  4. Kein restore mit backitup [gelöst]
    6.4k
46 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    @christian-sandkaulen
    Restore kann geraume Zeit dauern.
    ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    sehe ich denn irgtwas am bildschirm? oder unter putty ?
    • ChrisNettC ChrisNett
      @thomas-braun said in Kein restore mit backitup:
      node
      v12.22.1 ist nicht aktuell?
      Node 12.22.5 ist aktuell. Das sollte dir bei sauberer Installation aber auch der Paketmanager verraten
        iobroker logs --watch
        zeigt den Fortgang im Log File.
        ChrisNettC 1 Antwort Letzte Antwort
          ChrisNettC Offline
          ChrisNettC Offline
          ChrisNett
          2021-08-16 15:43:23.925  - info: host.PI4 All instances are stopped.
          2021-08-16 15:43:23.987  - info: host.PI4 terminated
          2021-08-16 15:43:23.446  - info: host.PI4 instance system.adapter.mqtt.0 terminated with code null ()
          2021-08-16 15:43:23.575  - warn: host.PI4 instance system.adapter.ping.0 terminated due to SIGTERM
          2021-08-16 15:43:23.576  - info: host.PI4 instance system.adapter.ping.0 terminated with code null ()
          2021-08-16 15:43:23.577  - warn: host.PI4 instance system.adapter.sonoff.0 terminated due to SIGTERM
          2021-08-16 15:43:23.577  - info: host.PI4 instance system.adapter.sonoff.0 terminated with code null ()
          2021-08-16 15:43:23.765  - warn: host.PI4 instance system.adapter.logparser.0 terminated due to SIGTERM
          2021-08-16 15:43:23.765  - info: host.PI4 instance system.adapter.logparser.0 terminated with code null ()
          2021-08-16 15:43:23.766  - warn: host.PI4 instance system.adapter.shelly.0 terminated due to SIGTERM
          2021-08-16 15:43:23.766  - info: host.PI4 instance system.adapter.shelly.0 terminated with code null ()
          2021-08-16 15:43:23.854  - warn: host.PI4 instance system.adapter.zigbee.0 terminated due to SIGTERM
          2021-08-16 15:43:23.855  - info: host.PI4 instance system.adapter.zigbee.0 terminated with code null ()
          2021-08-16 15:43:23.855  - warn: host.PI4 instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
          2021-08-16 15:43:23.856  - info: host.PI4 instance system.adapter.tankerkoenig.0 terminated with code null ()
          2021-08-16 15:43:23.924  - info: host.PI4 instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          müsste da nicht mehr stehen?
            Seit einer Stunde läuft das? Oder ist deine Zeitzone falsch?
            date && date -u
              date && date -u
              ChrisNettC Offline
              ChrisNettC Offline
              ChrisNett
              date && date -u
              ne seit einer stunde
              Mo 16. Aug 16:44:45 CEST 2021
              Mo 16. Aug 14:44:45 UTC 2021
                date && date -u
                Das dürfte dann abgenippelt sein.
                iobroker start
                Iobroker status
                which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                  iobroker start
                  Iobroker status
                  ChrisNettC Offline
                  ChrisNettC Offline
                  ChrisNett
                  Iobroker status
                  Objects type: file
                  States  type: file
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.22.1
                  v12.22.1
                  6.14.12
                  nodejs:
                    Installiert:           12.22.1-1nodesource1
                    Installationskandidat: 12.22.1-1nodesource1
                    Versionstabelle:
                   *** 12.22.1-1nodesource1 500
                          500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                       10.24.0~dfsg-1~deb10u1 500
                  Thomas BraunT ChrisNettC 2 Antworten Letzte Antwort
                    Iobroker status
                    Objects type: file
                    States  type: file
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.1
                    v12.22.1
                    6.14.12
                    nodejs:
                      Versionstabelle:
                    Damn bringst du jetzt erstmal dein Betriebssystem auf Stand:
                    iobroker stop
                    sudo apt update
                    sudo apt dist-upgrade
                    sudo reboot
                      Iobroker status
                      Objects type: file
                      States  type: file
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.1
                      v12.22.1
                      6.14.12
                      nodejs:
                        Versionstabelle:
                      ChrisNettC Offline
                      ChrisNettC Offline
                      ChrisNett
                      im backitup adapter ist jetzt das aufgetaucht
                      Started restore ...
                      [DEBUG] [iobroker] Start ioBroker Restore ...
                      [EXIT] 0
                        Started restore ...
                        [EXIT] 0
                        ChrisNettC Offline
                        ChrisNettC Offline
                        ChrisNett
                        nach einiger zeit hier der log
                        brauchst du den log?
                          Ist dein OS jetzt gepatcht?
                            ChrisNettC Offline
                            ChrisNettC Offline
                            ChrisNett
                            pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy        nodejs
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.5
                            v12.22.5
                            6.14.14
                            nodejs:
                              Installiert:           12.22.5-1nodesource1
                              Installationskandidat: 12.22.5-1nodesource1
                              Versionstabelle:
                             *** 12.22.5-1nodesource1 500
                            pi@PI4:~ $
                            denke schon oder?
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v12.22.5
                              v12.22.5
                              6.14.14
                              nodejs:
                                Versionstabelle:
                              pi@PI4:~ $
                              denke schon oder?
                              Und wie ist jetzt der Status? Backup drin?
                                ChrisNettC Offline
                                ChrisNettC Offline
                                ChrisNett
                                nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
                                  ChrisNettC Offline
                                  ChrisNettC Offline
                                  ChrisNett
                                  kann ich mit putty versuchen ein bestimmtes einzuspielen?
                                    ChrisNettC Offline
                                    ChrisNettC Offline
                                    ChrisNett
                                    nach dem Neustart vom iobroker kommt dieser Fehler
                                    backitup.0
                                    2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
                                    der Adapter ist aber grün.
                                    • Thomas BraunT Online
                                      Installier den Adapter nochmal.
                                        ChrisNettC Offline
                                        ChrisNettC Offline
                                        ChrisNett
                                        als zweite Instanz ?
                                          Nein, über den Adapter drüber.
                                          iobroker upgrade backitup@2.1.13
