  4. Kein restore mit backitup [gelöst]
    6.4k
46 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    @christian-sandkaulen
    iobroker logs --watch
    zeigt den Fortgang im Log File.
    ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    2021-08-16 15:43:23.925  - info: host.PI4 All instances are stopped.
    2021-08-16 15:43:23.987  - info: host.PI4 terminated
    2021-08-16 15:43:23.446  - info: host.PI4 instance system.adapter.mqtt.0 terminated with code null ()
    2021-08-16 15:43:23.575  - warn: host.PI4 instance system.adapter.ping.0 terminated due to SIGTERM
    2021-08-16 15:43:23.576  - info: host.PI4 instance system.adapter.ping.0 terminated with code null ()
    2021-08-16 15:43:23.577  - warn: host.PI4 instance system.adapter.sonoff.0 terminated due to SIGTERM
    2021-08-16 15:43:23.577  - info: host.PI4 instance system.adapter.sonoff.0 terminated with code null ()
    2021-08-16 15:43:23.765  - warn: host.PI4 instance system.adapter.logparser.0 terminated due to SIGTERM
    2021-08-16 15:43:23.765  - info: host.PI4 instance system.adapter.logparser.0 terminated with code null ()
    2021-08-16 15:43:23.766  - warn: host.PI4 instance system.adapter.shelly.0 terminated due to SIGTERM
    2021-08-16 15:43:23.766  - info: host.PI4 instance system.adapter.shelly.0 terminated with code null ()
    2021-08-16 15:43:23.854  - warn: host.PI4 instance system.adapter.zigbee.0 terminated due to SIGTERM
    2021-08-16 15:43:23.855  - info: host.PI4 instance system.adapter.zigbee.0 terminated with code null ()
    2021-08-16 15:43:23.855  - warn: host.PI4 instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
    2021-08-16 15:43:23.856  - info: host.PI4 instance system.adapter.tankerkoenig.0 terminated with code null ()
    2021-08-16 15:43:23.924  - info: host.PI4 instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    müsste da nicht mehr stehen?
    • ChrisNettC ChrisNett
      Seit einer Stunde läuft das? Oder ist deine Zeitzone falsch?
      date && date -u
      ChrisNettC 1 Antwort Letzte Antwort
        date && date -u
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        @thomas-braun said in Kein restore mit backitup:
        date && date -u
        ne seit einer stunde
        Mo 16. Aug 16:44:45 CEST 2021
        Mo 16. Aug 14:44:45 UTC 2021
          date && date -u
          Das dürfte dann abgenippelt sein.
          iobroker start
          Iobroker status
          which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
            iobroker start
            Iobroker status
            ChrisNettC Offline
            ChrisNettC Offline
            ChrisNett
            Iobroker status
            Objects type: file
            States  type: file
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.1
            v12.22.1
            6.14.12
            nodejs:
              Installiert:           12.22.1-1nodesource1
              Installationskandidat: 12.22.1-1nodesource1
              Versionstabelle:
             *** 12.22.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u1 500
            Thomas BraunT ChrisNettC 2 Antworten Letzte Antwort
              Iobroker status
              Objects type: file
              States  type: file
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.1
              v12.22.1
              6.14.12
              nodejs:
                Versionstabelle:
              Damn bringst du jetzt erstmal dein Betriebssystem auf Stand:
              iobroker stop
              sudo apt update
              sudo apt dist-upgrade
              sudo reboot
                Iobroker status
                Objects type: file
                States  type: file
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.1
                v12.22.1
                6.14.12
                nodejs:
                  Versionstabelle:
                ChrisNettC Offline
                ChrisNettC Offline
                ChrisNett
                im backitup adapter ist jetzt das aufgetaucht
                Started restore ...
                [DEBUG] [iobroker] Start ioBroker Restore ...
                [EXIT] 0
                  Started restore ...
                  [EXIT] 0
                  ChrisNettC Offline
                  ChrisNettC Offline
                  ChrisNett
                  nach einiger zeit hier der log
                  brauchst du den log?
                    Ist dein OS jetzt gepatcht?
                      ChrisNettC Offline
                      ChrisNettC Offline
                      ChrisNett
                      pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy        nodejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.5
                      v12.22.5
                      6.14.14
                      nodejs:
                        Installiert:           12.22.5-1nodesource1
                        Installationskandidat: 12.22.5-1nodesource1
                        Versionstabelle:
                       *** 12.22.5-1nodesource1 500
                      pi@PI4:~ $
                      denke schon oder?
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v12.22.5
                        v12.22.5
                        6.14.14
                        nodejs:
                          Versionstabelle:
                        pi@PI4:~ $
                        denke schon oder?
                        Und wie ist jetzt der Status? Backup drin?
                          ChrisNettC Offline
                          ChrisNettC Offline
                          ChrisNett
                          nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
                            ChrisNettC Offline
                            ChrisNettC Offline
                            ChrisNett
                            kann ich mit putty versuchen ein bestimmtes einzuspielen?
                              ChrisNettC Offline
                              ChrisNettC Offline
                              ChrisNett
                              nach dem Neustart vom iobroker kommt dieser Fehler
                              backitup.0
                              2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
                              der Adapter ist aber grün.
                              • Thomas BraunT Online
                                Installier den Adapter nochmal.
                                  ChrisNettC Offline
                                  ChrisNettC Offline
                                  ChrisNett
                                  als zweite Instanz ?
                                    Nein, über den Adapter drüber.
                                    iobroker upgrade backitup@2.1.13
                                      ChrisNettC Offline
                                      ChrisNettC Offline
                                      ChrisNett
                                      pi@PI4:~ $ iobroker upgrade backitup@2.1.13
                                      Would you like to reinstall version 2.1.13 of backitup now? [(y)es, (n)o]: y
                                      Update backitup from @2.1.13 to @2.1.13
                                      host.PI4 Adapter "system.adapter.backitup.0" is stopped.
                                      NPM version: 6.14.14
                                      npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (        System call)
                                      müsste da nicht mehr passsieren?
                                        ChrisNettC Offline
                                        ChrisNettC Offline
                                        ChrisNett
                                        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                        Adapter "backitup" updated
                                        hat ewig gedauert.
                                          hat ewig gedauert.
                                          Du bist zu ungeduldig.
