  4. Test Adapter Alarm 3.6.x
    6.7k
alarmalarmanlagealarmsystem
1.4k Beiträge 111 Kommentatoren 685.9k Aufrufe 115 Beobachtet
  • hg6806H Offline
    hg6806H Offline
    hg6806
    schrieb am zuletzt editiert von hg6806
    #933
    Moin!
    Morgen früh geht's in den Urlaub und da wollte ich den Alarm mal testen.
    Der Adapter bleibt rot und im Log steht folgende Fehlermeldung:
    host.raspberrypi
    2021-05-31 07:48:51.229	error	instance system.adapter.alarm.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    alarm.0
    2021-05-31 07:48:50.564	error	The id is empty! Please provide a valid id.
    alarm.0
    2021-05-31 07:48:50.563	error	Error: The id is empty! Please provide a valid id. at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:496:19) at Adapter.getForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6679:17) at /opt/iobroker/node_modules/iobroker.alarm/main.js:1358:17 at new Promise (<anonymous>) at get_state_async (/opt/iobroker/node_modules/iobroker.alarm/main.js:1357:12) at get_states_delay (/opt/iobroker/node_modules/iobroker.alarm/main.js:1370:25) at get_other_states (/opt/iobroker/node_modules/iobroker.alarm/main.js:1388:33) at Object.main [as ready] (/opt/iobroker/node_modules/iobroker.alarm/main.js:199:5) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8478:76
    alarm.0
    2021-05-31 07:48:50.559	error	unhandled promise rejection: The id is empty! Please provide a valid id.
    alarm.0
    2021-05-31 07:48:50.554	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi
    2021-05-31 07:48:33.558	error	instance system.adapter.alarm.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    alarm.0
    2021-05-31 07:48:32.895	error	The id is empty! Please provide a valid id.
    alarm.0
    2021-05-31 07:48:32.894	error	Error: The id is empty! Please provide a valid id. at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:496:19) at Adapter.getForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6679:17) at /opt/iobroker/node_modules/iobroker.alarm/main.js:1358:17 at new Promise (<anonymous>) at get_state_async (/opt/iobroker/node_modules/iobroker.alarm/main.js:1357:12) at get_states_delay (/opt/iobroker/node_modules/iobroker.alarm/main.js:1370:25) at get_other_states (/opt/iobroker/node_modules/iobroker.alarm/main.js:1388:33) at Object.main [as ready] (/opt/iobroker/node_modules/iobroker.alarm/main.js:199:5) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8478:76
    alarm.0
    2021-05-31 07:48:32.891	error	unhandled promise rejection: The id is empty! Please provide a valid id.
    alarm.0
    2021-05-31 07:48:32.890	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Welche ID fehlt hier?
    Es ging ja sonst immer.
    • hg6806H hg6806
      Moin!
      host.raspberrypi
      alarm.0
      alarm.0
      alarm.0
      alarm.0
      host.raspberrypi
      alarm.0
      alarm.0
      alarm.0
      alarm.0
      #934
      @hg6806 Ich denke ein GitHub Issue hilft auch das der Entwickler es sieht. Da wird scheinbar eine leere ID versucht zu lesen.
      • hg6806H Offline
        hg6806H Offline
        hg6806
        #935
        Es war ein Homematic Rauchmelder, der nicht erreichbar war.
        F 1 Antwort Letzte Antwort
        • hg6806H hg6806
          Frank579
          #936
          @blauholsten Ich habe ein kleines Problemchen mit dem Adapter ... Habe kürzlich IOBroker von einm LXC auf eine VM umgezogen, seit dem bekomme ich nach einer Auslösung keine Meldungen mehr. Sprich es kommt die Meldung das ein melder Ausgelösß hat und danach wenn ein weiterer Melder auslöst kommt keine weitere Meldung mehr. Bei der Alten Installation war das anders nicht so. Habe schon x mal die Einstellungen gecheckt, alles gleich. Auch auf beiden Systemen die Version 2.0.1 hast du eine Idee was das sein könnte / ist das absicht ?
          blauholstenB 1 Antwort Letzte Antwort
          • F Frank579
            blauholstenB Offline
            blauholsten
            #937
            @frank579 Hallo,
            das lässt sich natürlich von der Ferne schlecht beurteilen. Was sagt denn der log
            - Alarm Adapter
            • blauholstenB blauholsten
              @frank579 Hallo,
              Frank579
              #938
              @blauholsten
              Hi danke für deine schnelle Antwort habe eben noch was rum getetet , ist wohl nur beim Alarmkreis so.
              Schalte scharf , löse einen melder aus dem innen Kreis aus -> meldung dann einen aus dem Alarmkreis -> Meldung und burgle wenn ich dann noch einen aus dem Alarmkreis auslöse passiert nicht, beim Innen Kreis bekomme ich eine weitere meldung ... im Log sehe ich nichts ....
              • F Frank579
                @blauholsten
                blauholsten
                #939
                @frank579 Hallo,
                Ich habe mir den Code nochmal angeschaut, eigentlich kommt definitiv keine weitere Meldungen, da das System quasi im Einbruchsmodus ist.
                Dies war aber eigentlich schon immer so.:man-shrugging:
                - Alarm Adapter
                  @frank579 Hallo,
                  Frank579
                  #940
                  @blauholsten Hallo, okay danke, hatte echt im Kopf wäre mal anders gewesen...
                  Dann mache ich mir mit blockly noch was wenn die Anlage ausgelöst hat ....
                  • F Frank579
                    blauholsten
                    #941
                    @frank579 sagte in Test Adapter Alarm 2.0.x:
                    Genau das, war nicht der Grundgedanke des Adapters. Rein logisch gedacht, ist es überhaupt sinnig noch weitere Auslöser zu melden???
                    - Alarm Adapter
                      Frank579
                      #942
                      @blauholsten sagte in Test Adapter Alarm 2.0.x:
                      Das glaube ich dir ja ☺️ der Adapter ist ja auch super nutze ihn schon lange. Vielen Dank erst Mal dafür 👍
                      Ist halt derzeit bei mir so das ich gerne wissen möchte was nach der Auslosung noch weiter passiert ist/ welche Räume nach der ersten Auslösung noch betreten wurden etc.
                        Marsx79
                        schrieb am zuletzt editiert von Marsx79
                        #943
                        @blauholsten
                        Ist es vielleicht möglich bei dem Menüpunkt "Sprachausgabe" einzelne Ansagen abzuschalten. Gut wäre es wenn man einzelne Ansagen einfach deaktivieren könnte (eine Feld mit Häkchen z.B.) und der Text erhalten bleibt.
                        Oder geht das vielleicht sogar bereits und ich finde es nicht? :)
                        • M Marsx79
                          @blauholsten
                          blauholsten
                          #944
                          @marsx79 Hallo,
                          ist möglich, sogar bei jedem einzelnen Gerät. Einfach den Haken entsprechend raus nehmen.
                          - Alarm Adapter
                            @marsx79 Hallo,
                            Marsx79
                            #945
                            @blauholsten
                            Ups hatte ioBroker neu aufgesetzt und noch kein Gerät für die Sprachausgabe hinzugefügt. Jetzt sehe ich auch das es da geht. Sorry! :man-facepalming:
                            • O Offline
                              O Offline
                              Octopyrox
                              #946
                              vielen Dank für den coolen Adapter!! Funktioniert super aber eins versteh ich nicht.
                              Warum kann die Anlage nicht scharf geschaltet werden, wenn noch ein Fenster o. ä. offen ist.
                              Hinweis ist ja OK aber dann nicht scharf schalten find ich unpraktisch.
                              Oder kann man das irgendwo einstellen?
                              Danke und Gruß
                              Markus
                              • O Octopyrox
                                Danke und Gruß
                                Markus
                                blauholsten
                                #947
                                @octopyrox
                                Aud der ersten Seite in den Einstellungen, findest du die Option, aktivieren mit Warnungen.
                                - Alarm Adapter
                                O 1 Antwort Letzte Antwort
                                • H Offline
                                  HamburgMeinePerle
                                  #948
                                  Moin,
                                  ich teste gerade den Adapter.
                                  Solange ich den State auf "enable" stelle, funktioniert alles super.
                                  allerdings löst mein System keinen Alarm aus wenn ich auf "sharp inside" stelle. Ich bekomme eine Whatsapp, aber die Datenpunkte "silent alarm" und "burgle" bleiben false.
                                  Bis auf negieren habe ich alle Auswahlfelder bei der Überwachung aktiviert (ist nur ein Fensteröffner zum testen).
                                  Ist das so richtig?
                                    @octopyrox
                                    O Offline
                                    O Offline
                                    Octopyrox
                                    #949
                                    @blauholsten Hallo Blauholstein,
                                    Vielleicht stell ich mich blöd an aber was meinst du hier?
                                    Meinst du "Konf. Zustände bei..."?
                                    • O Octopyrox
                                      blauholsten
                                      #950
                                      @octopyrox
                                      jup, ....ich denke da hat sich ein Übersetzungsfehler eingeschlichen
                                      - Alarm Adapter
                                      • H HamburgMeinePerle
                                        Moin,
                                        Ist das so richtig?
                                        blauholsten
                                        #951
                                        @hamburgmeineperle
                                        Stiller Alarm und Einbruch, werden nur bei sharp gesetzt. Für Scharff innen gibt es separate Datenpunkte.
                                        - Alarm Adapter
                                        H 1 Antwort Letzte Antwort
                                        • D dodi666
                                          @blauholsten:
                                          Ich habe derzeit deinen tollen Adapter in meinem Testsystem installiert, und versuche die Funktionen meiner bisherigen Alarmanlage in Homematic auf diesen zu übertragen.
                                          Ich habe dort die Vorwahl zur Scharfschaltung der Alarmanlage so realisiert, dass diese mittels eines Buttons, sofern alle Fenster und Türen mit Ausnahme der Haustür geschlossen sind, vorgewählt werden kann. Intern läuft dann ein 5 Minuten Timer. Schließe ich beim Verlassen innerhalb dieser 5 Minuten die Haustüre, so wird die Alarmanlage scharf geschaltet. Wird die Wohnung nicht verlassen, so wird die Vorwahl wieder zurückgesetzt.
                                          Ich finde diesen Ansatz um einiges eleganter als einen stupiden Timer ablaufen zu lassen.
                                          Hättest du vielleicht Lust das in deinen Adapter zu integrieren?
                                          Sascha
                                          dodi666
                                          #952
                                          @dodi666 sagte in Test Adapter Alarm 2.0.x:
                                          @blauholsten:
                                          Sascha
                                          @blauholsten
                                          Konntest du die Funktionalität schon implementieren?
                                          Sascha
