  4. Influx DB abgelehnt
    6.6k
Influx DB abgelehnt
influxdb
79 Beiträge 15 Kommentatoren 18.8k Aufrufe 12 Beobachtet
  • A albi_63
    @crunchip
    Die läuft auf meinem Raspi4
    Folgendes kommt zurück
    pi@raspberrypi-4:~ $ sudo systemctl status influxdb
    ● influxdb.service - InfluxDB is an open-source, distributed, time series databa
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset:
       Active: activating (start) since Mon 2021-08-09 19:53:39 CEST; 869ms ago
         Docs: https://docs.influxdata.com/influxdb/
    Cntrl PID: 3868 (influxd-systemd)
        Tasks: 14 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               ├─3868 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.s
               ├─3869 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
               └─3898 sleep 1
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:5
    lines 1-21/21 (END)...skipping...
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
               ├─3868 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
               └─3898 sleep 1
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.030148Z lvl=info msg="Opened shard" log_id=0
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.034577Z lvl=info msg="Opened shard" log_id=0
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.038945Z lvl=info msg="Opened file" log_id=0V
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.039547Z lvl=info msg="Opened file" log_id=0V
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.069378Z lvl=info msg="Opened shard" log_id=0
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.073503Z lvl=info msg="Opened file" log_id=0V
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.109773Z lvl=info msg="Opened shard" log_id=0
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.111716Z lvl=info msg="Opened file" log_id=0V
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.112566Z lvl=info msg="Opened shard" log_id=0
    Aug 09 19:53:40 raspberrypi-4 influxd-systemd-start.sh[3868]: ts=2021-08-09T17:53:40.113951Z lvl=info msg="Opened file" log_id=0V
    crunchipC Abwesend
    crunchipC Abwesend
    @albi_63
    sudo systemctl start influxdb
    und danach nochmal
      @albi_63
      und danach nochmal
      albi_63
      @crunchip
      pi@raspberrypi-4:~ $ sudo systemctl start influxdb
      Job for influxdb.service failed because the control process exited with error co                                de.
      See "systemctl status influxdb.service" and "journalctl -xe" for details.
         Active: activating (start) since Mon 2021-08-09 20:03:10 CEST; 4s ago
      Cntrl PID: 9061 (influxd-systemd)
                 ├─9061 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                 ├─9062 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                 └─9117 sleep 1
      Aug 09 20:03:11 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:11.987162Z lvl=info msg="Opene
      Aug 09 20:03:11 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:11.988535Z lvl=info msg="Opene
      Aug 09 20:03:11 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:11.990493Z lvl=info msg="Opene
      Aug 09 20:03:11 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:11.992701Z lvl=info msg="Opene
      Aug 09 20:03:12 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:12.011117Z lvl=info msg="Opene
      Aug 09 20:03:12 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:12.013498Z lvl=info msg="Opene
      Aug 09 20:03:12 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:12.026994Z lvl=info msg="Opene
      Aug 09 20:03:12 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:12.033842Z lvl=info msg="Opene
      Aug 09 20:03:12 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:12.530789Z lvl=info msg="Opene
      Aug 09 20:03:14 raspberrypi-4 influxd-systemd-start.sh[9061]: ts=2021-08-09T18:03:14.776764Z lvl=info msg="Readi
      lines 1-21/21 (END)
      • A albi_63
        @crunchip
                   └─9117 sleep 1
        lines 1-21/21 (END)
        crunchipC Abwesend
        crunchipC Abwesend
        @albi_63 welche version von influx läuft da?
        apt policy influxdb
          apt policy influxdb
          albi_63
          @crunchip
          pi@raspberrypi-4:~ $ apt policy influxdb
          influxdb:
            Installiert:           1.8.9-1
            Installationskandidat: 1.8.9-1
            Versionstabelle:
           *** 1.8.9-1 500
                  500 https://repos.influxdata.com/debian buster/stable armhf Packages
               1.6.4-1+deb10u1 500
          crunchipC Thomas BraunT 2 Antworten Letzte Antwort
          • A albi_63
            @crunchip
            influxdb:
              Versionstabelle:
             *** 1.8.9-1 500
                 1.6.4-1+deb10u1 500
            crunchipC Abwesend
            crunchipC Abwesend
            @albi_63 ok passt
            probier mal nach der Reihe, eins nach dem anderen
            sudo systemctl stop influxdb
            sudo systemctl daemon-reload
            sudo systemctl unmask influxdb.service
            sudo systemctl enable influxdb
            • A albi_63
              @crunchip
              influxdb:
                Versionstabelle:
               *** 1.8.9-1 500
                   1.6.4-1+deb10u1 500
              @albi_63
              Und woher kommt dann eine influxdb.0 v1.9.5 ?
              (Edith:) Sorry, war die Adapterversion...
                @albi_63
                crunchipC Abwesend
                crunchipC Abwesend
                @thomas-braun der Adapter
                  @albi_63 ok passt
                  albi_63
                  @crunchip
                  Kriege denselben Fehler beim Start
                  pi@raspberrypi-4:~ $ sudo systemctl stop influxdb
                  pi@raspberrypi-4:~ $ sudo systemctl daemon-reload
                  pi@raspberrypi-4:~ $ sudo systemctl unmask influxdb.service
                  pi@raspberrypi-4:~ $ sudo systemctl enable influxdb
                  Job for influxdb.service failed because the control process exited with error code.
                  • A albi_63
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @albi_63 sagte in Influx DB abgelehnt:
                    ich erinnere mich, es gab nach dem update beim PI ne Änderung, siehe https://www.reddit.com/r/influxdb/comments/ovulei/cant_start_influxdb_after_last_update/
                    sudo chown -R influxdb:influxdb /usr/lib/influxdb
                    A 4 Antworten Letzte Antwort
                      albi_63
                      @crunchip
                      ich starte mal den pi neu
                      Habe deinen Befehl mal abgesetzt mit folgendere Mldung
                      pi@raspberrypi-4:~ $ sudo chown -R influxdb:influxdb /usr/lib/influxdb
                         Active: activating (start) since Mon 2021-08-09 20:30:32 CEST; 7s ago
                      Cntrl PID: 23741 (influxd-systemd)
                                 ├─23741 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.
                                 ├─23742 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                 └─23809 sleep 1
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:
                      Aug 09 20:30:36 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:
                                 ├─23741 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                                 └─23809 sleep 1
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.169851Z lvl=info msg="Opened shard
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.172000Z lvl=info msg="Opened file"
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.182599Z lvl=info msg="Opened shard
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.186909Z lvl=info msg="Opened file"
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.210084Z lvl=info msg="Opened shard
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.211484Z lvl=info msg="Opened file"
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.216219Z lvl=info msg="Opened shard
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.226941Z lvl=info msg="Opened shard
                      Aug 09 20:30:34 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:34.715741Z lvl=info msg="Opened shard
                      Aug 09 20:30:36 raspberrypi-4 influxd-systemd-start.sh[23741]: ts=2021-08-09T18:30:36.901402Z lvl=info msg="Reading file
                        albi_63
                        @crunchip
                        Aktuells LOG
                        pi@raspberrypi-4:~ $ sudo service grafana-server stop
                        pi@raspberrypi-4:~ $ sudo service grafana-server start
                        pi@raspberrypi-4:~ $ sudo service grafana-server status
                        ● grafana-server.service - Grafana instance
                           Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vend
                           Active: active (running) since Mon 2021-08-09 20:37:49 CEST; 41s ago
                             Docs: http://docs.grafana.org
                         Main PID: 4403 (grafana-server)
                            Tasks: 12 (limit: 4915)
                           CGroup: /system.slice/grafana-server.service
                                   └─4403 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --p
                        Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 l
                        lines 1-19/19 (END)
                           Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                                   └─4403 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafan
                        Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=info msg="Initializ
                        Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=info msg="Backend r
                        Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=warn msg="phantomJS
                        Aug 09 20:37:50 raspberrypi-4 grafana-server[4403]: t=2021-08-09T20:37:50+0200 lvl=info msg="HTTP Serv
                          albi_63
                          @crunchip
                             Active: activating (start) since Mon 2021-08-09 20:42:24 CEST; 608ms ago
                          Cntrl PID: 6850 (influxd-systemd)
                                     ├─6850 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                                     ├─6851 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                     └─6881 sleep 1
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.853626Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.854913Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.867937Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.869383Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.874605Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.876170Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.897106Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.898455Z lvl=info
                          Aug 09 20:42:24 raspberrypi-4 influxd-systemd-start.sh[6850]: ts=2021-08-09T18:42:24.910176Z lvl=info
                          • A albi_63
                            @crunchip
                            Aktuells LOG
                            lines 1-19/19 (END)
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @albi_63 da läuft es doch nun
                            edit
                            grafana
                            aber dein influx noch nicht
                            • ? Offline
                              https://forum.iobroker.net/topic/46664/influxdb-startet-nach-update-nicht-mehr-31-01-20121?_=1628533276974
                                albi_63
                                @crunchip
                                Leider nein
                                Der Server läuft aber ich bekomme im IoBroker immer
                                influxdb.0
                                	2021-08-09 20:48:18.754	error	Error: connect ECONNREFUSED 127.0.0.1:8086
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @blechsoldat haben wir doch schon gemacht
                                  • A albi_63
                                    @crunchip
                                    Leider nein
                                    influxdb.0
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    Der Server läuft
                                    mich stört aber das
                                    sollte so aussehen
                                     Active: active (running) since Sat 2021-08-07 07:47:32 CEST; 2 days ago
                                    guck dir mal das an https://community.influxdata.com/t/influxdb-1-8-7-will-not-start/20965/4
                                      Der Server läuft
                                      mich stört aber das
                                      sollte so aussehen
                                      albi_63
                                      @crunchip
                                      Könnte aber ein Rechteproblem sein nur bringt mir auch dieser Befehl nichts:
                                      sudo chown -R influxdb:influxdb /usr/lib/influxdb/*
                                      Wenn ich im IoBroker auf Verbindung testen gehe erhalte ich:
                                      • A albi_63
                                        @crunchip
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @albi_63 hab eins drüber nen link gepostet, da steht es wurde an der v 1.8.9 etwas am startscript geändert, les das mal durch und probier
                                          albi_63
                                          Habe jetzt mal einen Downgrade auf 1.8.8 gemacht mit dem gleichen Ergebnis😕
                                          Für heute habe ich genug. Ich danke euch allen für eure Tips.
                                          Ich muss mal eine oder zwei Nächte drüber schlafen......
