  4. Asterisk bringt "Error while dialing (2). Error: {}"
    6.4k
116 Beiträge 10 Kommentatoren 20.1k Aufrufe 11 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #70
    Über putty kam dies:
    root@VM-iobroker:/opt/iobroker# asterisk -rvvvvvv
    Asterisk 16.2.1~dfsg-1+deb10u2, Copyright (C) 1999 - 2018, Digium, Inc. and others.
    Created by Mark Spencer <markster@digium.com>
    Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
    This is free software, with components licensed under the GNU General Public
    License version 2 and other licenses; you are welcome to redistribute it under
    certain conditions. Type 'core show license' for details.
    Connected to Asterisk 16.2.1~dfsg-1+deb10u2 currently running on VM-iobroker (pid = 402)
      == Manager 'manager' logged off from 192.168.243.12
      == Manager 'manager' logged on from 192.168.243.12
    [Jun  9 20:23:56] WARNING[11463]: chan_sip.c:6331 create_addr: Purely numeric hostname (123456789), and not a peer--rejecting!
        -- Executing [failed@ael-ansage:1] Answer("OutgoingSpoolFailed", "") in new stack
        -- Executing [failed@ael-ansage:2] Wait("OutgoingSpoolFailed", "1") in new stack
        -- Executing [failed@ael-ansage:3] Read("OutgoingSpoolFailed", "dtmf,/tmp/ttsifixalarm&beep,0,s,5,1") in new stack
        -- Executing [failed@ael-ansage:4] GotoIf("OutgoingSpoolFailed", "0?5:6") in new stack
        -- Goto (ael-ansage,failed,6)
        -- Executing [failed@ael-ansage:6] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_1") in new stack
        -- Executing [failed@ael-ansage:7] Hangup("OutgoingSpoolFailed", "") in new stack
      == Spawn extension (ael-ansage, failed, 7) exited non-zero on 'OutgoingSpoolFailed'
        -- Executing [h@ael-ansage:1] GotoIf("OutgoingSpoolFailed", "0?2:4") in new stack
        -- Goto (ael-ansage,h,4)
        -- Executing [h@ael-ansage:4] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_2") in new stack
        -- Executing [h@ael-ansage:5] SayDigits("OutgoingSpoolFailed", "") in new stack
        -- Executing [h@ael-ansage:6] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_1") in new stack
        -- Executing [h@ael-ansage:7] Hangup("OutgoingSpoolFailed", "") in new stack
      == Spawn extension (ael-ansage, h, 7) exited non-zero on 'OutgoingSpoolFailed'
    VM-iobroker*CLI>
    Danke.
    Thomas BraunT B 2 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      VM-iobroker*CLI>
      #71
      @bahnuhr
      Du solltest keine root shell offen haben.
      • bahnuhrB bahnuhr
        VM-iobroker*CLI>
        boeskij
        #72
        @bahnuhr
        nun bin ich raus...
        die Asterisk-Instanz hat aber schon mal gelaufen?
        Die CallerId im Schnippsel stimmt?
        sendTo('asterisk.0', "dial", { telnr: TELNR, callerid: CALLERID, audiofile: AUDIOFILE},  (res) => { ...
        • B boeskij
          @bahnuhr
          nun bin ich raus...
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          #73
          @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
          Nein
          ich lass diese mal weg.
          Danke.
          • bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #74
            so, keine Veränderung.
            Es kommt immer:
            "Originate failed"
            Danke.
            • bahnuhrB bahnuhr
              Es kommt immer:
              "Originate failed"
              boeskij
              #75
              @bahnuhr
              Angebunden nach Anleitung an eine Fritzbox?
              Beantwortet der iobroker einen eingehenden Anruf (wenn auch nur mit "beep" da die TTS-Datei nicht erzeugt werden kann)?
              • B boeskij
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #76
                Ich denke schon, manager ist logged on
                Weiß ich jetzt nicht, wie und was ich da machen soll.
                Danke.
                • bahnuhrB bahnuhr
                  boeskij
                  #77
                  @bahnuhr
                  Für den Asterisk musste auf der Fritzbox eine SIP-Nebenstelle eingerichtet werden.
                  Diese hat mindestens eine interne Rufnummer, ggf. auch eine externe Rufnummer.
                  Die einfach mal anrufen und schauen was passiert
                  • B boeskij
                    @bahnuhr
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #78
                    @bahnuhr
                    Ja, sip nach Anleitung.
                    Nummer hab ich mit meinem Handy mal angerufen.
                    Alle Telefone klingeln.
                    Der Fritzbox Adapter reagiert.
                    Aber Astersik nicht.
                    Danke.
                    • bahnuhrB bahnuhr
                      @bahnuhr
                      boeskij
                      #79
                      @bahnuhr
                      dann würde ich mal behaupten passt da etwas in deiner Konfig nicht...
                      das "Manager logged on/off" bedeutet nur, dass der Asterisk-Adapter sich mit dem Asterisk verbunden hat.
                      Vorher muss sich der Asterisk ja noch mit der Fritzbox verbinden, vermutlich tut er das gar nicht
                      Am besten nochmal alles kontrollieren, die Konfig-Dateien neu erzeugen und ganz wichtig: Asterisk neustarten und danach den Asterist-Adapter neustarten
                      • B boeskij
                        @bahnuhr
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #80
                        @boeskij
                        Oh je, das hab ich schon mehrfach gemacht.
                        Aber ich gehe es nochmal durch.
                        Langsam weiß ich nicht mehr weiter.
                        mfg
                        Danke.
                        • bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #81
                          So, erst einmal Danke für eure Unterstützung.
                          Aber, ich bekomme es nicht hin.
                          Alles nochmal durchgegangen.
                          Irgendwo ist was falsch.
                          Ich finde es aber nicht.
                          mfg
                          Dieter
                          Danke.
                          • bahnuhrB bahnuhr
                            mfg
                            Dieter
                            #82
                            @bahnuhr sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                            Ja, dein login prompt.
                              boeskij
                              schrieb am zuletzt editiert von boeskij
                              #83
                              So sollte das iobroker-Log beim Starten des Asterisk-Adapters aussehen:
                              asterisk.0	2021-06-09 21:10:23.889	error	(2005) Error while Converting File: {}
                              asterisk.0	2021-06-09 21:10:23.107	info	(2005) Connected to Asterisk Manager
                              asterisk.0	2021-06-09 21:10:23.075	info	(2005) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                              asterisk.0	2021-06-09 21:10:22.956	info	(2005) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v10.24.0, js-controller: 3.2.16
                              Die Meldung "Error while Converting File: {}" ist das angesprochene Problem, dass beim Starten versucht wird die asterisk_dtmf für Dial-In-Calls zu erzeugen
                              Bei einem eingehenden Anruf (ich habs über die interne Rufnummer versucht) sehe ich im putty mit "asterisk -rvvvvv"
                                == Using SIP RTP CoS mark 5
                                     > 0x28e2bc8 -- Strict RTP learning after remote address set to: 192.168.178.20:7080
                                  -- Executing [1000@default:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
                                  -- Goto (ael-antwort,s,1)
                                  -- Executing [s@ael-antwort:1] Answer("SIP/iobroker-00000002", "") in new stack
                                     > 0x28e2bc8 -- Strict RTP switching to RTP target address 192.168.178.20:7080 as source
                                  -- Executing [s@ael-antwort:2] Wait("SIP/iobroker-00000002", "1") in new stack
                                  -- Executing [s@ael-antwort:3] Set("SIP/iobroker-00000002", "repeat=5") in new stack
                                  -- Executing [s@ael-antwort:4] Read("SIP/iobroker-00000002", "dtmf,/tmp//asterisk_dtmf&beep,0,s,5,1") in new stack
                              [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                              [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                  -- <SIP/iobroker-00000002> Playing 'beep.gsm' (language 'en')
                                     > 0x28e2bc8 -- Strict RTP learning complete - Locking on source address 192.168.178.20:7080
                                  -- User entered nothing, 4 chances left
                              [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                              [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                  -- User entered nothing, 3 chances left
                              [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                              [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                  -- User entered nothing, 2 chances left
                              [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                              [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                  -- User entered nothing, 1 chance left
                              [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                              [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                  -- User entered nothing.
                                  -- Executing [s@ael-antwort:5] GotoIf("SIP/iobroker-00000002", "0?6:7") in new stack
                                  -- Goto (ael-antwort,s,7)
                                  -- Executing [s@ael-antwort:7] NoOp("SIP/iobroker-00000002", "Finish if_ael-antwort_9") in new stack
                                  -- Executing [s@ael-antwort:8] Hangup("SIP/iobroker-00000002", "") in new stack
                                == Spawn extension (ael-antwort, s, 8) exited non-zero on 'SIP/iobroker-00000002'
                                  -- Executing [h@ael-antwort:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
                                == Spawn extension (ael-antwort, s, 1) exited non-zero on 'SIP/iobroker-00000002'
                              raspberrypi*CLI>
                              Da die Datei nicht erzeugt wurde kann sie natürlich auch nicht gefunden und abgespielt werden, also hört man nur das "beep"
                              Die sip.conf sieht bei mir so aus:
                              [general]                               ; Do not change
                              port = 5060                             ; Do not change
                              bindaddr = 0.0.0.0                      ; Do not change
                              context = default                       ; Do not change
                              subscribecontext = default              ; Do not change
                              register => iobroker:einPasswort@192.168.178.20/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                              [iobroker]                              ; Change to username of Fritzbox WLAN/LAN telephone
                              type = friend                           ; Do not change
                              username = iobroker                     ; Change to username of Fritzbox WLAN/LAN telephone
                              host = 192.168.178.20                   ; Change hostname / IP address of Fritzbox
                              secret = einPasswort         ; Change password of Fritzbox WLAN/LAN telephone
                              fromdomain =  192.168.178.20            ; Change hostname / IP address of Fritzbox
                              fromuser = iobroker             ; Change username of Fritzbox WLAN/LAN telephone
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #84
                                @thomas-braun sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                Lt. Anleitung stolpere ich immer über diesen Punkt
                                Was heißt das ?
                                Muss ich einen neuen Benutzer anlegen mit einer Zahl.
                                Geht aber in meiner FB7490 nicht (diese verlangt am Anfang einen Buchstaben).
                                Könnte dies das Problem sein ?
                                Danke.
                                • bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #85
                                  Start Adapter:
                                  asterisk.0	2021-06-09 21:35:58.998	error	(13563) Error while Converting File: {}
                                  asterisk.0	2021-06-09 21:35:58.388	info	(13563) Connected to Asterisk Manager
                                  asterisk.0	2021-06-09 21:35:58.373	info	(13563) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                                  asterisk.0	2021-06-09 21:35:58.287	info	(13563) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v12.21.0, js-controller: 3.2.16
                                  passt mit deinem überein.
                                  Danke.
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #86
                                    Nachtrag:
                                    Wenn ich mit meinem Fritzfon die interne Nr. anrufen kommt:
                                    ...keine Verbindung...
                                    Und in putty wird auch nichts angezeigt.
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      Was heißt das ?
                                      boeskij
                                      #87
                                      @bahnuhr said in Asterisk bringt "Error while dialing (2). Error: {}":
                                      Bei mir funktioniert es mit einem Benutzernamen der nur aus Buchstaben besteht...
                                      zeig mal deine sip.conf
                                      • B boeskij
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        #88
                                        Ich habe 2
                                        • sip.conf
                                        • sip_fritzbox.conf
                                        Zeigen aber beide das gleiche:
                                        register => 123456789:abcde16@192.168.243.1/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                                        [123456789]               		; Change to username of Fritzbox WLAN/LAN telephone
                                        username = 123456789      		; Change to username of Fritzbox WLAN/LAN telephone
                                        host = 192.168.243.1          		; Change hostname / IP address of Fritzbox
                                        secret = abcde16         ; Change password of Fritzbox WLAN/LAN telephone
                                        fromdomain =  192.168.243.1  		; Change hostname / IP address of Fritzbox
                                        fromuser = 123456789   	  	; Change username of Fritzbox WLAN/LAN telephone
                                        Danke.
                                        • bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #89
                                          Und in der FB hab ich dies:
                                          Und dies habe ich auch im Adapter eingegeben.
                                          Danke.
