    6.5k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • B blackeagle998
    @meerkat
    Kannst du mal dein komplettes Skript Aussenanlage.vacuum_eg hier posten, dann kann ich vielleicht helfen.
    meerkat
    schrieb am zuletzt editiert von meerkat
    #5538
    @blackeagle998
    klar, kein Problem. Ist 1zu1 das Script aus deiner ZIP-Datei. Hat halt nur einen anderen Namen.
    // jshint maxerr:1000
    const dp_vacuum_state               = 'mihome-vacuum.0.info.state';
    const dp_vacuum_map                 = 'mihome-vacuum.0.map.map64';
    const dp_vacuum_emptying_spot       = '0_userdata.0.vacuum.emptying_spot';
    const dp_vacuum_html                = '0_userdata.0.vacuum.html';
    const dp_vacuum_iqontrol_ip         = '0_userdata.0.vacuum.iqontrol_ip';
    const dp_vacuum_map_hide            = '0_userdata.0.vacuum.map_hide';
    const dp_vacuum_map_rotate          = '0_userdata.0.vacuum.map_rotate';
    const dp_vacuum_room_clean          = '0_userdata.0.vacuum.room_clean';
    const dp_vacuum_room_clean_active   = '0_userdata.0.vacuum.room_clean_active';
    const dp_vacuum_popup_message       = '0_userdata.0.vacuum.popup_message';
    const dp_vacuum_control_start       = 'mihome-vacuum.0.control.start';
    const dp_vacuum_control_pause       = 'mihome-vacuum.0.control.pause';
    const dp_vacuum_control_home        = 'mihome-vacuum.0.control.home';
    const dp_vacuum_control_goTo        = 'mihome-vacuum.0.control.goTo';
    const dp_vacuum_control_clearQueue  = 'mihome-vacuum.0.control.clearQueue';
    var arr_vacuum_rooms            = [];
    var arr_vacuum_onID             = [];
    var arr_vacuum_onID_button      = [];
    var arr_vacuum_onID_consumer    = [];
    var arr_vacuum_onID_room_states = [];
    fctInit();
    on({id:arr_vacuum_onID, change:'ne'} , function (dp) {
        getRoomState();
    on({id:arr_vacuum_onID_consumer, change:'ne'} , function (dp) {
        getRoomState();
    on({id:arr_vacuum_onID_room_states, change: 'any'}, function () {
        getRoomState();
    on({id:arr_vacuum_onID_button} , function (dp) {
        getRoomState();
    on({id:dp_vacuum_room_clean, change:'ne'} , function (dp) {
        startRoomClean(dp.state.val);
        setState(dp.id, '');
    on({id:dp_vacuum_popup_message, change:'ne'} , function (dp) {
        showPopup(dp.state.val);
    function fctInit(){
        if (existsAdapter()){
            createVacuumStates();
            if (existsIP()){
                arr_vacuum_rooms = initRooms();
                if (arr_vacuum_rooms.length !== 0){
                    fctInitOnID();
                    setTimeout(function(){
                        getRoomState();
                    },2000);
                }else{
                    log('In der Objektstruktur \'mihome-vacuum.0.rooms\' wurden keine Räume gefunden.', 'warn');
            }else{
                log('Bitte geben Sie im Datenpunkt ' + dp_vacuum_iqontrol_ip + ' eine gültige IP-Adresse ein.', 'warn');
        }else{
            log('Der Adapter \'mihome-vacuum\' scheint nicht installiert zu sein (Datenpunkt \'' + dp_vacuum_state + '\' nicht gefunden.', 'error');
    function fctInitOnID(){
        arr_vacuum_onID.push(dp_vacuum_state);
        arr_vacuum_onID.push(dp_vacuum_map_hide);
        arr_vacuum_onID.push(dp_vacuum_map_rotate);
        arr_vacuum_onID.push(dp_vacuum_emptying_spot);
        arr_vacuum_onID.push('mihome-vacuum.0.info.connection');
        arr_vacuum_onID.push('mihome-vacuum.0.info.error');
        arr_vacuum_onID.push('mihome-vacuum.0.info.battery');
        arr_vacuum_onID.push('mihome-vacuum.0.info.queue');
        arr_vacuum_onID_consumer.push('mihome-vacuum.0.consumable.filter');
        arr_vacuum_onID_consumer.push('mihome-vacuum.0.consumable.main_brush');
        arr_vacuum_onID_consumer.push('mihome-vacuum.0.consumable.sensors');
        arr_vacuum_onID_consumer.push('mihome-vacuum.0.consumable.side_brush');
        arr_vacuum_onID_consumer.push('mihome-vacuum.0.consumable.water_filter');
        arr_vacuum_onID_button.push(dp_vacuum_control_start);
        arr_vacuum_onID_button.push(dp_vacuum_control_pause);
        arr_vacuum_onID_button.push(dp_vacuum_control_home);
        arr_vacuum_onID_button.push(dp_vacuum_control_clearQueue);
        for (let i = 0; i < arr_vacuum_rooms.length; i++){
            arr_vacuum_onID_room_states.push(arr_vacuum_rooms[i].id + '.state');
    function createVacuumStates(){
        if(!existsState(dp_vacuum_emptying_spot)) {
            createState(dp_vacuum_emptying_spot,
                {type: 'string', name: 'Koordinaten Entleerung', role: 'value', read: true , write: true , def: ''}
        if(!existsState(dp_vacuum_html)) {
            createState(dp_vacuum_html,
                {type: 'string', name: 'html', role: 'value', read: true , write: true , def: ''}
        if(!existsState(dp_vacuum_iqontrol_ip)) {
            createState(dp_vacuum_iqontrol_ip,
                {type: 'string', name: 'IP iQontrol', role: 'value', read: true , write: true , def: '192.x.x.x'}
        if(!existsState(dp_vacuum_map_hide)) {
            createState(dp_vacuum_map_hide,
                {type: 'boolean', name: 'Karte verstecken', role: 'switch', read: true , write: true , def: true}
        if(!existsState(dp_vacuum_map_rotate)) {
            createState(dp_vacuum_map_rotate,
                {type: 'number', name: 'Karte x° drehen', role: '', read: true , write: true , def: 0,
                    states: {
                        "0": "keine Drehung",
                        "90": "90° Drehung",
                        "180": "180° Drehung",
                        "270": "270° Drehung"
        if(!existsState(dp_vacuum_room_clean)) {
            createState(dp_vacuum_room_clean,
                {type: 'string', name: 'Raum Reinigung', role: 'value', read: true , write: true , def: ''}
        if(!existsState(dp_vacuum_room_clean_active)) {
            createState(dp_vacuum_room_clean_active,
                {type: 'string', name: 'Raum Reinigung aktiv', role: 'value', read: true , write: true , def: ''}
        if(!existsState(dp_vacuum_popup_message)) {
            createState(dp_vacuum_popup_message,
                {type: 'string', name: 'Popup Nachricht', role: 'value', read: true , write: true , def: ''}
    function getRoomState(){
            if (existsIP()){
                let room_active = false;;
                    let str_state = getState(arr_vacuum_rooms[i].id + '.state').val;
                    if (str_state == 'sauge Zimmer'){
                        setState(dp_vacuum_room_clean_active, arr_vacuum_rooms[i].name);
                        arr_vacuum_rooms[i].state = 'active';
                        room_active = true;
                    }else{
                        if (str_state.indexOf('Warteposition') + 1 > 0) {
                            let queue_position = str_state.slice(-1).charAt(0);
                            arr_vacuum_rooms[i].state = queue_position;
                        }else{
                            arr_vacuum_rooms[i].state = 'inactive';
                if (!room_active){
                    setState(dp_vacuum_room_clean_active, '');
                setState(dp_vacuum_html, createVacuumHTML());
            }else{
        }else{
    function createVacuumHTML() {
        let css_file            = './../iqontrol.meta/userimages/userwidgets/vacuum.css';
        let js_file             = './../iqontrol.meta/userimages/userwidgets/vacuum.js';
        let ip                  = getState(dp_vacuum_iqontrol_ip).val;
        let emptying_spot       = getState(dp_vacuum_emptying_spot).val;
        let map_link            = 'http://' + ip + ':8082/mihome-vacuum.admin/actualMap_0.png?' + Math.random();
        let str_html            = '';
        let str_html_head       = '';
        let str_html_error      = '';
        let img_blank           = './images/icons/blank.png';
        let img_vacuum          = './../iqontrol.meta/userimages/usericons/vacuum/vacuum.png';
        let img_wifi            = './../iqontrol.meta/userimages/usericons/vacuum/wifi.png';
        let img_wifi_disconnected = './../iqontrol.meta/userimages/usericons/vacuum/wifi_disconnected.png';
        let img_clear_queue     = './../iqontrol.meta/userimages/usericons/vacuum/clear_queue.png';
        let img_back_home       = './../iqontrol.meta/userimages/usericons/vacuum/back_home.png';
        let img_pause_cleaning  = './../iqontrol.meta/userimages/usericons/vacuum/pause_cleaning.png';
        let img_resume_cleaning = './../iqontrol.meta/userimages/usericons/vacuum/resume_cleaning.png';
        let img_trashcan        = './../iqontrol.meta/userimages/usericons/vacuum/trashcan.png';
        let gif_sirene          = './../iqontrol.meta/userimages/usericons/vacuum/sirene.gif';
        str_html_head = str_html_head + '<head><meta name="viewport" content="width=device-width, initial-scale=1.0, minimum-scale=1.0">';
        str_html_head = str_html_head + '<link rel="stylesheet" href="' + css_file + '" />';
        str_html_head = str_html_head + '<script type="text/javascript" src="' + js_file + '"></script>';
        str_html_head = str_html_head + '</head>';
        str_html = str_html_head + '<body>';
        //Box Error
        let vacuum_error = getState('mihome-vacuum.0.info.error').val;
        if (vacuum_error !== 0){
            str_html_error = str_html_error + '<div class="box_row">';
            str_html_error = str_html_error + '<img class="img_sirene" src="' + gif_sirene + '"/>';
            str_html_error = str_html_error + '<label class="box_row" id="box_sirene_value">';
            str_html_error = str_html_error + getStatetxt('mihome-vacuum.0.info.error', vacuum_error);
            str_html_error = str_html_error + '</label>';
            str_html_error = str_html_error + '</div>';
        }else{
            let str_consumer    = '';
            let consumer_limit  = 10;
            for (let i = 0; i < arr_vacuum_onID_consumer.length; i++){
                if (getState(arr_vacuum_onID_consumer[i]).val < consumer_limit){
                    if (str_consumer !== ''){
                        str_consumer = str_consumer + ', ' + arr_vacuum_onID_consumer[i];
                    }else{
                        str_consumer = arr_vacuum_onID_consumer[i];
                str_consumer = str_consumer.replace(/mihome-vacuum.0.consumable./g, '');
                str_html_error = str_html_error + '<div class="box_row" id="box_consumer">';
                str_html_error = str_html_error + '<div class="box_column">';
                str_html_error = str_html_error + '<label class="box_row" id="box_consumer_value_headline">Bitte reinigen:</label>';
                str_html_error = str_html_error + '<label class="box_row" id="box_consumer_value">' + str_consumer + '</label>';
            }else{
                str_html_error = str_html_error + '<div class="box_column"></div>';
        //Box 1 = Alarm
        str_html = str_html + str_html_error;
        //Box 2 = Statusangaben
        let vacuum_state        = getState(dp_vacuum_state).val;
        let vacuum_state_txt    = getStatetxt(dp_vacuum_state, vacuum_state);
        str_html = str_html + '<div class="box_column" id="box_states">';
        str_html = str_html + '<div class="box_row">';
        str_html = str_html + '<div class="box_row" id="box_state">Status:</div>';
        str_html = str_html + '<div class="box_row" id="box_battery">Batterie:</div>';
        str_html = str_html + '<div class="box_row" id="box_connection">Verbindung:</div>';
        str_html = str_html + '</div>';
        str_html = str_html + '<div class="box_row" id="box_state_value"><center>' + vacuum_state_txt;
        let str_active_room = getState(dp_vacuum_room_clean_active).val;
        if (str_active_room !== ''){
            str_html = str_html + '</br>(' + str_active_room + ')';
        str_html = str_html + '</center></div>';
        str_html = str_html + '<div class="box_row" id="box_battery_value">' + getState('mihome-vacuum.0.info.battery').val + '%</div>';
        str_html = str_html + '<div class="box_row" id="box_connection_value">';
        if (getState('mihome-vacuum.0.info.connection').val == true){
            str_html = str_html + '<img class="img_wifi" src="' + img_wifi + '" />';
        }else{
            str_html = str_html + '<img class="img_wifi" src="' + img_wifi_disconnected + '" />';
        //Box 3 = Raumauswahl und Warteschlange
        str_html = str_html + '<div class="box_row" id="box_rooms_and_controls">';
        str_html = str_html + '<div class="box_column" id="box_room_selection">';
        str_html = str_html + '<div class="box_row"><label class="lbl_room_selection">Raumauswahl:</label></div>';
        str_html = str_html + '<div class="box_row"><form name="rooms">';
        str_html = str_html + '<select name="room" id="room">';
        str_html = str_html + '<option selected>bitte wählen...</option>';
        let arr_vacuum_rooms_sort = [];
        for (let i = 0;i < arr_vacuum_rooms.length; i++){
            arr_vacuum_rooms_sort.push(arr_vacuum_rooms[i].name);
        arr_vacuum_rooms_sort.sort();
        arr_vacuum_rooms_sort.push('Komplettreinigung');
        for (let j = 0; j < arr_vacuum_rooms_sort.length; j++){
            str_html = str_html + '<option>' + arr_vacuum_rooms_sort[j] + '</option>';
        str_html = str_html + '</select>';
        str_html = str_html + '</form></div>';
        let str_html_queue = getQueue();
        if (str_html_queue !== ''){
            str_html = str_html + '<div class="box_column" id="box_queue">';
            str_html = str_html + '<div class="box_column">';
            str_html = str_html + '<div class="box_row" id="box_queue_headline">';
            str_html = str_html + '<div><label class="lbl_queue_headline"><center>Warteschlange</center></label></div>';
            str_html = str_html + '<div><input type="image" class="img_queue_clear" onclick="setState(\'' + dp_vacuum_control_clearQueue + '\', true)" src="' + img_clear_queue + '" /></div>';
            str_html = str_html + '<div class="box_column" id="box_queue_rooms">';
            str_html = str_html + str_html_queue;
        //Box 4 = Steuerung, aktiver Raum und Karte
        str_html = str_html + '<div class="box_column" id="box_controls_and_active_room">';
        str_html = str_html + '<div class="box_row" id="box_controls">';
        str_html = str_html + '<input type="image" class="img_control"';
        str_html = str_html + 'onclick="setState(\'' + dp_vacuum_room_clean + '\', document.rooms.room.options[document.rooms.room.selectedIndex].text)" ';
        str_html = str_html + 'src="' + img_vacuum + '" />';
        if ((vacuum_state_txt !== 'Unknown') && (vacuum_state_txt !== 'Initiating') && (vacuum_state_txt !== '?') && (vacuum_state_txt !== 'Charging') && (vacuum_state_txt !== 'Charging Error') && (vacuum_state_txt !== 'Pause') && (vacuum_state_txt !== 'In Error') && (vacuum_state_txt !== 'Sleeping')){
            str_html = str_html + '<input type="image" class="img_control" onclick="setState(\'' + dp_vacuum_control_pause + '\', true)" src="' + img_pause_cleaning + '" />';
        }else{
            str_html = str_html + '<input type="image" class="img_control" src="' + img_blank + '" />';
        if ((vacuum_state_txt == 'Sleeping') || (vacuum_state_txt == 'Waiting') || (vacuum_state_txt == 'Pause')){
            str_html = str_html + '<input type="image" class="img_control" onclick="setState(\'' + dp_vacuum_control_start + '\', true)" src="' + img_resume_cleaning + '" />';
        }else{
        if ((vacuum_state_txt !== 'Unknown') && (vacuum_state_txt !== 'Initiating') && (vacuum_state_txt !== '?') && (vacuum_state_txt !== 'Charging') && (vacuum_state_txt !== 'Charging Error') && (vacuum_state_txt !== 'In Error')){
            str_html = str_html + '<input type="image" class="img_control" onclick="setState(\'' + dp_vacuum_control_home + '\', true)" src="' + img_back_home + '" />';
        }else{
        if (emptying_spot !== ''){
            str_html = str_html + '<input type="image" class="img_control" onclick="setState(\'' + dp_vacuum_control_goTo + '\', \'' + emptying_spot + '\')" src="' + img_trashcan + '" />';
        }else{
        let map_rotate = getState(dp_vacuum_map_rotate).val;
        if (vacuum_state_txt !== 'Charging'){
            str_html = str_html + '<div class="box_row" id="box_map">';
            if (map_rotate !== 0){
                str_html = str_html + '<img id="img_map" style="transform: rotate(' + map_rotate + 'deg)" src="' + map_link + '" />';
            }else{
                str_html = str_html + '<img id="img_map" src="' + map_link + '" />';
            str_html = str_html + '<script type="text/javascript">';
            str_html = str_html + 'startMapReload("' + map_link + '")';
            str_html = str_html + '</script>';
        }else{
            if (getState(dp_vacuum_map_hide).val){
            }else{
                }else{
            str_html = str_html + 'endMapReload()';
        str_html = str_html + '</body>';
    	return str_html;
    function getQueue(){
        let str_html = '';
        let arr_temp = [];
            let str_state = arr_vacuum_rooms[i].state;
            if ((str_state !== '') && (str_state !== 'active') && (str_state !== 'inactive')){
                arr_temp[parseInt(str_state)] = arr_vacuum_rooms[i].name;
        if (arr_temp.length !== 0){
            for (let j = 0; j < arr_temp.length; j++){
                str_html = str_html + '<label class="lbl_queue_room">' + (j + 1) + '. ' + arr_temp[j] + '</label>';
        return str_html;
    function startRoomClean(room){
        if ((room !== null) && (room !== undefined)){
            if ((room !== '') && (room !== 'bitte wählen...')){
                if (room !== 'Komplettreinigung'){
                        if (arr_vacuum_rooms[i].name == room){
                            if (str_state == 'inactive'){
                                setState(dp_vacuum_popup_message, room  + ' wird zur Reinigung hinzugefügt.');
                                setState(arr_vacuum_rooms[i].id + '.roomClean', true);
                            }else{
                                if (str_state == 'active'){
                                    setState(dp_vacuum_popup_message, room  + ' wird bereits gesaugt.');
                                }else{
                                    setState(dp_vacuum_popup_message, room  + ' befindet sich bereits in der Warteschlange.');
                }else{
                    let popup_message       = '';
                        popup_message = 'Die Komplettreinigung kann nur gestartet werden, wenn sich der Staubsaugerroboter auf der Ladestation befindet.';
                    }else{
                        popup_message = 'Komplettreiniguung gestartet';
                        setState(dp_vacuum_control_start, true);
                    setState(dp_vacuum_popup_message, popup_message);
        }else{
            log('An die Funktion startRoomClean wurde ein NULL/UNDEFINED Wert übergeben.', 'warn');
    function initRooms(){
        let arr_rooms           = [];
        let arr_rooms_states    = [];
        // Ermittle alle States unterhalb der Struktur mihome-vacuum.0.rooms.room*
        arr_rooms_states = Array.prototype.slice.apply($("mihome-vacuum.0.rooms.room*"));
        if (arr_rooms_states.length !== 0){
            for (let i = 0; i < arr_rooms_states.length; i++){
                let room_id     = arr_rooms_states[i].slice(0, arr_rooms_states[i].lastIndexOf("."));
                let room_name   = getObject(room_id).common.name;
                let found = false
                if (arr_rooms.length !== 0){
                    for (let j = 0; j < arr_rooms.length; j++){
                        if (arr_rooms[j].name == room_name){
                            found = true;
                if (!found){
                    let obj_room = {};
                    obj_room.id     = room_id;
                    obj_room.name   = room_name;
                    obj_room.state  = 'inactive';
                    arr_rooms.push(obj_room);
        return arr_rooms;
    function existsAdapter() {
        if (existsState(dp_vacuum_state)){
            return true;
        }else{
            return false;
    function existsIP() {
        if (existsState(dp_vacuum_iqontrol_ip)){
            let str_ip = getState(dp_vacuum_iqontrol_ip).val;
            if ((str_ip !== '') && (str_ip !== '192.x.x.x')){
                return true;
            }else{
                return false;
        }else{
            return false;
    function showPopup(message){
        if (message !== ''){
            sendTo("iqontrol.0", "send", {
                PopupMessage: message,
                PopupDuration: 5000
    function getStatetxt(id, val) {
        let states = getStatesObj(id);
        if(states) return states[val];
        else return null;
    function getStatesObj(id) {
        if(!getObject(id)) {
            log(id + ': kein Objekt', 'warn');
            return null;
        let obj = getObject(id);
        if (!obj.common.states) {
            log(id + ': keine Zustandtexte', 'warn');
            return null;
        var states = obj.common.states;
        if (typeof states == 'string') {
            var arr = states.split(';');
            states = {};
            for(var i = 0; i < arr.length; i++) {
                var ele = arr[i].split(':');
                states[ele[0]] = ele[1];
        return states;
    • M meerkat
      @blackeagle998
      fctInit();
          getRoomState();
          getRoomState();
          getRoomState();
          getRoomState();
      function fctInit(){
              if (existsIP()){
                      fctInitOnID();
                          getRoomState();
                      },2000);
                  }else{
              }else{
          }else{
                      states: {
              if (existsIP()){
                          room_active = true;
                      }else{
                          }else{
                  if (!room_active){
              }else{
          }else{
          let str_html            = '';
          //Box Error
          }else{
                      }else{
              }else{
          //Box 1 = Alarm
          }else{
          }else{
          }else{
          }else{
          }else{
              }else{
          }else{
              }else{
                  }else{
      	return str_html;
          let str_html = '';
          let arr_temp = [];
          return str_html;
                              }else{
                                  }else{
                  }else{
                      }else{
          }else{
          let arr_rooms           = [];
                  let found = false
                              found = true;
                  if (!found){
                      let obj_room = {};
          return arr_rooms;
              return true;
          }else{
              return false;
                  return true;
              }else{
                  return false;
          }else{
              return false;
                  PopupDuration: 5000
          else return null;
              return null;
              return null;
              states = {};
          return states;
      blackeagle998
      schrieb am zuletzt editiert von blackeagle998
      #5539
      @meerkat
      Zeig mir mal bitte deine Objektstruktur unter
      mihome-vacuum.0.rooms., scheint, als würde er da nichts finden.
      Er sucht ja nach Raumnamen beginnend mit room
      , wenn deine anders heißen, dann musst du das anpassen, Skriptzeile 451:
      • B blackeagle998
        @meerkat
        meerkat
        #5540
        @blackeagle998
        Mist, da habe ich dir jetzt genau das falsche gechickt. Ich habe die Zeile schon auf
        arr_rooms_states = Array.prototype.slice.apply($("mihome-vacuum.0.rooms.*"));
        abgeändert.
        • M meerkat
          @blackeagle998
          abgeändert.
          blackeagle998
          #5541
          @meerkat
          Dann kann ich dir nicht wirklich helfen.
          Die Fehlermeldung "TypeError: Cannot read property 'common' of null" sagt ja, dass die getObject Funktion einen NULL Wert zurück gibt. Warum, musst du selber herausfinden.
          Vielleicht lässt du mal alle Inhalte des Arrays in der log console ausgeben, dann siehst du ja, ob da ein Datenpunkt dabei ist, der kein Raum ist.
          • M muuulle
            @s-bormann said in Test Adapter iQontrol 1.8.x Vis:
            @peks-67 sagte in Test Adapter iQontrol 1.8.x Vis:
            Hi zusammen,
            ich bastle mir gerade eine automatisierte Bewässerung.
            Nun möchte ich natürlich die Startzeit in iQontrol festlegen um welche Uhrzeit bewässert werden soll.
            Funktioniert soweit auch schon. Nur wollte ich frage ob es in iQontrol möglich ist die Uhrzeit mit einem Slider oder Rad oder ähnlichen einzustellen.
            Aktuell muss ich die Zeit von Hand eingeben und auf Absenden klicken.
            Der Datenpunkt ist als state / Time festgelegt.
            Vllt. hatte das Thema ja schon jemand. Finden konnte ich im Forum allerdings nichts 😊
            Hi, mit der aktuellen Version sollte Date, Time und Durations eigentlich gehen. Es gibt ein eigenes Gerät dafür.
            https://github.com/sbormann/ioBroker.iqontrol#-date-and-time
            VG!
            Moin,
            bitte beachten, dass der max. Wert des Datenpunkts der Zeit nicht beschränkt ist. Ansonsten funktioniert das nicht und der Wert des Datenpunkts wird auf 1 gesetzt.
            p.endeP Offline
            p.endeP Offline
            p.ende
            #5542
            @muuulle said in Test Adapter iQontrol 1.8.x Vis:
            Hi zusammen,
            VG!
            Moin,
            Sehr geil und so einfach umzustellen DANKE 😀
            @SiKo
            Ich nutze das Gardena System. Habe die Steuerung jetzt aber komplett über Blockly Scripte und Datenpunkte gelöst da mir die Gardena eigene App nicht wirklich zusagt.
            Für meine drei Bewässerungskreise sieht das im iQontrol nun so aus.
            Wenn ich auf das Bewässerungsicon gehe kommt das Fenster:
            Und wenn ich auf Automatik gehe kommt dieses:
            Hier ist dann alles einstellbar :)
            dslraserD C S 3 Antworten Letzte Antwort
            • p.endeP p.ende
              Hi zusammen,
              VG!
              Moin,
              @SiKo
              dslraserD Offline
              dslraserD Offline
              dslraser
              #5543
              Welches Gardena Systen nutzt Du ?
              p.endeP 1 Antwort Letzte Antwort
              • dslraserD dslraser
                p.endeP Offline
                p.endeP Offline
                p.ende
                #5544
                @dslraser said in Test Adapter iQontrol 1.8.x Vis:
                Ich nutze das Gardena Gateway mit Irrigation Control und V3 Ventilbox.
                Lässt sich über den Adapter "smartgarden"
                im iobroker steuern.
                • p.endeP p.ende
                  Hi zusammen,
                  VG!
                  Moin,
                  @SiKo
                  Cino
                  #5545
                  @peks-67 sieht top aus. Sowas könnte ich für meine Poolpumpe gebrauchen. Gerade läuft das alles mit den Timern noch über die Shelly App
                  IOB@RPI4
                  Shelly, Zigbee, ebus
                  • C Cino
                    SiKo
                    #5546
                    @cino
                    geht auch mit Shelly: https://forum.iobroker.net/post/654895
                    C 1 Antwort Letzte Antwort
                    • S SiKo
                      @cino
                      Cino
                      #5547
                      @siko und die Zeit ist einfach eine Variable die im Blockly als Ausschaltverzögerung dient?
                      Und für die Wochentage einfach eine Variable setzen und mit einer Und Verknüpfung auf die Switch Variable vom Shelly? Ist das so richtig?
                      Ich habe es gestern mit ach und krach gerade mal geschafft in blockly eine Lampe durch einen Bewegungsmelder zuschalten.
                      IOB@RPI4
                      • p.endeP p.ende
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #5548
                        Ah okay, das nutze ich auch.
                        Ich habe das auch über Blockly laufen, allerdings nicht über Uhrzeiten gesteuert.
                        Ich habe mir Deine Screenshots nochmal genauer angesehen und verstehe jetzt auch was Du mit automatik meinst. Da Du für die einzelnen Kreise unterschiedliche Zeiten hast funktioniert das ja auch. (Gehen ja immer max 2 Kreise gleichzeitig)
                        Ich hatte für mich einen etwas anderen Ansatz. Ich habe vier Ventile drann und kann die entweder einzeln steuern, oder alle nacheinander.
                        Z.B. Gesamtlaufzeit soll 80 Minuten sein, dann läuft alles brav nacheinander jeweils 20 Minuten.
                        Vielleicht kannst Du mal hier
                        https://forum.iobroker.net/post/408094
                        Deine Blocklys posten, das wäre interessant für mich.
                        (mein Blockly habe ich auch etwas angepasst, da Gardena die max Laufzeiten der Ventile erhöht hat, das waren mal max 59 Minuten)
                        Bei meiner Variante funktioniert die Steuerung sowohl über die Gardena App, oder über iQontrol. Es wird immer ä, wenn gewünscht in beiden angezeigt. Meine Frau nimmt die App, ich nehme lieber iQontrol.
                          SiKo
                          #5549
                          @cino Ich fülle per VIS/Blockly den Shelly Datenpunkt "Auto Off" somit ist sicher auch wenn sich mal das Script aufhängen würde, das der Shelly stopt.
                          Ich nutze dazu einen eigenen Datenpunkt für Minuten und nehme das mit 60 mal und trage das dann bei Shelly ein.
                            meerkat
                            #5550
                            Hi an alle,
                            man kann für das Media Element ja so schön die Sender hinterlegen
                            und das alles über die Eigenschaft RemoteChannels pflegen. 85aee5af-92c1-4cbd-b866-eb1650827cef-image.png
                            Kann man das Array auch irgendwie kopieren oder da auch einen Datenpunkt hinterlegen? Habe mehrere Alexa´s und nicht wirklich Lust, bei jedem neuen Sender alle Geräte durchzugehen.
                            da_WoodyD ldittmarL 2 Antworten Letzte Antwort
                            • M meerkat
                              Hi an alle,
                              da_WoodyD Offline
                              da_WoodyD Offline
                              #5551
                              @meerkat wenn ich dich richtig verstehe, dann kopier doch das gerät in den raum wo soll und ändere dort die daten der schnepfe...
                                SiKo
                                #5552
                                hat jemand von euch sein Auto mit eingebunden.
                                hab noch keine genaue Vorstellung wie ich diese Infos am Besten visualisieren könnte.
                                • s.bormannS Offline
                                  s.bormannS Offline
                                  s.bormann
                                  #5553
                                  Habe mal das schlechte Wetter im Urlaub genutzt :)
                                  Beim FLOT-Widget kann man nun die Achsen konfigurieren:
                                  1.8.1 (2021-07-28)
                                  • (sbormann) Some design-adjustments for react-ui.
                                  • (sbormann) Keep track of ioBroker object changes in admin.
                                  • (sbormann) Fixed crash if active view has no devices.
                                  • (sbormann) Removed old conn.js from admin.
                                  • (Einstein2002, sbormann) Added HomematicIP-Thermostat.
                                  • (sbormann) Enhanced max-height of dialog.
                                  • (sbormann) Fixed up, down and stop button for blinds.
                                  • (sbormann) Changed some log messages.
                                  • (sbormann) Enhanced FLOT-Chart-Widget to set axis options.
                                  ldittmarL 1 Antwort Letzte Antwort
                                  • s.bormannS s.bormann
                                    1.8.1 (2021-07-28)
                                    ldittmarL Offline
                                    ldittmarL Offline
                                    ldittmar
                                    #5554
                                    ich bin gerade dabei meine Instanzen ins iQontrol zu packen:
                                    Dabei werden Adapter die aktualisiert werden können grün dargestellt, CPU und RAM werden angezeigt und oben ein Badge mit Anzahl der Logmeldungen (warn/error)
                                    Wenn man es öffnet...
                                    ...kann man Adapter ein-/ausschalten, Logeinträge löschen, die aktuellen Versionen (installiert, stable, latest und auf Github) sehen und die letzten 100 Logeinträge (warn/error) lesen.
                                    Was ich noch gerne hätte, ist dass die aktuell installierte Adapter-Version auf dem Kachel angezeigt wird, aber nicht in INFO-A oder B, sondern irgendwo anders. Von mir aus unten rechts oder hinter der Bezeichnung. Egal... Hat jemand eine Idee?
                                    Und wenn ich schon dabei bin: Hat jemand noch eine Idee man noch als Info oder Funktion zu den Instanzen hinzufügen kann? Ich will mein Template fertig machen, bevor ich alle Instanzen hinzufüge 😏
                                    S da_WoodyD 2 Antworten Letzte Antwort
                                    • da_WoodyD Offline
                                      da_WoodyD Offline
                                      #5555
                                      @ldittmar mir fällt im mom nichts besseres ein, als eventuell Badge für die Version zu nehmen, oder CPU und RAM in InfoA als Arrey zu packen, dann wäre InfoB frei für Version.
                                      • M meerkat
                                        Hi an alle,
                                        ldittmarL Offline
                                        ldittmarL Offline
                                        ldittmar
                                        schrieb am zuletzt editiert von ldittmar
                                        #5556
                                        @meerkat Das wäre wirklich gut, denn ich habe 9 Alexas schon fetig eingestellt und es wäre echt cool, wenn ich diese Arrays einfach rein pasten könnte. Und nochmal kurz die Frage: Wie hast du das gemacht, dass man auf dem Button klickt und Alexa darauf reagiert bzw den richtigen Sender auswählt?
                                        dslraserD M 2 Antworten Letzte Antwort
                                        • da_WoodyD da_Woody
                                          ldittmarL Offline
                                          ldittmarL Offline
                                          ldittmar
                                          #5557
                                          @da_woody Ja... ich habe es jetzt so gelöst, dass ich die CPU in den "Weiteren Infos" gepackt habe und dafür die aktuell installierte Version in Info A rein. Dann habe ich noch den ERROR Icon missbraucht um anzuzeigen, falls ein Adapter nicht auf Stable läuft (hab ein paar Adapter, die auf Latest laufen). Ich wollte noch, bei möglichen Updates, dass die mögliche Version noch angezeigt wird. Diese würde ich dann auch zu Info A packen, nur dass das Feld meistens leer ist, denn meistens sind die Adapter Uptodate. Es müsste also so sein, dass wenn der Wert eines Feldes leer ist, die Info nicht angezeigt wird.
                                          Aber so langsam wirds... :-)
