  4. Kein restore mit backitup [gelöst]
    6.4k
46 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • ChrisNettC ChrisNett
    @thomas-braun said in Kein restore mit backitup:
    node
    v12.22.1 ist nicht aktuell?
    @christian-sandkaulen
    Node 12.22.5 ist aktuell. Das sollte dir bei sauberer Installation aber auch der Paketmanager verraten
      sehe ich denn irgtwas am bildschirm? oder unter putty ?
      iobroker logs --watch
      zeigt den Fortgang im Log File.
      ChrisNettC 1 Antwort Letzte Antwort
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        2021-08-16 15:43:23.925  - info: host.PI4 All instances are stopped.
        2021-08-16 15:43:23.987  - info: host.PI4 terminated
        2021-08-16 15:43:23.446  - info: host.PI4 instance system.adapter.mqtt.0 terminated with code null ()
        2021-08-16 15:43:23.575  - warn: host.PI4 instance system.adapter.ping.0 terminated due to SIGTERM
        2021-08-16 15:43:23.576  - info: host.PI4 instance system.adapter.ping.0 terminated with code null ()
        2021-08-16 15:43:23.577  - warn: host.PI4 instance system.adapter.sonoff.0 terminated due to SIGTERM
        2021-08-16 15:43:23.577  - info: host.PI4 instance system.adapter.sonoff.0 terminated with code null ()
        2021-08-16 15:43:23.765  - warn: host.PI4 instance system.adapter.logparser.0 terminated due to SIGTERM
        2021-08-16 15:43:23.765  - info: host.PI4 instance system.adapter.logparser.0 terminated with code null ()
        2021-08-16 15:43:23.766  - warn: host.PI4 instance system.adapter.shelly.0 terminated due to SIGTERM
        2021-08-16 15:43:23.766  - info: host.PI4 instance system.adapter.shelly.0 terminated with code null ()
        2021-08-16 15:43:23.854  - warn: host.PI4 instance system.adapter.zigbee.0 terminated due to SIGTERM
        2021-08-16 15:43:23.855  - info: host.PI4 instance system.adapter.zigbee.0 terminated with code null ()
        2021-08-16 15:43:23.855  - warn: host.PI4 instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
        2021-08-16 15:43:23.856  - info: host.PI4 instance system.adapter.tankerkoenig.0 terminated with code null ()
        2021-08-16 15:43:23.924  - info: host.PI4 instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        müsste da nicht mehr stehen?
          Seit einer Stunde läuft das? Oder ist deine Zeitzone falsch?
          date && date -u
            date && date -u
            ChrisNettC Offline
            ChrisNettC Offline
            ChrisNett
            date && date -u
            ne seit einer stunde
            Mo 16. Aug 16:44:45 CEST 2021
            Mo 16. Aug 14:44:45 UTC 2021
              date && date -u
              Das dürfte dann abgenippelt sein.
              iobroker start
              Iobroker status
              which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                iobroker start
                Iobroker status
                ChrisNettC Offline
                ChrisNettC Offline
                ChrisNett
                Iobroker status
                Objects type: file
                States  type: file
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.1
                v12.22.1
                6.14.12
                nodejs:
                  Installiert:           12.22.1-1nodesource1
                  Installationskandidat: 12.22.1-1nodesource1
                  Versionstabelle:
                 *** 12.22.1-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                     10.24.0~dfsg-1~deb10u1 500
                Thomas BraunT ChrisNettC 2 Antworten Letzte Antwort
                  Iobroker status
                  Objects type: file
                  States  type: file
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.22.1
                  v12.22.1
                  6.14.12
                  nodejs:
                    Versionstabelle:
                  Damn bringst du jetzt erstmal dein Betriebssystem auf Stand:
                  iobroker stop
                  sudo apt update
                  sudo apt dist-upgrade
                  sudo reboot
                    Iobroker status
                    Objects type: file
                    States  type: file
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.1
                    v12.22.1
                    6.14.12
                    nodejs:
                      Versionstabelle:
                    ChrisNettC Offline
                    ChrisNettC Offline
                    ChrisNett
                    im backitup adapter ist jetzt das aufgetaucht
                    Started restore ...
                    [DEBUG] [iobroker] Start ioBroker Restore ...
                    [EXIT] 0
                      Started restore ...
                      [EXIT] 0
                      ChrisNettC Offline
                      ChrisNettC Offline
                      ChrisNett
                      nach einiger zeit hier der log
                      brauchst du den log?
                        Ist dein OS jetzt gepatcht?
                          ChrisNettC Offline
                          ChrisNettC Offline
                          ChrisNett
                          pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy        nodejs
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v12.22.5
                          v12.22.5
                          6.14.14
                          nodejs:
                            Installiert:           12.22.5-1nodesource1
                            Installationskandidat: 12.22.5-1nodesource1
                            Versionstabelle:
                           *** 12.22.5-1nodesource1 500
                          pi@PI4:~ $
                          denke schon oder?
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.5
                            v12.22.5
                            6.14.14
                            nodejs:
                              Versionstabelle:
                            pi@PI4:~ $
                            denke schon oder?
                            Und wie ist jetzt der Status? Backup drin?
                              ChrisNettC Offline
                              ChrisNettC Offline
                              ChrisNett
                              nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
                                ChrisNettC Offline
                                ChrisNettC Offline
                                ChrisNett
                                kann ich mit putty versuchen ein bestimmtes einzuspielen?
                                  ChrisNettC Offline
                                  ChrisNettC Offline
                                  ChrisNett
                                  nach dem Neustart vom iobroker kommt dieser Fehler
                                  backitup.0
                                  2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
                                  der Adapter ist aber grün.
                                  • Thomas BraunT Online
                                    Installier den Adapter nochmal.
                                      ChrisNettC Offline
                                      ChrisNettC Offline
                                      ChrisNett
                                      als zweite Instanz ?
                                        Nein, über den Adapter drüber.
                                        iobroker upgrade backitup@2.1.13
                                          ChrisNettC Offline
                                          ChrisNettC Offline
                                          ChrisNett
                                          pi@PI4:~ $ iobroker upgrade backitup@2.1.13
                                          Would you like to reinstall version 2.1.13 of backitup now? [(y)es, (n)o]: y
                                          Update backitup from @2.1.13 to @2.1.13
                                          host.PI4 Adapter "system.adapter.backitup.0" is stopped.
                                          NPM version: 6.14.14
                                          npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (        System call)
                                          müsste da nicht mehr passsieren?
