  4. Iobroker Sicherung nicht möglich
    6.7k
35 Beiträge 5 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • T TinoNikol
    Jetzt kommt das?
    pi@raspberrypi:~ $ iobroker backup
    host.raspberrypi 6606 states saved
    host.raspberrypi 7651 objects saved
    Objects database error: read ECONNRESET
    Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    States database error: connect ECONNREFUSED 127.0.0.1:9000
    @tinonikol
    iobroker status
      @tinonikol
      iobroker status
      TinoNikol
      pi@raspberrypi:~ $ iobroker status
      Objects type: file
      States  type: file
      • T TinoNikol
        Objects type: file
        States  type: file
        simatecS Offline
        simatecS Offline
        simatec
        @tinonikol
        Zeige mal bitte die Ausgabe von
        df -h
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          @tinonikol
          df -h
          TinoNikol
          @simatec
          pi@raspberrypi:~ $ df -h
          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
          /dev/root        59G     12G   45G   21% /
          devtmpfs        1,8G       0  1,8G    0% /dev
          tmpfs           1,9G       0  1,9G    0% /dev/shm
          tmpfs           1,9G    8,5M  1,9G    1% /run
          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
          tmpfs           1,9G       0  1,9G    0% /sys/fs/cgroup
          /dev/mmcblk0p1  253M     48M  205M   19% /boot
          tmpfs           383M       0  383M    0% /run/user/1000
          pi@raspberrypi:~ $
          • T TinoNikol
            Hi evtl. kann mir hier jemand helfen ich bekomme ständig diese Meldung beim Versuch Iobroker Sicherung zu machen!
            permitted by applicable law.
            Last login: Fri Jul 23 12:58:15 2021 from 192.168.178.46
            pi@raspberrypi:~ $ iobroker stop
            pi@raspberrypi:~ $ sudo iobroker backup
            host.raspberrypi 6429 states saved
            host.raspberrypi 7476 objects saved
            internal/buffer.js:956
                super(bufferOrLength, byteOffset, length);
            RangeError: Array buffer allocation failed
                at arrayBufferConstructor_DoNotInitialize (<anonymous>)
                at new Uint8Array (<anonymous>)
                at new FastBuffer (internal/buffer.js:956:5)
                at fromArrayLike (buffer.js:501:10)
                at fromObject (buffer.js:509:12)
                at Function.from (buffer.js:318:15)
                at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemServerRedis.js:452:60)
                at RedisHandler.emit (events.js:375:28)
                at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js:100:37)
                at processImmediate (internal/timers.js:464:21)
            pi@raspberrypi:~ $
            TinoNikol
            @tinonikol said in Iobroker Sicherung nicht möglich:
            pi@raspberrypi:~ $
            Keiner mehr einen vorschlag?
            • T TinoNikol
              pi@raspberrypi:~ $
              @tinonikol
              Da wird nicht mit sudo herumhantiert!
                @tinonikol
                TinoNikol
                @thomas-braun Ja ich weiß es nun, danke!
                Thomas BraunT H 2 Antworten Letzte Antwort
                • T TinoNikol
                  @tinonikol
                  Schau Mal nach dem 'Mini-HowTo' vielleicht funktioniert das hier auch.
                  • T TinoNikol
                    Heisenberg0709
                    schrieb am zuletzt editiert von Heisenberg0709
                    @tinonikol
                    konntest du deinem Problem Abhilfe schaffen?
                    Ich habe aktuell scheinbar ein ähnliches Problem...
                    Beste Grüße
                    • H Heisenberg0709
                      @tinonikol
                      Beste Grüße
                      @heisenberg0709 sagte in Iobroker Sicherung nicht möglich:
                      @tinonikol
                      Beste Grüße
                      Das hatten wir doch schon im anderen Thread von dir
                      H 1 Antwort Letzte Antwort
                        @tinonikol
                        Beste Grüße
                        Heisenberg0709
                        genau deswegen hatte ich hier ja nochmal gefragt, ob es ggf. hierfür einen Lösungsansatz gab/gibt,
                        • H Heisenberg0709
                          @heisenberg0709
                          Ja, das Mini-HowTo vielleicht:
                          https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1627985679112
                          • H Heisenberg0709
                            den hatten wir dir doch hier schon genannt:
                            https://forum.iobroker.net/topic/46660/backupit-keine-iobroker-backups-möglich/26?_=1627985833432
                            und hat uns nicht weitergebracht
                              Heisenberg0709
                              @Thomas-Braun
                              ja, das Mini How-To habt ihr mir genannt, dass hatte ich auch durchgeführt, leider ohne Erfolg/Änderungen an der Problematik.
                              deswegen hatte ich hier nochmal @TinoNikol gefragt, ob er ggf. schon weiter ist oder ob das Problem bei ihm noch besteht :-)
                              oder wurde hier das Problem mit dem Mini HowTo gelöst?
