  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 504.0k Aufrufe 82 Beobachtet
  • S saeft_2003
    @thomas-braun @Meistertr
    Gerade war er aktiv und es gab wieder einen crash. Ich kann mir nicht erklären an was das liegt?
    host.iobroker	2021-06-29 08:44:16.591	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at UDP.onMessage (dgram.js:921:8)
    host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
    host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.emit (events.js:326:22)
    host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
    host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
    host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Decipheriv.final (internal/crypto/cipher.js:172:29)
    host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Object.final (<anonymous>)
    host.iobroker	2021-06-29 08:44:16.588	error	Caught by controller[0]: Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	at UDP.onMessage (dgram.js:921:8)
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.EventEmitter.emit (domain.js:483:12)
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.emit (events.js:326:22)
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Decipheriv.final (internal/crypto/cipher.js:172:29)
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Object.final (<anonymous>)
    mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    mihome-vacuum.0	2021-06-29 08:44:16.284	error	(27481) uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
    MeistertrM Offline
    MeistertrM Offline
    Meistertr
    schrieb am zuletzt editiert von Meistertr
    #243
    @saeft_2003 scheint dass die Massage vom Roboter nicht korrekt ankommt aufgrund irgendwelcher netzwerkstörungen und sie dann nicht korrekt decodiert werden kann, werde den Fehler abfangen bitte eben ein Issue für anlegen
    • S saeft_2003
      #244
      @saeft_2003 Bitte mal GitHub Version versuchen ... damit auch noch oder weg?
      • apollon77A apollon77
        saeft_2003
        schrieb am zuletzt editiert von saeft_2003
        #245
        @apollon77 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
        Hab ich installiert, aber auch nach 10 min warten wird der Adapter nicht mehr grün. Ich weiß nicht ob es ein dummer Zufall ist (weil gestern bin ich auch aus der app gefolgen und musste mich neu anmelden) oder ob das update schuld ist.
        Aber ich tippe auf das Update weil bevor ich das gemacht habe warn auch keine warn/error im log. Kanns du das auf github wieder anpassen oder zurück ändern?
        p.s. ich habe gerade ein snapshot eingespielt und jetzt ist der adapter wieder grün.
        mihome-vacuum.0	2021-06-30 07:30:42.607	warn	(16620) No Answer for DeviceModel use model from Config
        mihome-vacuum.0	2021-06-30 07:30:42.607	warn	(16620) No Answer for DeviceModel use old one
        mihome-vacuum.0	2021-06-30 07:30:42.606	warn	(16620) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
        mihome-vacuum.0	2021-06-30 07:29:25.066	error	(16033) Socket Close
        mihome-vacuum.0	2021-06-30 07:19:47.012	warn	(16033) No Answer for DeviceModel use model from Config
        mihome-vacuum.0	2021-06-30 07:19:47.012	warn	(16033) No Answer for DeviceModel use old one
        mihome-vacuum.0	2021-06-30 07:19:47.011	warn	(16033) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
        mihome-vacuum.0	2021-06-30 07:19:41.065	error	(15781) Socket Close
        mihome-vacuum.0	2021-06-30 07:16:02.260	warn	(15781) No Answer for DeviceModel use model from Config
        mihome-vacuum.0	2021-06-30 07:16:02.260	warn	(15781) No Answer for DeviceModel use old one
        mihome-vacuum.0	2021-06-30 07:16:02.259	warn	(15781) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
        • S saeft_2003
          #246
          @saeft_2003 Ok, dann bitte hier GitHub Issue anlegen ... Welche Version hattest Du vorher? Die 3.2.0?
            saeft_2003
            #247
            @apollon77
            ja ich hatte vorher die 3.2.0 schon drauf. ich habe jetzt auf das bestehende issues geantwortet. Reicht das, oder soll ich ein komplett neues erstellen?
            p.s. ich habe bei git noch nicht geschnallt wie man in code tags postet?!
            apollon77A 2 Antworten Letzte Antwort
            • S saeft_2003
              @apollon77
              #248
              @saeft_2003 Wie sieht das Log bei 3.2.0 aus?
              • S saeft_2003
                @apollon77
                #249
                @saeft_2003 PS: Versuch GitHub version bitte nochmal
                  saeft_2003
                  #250
                  @apollon77
                  Kann ich machen, gibt es eine einfache Möglichkeit falls diese nicht funktioniert wieder zurück auf die jetzige zu gehen?
                  • S saeft_2003
                    @apollon77
                    da_WoodyD Offline
                    da_WoodyD Offline
                    #251
                    @saeft_2003 adapter ansicht, experten modus aktivieren,fa26e46f-a519-4c4d-ae57-9995728df3d3-grafik.png anklicken, dann kannst du dir die verion aussuchen...
                    • da_WoodyD da_Woody
                      saeft_2003
                      #252
                      @da_woody
                      ja das kenne ich. Ich glaube aber apollon hat nicht eine 3.2.1 gemacht sondern die 3.2.0 angepasst.
                      Oder ich steh auf dem Schlauch :man-shrugging:
                      • S saeft_2003
                        @da_woody
                        da_WoodyD Offline
                        da_WoodyD Offline
                        #253
                        @saeft_2003 sorry, nicht auf github geschaut. sieht so aus, wie wenn er die 3.0.2 geändert hat. sind auch dokumentiert...
                        • apollon77A Offline
                          #254
                          Die 3.2.0 ist auf npm, meine Änderungen jur auf GitHub, damit einfach npm version installieren ist der Weg zurück. im zweifel ein "npm i iobroker.mihome-vacuum && iob upload mihome-vacuum" im iobroker verzeichnis
                            saeft_2003
                            #255
                            @apollon77
                            ich habe wieder über git aktualisiert --> Adapter bleibt weiterhin gelb!
                            Dann hab ich über die Kommandozeile versucht wieder die alte Version zu bekommen dann kommt der Fehler:
                            patrick@iobroker:/opt/iobroker$ npm i iobroker-mihome-vacuum && iob upload mihom        e-vacuum
                            npm ERR! code E404
                            npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker-mihome-vacuum -        Not found
                            npm ERR! 404
                            npm ERR! 404  'iobroker-mihome-vacuum@latest' is not in the npm registry.
                            npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                            npm ERR! 404
                            npm ERR! 404 Note that you can also install from a
                            npm ERR! 404 tarball, folder, http url, or git url.
                            npm ERR!     /home/patrick/.npm/_logs/2021-06-30T08_55_04_846Z-debug.log
                            Also habe ich wieder ein Snapshot eingespielt, gut das ich proxmox nutze ;-)
                            Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                            • S saeft_2003
                              @apollon77
                              npm ERR! code E404
                              npm ERR! 404
                              npm ERR! 404
                              #256
                              @saeft_2003 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                              Falscher Modulname.
                              Das dürfte
                              lauten müssen.
                                Falscher Modulname.
                                Das dürfte
                                lauten müssen.
                                saeft_2003
                                #257
                                Ah das könnte gut sein.
                                • S saeft_2003
                                  #258
                                  @saeft_2003 Ja sorry ,,, typio von mir ... fixed oben
                                  • S saeft_2003
                                    @apollon77
                                    npm ERR! code E404
                                    npm ERR! 404
                                    npm ERR! 404
                                    #259
                                    Dann muss @Meistertr checken ... :-( Ich kapiere nicht warum das passiert
                                      #260
                                      Ok, @Meistertr hat den Fehlert gefunden. Bitte GitHub Version nochmal checken
                                        saeft_2003
                                        #261
                                        @apollon77 @Meistertr
                                        ist installiert --> adapter wird grün --> reinigung läuft im Moment
                                        In ein paar Tagen kann ich Rückmeldung geben ob die Adapter crashs noch vorkommen oder nicht. Vielen Dank soweit!!!
                                        Edit: Es kam gerade wieder ein Error (der gleiche wie bei den Adapter crashs), aber der Adapter ist diesmal nicht gecrasht.
                                        mihome-vacuum.0	2021-07-01 08:47:45.919	error	(13809) Socket Close
                                        • S saeft_2003
                                          #262
                                          @saeft_2003 Ich denke das hesist erstmal nur das der Adaper die verbindung zum Gerät verlorten hat ... denke er baut die dann neu auf. Wenn noch alles tut wäre das in meinen Augen ok
                                          S 2 Antworten Letzte Antwort
