  4. [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr
    6.4k
53 Beiträge 4 Kommentatoren 6.1k Aufrufe 3 Beobachtet
  • BerserkerB Berserker
    Das kommt dabei raus
    pi@pi:~ $ cd /opt/iobroker
    pi@pi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.12
    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
    ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
       Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
    In file included from ../authenticate_pam.cc:23:
    ../../nan/nan.h:1026:46: note: declared here
       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
    In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,
                     from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,
                     from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,
                     from ../../nan/nan.h:56,
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here
       V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
    In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
       int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
    ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
    ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      username->WriteUtf8(m->username, sizeof(m->username) - 1);
    ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      password->WriteUtf8(m->password, sizeof(m->password) - 1);
    ../authenticate_pam.cc: At global scope:
    ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
     void init(Handle<Object> exports) {
    ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
               rand_r
    ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
    In file included from ../../nan/nan.h:56,
    ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
     NODE_MODULE(authenticate_pam, init);
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.10.17-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v12.22.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
     Cannot read system.config: null (OK when migrating or restoring)
    object 0_userdata.0.example_state created
    object 0_userdata.0 created
    object alias.0 created
    object system.certificates created
    object system.repositories created
    object system.config created
    object enum.functions created
    object enum.rooms created
    object system.group.user created
    object system.group.administrator created
    object _design/system created
    The following notifications happened during sync:
    - Ignoring Directory "admin.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "alexa2.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "deconz.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "eufy-security.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "history.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "homee.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "hue.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "info.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "javascript.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "ph803w.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "sonos.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "web" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "web.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "yahka.admin" because officially not created as meta object. Please remove directory!
    Renamed repository "default to "stable"
    Renamed repository "latest to "beta"
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.js-controller@3.2.16
    added 13 packages from 33 contributors in 35.592s
    54 packages are looking for funding
      run `npm fund` for details
       │      New major version of npm available! 6.14.12 → 7.19.0      │
       │   Changelog: https://github.com/npm/cli/releases/tag/v7.19.0   │
       │               Run npm install -g npm to update!                │
    @berserker Der erste Teil mit den Fehlern stammt vom terminal-Adapter. Den würde ich rauswerfen, wenn das System wieder läuft.
    iobroker restart
    iobroker status
    iobroker list instances
    BerserkerB 1 Antwort Letzte Antwort
      Ok
      Ich bin dankbar für jeden Tipp.
      Verstehen tue ich das alles nicht, ich copy paste nur was anscheinend bei anderen funktioniert haben soll :(
      internal/modules/cjs/loader.js:818
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      @berserker sagte in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
      wenn du so etwas machst musst du aber genau darauf achten, für welche Installation diese codes genutzt wurden.
      Da hat sich in den 7 Jahren ioBroker einiges geändert
        iobroker restart
        iobroker status
        BerserkerB Offline
        BerserkerB Offline
        Berserker
        Okay werde ich machen
        Ausgabe ist folgendes:
        pi@pi:/opt/iobroker $ iobroker restart
        pi@pi:/opt/iobroker $ iobroker status
        Objects type: file
        States  type: file
        pi@pi:/opt/iobroker $ iobroker list instances
        + instance is alive
        Danke schonmal für die Hilfe!!
          Objects type: file
          States  type: file
          + instance is alive
          @berserker
          iobroker list adapters
            @berserker
            BerserkerB Offline
            BerserkerB Offline
            Berserker
            da kommt nichts
            pi@pi:/opt/iobroker $ iobroker list adapters
              da kommt nichts
              @berserker Okay.
              iobroker add admin
                > node-gyp rebuild
                           rand_r
                gyp ERR! not ok
                Da gibt's Arbeit für das Mini HowTo
                  @berserker Okay.
                  iobroker add admin
                  BerserkerB Offline
                  BerserkerB Offline
                  Berserker
                  @thomas-braun said in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
                  iobroker add admin
                  pi@pi:/opt/iobroker $ iobroker add admin
                  host.pi install adapter admin
                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                  host.pi object system.adapter.admin created/updated
                  host.pi create instance admin
                  host.pi object admin.0.info.newsETag created
                  host.pi object admin.0.info.newsfeed created
                  host.pi object admin.0.connected created
                  host.pi object admin.0 created
                  host.pi object admin.0.info created
                  host.pi object system.adapter.admin.upload created
                  host.pi object system.adapter.admin.0.logLevel created
                  host.pi object system.adapter.admin.0.sigKill created
                  host.pi object system.adapter.admin.0.eventLoopLag created
                  host.pi object system.adapter.admin.0.outputCount created
                  host.pi object system.adapter.admin.0.inputCount created
                  host.pi object system.adapter.admin.0.uptime created
                  host.pi object system.adapter.admin.0.memRss created
                  host.pi object system.adapter.admin.0.memHeapTotal created
                  host.pi object system.adapter.admin.0.memHeapUsed created
                  host.pi object system.adapter.admin.0.cputime created
                  host.pi object system.adapter.admin.0.cpu created
                  host.pi object system.adapter.admin.0.compactMode created
                  host.pi object system.adapter.admin.0.connected created
                  host.pi object system.adapter.admin.0.alive created
                  host.pi object system.adapter.admin.0 created
                  Thomas BraunT BerserkerB 2 Antworten Letzte Antwort
                    iobroker add admin
                    @berserker
                    Läuft der Admin jetzt?
                      iobroker add admin
                      BerserkerB Offline
                      BerserkerB Offline
                      Berserker
                      @berserker
                      Die Web Oberfläche ist wieder da.
                      Ich lass erstmal die Finger weg bis du etwas dazu sagst.
                        @berserker
                        BerserkerB Offline
                        BerserkerB Offline
                        Berserker
                        + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + instance is alive
                          @berserker
                          @berserker Dann solltest du jetzt die fehlenden Adapter ja nachinstallieren können.
                            BerserkerB Offline
                            BerserkerB Offline
                            Berserker
                            Wenn ich jetzt die fehlenden Adapter nachinstalliert, sind die Settings dann noch da ??
                            Vielen Dank erstmal
                              BerserkerB Offline
                              BerserkerB Offline
                              Berserker
                              Wenn ich Adapter installieren möchte, dann steht bei den Adaptern die ich hatte, dass schon einer Installiert ist.
                              Kann ich zB. den Skripte Adapter irgendwie mit den alten Skripten herunterladen?
                                BerserkerB Offline
                                BerserkerB Offline
                                Berserker
                                @berserker
                                So wie hier
                                  Vielen Dank erstmal
                                  @berserker Vermutlich so einfach nicht.
                                  Du kannst jetzt Mal nach dem
                                  https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1625594165671
                                  versuchen die alten Einstellungen herbeizaubern.
                                    @berserker
                                    So wie hier
                                    @berserker
                                    Und ein
                                    iobroker stop
                                    iobroker fix
                                    kann auch nicht Schaden.
                                      @berserker
                                      Und ein
                                      iobroker stop
                                      iobroker fix
                                      BerserkerB Offline
                                      BerserkerB Offline
                                      Berserker
                                      Hab ich getan
                                      Eine frage:
                                      Der Post den du mir verlinkt hast ist doch nur um den Iobroker wieder an laufen zu bekommen oder?
                                      Ich wüsste nicht an welcher Stelle ich da jetzt einsteigen müsste.
                                      Wäre dankbar wenn du mir noch einmal helfen könntest.
                                      Und könnte es sein das die Daten noch da sind, da ja mir angezeigt wird das die Instanzen installiert sind. Ich kann sie im der Instanzen Liste und in den Objekten nur leider nicht sehen.
                                        Hab ich getan
                                        Eine frage:
                                        @berserker
                                        Du kannst probieren per
                                        iobroker upload all
                                        Oder aus dem Mini-HowTo deine alten states und objects wieder herstellen.
                                          @berserker
                                          iobroker upload all
                                          BerserkerB Offline
                                          BerserkerB Offline
                                          Berserker
                                          pi@pi:/opt/iobroker $ iobroker upload all
                                          upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                          upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                          upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                          upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                          upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                          upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                          upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                                          upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                                          upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                                          upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                                          upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                                          upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                          upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                          upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                                          upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                                          upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                                          upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                          upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                                          upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                                          upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                          upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                          upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                          upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                          upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                          upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                          upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                          upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                          Update "system.adapter.info.0"
                                          upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                                          upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                                          upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                                          upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                                          upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                                          upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                                          upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                                          upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                                          upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                                          Update "system.adapter.deconz.0"
                                          Update "system.adapter.admin.0"
                                          Das kommt bei raus.
                                          Ich finde irgendwie keinen Post indem etwas in dem Sinne zu finden ist
                                          Abgesehen davon erstmal meinen Respekt und ein großes Danke für deine Hilfe!!
