  4. [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr
    6.5k
53 Beiträge 4 Kommentatoren 6.1k Aufrufe 3 Beobachtet
    @berserker
    iobroker list adapters
    BerserkerB Offline
    BerserkerB Offline
    Berserker
    da kommt nichts
    pi@pi:/opt/iobroker $ iobroker list adapters
    • BerserkerB Berserker
      da kommt nichts
      @berserker Okay.
      iobroker add admin
      BerserkerB 1 Antwort Letzte Antwort
        Das kommt dabei raus
        pi@pi:~ $ cd /opt/iobroker
        pi@pi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.12
        > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
          CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
        ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
        ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
           Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
        In file included from ../authenticate_pam.cc:23:
        ../../nan/nan.h:1026:46: note: declared here
           NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
        ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
        In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,
                         from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,
                         from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,
                         from ../../nan/nan.h:56,
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here
           V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
            serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
        In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
           int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
        ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
        ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
            remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
        ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
          username->WriteUtf8(m->username, sizeof(m->username) - 1);
        ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
          password->WriteUtf8(m->password, sizeof(m->password) - 1);
        ../authenticate_pam.cc: At global scope:
        ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
         void init(Handle<Object> exports) {
        ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
        ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
                   rand_r
        ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
        ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
        In file included from ../../nan/nan.h:56,
        ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
         NODE_MODULE(authenticate_pam, init);
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’
               (node::addon_register_func) (regfunc),                          \
        ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
        ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
        make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
        gyp ERR! System Linux 5.10.17-v7l+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
        gyp ERR! node -v v12.22.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
         Cannot read system.config: null (OK when migrating or restoring)
        object 0_userdata.0.example_state created
        object 0_userdata.0 created
        object alias.0 created
        object system.certificates created
        object system.repositories created
        object system.config created
        object enum.functions created
        object enum.rooms created
        object system.group.user created
        object system.group.administrator created
        object _design/system created
        The following notifications happened during sync:
        - Ignoring Directory "admin.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "alexa2.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "deconz.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "eufy-security.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "history.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "homee.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "hue.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "info.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "javascript.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "ph803w.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "sonos.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "web" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "web.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "yahka.admin" because officially not created as meta object. Please remove directory!
        Renamed repository "default to "stable"
        Renamed repository "latest to "beta"
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        + iobroker.js-controller@3.2.16
        added 13 packages from 33 contributors in 35.592s
        54 packages are looking for funding
          run `npm fund` for details
           │      New major version of npm available! 6.14.12 → 7.19.0      │
           │   Changelog: https://github.com/npm/cli/releases/tag/v7.19.0   │
           │               Run npm install -g npm to update!                │
        @berserker sagte in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
        Da gibt's Arbeit für das Mini HowTo
          @berserker Okay.
          iobroker add admin
          BerserkerB Offline
          BerserkerB Offline
          Berserker
          @thomas-braun said in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
          iobroker add admin
          pi@pi:/opt/iobroker $ iobroker add admin
          host.pi install adapter admin
          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
          host.pi object system.adapter.admin created/updated
          host.pi create instance admin
          host.pi object admin.0.info.newsETag created
          host.pi object admin.0.info.newsfeed created
          host.pi object admin.0.connected created
          host.pi object admin.0 created
          host.pi object admin.0.info created
          host.pi object system.adapter.admin.upload created
          host.pi object system.adapter.admin.0.logLevel created
          host.pi object system.adapter.admin.0.sigKill created
          host.pi object system.adapter.admin.0.eventLoopLag created
          host.pi object system.adapter.admin.0.outputCount created
          host.pi object system.adapter.admin.0.inputCount created
          host.pi object system.adapter.admin.0.uptime created
          host.pi object system.adapter.admin.0.memRss created
          host.pi object system.adapter.admin.0.memHeapTotal created
          host.pi object system.adapter.admin.0.memHeapUsed created
          host.pi object system.adapter.admin.0.cputime created
          host.pi object system.adapter.admin.0.cpu created
          host.pi object system.adapter.admin.0.compactMode created
          host.pi object system.adapter.admin.0.connected created
          host.pi object system.adapter.admin.0.alive created
          host.pi object system.adapter.admin.0 created
          Thomas BraunT BerserkerB 2 Antworten Letzte Antwort
            iobroker add admin
            @berserker
            Läuft der Admin jetzt?
            iobroker list instances
              iobroker add admin
              BerserkerB Offline
              BerserkerB Offline
              Berserker
              @berserker
              Die Web Oberfläche ist wieder da.
              Ich lass erstmal die Finger weg bis du etwas dazu sagst.
                @berserker
                BerserkerB Offline
                BerserkerB Offline
                Berserker
                pi@pi:/opt/iobroker $ iobroker list instances
                + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + instance is alive
                  @berserker
                  @berserker Dann solltest du jetzt die fehlenden Adapter ja nachinstallieren können.
                    BerserkerB Offline
                    BerserkerB Offline
                    Berserker
                    Wenn ich jetzt die fehlenden Adapter nachinstalliert, sind die Settings dann noch da ??
                    Vielen Dank erstmal
                      BerserkerB Offline
                      BerserkerB Offline
                      Berserker
                      Wenn ich Adapter installieren möchte, dann steht bei den Adaptern die ich hatte, dass schon einer Installiert ist.
                      Kann ich zB. den Skripte Adapter irgendwie mit den alten Skripten herunterladen?
                        BerserkerB Offline
                        BerserkerB Offline
                        Berserker
                        @berserker
                        So wie hier
                          Vielen Dank erstmal
                          @berserker Vermutlich so einfach nicht.
                          Du kannst jetzt Mal nach dem
                          https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1625594165671
                          versuchen die alten Einstellungen herbeizaubern.
                            @berserker
                            So wie hier
                            @berserker
                            Und ein
                            iobroker stop
                            iobroker fix
                            kann auch nicht Schaden.
                              @berserker
                              Und ein
                              iobroker stop
                              iobroker fix
                              BerserkerB Offline
                              BerserkerB Offline
                              Berserker
                              Hab ich getan
                              Eine frage:
                              Der Post den du mir verlinkt hast ist doch nur um den Iobroker wieder an laufen zu bekommen oder?
                              Ich wüsste nicht an welcher Stelle ich da jetzt einsteigen müsste.
                              Wäre dankbar wenn du mir noch einmal helfen könntest.
                              Und könnte es sein das die Daten noch da sind, da ja mir angezeigt wird das die Instanzen installiert sind. Ich kann sie im der Instanzen Liste und in den Objekten nur leider nicht sehen.
                                Hab ich getan
                                Eine frage:
                                @berserker
                                Du kannst probieren per
                                iobroker upload all
                                Oder aus dem Mini-HowTo deine alten states und objects wieder herstellen.
                                  @berserker
                                  iobroker upload all
                                  BerserkerB Offline
                                  BerserkerB Offline
                                  Berserker
                                  pi@pi:/opt/iobroker $ iobroker upload all
                                  upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                  upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                  upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                  upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                  upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                  upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                  upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                                  upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                                  upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                                  upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                                  upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                                  upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                  upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                  upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                                  upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                                  upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                                  upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                  upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                                  upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                                  upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                  upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                  upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                  upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                  upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                  upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                  upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                  upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                  Update "system.adapter.info.0"
                                  upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                                  upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                                  upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                                  upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                                  upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                                  upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                                  upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                                  upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                                  upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                                  Update "system.adapter.deconz.0"
                                  Update "system.adapter.admin.0"
                                  Das kommt bei raus.
                                  Ich finde irgendwie keinen Post indem etwas in dem Sinne zu finden ist
                                  Abgesehen davon erstmal meinen Respekt und ein großes Danke für deine Hilfe!!
                                    Hab ich getan
                                    Eine frage:
                                    am Anfang.
                                    weil es wahrsche7nlich die Datenbanken der Objekte ind States terschossen hat
                                    die stellst du mit der verlinkten Anleit6ng aus deren internen backups wieder her
                                      am Anfang.
                                      BerserkerB Offline
                                      BerserkerB Offline
                                      Berserker
                                      @homoran @homoran
                                      pi@pi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/backup-objects/
                                      insgesamt 45036
                                      drwxrwxrwx+ 2 iobroker iobroker   4096 Jul  6 20:13 .
                                      drwxrwxrwx+ 8 iobroker iobroker   4096 Jul  6 20:22 ..
                                      -rwxrwxrwx+ 1 iobroker iobroker 978138 Jul  4 20:37 2021-07-04_20-37_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 585862 Jul  4 21:32 2021-07-04_21-32_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978121 Jul  4 22:37 2021-07-04_22-37_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 677255 Jul  4 23:32 2021-07-04_23-32_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978113 Jul  5 00:44 2021-07-05_00-44_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 667109 Jul  5 01:32 2021-07-05_01-32_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 02:44 2021-07-05_02-44_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 667112 Jul  5 03:32 2021-07-05_03-32_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978125 Jul  5 04:46 2021-07-05_04-46_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 718539 Jul  5 05:32 2021-07-05_05-32_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978141 Jul  5 06:54 2021-07-05_06-54_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 762710 Jul  5 07:33 2021-07-05_07-33_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978086 Jul  5 09:02 2021-07-05_09-02_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 762745 Jul  5 09:33 2021-07-05_09-33_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978115 Jul  5 11:02 2021-07-05_11-02_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 843746 Jul  5 11:33 2021-07-05_11-33_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 13:02 2021-07-05_13-02_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 675898 Jul  5 13:33 2021-07-05_13-33_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 15:03 2021-07-05_15-03_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 735153 Jul  5 15:34 2021-07-05_15-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 978339 Jul  5 17:04 2021-07-05_17-04_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 760527 Jul  5 17:34 2021-07-05_17-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 985171 Jul  5 19:04 2021-07-05_19-04_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 750921 Jul  5 19:34 2021-07-05_19-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 985169 Jul  5 21:05 2021-07-05_21-05_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 749874 Jul  5 21:34 2021-07-05_21-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 985157 Jul  5 23:05 2021-07-05_23-05_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 876184 Jul  5 23:34 2021-07-05_23-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 985178 Jul  6 01:05 2021-07-06_01-05_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 876145 Jul  6 01:34 2021-07-06_01-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984256 Jul  6 03:15 2021-07-06_03-15_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 876278 Jul  6 03:34 2021-07-06_03-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984275 Jul  6 05:15 2021-07-06_05-15_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 876270 Jul  6 05:34 2021-07-06_05-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984292 Jul  6 07:16 2021-07-06_07-16_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 805282 Jul  6 07:34 2021-07-06_07-34_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984302 Jul  6 09:16 2021-07-06_09-16_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 810170 Jul  6 09:35 2021-07-06_09-35_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984304 Jul  6 11:16 2021-07-06_11-16_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 796188 Jul  6 11:35 2021-07-06_11-35_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984288 Jul  6 13:16 2021-07-06_13-16_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 650163 Jul  6 13:36 2021-07-06_13-36_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984294 Jul  6 15:16 2021-07-06_15-16_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 652989 Jul  6 15:36 2021-07-06_15-36_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 984240 Jul  6 17:21 2021-07-06_17-21_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 681146 Jul  6 17:36 2021-07-06_17-36_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker   3487 Jul  6 18:41 2021-07-06_18-41_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 681758 Jul  6 19:01 2021-07-06_19-01_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:03 2021-07-06_19-03_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 681483 Jul  6 19:04 2021-07-06_19-04_states.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:05 2021-07-06_19-05_objects.json.gz
                                      -rwxrwxrwx+ 1 iobroker iobroker 681482 Jul  6 19:06 2021-07-06_19-06_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:37 2021-07-06_19-37_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 681474 Jul  6 19:37 2021-07-06_19-37_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:42 2021-07-06_19-42_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 681484 Jul  6 19:43 2021-07-06_19-43_states.json.gz
                                      -rw-rw-r--+ 1 iobroker iobroker 684488 Jul  6 20:06 2021-07-06_20-06_objects.json.gz
                                      -rw-rw-r--+ 1 iobroker iobroker 682204 Jul  6 20:06 2021-07-06_20-06_states.json.gz
                                      -rw-rw-r--+ 1 iobroker iobroker 684596 Jul  6 20:13 2021-07-06_20-13_objects.json.gz
                                      -rw-rw-r--+ 1 iobroker iobroker 682357 Jul  6 20:13 2021-07-06_20-13_states.json.gz
                                      Sagt das was aus?
                                      Ich habe außerdem über Backitup vor einer Woche ein Backup gemacht.
                                      Weiß einer wie ich das vielleicht wiederherstellen könnte?
                                      Thomas BraunT BerserkerB HomoranH F 4 Antworten Letzte Antwort
                                        @homoran @homoran
                                        insgesamt 45036
                                        Sagt das was aus?
                                        @berserker
                                        ist die letzte intakte Datei. Die nächste ist kaputt.
                                          @homoran @homoran
                                          insgesamt 45036
                                          Sagt das was aus?
                                          BerserkerB Offline
                                          BerserkerB Offline
                                          Berserker
                                          @berserker
                                          Ich kann sogar Adapter, die vorher installiert waren Updaten.
                                          Dann ist doch noch nicht alles verloren oder?
                                          $ ./iobroker upgrade backitup
                                          Update backitup from @2.1.11 to @2.1.13
                                          npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (System call)
                                          ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
                                          ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here
                                             V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~
                                          /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                             res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^
                                          In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                                          ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^
                                          ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~
                                           void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^
                                          ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
                                                           from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                                          gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                          gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.10.17-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.22.1gyp ERR! node-gyp -v v5.1.0
                                          gyp ERR! not ok
                                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                          Adapter "backitup" updated
                                          process exited with code 0
                                          Das ist jetzt aber eine Ausgabe aus diesem Fenster:
