  4. Kein restore mit backitup [gelöst]
    6.4k
46 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • ChrisNettC ChrisNett
    2021-08-16 15:43:23.925  - info: host.PI4 All instances are stopped.
    2021-08-16 15:43:23.987  - info: host.PI4 terminated
    2021-08-16 15:43:23.446  - info: host.PI4 instance system.adapter.mqtt.0 terminated with code null ()
    2021-08-16 15:43:23.575  - warn: host.PI4 instance system.adapter.ping.0 terminated due to SIGTERM
    2021-08-16 15:43:23.576  - info: host.PI4 instance system.adapter.ping.0 terminated with code null ()
    2021-08-16 15:43:23.577  - warn: host.PI4 instance system.adapter.sonoff.0 terminated due to SIGTERM
    2021-08-16 15:43:23.577  - info: host.PI4 instance system.adapter.sonoff.0 terminated with code null ()
    2021-08-16 15:43:23.765  - warn: host.PI4 instance system.adapter.logparser.0 terminated due to SIGTERM
    2021-08-16 15:43:23.765  - info: host.PI4 instance system.adapter.logparser.0 terminated with code null ()
    2021-08-16 15:43:23.766  - warn: host.PI4 instance system.adapter.shelly.0 terminated due to SIGTERM
    2021-08-16 15:43:23.766  - info: host.PI4 instance system.adapter.shelly.0 terminated with code null ()
    2021-08-16 15:43:23.854  - warn: host.PI4 instance system.adapter.zigbee.0 terminated due to SIGTERM
    2021-08-16 15:43:23.855  - info: host.PI4 instance system.adapter.zigbee.0 terminated with code null ()
    2021-08-16 15:43:23.855  - warn: host.PI4 instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
    2021-08-16 15:43:23.856  - info: host.PI4 instance system.adapter.tankerkoenig.0 terminated with code null ()
    2021-08-16 15:43:23.924  - info: host.PI4 instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    müsste da nicht mehr stehen?
    @christian-sandkaulen
    Seit einer Stunde läuft das? Oder ist deine Zeitzone falsch?
    date && date -u
    ChrisNettC 1 Antwort Letzte Antwort
      date && date -u
      ChrisNettC Offline
      ChrisNettC Offline
      ChrisNett
      @thomas-braun said in Kein restore mit backitup:
      date && date -u
      ne seit einer stunde
      Mo 16. Aug 16:44:45 CEST 2021
      Mo 16. Aug 14:44:45 UTC 2021
        date && date -u
        Das dürfte dann abgenippelt sein.
        iobroker start
        Iobroker status
        which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
          iobroker start
          Iobroker status
          ChrisNettC Offline
          ChrisNettC Offline
          ChrisNett
          Iobroker status
          Objects type: file
          States  type: file
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.1
          v12.22.1
          6.14.12
          nodejs:
            Installiert:           12.22.1-1nodesource1
            Installationskandidat: 12.22.1-1nodesource1
            Versionstabelle:
           *** 12.22.1-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u1 500
          Thomas BraunT ChrisNettC 2 Antworten Letzte Antwort
            Iobroker status
            Objects type: file
            States  type: file
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.1
            v12.22.1
            6.14.12
            nodejs:
              Versionstabelle:
            Damn bringst du jetzt erstmal dein Betriebssystem auf Stand:
            iobroker stop
            sudo apt update
            sudo apt dist-upgrade
            sudo reboot
              Iobroker status
              Objects type: file
              States  type: file
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.1
              v12.22.1
              6.14.12
              nodejs:
                Versionstabelle:
              ChrisNettC Offline
              ChrisNettC Offline
              ChrisNett
              im backitup adapter ist jetzt das aufgetaucht
              Started restore ...
              [DEBUG] [iobroker] Start ioBroker Restore ...
              [EXIT] 0
                Started restore ...
                [EXIT] 0
                ChrisNettC Offline
                ChrisNettC Offline
                ChrisNett
                nach einiger zeit hier der log
                brauchst du den log?
                  Ist dein OS jetzt gepatcht?
                    ChrisNettC Offline
                    ChrisNettC Offline
                    ChrisNett
                    pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy        nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.5
                    v12.22.5
                    6.14.14
                    nodejs:
                      Installiert:           12.22.5-1nodesource1
                      Installationskandidat: 12.22.5-1nodesource1
                      Versionstabelle:
                     *** 12.22.5-1nodesource1 500
                    pi@PI4:~ $
                    denke schon oder?
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.5
                      v12.22.5
                      6.14.14
                      nodejs:
                        Versionstabelle:
                      pi@PI4:~ $
                      denke schon oder?
                      Und wie ist jetzt der Status? Backup drin?
                        ChrisNettC Offline
                        ChrisNettC Offline
                        ChrisNett
                        nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
                          ChrisNettC Offline
                          ChrisNettC Offline
                          ChrisNett
                          kann ich mit putty versuchen ein bestimmtes einzuspielen?
                            ChrisNettC Offline
                            ChrisNettC Offline
                            ChrisNett
                            nach dem Neustart vom iobroker kommt dieser Fehler
                            backitup.0
                            2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
                            der Adapter ist aber grün.
                            • Thomas BraunT Online
                              Installier den Adapter nochmal.
                                ChrisNettC Offline
                                ChrisNettC Offline
                                ChrisNett
                                als zweite Instanz ?
                                  Nein, über den Adapter drüber.
                                  iobroker upgrade backitup@2.1.13
                                    ChrisNettC Offline
                                    ChrisNettC Offline
                                    ChrisNett
                                    pi@PI4:~ $ iobroker upgrade backitup@2.1.13
                                    Would you like to reinstall version 2.1.13 of backitup now? [(y)es, (n)o]: y
                                    Update backitup from @2.1.13 to @2.1.13
                                    host.PI4 Adapter "system.adapter.backitup.0" is stopped.
                                    NPM version: 6.14.14
                                    npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (        System call)
                                    müsste da nicht mehr passsieren?
                                      ChrisNettC Offline
                                      ChrisNettC Offline
                                      ChrisNett
                                      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                      Adapter "backitup" updated
                                      hat ewig gedauert.
                                        hat ewig gedauert.
                                        Du bist zu ungeduldig.
                                          hat ewig gedauert.
                                          @christian-sandkaulen sagte in Kein restore mit backitup:
                                          hat ewig gedauert.
                                          5 Minuten?
                                          was ist dein Server?
