diese aus dem GIT installieren
                            https://github.com/ioBroker/ioBroker.zigbee/tarball/old_herdsman
                            sollte der Adapter immer noch nicht starten
                            hierzu muss noch die nvbackup.json gelöscht werden
                            adapter stoppen
                            rm /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                            adapter starten
                            warum so ein hickmeck....
                            es betrifft nicht die conbee Sticks
                            es hängt mit der Firmware zusammen die auf den Sticks drauf ist. Vor allem auf den CC2538 + CC2592 hat sich die Firmware nach und nach weiter entwickelt und
                            NUR die CC2538 + CC2592 sind BETROFFEN
                            alle die eine Firmware 20201010 haben sollten keine Probleme bekommen. Diese Firmware unterstützt das sichern und zurückspielen der Zigbee Netz Parameter.
                            alles was älter ist kann laufen was eher unwarscheinlich ist.
                            darüberhinaus hat das Projekt zigbee2mqtt erst jetzt damit begonen das zu unterstützen und da wir drauf aufsetzten sind wir von abhängig
                            wo sehe ich meine Firmware :
                            in der Kachel
                            p.s: wenn ihr wollt kann ich euch meine Sticks auf die neue Firmware bringen. Bedenkt aber auch dass es ein komplettes neu anlernen der Geräte mit sich zieht.
                            hierzu PM an mich
                            rotamint
                            @arteck Hallo zusammen, ich hoffe ich habe hier die richtige Kategorie ausgewählt. Ich habe ebenfalls auf die 1.6.0 upgedatet und erhalte seitdem drei Fehlermeldungen, wenn ich drei Lampen einer Gruppe schalte.
                            Ich benutze den ConbeeII Stick:
                            Und erhalte sowohl beim ein- als auch beim ausschalten folgende Fehlermeldung:
                            zigbee.0
                            	2021-09-21 15:05:38.529	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:38.519	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:37.182	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:37.173	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:35.310	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:35.297	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:13.953	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:13.948	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            zigbee.0
                            	2021-09-21 15:05:12.313	error	Device 0x00212effff05b783 "undefined" not described in statesMapping.
                            Allerdings funktionieren die Lampen einwanfrei. Habe die Gruppe gelöscht, neu angelegt, andere Lampen probiert, etc... Gleiches Ergebnis... Die Fehlermeldung erscheint lediglich beim ein- und ausschalten einer Gruppe.
                            Danke bereits Vorab für Deine / Eure Hilfe!
                            AsgothianA mickymM 2 Antworten Letzte Antwort
                            • R rotamint
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @rotamint Du musst schauen wo du ein Device 0x00212effff05b783 hast. Dieses Device ist anscheinend einer Gruppe zugeordnet.
                              • Was ist das fuer ein Device ?
                              • Funktioniert es ?
                              A.
                              R 1 Antwort Letzte Antwort
                              • AsgothianA Asgothian
                                • Funktioniert es ?
                                A.
                                rotamint
                                @asgothian Sorry. Das hatte ich vergessen zu schreiben. Das Device habe ich auch gesucht. Es existiert nicht, und ist auch nicht den Gruppen zugeordnet. Diese Fehlermeldung kommt bei jeder Gruppe, die ich ein- oder ausschalte. Habe eine neue Gruppe erstellt, dann nur eine Lampe zugeordnet. Dann kommt die Meldung nur einmal. Bei zwei Lampen zweimal, bei drei - dreimal. Ist auch nicht abhängig von "den" Lampen, habe es auch mit anderen Versucht - gleiches Ergebnis. Danke! Stefan.
                                • R rotamint
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @rotamint
                                  Bitte schauen ob in der shepherd.db ein Objekt mit dieser Bezeichnung aufgeführt ist.
                                  shepherd.db ist eine JSON Datei die von hand lesbar sein sollte, und liegt unter /opt/iobroker/iobroker-data/zigbee_0
                                  A.
                                    @rotamint
                                    A.
                                    rotamint
                                    @asgothian Es ist an 12 Stellen zu finden. Zu allererst in der ersten Zeile:
                                    {"id":1,"type":"Coordinator","ieeeAddr":"0x00212effff05b783","nwkAddr":0,"manufId":4405,"epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterList":[0,10,25],"outClusterList":[1,32,1280],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":100,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"interviewCompleted":true,"meta":{},"lastSeen":1632229538506}
                                    • R rotamint
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @rotamint
                                      Da ist etwas grossflächig faul. Bitte mach folgendes:
                                      • Zigbee Adapter anhalten
                                      • shepherd.db und (wenn vorhanden) nvbackup.json Datei sichern
                                      • shepherd.db editieren - alle Geräte mit der ieeeAddr 0x00212effff05b783 löschen - dabei darauf achten das das Format sauber bleibt.
                                      • Zigbee Adapter neu starten - schauen ob die Geräte normal addressierbar sind.
                                      Sollte es Probleme geben kann durch Wiederherstellen der shepherd.db der Vorherige Zustand restauriert werden. Dieses natürlich auch nur wenn der Zigbee Adapter angehalten ist.
                                      A.
                                        @rotamint
                                        A.
                                        rotamint
                                        @asgothian said in ZigBee neue Version 1.6.0:
                                        Danke für Deine Hilfe. Wie muss das "saubere" Format aussehen?
                                        LG Stefan.
                                        BananaJoeB AsgothianA 2 Antworten Letzte Antwort
                                        • R rotamint
                                          LG Stefan.
                                          BananaJoeB Online
                                          BananaJoeB Online
                                          BananaJoe
                                          @rotamint kopiere den Text hinterher hier rein:
                                          https://jsonformatter.curiousconcept.com/
                                          Der sagt dir dann ob noch jedes Komma und jede Klammer richtig gesetzt ist.
                                          Da ist rechts auch ein "Fix JSON" Button der es ggf. reparieren kann. Beim ersten mal eventuell den Haken rausnehmen
