  4. Test Adapter Growatt v3.3.1
adaptergrowattpv-anlageshinesolartesttester
808 Beiträge 72 Kommentatoren 492.2k Aufrufe 63 Beobachtet
  • PLCHome 0P PLCHome 0
    @ra65ma tja was soll ich sagen, ich hab keinen Plan. Irgendwas läuft schief, aber was kann ich dir mit den Informationen nicht sagen. Sonst stelle den Adapter nach Silly und Poste das Log vom Verbindungsaufbau bis zum ersten Zyklus.
    R
    R
    ra65ma
    #70
    @plchome-0 logfile
    R 1 Antwort Letzte Antwort
    • R ra65ma
      @plchome-0 logfile
      R
      R
      ra65ma
      #71
      @ra65ma ```
      growatt.0 2021-06-29 16:24:54.757 debug (22467) Growatt connected true
      growatt.0 2021-06-29 16:24:54.661 debug (22467) Growatt share plant login
      growatt.0 2021-06-29 16:24:24.463 debug (22467) Growatt connected true
      growatt.0 2021-06-29 16:24:24.362 debug (22467) Growatt share plant login
      growatt.0 2021-06-29 16:23:58.043 debug (22467) system.adapter.admin.0: logging true
      growatt.0 2021-06-29 16:23:58.042 silly (22467) States system redis pmessage *.logging/system.adapter.admin.0.logging:{"val":true,"ack":true,"ts":1624976638027,"q":0,"from":"system.adapter.admin.0","lc":1624976638027}
      growatt.0 2021-06-29 16:23:54.180 debug (22467) Growatt connected true
      growatt.0 2021-06-29 16:23:53.955 silly (22467) States system redis pmessage system.adapter.growatt.0.logLevel/system.adapter.growatt.0.logLevel:{"val":"silly","ack":true,"ts":1624976633754,"q":0,"from":"system.adapter.growatt.0","lc":1624
      growatt.0 2021-06-29 16:23:53.836 debug (22467) Growatt share plant login
      growatt.0 2021-06-29 16:23:53.679 info (22467) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.growatt, node: v10.15.2, js-controller: 3.1.6
      growatt.0 2021-06-29 16:23:53.002 debug (22467) statesDB connected
      growatt.0 2021-06-29 16:23:53.000 debug (22467) States connected to redis: 127.0.0.1:9000
      growatt.0 2021-06-29 16:23:52.980 debug (22467) States create System PubSub Client
      growatt.0 2021-06-29 16:23:52.975 debug (22467) States create User PubSub Client
      growatt.0 2021-06-29 16:23:52.960 debug (22467) Redis States: Use Redis connection: 127.0.0.1:9000
      growatt.0 2021-06-29 16:23:52.952 debug (22467) objectDB connected
      growatt.0 2021-06-29 16:23:52.928 debug (22467) Objects connected to redis: 127.0.0.1:9001
      growatt.0 2021-06-29 16:23:52.893 debug (22467) Objects client initialize lua scripts
      growatt.0 2021-06-29 16:23:52.891 debug (22467) Objects create User PubSub Client
      growatt.0 2021-06-29 16:23:52.888 debug (22467) Objects create System PubSub Client
      growatt.0 2021-06-29 16:23:52.875 debug (22467) Objects client ready ... initialize now
      PLCHome 0P 1 Antwort Letzte Antwort
      • R ra65ma
        @ra65ma ```
        PLCHome 0P
        PLCHome 0P
        PLCHome 0
        #72
        @ra65ma Das log sieht aus als wenn du eine Key verwendest. Probiere bitte mal ob der Key noch funktioniert. Oder erneuere den mal bitte ich glaube der ist Abgelaufen oder ungültig. Ich hatte diese Erscheinung auch schon mal der Login ging es kamen aber keine Daten mehr. Beim Aufruf der URL zeigte die Webseite keine Daten mehr.
          R
          R
          ra65ma
          #73
          @plchome-0 Hallo,
          das war der entscheidende Tipp. Danke. Der Token war abgelaufen. Dennoch war der Connect immer noch vorhanden. Sollte jemand das selbe Problem haben, bei dem die Objekte beim Growatt Adapter nicht mehr aktualisiert werden, dennoch die Verbindung aber online ist, einfach einen neuen Token auf der Webseite unter Energie=>Kraftwerksverwaltung=>Bedienung, den Button "Kraftwerk teilen" drücken, einen neuen Token erzeugen.
          • R ra65ma
            @plchome-0 Hallo,
            PLCHome 0P
            PLCHome 0P
            PLCHome 0
            #74
            @ra65ma vielleicht magst du mir den Abgelaufenen Token einmal per PN zur Verfügung stellen. Vielleicht kann ich ja eine Fehlermeldung erzeugen. Ich bin ja auch daran interessiert den Adapter besser zu machen...
            • M
              M
              magix
              #75
              das Timeout Problem besteht bei mir immer noch und wird gefühlt immer schlimmer.
              Habe pro Tag ca. 32 mal Timeout Einträge im Log.
              2021-07-23 14:26:14.579 - error: growatt.0 (15981) Login:{"message":"timeout of 5000ms exceeded","name":"Error","stack":"Error: timeout of 5000ms
              2021-07-23 14:26:14.583 - info: growatt.0 (15981) not connected
              Kann das jemand bestäigen oder liegt das Problem doch bei mir wo?
              • M magix
                #76
                @magix
                Ich hbae diese Meldung 2 x. Einmal bei der DSL Trennung und einmal wenn ich den PC Anschalte.
                Warum ? Keine Ahnung. Muss irgendwas mit diesem Neuland Dings sein von dem alle Reden.
                  Ich habe einen Weg gefunden, den Logger von 5 Min auf 1 Min zustellen.
                  Vielleicht möcht das jemand testen und Rückmeldung geben.
                  Den Gummi vor dem KEY Button des ShineWiFi-S entfernen und den Button kurz drücken.
                  Der ShineWiFi-S spielt nun kurz Hotspot (SSID = Seriennummer des ShineWiFi-S). Beim Netz mit einem Laptop oder dem Handy anmelden.
                  Einloggen
                  als Webadresse http://192.168.10.100 in der Browser eingeben.
                  Der Username ist Admin und das Passwort 12345678 (sollte man gleich auch mal ändern, geht in System Management)
                  Advanced Settings
                  auf "Advanced Settings" gehen und das Intervall ändern. (von 5 auf 1)
                  Neustart
                  auf System Restart gehen und Button herzhaft, aber vorsichtig Klicken.
                  Links 5 Minuten-Raster rechts 1 Minuten Raster. Gestern war auch wenig Sonne
                  A
                  A
                  Alveran
                  #77
                  @plchome-0
                  Erstmal ein großes Lob für den Klasse Adapter. Eine Frage hätte ich noch. Ich möchte den Logger auf 1s setzen. Wenn ich den Button am WiFi Stick drücke und der Stick das WLAN mit seiner Seriennummer öffnet ist das bei mir Passwort geschützt. Hat jemand eine Ahnung wie das Passwort lautet.
                  • A Alveran
                    @plchome-0
                    PLCHome 0P
                    PLCHome 0P
                    PLCHome 0
                    schrieb am zuletzt editiert von PLCHome 0
                    #78
                    @alveran
                    Einfach die Anleitung lesen?
                    Wenn es nicht 12345678 ist, hat es wohl jemand geändert...
                    Eine Sekunde geht leider nicht, nur eine Minute....
                      @alveran
                      A
                      A
                      Alveran
                      #79
                      @plchome-0
                      Sorry falsche ausgedrückt. Bei mir hat das WLAN was der Stick öffnet ein Passwort.
                      • A Alveran
                        @plchome-0
                        #80
                        @alveran
                        Werkseinstellungen ?
                        z.b. Connect Taste x Sekunden festhalten oder gibt es eine "AufgebogeneBüroklammerResetÖffnung" ?
                        Nur ne Idee ...
                          @alveran
                          Nur ne Idee ...
                          A
                          A
                          Alveran
                          #81
                          @blechsoldat
                          Die Anlage ist neu wurde am Wochenende erst aufgebaut. Der Stick hatte ab Anfang an ein verschlüsseltes WLAN. Er war auch original Verpackt und verschlossen. Ich kann es mit einem reset probieren mach mir aber nicht viel Hoffnung. Ich dachte ehr da es dafür ein Standard Passwort gibt.
                          • PLCHome 0P
                            PLCHome 0P
                            PLCHome 0
                            #82
                            Ok, das ist neu mit dem W-Lan-Passwort. Natürlich ist das besser, weil verschlüsselt. Da muss ich mich für die pappige Antwort wohl entschuldigen.
                            Was ist das für ein Typ? Shine-Wifi-X
                            Hast du schon mal versucht, den QR-Code mit einer HandyApp auszulesen? Vielleicht verbirgt sich darin ein Hinweis.
                            In den Anleitungen wird immer der CC Code erwähnt, vielleicht der ohne CC oder mit CC?
                            Vielleicht die Seriennummer mit großen oder kleinen Buchstaben?
                            Die App müsste bei der Ersteinrichtung auch eine Verbindung mit dem Stick aufbauen. Wenn du glück hast, kannst du in der Zeit den Browser öffnen oder sogar in der Wifi-Verbindung das Passwort nachschauen.
                            Solltest du eine Lösung finden, würde ich mich über die Info für andere User freuen und die Information in die readme einarbeiten.
                            Zum Zurücksetzen auf Werkseinstellungen muss der Knopf länger als 6 sec gedrückt werden. Einmal kurz öffnet den AP Modus.
                              A
                              A
                              Alveran
                              schrieb am zuletzt editiert von Alveran
                              #83
                              @plchome-0
                              Sorry, die Woche war etwas stressig. Die Anlage ist mittlerweile vom EVU abgenommen und offiziell am Netz. Konnte deswegen jetzt erst am Wochenende wieder damit rum probieren.
                              Es handelt sich um einen Shine-Wifi-S
                              Der QR Code beinhaltet die Seriennummer die auch unten drunter steht. Habe alle Kombinationen aus der Seriennnummer und CC ausprobiert. Leider ohne Erfolg. :-(
                              Nach einen Werksreset wird das WLAN leider auch verschlüsselt ausgesendet. Die App hat immer so ihre Probleme bei der erst Verbindung, musste den Code mit der App immer mehrmals scannen bis es irgendwann klappt.
                              Edit
                              Asche auf mein Haupt. Das WLAN Passwort für den Growatt Shine Adapter lautet 12345678
                              Ich habe mich wohl mit dem Handy vertippt.
                              Er sendet sowohl nach dem Werksreset als auch nach der Einrichtung immer das selbe verschlüsselte WLAN aus wenn man den Config Button drückt.
                              • A Alveran
                                @plchome-0
                                Edit
                                M
                                M
                                mosgetter
                                schrieb am zuletzt editiert von mosgetter
                                #84
                                Hallo, ich muss auch noch mal hier nachfragen.
                                Ich komme auf die Webseite von dem Wifi Stick nicht drauf um die Intervallzeit auf 1s umzustellen.
                                Mit dem WLAN Hotspot bin ich verbunden. Ich kann auch mit einem LAN Scanner die IP vom Stick sehen.
                                Wenn ich die IP im Browser eingebe meldet er immer zurück dass mein Anfrage zurückgewiesen wird.
                                Keine Berechtigung. Wurde da was geändert. Der Stick ist relativ neu. ShineWifi-X FW 3.1.0.2
                                Edit: Bei der Einrichtung des Datenloggers in der Shine Phone APP kann ja bei dem Einrichten des der fortgeschrittene Modus gewählt werden. Dort kann auch der Updateintervall vorgewählt werden, allerdings braucht man zum ändern ein Passwort. Hab 12345678 die Stick SN, die Umrichter SN versucht, nix.
                                fischi87F 1 Antwort Letzte Antwort
                                • M
                                  M
                                  magix
                                  #85
                                  @PLCHome-0
                                  Hat sich was verändert bei Growatt?
                                  Habe seit 3-4 Tagen Probleme mit der Datenaktualisierung.
                                  LOG:
                                  DB closed
                                  Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20) at Object.onceWrapper (events.js:421:26) at Socket.emit (events.js:314:20) at TCP.<anonymous> (net.js:675:12)
                                  unhandled promise rejection: DB closed
                                  Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  • O
                                    O
                                    oxident
                                    #86
                                    @PLCHome-0 Irgendwie ist der Growatt-Server nervig. Ich bekomme seit Monaten sehr häufig Timeouts beim Auslesen der Werte und das flutet das Log. Wäre es vielleicht denkbar, die Timeout-Meldungen als Warnung (anstelle als Fehler) zu werten? Dann kann man das besser filtern ;-)
                                    Alternativ wäre auch ein Timeout >5sec denkbar...
                                    • W
                                      W
                                      Wildbill
                                      #87
                                      @oxident Es gibt bei Github ein Issue zu genau dem Problem. Dort liken, vielleicht beschleunigt es das etwas. Allerdings scheint es momentan eher ein Zeitproblem des Entwicklers zu sein.
                                      Gruss, Jürgen
                                      O 1 Antwort Letzte Antwort
                                      • W Wildbill
                                        Gruss, Jürgen
                                        O
                                        O
                                        oxident
                                        #88
                                        @wildbill Alles klar, gesagt, getan :-)
                                        • fischi87F
                                          fischi87F
                                          fischi87
                                          #89
                                          Hallo, mir ist aufgefallen das der Adapter nicht aktualisiert. erst wenn ich den Adapter händisch neu starte kommen neue, aktuelle Daten?!
                                          grüße
                                          33.2k
                                          84.3k
