  4. Asterisk bringt "Error while dialing (2). Error: {}"
    6.4k
116 Beiträge 10 Kommentatoren 20.1k Aufrufe 11 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #69
    Im debug kommt:
    asterisk.0	2021-06-09 20:23:57.572	debug	(11448) sendTo "dial" to system.adapter.javascript.0 from system.adapter.asterisk.0
    asterisk.0	2021-06-09 20:23:57.571	debug	(11448) Calling callback function: (res, err) => { adapter.sendTo(msg.from, msg.command, { result: res, error: err }, msg.callback); }
    asterisk.0	2021-06-09 20:23:57.570	error	(11448) Error while dialing (1). Error: {"response":"Error","actionid":"9ef349c2-d53f-ca4e-1a24-caa343e23b19","message":"Originate failed"}, Result: {"parameter":{"telnr":"0176471123123","callerid":"06
    asterisk.0	2021-06-09 20:23:56.563	info	(11448) Start dialing
    asterisk.0	2021-06-09 20:23:56.563	debug	(11448) Got GSM audio file /tmp/ttsifixalarm.gsm
    asterisk.0	2021-06-09 20:23:56.562	debug	(11448) Parameter: {"telnr":"017sdfsdf","callerid":"066512313","audiofile":"/tmp/ttsifixalarm","extension":"123456789"}
    asterisk.0	2021-06-09 20:23:56.561	debug	(11448) Dial Command
    asterisk.0	2021-06-09 20:23:56.560	debug	(11448) Message: {"telnr":"017sdfsdfsdf","callerid":"0665123123","audiofile":"/tmp/ttsifixalarm.gsm"}
    asterisk.0	2021-06-09 20:23:56.558	debug	(11448) Connected to Asterisk
    Tel.Nr. wieder geändert.
    Danke.
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #70
      Über putty kam dies:
      root@VM-iobroker:/opt/iobroker# asterisk -rvvvvvv
      Asterisk 16.2.1~dfsg-1+deb10u2, Copyright (C) 1999 - 2018, Digium, Inc. and others.
      Created by Mark Spencer <markster@digium.com>
      Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
      This is free software, with components licensed under the GNU General Public
      License version 2 and other licenses; you are welcome to redistribute it under
      certain conditions. Type 'core show license' for details.
      Connected to Asterisk 16.2.1~dfsg-1+deb10u2 currently running on VM-iobroker (pid = 402)
        == Manager 'manager' logged off from 192.168.243.12
        == Manager 'manager' logged on from 192.168.243.12
      [Jun  9 20:23:56] WARNING[11463]: chan_sip.c:6331 create_addr: Purely numeric hostname (123456789), and not a peer--rejecting!
          -- Executing [failed@ael-ansage:1] Answer("OutgoingSpoolFailed", "") in new stack
          -- Executing [failed@ael-ansage:2] Wait("OutgoingSpoolFailed", "1") in new stack
          -- Executing [failed@ael-ansage:3] Read("OutgoingSpoolFailed", "dtmf,/tmp/ttsifixalarm&beep,0,s,5,1") in new stack
          -- Executing [failed@ael-ansage:4] GotoIf("OutgoingSpoolFailed", "0?5:6") in new stack
          -- Goto (ael-ansage,failed,6)
          -- Executing [failed@ael-ansage:6] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_1") in new stack
          -- Executing [failed@ael-ansage:7] Hangup("OutgoingSpoolFailed", "") in new stack
        == Spawn extension (ael-ansage, failed, 7) exited non-zero on 'OutgoingSpoolFailed'
          -- Executing [h@ael-ansage:1] GotoIf("OutgoingSpoolFailed", "0?2:4") in new stack
          -- Goto (ael-ansage,h,4)
          -- Executing [h@ael-ansage:4] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_2") in new stack
          -- Executing [h@ael-ansage:5] SayDigits("OutgoingSpoolFailed", "") in new stack
          -- Executing [h@ael-ansage:6] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_1") in new stack
          -- Executing [h@ael-ansage:7] Hangup("OutgoingSpoolFailed", "") in new stack
        == Spawn extension (ael-ansage, h, 7) exited non-zero on 'OutgoingSpoolFailed'
      VM-iobroker*CLI>
      Danke.
      Thomas BraunT B 2 Antworten Letzte Antwort
      • bahnuhrB bahnuhr
        VM-iobroker*CLI>
        #71
        @bahnuhr
        Du solltest keine root shell offen haben.
        • bahnuhrB bahnuhr
          VM-iobroker*CLI>
          boeskij
          #72
          @bahnuhr
          nun bin ich raus...
          die Asterisk-Instanz hat aber schon mal gelaufen?
          Die CallerId im Schnippsel stimmt?
          sendTo('asterisk.0', "dial", { telnr: TELNR, callerid: CALLERID, audiofile: AUDIOFILE},  (res) => { ...
          • B boeskij
            @bahnuhr
            nun bin ich raus...
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #73
            @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
            Nein
            ich lass diese mal weg.
            Danke.
            • bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #74
              so, keine Veränderung.
              Es kommt immer:
              "Originate failed"
              Danke.
              • bahnuhrB bahnuhr
                Es kommt immer:
                "Originate failed"
                boeskij
                #75
                @bahnuhr
                Angebunden nach Anleitung an eine Fritzbox?
                Beantwortet der iobroker einen eingehenden Anruf (wenn auch nur mit "beep" da die TTS-Datei nicht erzeugt werden kann)?
                • B boeskij
                  @bahnuhr
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #76
                  Ich denke schon, manager ist logged on
                  Weiß ich jetzt nicht, wie und was ich da machen soll.
                  Danke.
                  • bahnuhrB bahnuhr
                    boeskij
                    #77
                    @bahnuhr
                    Für den Asterisk musste auf der Fritzbox eine SIP-Nebenstelle eingerichtet werden.
                    Diese hat mindestens eine interne Rufnummer, ggf. auch eine externe Rufnummer.
                    Die einfach mal anrufen und schauen was passiert
                    • B boeskij
                      @bahnuhr
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #78
                      @bahnuhr
                      Ja, sip nach Anleitung.
                      Nummer hab ich mit meinem Handy mal angerufen.
                      Alle Telefone klingeln.
                      Der Fritzbox Adapter reagiert.
                      Aber Astersik nicht.
                      Danke.
                      • bahnuhrB bahnuhr
                        @bahnuhr
                        boeskij
                        #79
                        @bahnuhr
                        dann würde ich mal behaupten passt da etwas in deiner Konfig nicht...
                        das "Manager logged on/off" bedeutet nur, dass der Asterisk-Adapter sich mit dem Asterisk verbunden hat.
                        Vorher muss sich der Asterisk ja noch mit der Fritzbox verbinden, vermutlich tut er das gar nicht
                        Am besten nochmal alles kontrollieren, die Konfig-Dateien neu erzeugen und ganz wichtig: Asterisk neustarten und danach den Asterist-Adapter neustarten
                        • B boeskij
                          @bahnuhr
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #80
                          @boeskij
                          Oh je, das hab ich schon mehrfach gemacht.
                          Aber ich gehe es nochmal durch.
                          Langsam weiß ich nicht mehr weiter.
                          mfg
                          Danke.
                          • bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #81
                            So, erst einmal Danke für eure Unterstützung.
                            Aber, ich bekomme es nicht hin.
                            Alles nochmal durchgegangen.
                            Irgendwo ist was falsch.
                            Ich finde es aber nicht.
                            mfg
                            Dieter
                            Danke.
                            • bahnuhrB bahnuhr
                              mfg
                              Dieter
                              #82
                              @bahnuhr sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                              Ja, dein login prompt.
                                boeskij
                                schrieb am zuletzt editiert von boeskij
                                #83
                                So sollte das iobroker-Log beim Starten des Asterisk-Adapters aussehen:
                                asterisk.0	2021-06-09 21:10:23.889	error	(2005) Error while Converting File: {}
                                asterisk.0	2021-06-09 21:10:23.107	info	(2005) Connected to Asterisk Manager
                                asterisk.0	2021-06-09 21:10:23.075	info	(2005) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                                asterisk.0	2021-06-09 21:10:22.956	info	(2005) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v10.24.0, js-controller: 3.2.16
                                Die Meldung "Error while Converting File: {}" ist das angesprochene Problem, dass beim Starten versucht wird die asterisk_dtmf für Dial-In-Calls zu erzeugen
                                Bei einem eingehenden Anruf (ich habs über die interne Rufnummer versucht) sehe ich im putty mit "asterisk -rvvvvv"
                                  == Using SIP RTP CoS mark 5
                                       > 0x28e2bc8 -- Strict RTP learning after remote address set to: 192.168.178.20:7080
                                    -- Executing [1000@default:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
                                    -- Goto (ael-antwort,s,1)
                                    -- Executing [s@ael-antwort:1] Answer("SIP/iobroker-00000002", "") in new stack
                                       > 0x28e2bc8 -- Strict RTP switching to RTP target address 192.168.178.20:7080 as source
                                    -- Executing [s@ael-antwort:2] Wait("SIP/iobroker-00000002", "1") in new stack
                                    -- Executing [s@ael-antwort:3] Set("SIP/iobroker-00000002", "repeat=5") in new stack
                                    -- Executing [s@ael-antwort:4] Read("SIP/iobroker-00000002", "dtmf,/tmp//asterisk_dtmf&beep,0,s,5,1") in new stack
                                [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                    -- <SIP/iobroker-00000002> Playing 'beep.gsm' (language 'en')
                                       > 0x28e2bc8 -- Strict RTP learning complete - Locking on source address 192.168.178.20:7080
                                    -- User entered nothing, 4 chances left
                                [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                    -- User entered nothing, 3 chances left
                                [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                    -- User entered nothing, 2 chances left
                                [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                    -- User entered nothing, 1 chance left
                                [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                    -- User entered nothing.
                                    -- Executing [s@ael-antwort:5] GotoIf("SIP/iobroker-00000002", "0?6:7") in new stack
                                    -- Goto (ael-antwort,s,7)
                                    -- Executing [s@ael-antwort:7] NoOp("SIP/iobroker-00000002", "Finish if_ael-antwort_9") in new stack
                                    -- Executing [s@ael-antwort:8] Hangup("SIP/iobroker-00000002", "") in new stack
                                  == Spawn extension (ael-antwort, s, 8) exited non-zero on 'SIP/iobroker-00000002'
                                    -- Executing [h@ael-antwort:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
                                  == Spawn extension (ael-antwort, s, 1) exited non-zero on 'SIP/iobroker-00000002'
                                raspberrypi*CLI>
                                Da die Datei nicht erzeugt wurde kann sie natürlich auch nicht gefunden und abgespielt werden, also hört man nur das "beep"
                                Die sip.conf sieht bei mir so aus:
                                [general]                               ; Do not change
                                port = 5060                             ; Do not change
                                bindaddr = 0.0.0.0                      ; Do not change
                                context = default                       ; Do not change
                                subscribecontext = default              ; Do not change
                                register => iobroker:einPasswort@192.168.178.20/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                                [iobroker]                              ; Change to username of Fritzbox WLAN/LAN telephone
                                type = friend                           ; Do not change
                                username = iobroker                     ; Change to username of Fritzbox WLAN/LAN telephone
                                host = 192.168.178.20                   ; Change hostname / IP address of Fritzbox
                                secret = einPasswort         ; Change password of Fritzbox WLAN/LAN telephone
                                fromdomain =  192.168.178.20            ; Change hostname / IP address of Fritzbox
                                fromuser = iobroker             ; Change username of Fritzbox WLAN/LAN telephone
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #84
                                  @thomas-braun sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                  Lt. Anleitung stolpere ich immer über diesen Punkt
                                  Was heißt das ?
                                  Muss ich einen neuen Benutzer anlegen mit einer Zahl.
                                  Geht aber in meiner FB7490 nicht (diese verlangt am Anfang einen Buchstaben).
                                  Könnte dies das Problem sein ?
                                  Danke.
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #85
                                    Start Adapter:
                                    asterisk.0	2021-06-09 21:35:58.998	error	(13563) Error while Converting File: {}
                                    asterisk.0	2021-06-09 21:35:58.388	info	(13563) Connected to Asterisk Manager
                                    asterisk.0	2021-06-09 21:35:58.373	info	(13563) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                                    asterisk.0	2021-06-09 21:35:58.287	info	(13563) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v12.21.0, js-controller: 3.2.16
                                    passt mit deinem überein.
                                    Danke.
                                    • bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #86
                                      Nachtrag:
                                      Wenn ich mit meinem Fritzfon die interne Nr. anrufen kommt:
                                      ...keine Verbindung...
                                      Und in putty wird auch nichts angezeigt.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        Was heißt das ?
                                        boeskij
                                        #87
                                        @bahnuhr said in Asterisk bringt "Error while dialing (2). Error: {}":
                                        Bei mir funktioniert es mit einem Benutzernamen der nur aus Buchstaben besteht...
                                        zeig mal deine sip.conf
                                        • B boeskij
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #88
                                          Ich habe 2
                                          • sip.conf
                                          • sip_fritzbox.conf
                                          Zeigen aber beide das gleiche:
                                          register => 123456789:abcde16@192.168.243.1/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                                          [123456789]               		; Change to username of Fritzbox WLAN/LAN telephone
                                          username = 123456789      		; Change to username of Fritzbox WLAN/LAN telephone
                                          host = 192.168.243.1          		; Change hostname / IP address of Fritzbox
                                          secret = abcde16         ; Change password of Fritzbox WLAN/LAN telephone
                                          fromdomain =  192.168.243.1  		; Change hostname / IP address of Fritzbox
                                          fromuser = 123456789   	  	; Change username of Fritzbox WLAN/LAN telephone
                                          Danke.
