  4. Influx DB abgelehnt
    6.6k
Influx DB abgelehnt
influxdb
79 Beiträge 15 Kommentatoren 18.8k Aufrufe 12 Beobachtet
    @albi_63 sagte in Influx DB abgelehnt:
    Job for influxdb.service failed because the control process exited with error code.
    ich erinnere mich, es gab nach dem update beim PI ne Änderung, siehe https://www.reddit.com/r/influxdb/comments/ovulei/cant_start_influxdb_after_last_update/
    sudo chown -R influxdb:influxdb /usr/lib/influxdb
    albi_63
    @crunchip
    pi@raspberrypi-4:~ $ sudo systemctl status influxdb
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: activating (start) since Mon 2021-08-09 20:42:24 CEST; 608ms ago
         Docs: https://docs.influxdata.com/influxdb/
    Cntrl PID: 6850 (influxd-systemd)
        Tasks: 14 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               ├─6850 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
               ├─6851 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
               └─6881 sleep 1
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.853626Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.854913Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.867937Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.869383Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.874605Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.876170Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.897106Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.898455Z lvl=info
    Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.910176Z lvl=info
    • A albi_63
      @crunchip
      Aktuells LOG
      pi@raspberrypi-4:~ $ sudo service grafana-server stop
      pi@raspberrypi-4:~ $ sudo service grafana-server start
      pi@raspberrypi-4:~ $ sudo service grafana-server status
      ● grafana-server.service - Grafana instance
         Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vend
         Active: active (running) since Mon 2021-08-09 20:37:49 CEST; 41s ago
           Docs: http://docs.grafana.org
       Main PID: 4403 (grafana-server)
          Tasks: 12 (limit: 4915)
         CGroup: /system.slice/grafana-server.service
                 └─4403 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --p
      Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 l
      lines 1-19/19 (END)
         Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                 └─4403 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafan
      Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=info msg="Initializ
      Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=info msg="Backend r
      Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=warn msg="phantomJS
      Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=info msg="HTTP Serv
      crunchipC Offline
      crunchipC Offline
      @albi_63 da läuft es doch nun
      edit
      grafana
      aber dein influx noch nicht
      • ? Offline
        https://forum.iobroker.net/topic/46664/influxdb-startet-nach-update-nicht-mehr-31-01-20121?_=1628533276974
          albi_63
          @crunchip
          Leider nein
          Der Server läuft aber ich bekomme im IoBroker immer
          influxdb.0
          	2021-08-09 20:48:18.754	error	Error: connect ECONNREFUSED 127.0.0.1:8086
            crunchipC Offline
            crunchipC Offline
            @blechsoldat haben wir doch schon gemacht
            • A albi_63
              @crunchip
              Leider nein
              influxdb.0
              crunchipC Offline
              crunchipC Offline
              Der Server läuft
              mich stört aber das
              sollte so aussehen
               Active: active (running) since Sat 2021-08-07 07:47:32 CEST; 2 days ago
              guck dir mal das an https://community.influxdata.com/t/influxdb-1-8-7-will-not-start/20965/4
                Der Server läuft
                mich stört aber das
                sollte so aussehen
                albi_63
                @crunchip
                Könnte aber ein Rechteproblem sein nur bringt mir auch dieser Befehl nichts:
                sudo chown -R influxdb:influxdb /usr/lib/influxdb/*
                Wenn ich im IoBroker auf Verbindung testen gehe erhalte ich:
                • A albi_63
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  @albi_63 hab eins drüber nen link gepostet, da steht es wurde an der v 1.8.9 etwas am startscript geändert, les das mal durch und probier
                    albi_63
                    Habe jetzt mal einen Downgrade auf 1.8.8 gemacht mit dem gleichen Ergebnis😕
                    Für heute habe ich genug. Ich danke euch allen für eure Tips.
                    Ich muss mal eine oder zwei Nächte drüber schlafen......
                    • A albi_63
                      crunchipC Offline
                      crunchipC Offline
                      @albi_63 wenn dann zurück auf die 1.8.6, oder das startscript anpassen, denn in der status abfrage hast du da sowas stehn
                      └─6881 sleep 1
                      das gehört ebenfalls nicht dahin
                        └─6881 sleep 1
                        @crunchip Ich würde wohl die Version direkt aus dem Debian-Repo nehmen. Auch wenn das Debian-Philosophie bedingt nicht top aktuell ist. Aber da wird es dir so gut wie nie passieren, das da am Startskript herumgedoktort wird
                          crunchipC Offline
                          crunchipC Offline
                          @thomas-braun dem link zu urteilen gibt es da ja schon seit v1.8.7 Probleme, wundert mich, das nicht noch mehr hier Probleme haben
                          wenn ich aus dem ersten Post zitiere
                          "Ich habe heute mein Raspi 4 aktualisiert mit Admin 5 und js-controller 3.3."
                          vermute ich, das influx mit aktualisiert wurde
                            @crunchip
                            Wobei influxdb ja nicht notwendigerweise bei einem Upgrade von iobroker mit kommt. apt ist ja eine andere Baustelle. Gut, wenn man den 'ich-update-einmal-im-Jahr-alles'-Kurs fährt... 😀
                              bloop
                              Hatte gestern exact das selbe problem. Hab alles versucht und konnte den Fehler nicht finden.
                              Auch eine einfache neu Installation hat nichts gebracht.
                              Am ende hab ich den Ordner var/lib/influxdb umbenannt/gelöscht und anschließend neu installiert und konfiguriert. Jetzt funktioniert wieder alles.
                              Leider sind natürlich sämtliche Daten weg da ich von Influx zu dem Zeitpunkt noch kein Backup gemacht habe. Lief aber e erst gut eine Woche.
                              • B bloop
                                @bloop sagte in Influx DB abgelehnt:
                                Das ist wenig Linux, mehr Windows-Style. Und funktioniert in der Regel auch nicht unter Linux
                                  bloop
                                  schrieb am zuletzt editiert von bloop
                                  Zumindest war es mir so möglich das Problem zu finden...
                                  Nachdem ich über zwei Stunden gesucht und diverse Foren durchwälzt habe, sah ich dies als meinen einzigen Ausweg. (Es sind nicht alles Experten im Umgang mit Linux ). Zumindest hats geklappt und ich hab was draus gelernt ;)
                                  • B bloop
                                    @bloop
                                    Das nützt dir halt nix, wenn die config (wie sonst üblich) unter /etc liegt. Da kannst du binairies löschen bis du lila wirst. Influxdb macht das offenbar dann anders.
                                    • P Offline
                                      Pupsimupsi
                                      ich habe aktuell das gleiche Problem...
                                      Influx läuft auf mit iobroker zusammen auf dem gleichen System.
                                      Seit ein paar Stunden bekommen ich keine Verbindung mehr...
                                      Rechte anpassen usw. alles schon probiert.
                                      Hatte kurz zurvor in der influx config die bind-adresse für RCP auf 127.0.0.1:8088 geändert und einkommentiert.
                                      Seitdem geht nichts mehr. Kann das damit zurun haben?
                                      pi@raspberrypi:~ $ sudo systemctl stop influxdb
                                      pi@raspberrypi:~ $ sudo systemctl daemon-reload
                                      pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
                                      pi@raspberrypi:~ $ sudo systemctl enable influxdb
                                      pi@raspberrypi:~ $ sudo systemctl start influxdb
                                      See "systemctl status influxdb.service" and "journalctl -xe" for details.
                                      pi@raspberrypi:~ $ sudo systemctl status influxdb
                                         Active: activating (start) since Mon 2021-08-09 22:45:20 CEST; 10s ago
                                      Cntrl PID: 6629 (influxd-systemd)
                                          Tasks: 15 (limit: 4915)
                                                 ├─6629 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.s
                                                 ├─6631 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                                 └─6790 sleep 1
                                      Aug 09 22:45:30 raspberrypi influxd-systemd-start.sh[6629]: ts=2021-08-09T20:45:
                                      lines 1-21/21 (END)
                                      iobroker wirft:
                                      influxdb.0
                                      	2021-08-09 22:51:02.184	error	Error: connect ECONNREFUSED 192.168.178.161:8086
                                      • P Pupsimupsi
                                                   └─6790 sleep 1
                                        lines 1-21/21 (END)
                                        iobroker wirft:
                                        influxdb.0
                                        crunchipC Offline
                                        crunchipC Offline
                                        @pupsimupsi sagte in Influx DB abgelehnt:
                                        mach mal ein 0.0.0.0:8088
                                        P 1 Antwort Letzte Antwort
                                          Pupsimupsi
                                          schrieb am zuletzt editiert von Pupsimupsi
                                          @crunchip
                                          Hab ich gemacht.
                                          Nach Startversuch weiterhin:
                                          pi@raspberrypi:~ $ sudo nano /etc/influxdb/influxdb.conf
                                          pi@raspberrypi:~ $ sudo systemctl restart influxdb
                                          pi@raspberrypi:~ $
                                          Auch nochmals alle Befehle der Reihe nach abarbeiten bring das gleiche Fehlerbild.
                                          Bin echt am verzweifeln... :(
                                          Das lief doch bis ich das an der bind-adresse gefummelt habe...nur ein dummer Zufall oder hab ich da noch was verbögt?
