  4. Admin v5.1.23 Fehler
    6.4k
25 Beiträge 4 Kommentatoren 3.2k Aufrufe 4 Beobachtet
    @matthiab
    Könntest du bitte die kompletten Ein- und Ausgabezeilen Posten?
    MatthiaB
    admin.0
    2021-08-08 15:22:05.746 warn State "admin.0.info.connection" has no existing object, this might lead to an error in future versions
    • M MatthiaB
      host.raspberrypi
      2021-08-08 15:20:26.084 info Restart adapter system.adapter.shelly.0 because enabled
      host.raspberrypi
      2021-08-08 15:20:26.084 info instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
      shelly.0
      2021-08-08 15:20:25.857 info Starting Shelly adapter in CoAP modus.
      shelly.0
      2021-08-08 15:20:25.815 info Starting Adapter shelly.0 in version 4.0.7
      shelly.0
      2021-08-08 15:20:25.777 info starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.3.15
      @matthiab
      Das ist a) nicht die komplette Ein- und Ausgabe und b) fehlen die CodeTags um den Text.
        @matthiab
        MatthiaB
        pi@raspberrypi:~ $ iob list adapters
        system.adapter.admin                   : admin          - v4.2.2
        system.adapter.backitup                : backitup       - v2.1.13
        system.adapter.discovery               : discovery      - v2.7.0
        system.adapter.flot                    : flot           - v1.10.6
        system.adapter.fritzdect               : fritzdect      - v2.1.15
        system.adapter.habpanel                : habpanel       - v0.4.3
        system.adapter.history                 : history        - v1.9.13
        system.adapter.icons-icons8            : icons-icons8   - v0.0.1
        system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
        system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
        system.adapter.influxdb                : influxdb       - v1.9.5
        system.adapter.info                    : info           - v1.7.14
        system.adapter.javascript              : javascript     - v5.1.3
        system.adapter.logparser               : logparser      - v1.1.0
        system.adapter.mqtt                    : mqtt           - v2.4.0
        system.adapter.shelly                  : shelly         - v4.0.7
        system.adapter.simple-api              : simple-api     - v2.6.1
        system.adapter.socketio                : socketio       - v3.1.4
        system.adapter.sonoff                  : sonoff         - v2.4.0
        system.adapter.sourceanalytix          : sourceanalytix - v0.4.8
        system.adapter.sql                     : sql            - v1.15.7
        system.adapter.statistics              : statistics     - v1.0.4
        system.adapter.telegram                : telegram       - v1.9.0
        system.adapter.text2command            : text2command   - v2.1.1
        system.adapter.tr-064                  : tr-064         - v4.2.12
        system.adapter.vis                     : vis            - v1.4.3
        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
        system.adapter.vis-inventwo            : vis-inventwo   - v3.0.11
        system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
        system.adapter.vis-map                 : vis-map        - v1.0.4
        system.adapter.vis-materialdesign      : vis-materialdesign - v0.4.2
        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
        system.adapter.vw-connect              : vw-connect     - v0.0.39
        system.adapter.web                     : web            - v3.4.1
        system.adapter.worx                    : worx           - v1.3.6
        pi@raspberrypi:~ $ iob list instances
        + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                                               n
        + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi        - disabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi        -  enabled
          system.adapter.habpanel.0               : habpanel              : raspberrypi        - disabled
        + system.adapter.history.0                : history               : raspberrypi        -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi        - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi        - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ras                                               pberrypi                              - disabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
        + system.adapter.logparser.0              : logparser             : raspberrypi        -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1886, bind: 0.0.0.0
          system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.socketio.0               : socketio              : raspberrypi        -  enabled, port: 8084, bind: 192.168.178.30, run a                                               s: admin
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi        -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi        -  enabled
        + system.adapter.sql.0                    : sql                   : raspberrypi        -  enabled, port: 0
        + system.adapter.sql.1                    : sql                   : raspberrypi        -  enabled, port: 0
        + system.adapter.statistics.0             : statistics            : raspberrypi        -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi        -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : raspberrypi        -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi        -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi        - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi        - disabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi        - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi        - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi        - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : raspberrypi        -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                                               n
        + system.adapter.worx.0                   : worx                  : raspberrypi        -  enabled
        + instance is alive
        pi@raspberrypi:~ $ iob update
        hash changed or no sources cached => force download of new sources
        update done
        Adapter    "admin"         : 5.1.23   , installed 5.1.23
        Adapter    "backitup"      : 2.1.13   , installed 2.1.13
        Adapter    "discovery"     : 2.7.0    , installed 2.7.0
        Adapter    "flot"          : 1.10.6   , installed 1.10.6
        Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
        Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
        Adapter    "history"       : 1.9.13   , installed 1.9.13
        Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
        Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
        Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
        Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
        Adapter    "info"          : 1.9.8    , installed 1.9.8
        Adapter    "javascript"    : 5.2.8    , installed 5.2.8
        Controller "js-controller" : 3.3.15   , installed 3.3.15
        Adapter    "logparser"     : 1.1.0    , installed 1.1.0
        Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
        Adapter    "shelly"        : 4.0.7    , installed 4.0.7
        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
        Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
        Adapter    "sql"           : 1.15.7   , installed 1.15.7
        Adapter    "statistics"    : 1.0.9    , installed 1.0.9
        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
        Adapter    "text2command"  : 2.1.1    , installed 2.1.1
        Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
        Adapter    "vis"           : 1.4.3    , installed 1.4.3
        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
        Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
        Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
        Adapter    "vw-connect"    : 0.0.39   , installed 0.0.39
        Adapter    "web"           : 3.4.7    , installed 3.4.7
        Adapter    "worx"          : 1.4.3    , installed 1.4.3
        • M MatthiaB
          + instance is alive
          update done
          @matthiab
          iobroker upload all
            @matthiab
            iobroker upload all
            MatthiaB
            habe ich durchgeführt, nun stimmt zumindest die Version des Admin-Adapters.
            Shelly geht weiterhin nicht, SourceAnalytics geht soweit, kann aber nicht mehr konfigurtiert werden
            Cannot load jsonConfig of sourceanalytix: Not exists
            • M MatthiaB
              @matthiab
              Und was steht im LogFile, wenn man den jeweiligen Adapter neustartet?
                @matthiab
                MatthiaB
                host.raspberrypi
                	2021-08-08 21:50:20.483	info	Restart adapter system.adapter.shelly.0 because enabled
                host.raspberrypi
                	2021-08-08 21:50:20.480	info	instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                shelly.0
                	2021-08-08 21:50:20.219	info	Starting Shelly adapter in CoAP modus.
                shelly.0
                	2021-08-08 21:50:20.177	info	Starting Adapter shelly.0 in version 4.0.7
                shelly.0
                	2021-08-08 21:50:20.136	info	starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.3.15
                Der SourceAnalytixs Adapter läuft ganz normal zeigt beim Neustart nur Feher bei einem Objekt an.
                sourceanalytix.0
                	2021-08-08 21:51:38.701	error	Cannot handle initialisation for javascript.0.Eigene.Bewässerung.Verbrauch.WasseruhrAktuell
                sourceanalytix.0
                	2021-08-08 21:51:27.979	error	Please choose unit manually in state configuration
                sourceanalytix.0
                	2021-08-08 21:51:27.979	error	No unit defined for javascript.0.Eigene.fb_kmStand2, cannot execute calculations !
                sourceanalytix.0
                	2021-08-08 21:51:27.958	error	Please choose unit manually in state configuration
                sourceanalytix.0
                	2021-08-08 21:51:27.956	error	No unit defined for javascript.0.Eigene.Bewässerung.Verbrauch.WasseruhrAktuell, cannot execute calculations !
                • M MatthiaB
                  host.raspberrypi
                  host.raspberrypi
                  shelly.0
                  shelly.0
                  shelly.0
                  sourceanalytix.0
                  sourceanalytix.0
                  sourceanalytix.0
                  sourceanalytix.0
                  sourceanalytix.0
                  @matthiab
                  Fällt mir zu beiden nix ein, habe ich nicht im Einsatz.
                    @matthiab
                    MatthiaB
                    okay danke,
                    wenigstens lässt sich der Aktor über einen HTTP-Befehl noch steuern.
                    • M MatthiaB
                      host.raspberrypi
                      host.raspberrypi
                      shelly.0
                      shelly.0
                      shelly.0
                      sourceanalytix.0
                      sourceanalytix.0
                      sourceanalytix.0
                      sourceanalytix.0
                      sourceanalytix.0
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @matthiab sagte in Admin v5.1.23 Fehler:
                      bei 2 Objekte, einmal hast du SA zweckenfremdet "Eigene.fb_kmStand2" dafür gibt es keine Unit, daher auch die Meldung "cannot execute calculations"
                      und zum anderen hast du scheinbar die unit nicht angegeben, bei "Eigene.Bewässerung.Verbrauch.WasseruhrAktuell"
                        MatthiaB
                        @crunchip
                        Moin.
                        Der Adapter lässt sich nicht mehr für Objekte konfigurieren. Es fehlt einfach in der Auswahl.
                        • M MatthiaB
                          @crunchip
                          Moin.
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @matthiab ja, du hattest ja geschrieben
                          wie man das behebt, weiss ich leider nicht
                          Edit: welche version ist installiert?
                          siehe https://github.com/ioBroker/ioBroker.admin/issues/965
                          und wenn wir schon dabei sind, dein shelly Adapter auch updaten, aktuell ist v4.0.8, du hast 4.0.7
                            MatthiaB
                            @crunchip
                            sourceAnalytix ist mit demUpdate wieder da, beim Shelly ist plötzlich eine Version 4.0.9. Beta drauf, aber auch hier keine Verbindung zum Host, kein Lebenszeichen.
                            Verbunden mit Geräte oder Dienst ist grün.
                            Daten werden aber nicht aktualisiert :(
                            da_WoodyD crunchipC 2 Antworten Letzte Antwort
                            • M MatthiaB
                              @crunchip
                              da_WoodyD Online
                              da_WoodyD Online
                              @matthiab hast du aktuelle FW auf den shellys? vom mcast auf unicast umgestellt?
                              die 4.0.9beta ist die 4.0.8.
                              • M MatthiaB
                                @crunchip
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @matthiab dann weiter im shelly thread oder einen eigenen aufmachen, denn das hat eigentlich nicht mit Admin Fehler zu tun
                                  MatthiaB
                                  schrieb am zuletzt editiert von MatthiaB
                                  @crunchip
                                  die Probleme fingen ja damit an, zumindestens glaube ich das. Ich habe den Adapter auf mqtt umgestellt, zumindestens ist die instance grün. Schauen wir ob es Daten gibt.
                                  ein Shelly funkt auf mqtt, bei den anderen ist das nicht eingestellt, aber die Datenpunkte sind sehr rar
                                  • da_WoodyD da_Woody
                                    MatthiaB
                                    @da_woody
                                    soll ich suf unicast umstellen oder war das eine Frage ob ich das gemacht haben?
                                    Bei mir steht mcast, ich habe an den Einstellungen nichts verändert.
                                    • M MatthiaB
                                      @crunchip
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      das shelly Problem gab es schon vorher, daher
                                      auf unicast umstellen
                                      • da_WoodyD Online
                                        da_WoodyD Online
                                        @matthiab sorry, hab das jetzt schon so oft erklärt in diversen shelly beiträgen.
                                        wie gesagt, hat nichts mit dem admin zu tun, also suchen, oder neuen beitrag aufmachen.
