  4. Aqara Bewegungsmelder -> Problem mit pairing
    5.2k
47 Beiträge 9 Kommentatoren 10.5k Aufrufe 8 Beobachtet
  • KusselinK Kusselin
    2021-06-06 11:21:39.551 - info: host.iobroker-live iobroker Update zigbee from @1.5.1 to @1.5.6
    2021-06-06 11:21:39.560 - info: host.iobroker-live iobroker host.iobroker-live Adapter "system.adapter.zigbee.0" is stopped.
    2021-06-06 11:21:39.572 - info: host.iobroker-live "system.adapter.zigbee.0" disabled
    2021-06-06 11:21:39.573 - info: host.iobroker-live stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-06-06 11:21:39.575 - info: host.iobroker-live stopInstance system.adapter.zigbee.0 send kill signal
    2021-06-06 11:21:39.574 - info: zigbee.0 (1218) Got terminate signal TERMINATE_YOURSELF
    2021-06-06 11:21:39.582 - info: zigbee.0 (1218) cleaned everything up...
    2021-06-06 11:21:39.584 - info: zigbee.0 (1218) Zigbee: disabling joining new devices.
    2021-06-06 11:21:39.791 - info: host.iobroker-live iobroker NPM version: 6.14.12
    2021-06-06 11:21:39.792 - info: host.iobroker-live iobroker npm install iobroker.zigbee@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
    2021-06-06 11:21:39.837 - info: zigbee.0 (1218) terminating
    2021-06-06 11:21:39.838 - info: zigbee.0 (1218) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    von 1.5.1 -> 1.5.6
    Was soll ich machen zurück gehen Thomas??
    @kusselin Und ein Neustart des Adapters sieht wie aus?
    • KusselinK Offline
      KusselinK Offline
      Kusselin
      schrieb am zuletzt editiert von Kusselin
      zigbee.0	2021-06-07 21:26:33.049	info	(12180) Zigbee started
      zigbee.0	2021-06-07 21:26:33.048	info	(12180) Currently no devices.
      zigbee.0	2021-06-07 21:26:33.043	info	(12180) --> transmitPower : high
      zigbee.0	2021-06-07 21:26:33.036	info	(12180) Disable LED
      zigbee.0	2021-06-07 21:26:33.032	info	(12180) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20181024}}
      zigbee.0	2021-06-07 21:26:31.069	info	(12180) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-07 21:26:30.916	info	(12180) Starting Zigbee npm ...
      zigbee.0	2021-06-07 21:26:30.850	info	(12180) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
      zigbee.0	2021-06-07 21:26:26.869	info	(30599) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-06-07 21:26:26.868	info	(30599) terminating
      zigbee.0	2021-06-07 21:26:26.635	info	(30599) Zigbee: disabling joining new devices.
      zigbee.0	2021-06-07 21:26:26.634	info	(30599) cleaned everything up...
      zigbee.0	2021-06-07 21:26:26.629	info	(30599) Got terminate signal TERMINATE_YOURSELF
      • KusselinK Offline
        KusselinK Offline
        Kusselin
        Habe jetzt mal ein Backup von iobroker von vorgerstern eingespielt in proxmox...
        das hat funktioniert udn ich bin wieder auf 1.5.1.
        Jetzt habe ich aber das Problem das der eigentlich durchgereichte ZigbeeStick (das habe ich nach dieser Anleitung gemacht: ab 3.0
        https://drozmotix.github.io/languages/de/BasicSetup/03.ProxmoxLXC.html#_2-lxc-container-erstellen
        dieser nicht mehr auf grün geht un ddiese meldungen im LOG bringt :-(
        zigbee.0	2021-06-07 22:57:26.975	error	(1521) Error: Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/ttyZigbee' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack
        zigbee.0	2021-06-07 22:57:26.975	error	(1521) Failed to start Zigbee
        zigbee.0	2021-06-07 22:57:26.817	info	(1521) Installed Version: iobroker.zigbee@1.5.1
        zigbee.0	2021-06-07 22:57:26.803	info	(1521) Starting Zigbee npm ...
        zigbee.0	2021-06-07 22:57:26.802	info	(1521) Try to reconnect. 1 attempts left
        zigbee.0	2021-06-07 22:57:16.801	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
        zigbee.0	2021-06-07 22:57:16.801	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        zigbee.0	2021-06-07 22:57:16.801	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
        zigbee.0	2021-06-07 22:57:16.801	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
        zigbee.0	2021-06-07 22:57:16.801	error	at new Promise (<anonymous>)
        zigbee.0	2021-06-07 22:57:16.801	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
        zigbee.0	2021-06-07 22:57:16.801	error	at Generator.next (<anonymous>)
        zigbee.0	2021-06-07 22:57:16.801	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
        zigbee.0	2021-06-07 22:57:16.801	error	(1521) Error: Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/ttyZigbee'
        zigbee.0	2021-06-07 22:57:16.800	error	(1521) Failed to start Zigbee
        zigbee.0	2021-06-07 22:57:16.655	info	(1521) Installed Version: iobroker.zigbee@1.5.1
        zigbee.0	2021-06-07 22:57:16.501	info	(1521) Starting Zigbee npm ...
        zigbee.0	2021-06-07 22:57:16.461	info	(1521) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
        Habe den Stick auch mal rausgezogen udn wieder angesteckt - gleiches Problem...geht nicht mehr auf Grün
        Über ne Info vielen Dank was ich jetzt machen kann?
          crunchipC Offline
          crunchipC Offline
          @kusselin starte mal proxmox neu
          KusselinK 1 Antwort Letzte Antwort
            KusselinK Offline
            KusselinK Offline
            Kusselin
            @crunchip hi, hab ich such schon gemacht..pve rebootet und alle container..immer noch..
            Ja hätte ich nicht den zigbee adapter updaten dürfen...?
            Gruss
              Gruss
              arteckA Offline
              arteckA Offline
              arteck
              @kusselin du hättest mal nur abwarten sollen... und nicht sofort in Panik verfallen .. jetzt ist alles strubellig
              erstmal auf die 1.5.6 wieder
              dann poste mal
              ls /opt/iobroker/iobroker-data/zigbee_0
              • arteckA arteck
                dann poste mal
                KusselinK Offline
                KusselinK Offline
                Kusselin
                @arteck Hi, wenn ich das so per copy & paste eingebe kommt das:
                 ls /opt/iobroker/iobroker-data/zigbee.0
                ls: cannot access '/opt/iobroker/iobroker-data/zigbee.0': No such file or directory
                in dem Ordner aber über Filezilla (/opt/iobroker/iobroker-data/zigbee_0) sind ein Haufen tar.gz Backups und die sheperd.db Datei enthalten
                Und jetzt
                  Und jetzt
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @kusselin
                  so
                  • arteckA arteck
                    @kusselin
                    so
                    KusselinK Offline
                    KusselinK Offline
                    Kusselin
                    @arteck
                    backup_2020_12_24-19_15_29.tar.gz  backup_2021_04_06-18_50_06.tar.gz
                    backup_2020_12_24-19_33_48.tar.gz  backup_2021_04_07-18_18_15.tar.gz
                    backup_2020_12_25-12_21_30.tar.gz  backup_2021_04_12-14_59_43.tar.gz
                    backup_2020_12_25-14_37_35.tar.gz  backup_2021_04_12-19_41_55.tar.gz
                    backup_2020_12_25-15_49_32.tar.gz  backup_2021_04_12-20_19_23.tar.gz
                    backup_2020_12_26-13_49_54.tar.gz  backup_2021_04_13-18_29_24.tar.gz
                    backup_2020_12_27-20_22_40.tar.gz  backup_2021_04_15-16_10_26.tar.gz
                    backup_2020_12_28-11_54_14.tar.gz  backup_2021_04_15-16_33_42.tar.gz
                    backup_2020_12_28-14_07_22.tar.gz  backup_2021_04_15-17_46_41.tar.gz
                    backup_2020_12_28-14_28_52.tar.gz  backup_2021_04_16-17_36_35.tar.gz
                    backup_2020_12_28-17_09_58.tar.gz  backup_2021_04_16-18_15_45.tar.gz
                    backup_2020_12_28-17_10_09.tar.gz  backup_2021_04_18-10_06_56.tar.gz
                    backup_2020_12_28-17_13_24.tar.gz  backup_2021_05_01-09_08_46.tar.gz
                    backup_2020_12_28-17_14_07.tar.gz  backup_2021_05_01-09_10_56.tar.gz
                    backup_2020_12_28-18_53_38.tar.gz  backup_2021_05_05-15_30_49.tar.gz
                    backup_2020_12_28-18_55_16.tar.gz  backup_2021_05_05-15_36_57.tar.gz
                    backup_2020_12_28-18_57_14.tar.gz  backup_2021_05_05-15_39_00.tar.gz
                    backup_2021_03_15-20_32_05.tar.gz  backup_2021_05_05-15_59_16.tar.gz
                    backup_2021_03_15-20_43_22.tar.gz  backup_2021_05_08-18_45_03.tar.gz
                    backup_2021_03_16-17_29_34.tar.gz  backup_2021_05_15-20_54_57.tar.gz
                    backup_2021_03_17-18_20_55.tar.gz  backup_2021_05_15-20_58_21.tar.gz
                    backup_2021_03_17-18_24_22.tar.gz  backup_2021_05_15-20_59_38.tar.gz
                    backup_2021_03_18-17_25_57.tar.gz  backup_2021_05_15-21_01_57.tar.gz
                    backup_2021_03_18-18_09_40.tar.gz  backup_2021_05_15-21_05_53.tar.gz
                    backup_2021_03_18-19_37_23.tar.gz  backup_2021_05_15-21_07_20.tar.gz
                    backup_2021_03_18-19_37_37.tar.gz  backup_2021_05_15-21_13_20.tar.gz
                    backup_2021_03_18-19_59_18.tar.gz  backup_2021_05_27-20_53_37.tar.gz
                    backup_2021_03_18-20_04_24.tar.gz  backup_2021_06_07-22_01_40.tar.gz
                    backup_2021_03_19-16_38_10.tar.gz  backup_2021_06_07-22_04_05.tar.gz
                    backup_2021_03_19-16_49_48.tar.gz  backup_2021_06_07-22_04_18.tar.gz
                    backup_2021_03_19-18_37_24.tar.gz  backup_2021_06_07-22_05_39.tar.gz
                    backup_2021_03_20-04_55_32.tar.gz  backup_2021_06_07-22_11_37.tar.gz
                    backup_2021_03_20-18_39_05.tar.gz  backup_2021_06_07-22_12_05.tar.gz
                    backup_2021_03_21-10_16_51.tar.gz  backup_2021_06_07-22_13_22.tar.gz
                    backup_2021_03_21-18_40_19.tar.gz  backup_2021_06_07-22_15_02.tar.gz
                    backup_2021_03_22-12_19_01.tar.gz  backup_2021_06_07-22_18_20.tar.gz
                    backup_2021_03_27-10_08_41.tar.gz  backup_2021_06_07-22_20_28.tar.gz
                    backup_2021_03_27-10_09_02.tar.gz  backup_2021_06_07-22_20_47.tar.gz
                    backup_2021_03_29-16_50_03.tar.gz  backup_2021_06_07-22_21_29.tar.gz
                    backup_2021_03_29-17_11_31.tar.gz  backup_2021_06_07-22_23_06.tar.gz
                    backup_2021_03_29-19_40_32.tar.gz  backup_2021_06_07-22_36_51.tar.gz
                    backup_2021_03_30-18_46_09.tar.gz  backup_2021_06_07-22_39_08.tar.gz
                    backup_2021_03_30-19_17_27.tar.gz  backup_2021_06_07-22_47_12.tar.gz
                    backup_2021_03_30-19_19_24.tar.gz  backup_2021_06_07-22_57_16.tar.gz
                    backup_2021_04_02-10_31_23.tar.gz  backup_2021_06_07-23_09_12.tar.gz
                    backup_2021_04_02-13_19_44.tar.gz  shepherd.db
                    backup_2021_04_02-13_21_31.tar.gz
                    Wo kommen denn die ganzen Backups her?
                    Wa sagt diese Log Eintrag aus?
                    zigbee.0	2021-06-08 16:21:17.430	error	(1675) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                    • KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      also....ich habe jetzt nochmal mein Backup eingespielt udn irgendwie ist der Adapter jetzt grün. Warum weiss ich nicht aber ist ja O.K.
                      Was aber jetzt nicht der Fall ist ist das die geräte nicht zu sehen sind (Bilder anbei)...
                      Muss ich das jetzt wieder anstossen wie es chrunchip schon mal geschrieben hat?
                      das wäre echt nettt wenn ihr mir hier das noch mitteilen könnt.
                      Danek und Gruss
                        Danek und Gruss
                        @kusselin
                        /dev/ttyZigbee
                        Ist das von dir angelegt worden oder vom System? Diese devicenode hab ich noch nie gesehen.
                          @kusselin
                          /dev/ttyZigbee
                          KusselinK Offline
                          KusselinK Offline
                          Kusselin
                          @thomas-braun Hab ich lt. der Anleitung angelegt:
                          https://drozmotix.github.io/languages/en/BasicSetup/03.ProxmoxLXC.html#_2-create-lxc-container
                          ab Punkt 3
                          Kannst du meinen post ev. beantworten?
                            ab Punkt 3
                            @kusselin
                            Ah, Link von Hand angelegt. Kann man machen.
                            Die Frage kann ich dir aber nicht beantworten.
                            • KusselinK Offline
                              KusselinK Offline
                              Kusselin
                              ich bins jetzt nochmal....wieso kann ich einige Zigbee devices wieder anstossen die mir im Adapter angezeigt werden udn andere wie die aquara motions nicht, aber unter Objekte mit "TRUE" angezeigt werden???
                              Gruss
                              • KusselinK Offline
                                KusselinK Offline
                                Kusselin
                                Hab nochmal das pairmodus angeschoben.... jetzt läuft wieder alles..
                                Glaube, ich bin beim Staubsaugen (Zigbeedose) hängengeblieben und hab so die Stromversorgung gekappt.. deshalb das Kuddelmuddel
                                  Sushibomba
                                  schrieb am zuletzt editiert von Sushibomba
                                  Hey Zigbee Freunde... Habe 8 von den Aquara Sensoren im Einsatz. Bei einem ist es seit kurzem so, dass er den Zähler !time from last motion" nicht mehr hoch zählt in Sekunden und occupancy dauerhaft auf true bleit. Habe ihn schon gelöscht und neu gepairt etc. aber das konnte das Problem nicht lösen. Jemand eine Idee woran das liegen kann? VG
                                  • S Sushibomba
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @sushibomba Schau nach ob die Batterie noch genug liefert. Wenn der DP voltage weniger als 2,9 liefert dann solltest Du die Batterie wechseln
                                    ... warst mit dem editieren schneller ;)
                                    Liefert genug
                                    Lehrling seit 1975 !!!
                                    • DJMarc75D DJMarc75
                                      Liefert genug
                                      Sushibomba
                                      @djmarc75
                                      Komisch auf einmal zeigt er es wieder an aber gefühlt nur dann wenn er Lust hat erhöht er die Sekunden. Geht also nicht zuverlässig wie bei den anderen. Obwohl der BWM der einzige war, der die ganze Zeit in der Schublade lag und keine Bewegungen erkennen musste und dadurch natürlich Batterie gespart hat. Aber er schaltet den Datenpunkt "Occupancy" nicht ehr auf false :(
                                      • S Sushibomba
                                        @djmarc75
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @sushibomba sagte in Aqara Bewegungsmelder -> Problem mit pairing:
                                        vll einfach nur irgendwie "kaputtttt" wegen Unterforderung ?!
                                        Seit wann hast Du den wieder in Betrieb ?
                                          Sushibomba
                                          @djmarc75
                                          Ich kann es dir ehrlich gesagt nicht sagen woran es liegt. Battery zeigt er immer 100% an aber die Battery Voltage geht runter.
                                          Wie viel Volt entsprechen denn den "wahren" Prozenten? Unter 3V heißt fast leer? Hast du da Werte?
