  4. IoBroker über ip:8081 nicht erreichber (Vis läuft jedoch)
34 Beiträge 8 Kommentatoren 37.1k Aufrufe
  • L Offline
    lewanpl
    @wendy2702:
    "Auch malps -ef |grep iound schauen welche prozesse laufen. `
    code im Spoiler
    pi@ioBroker-Pi:/opt/iobroker $ ps -ef |grep io
    root 9 2 0 Jan24 ? 00:00:00 [migration/0]
    root 10 2 0 Jan24 ? 00:00:00 [migration/1]
    root 14 2 0 Jan24 ? 00:00:00 [migration/2]
    root 18 2 0 Jan24 ? 00:00:00 [migration/3]
    root 28 2 0 Jan24 ? 00:00:00 [bioset]
    root 31 2 0 Jan24 ? 00:00:00 [rpciod]
    root 35 2 0 Jan24 ? 00:00:00 [nfsiod]
    root 46 2 0 Jan24 ? 00:00:00 [bioset]
    root 47 2 0 Jan24 ? 00:00:00 [bioset]
    root 48 2 0 Jan24 ? 00:00:00 [bioset]
    root 49 2 0 Jan24 ? 00:00:00 [bioset]
    root 50 2 0 Jan24 ? 00:00:00 [bioset]
    root 51 2 0 Jan24 ? 00:00:00 [bioset]
    root 52 2 0 Jan24 ? 00:00:00 [bioset]
    root 53 2 0 Jan24 ? 00:00:00 [bioset]
    root 54 2 0 Jan24 ? 00:00:00 [bioset]
    root 55 2 0 Jan24 ? 00:00:00 [bioset]
    root 56 2 0 Jan24 ? 00:00:00 [bioset]
    root 57 2 0 Jan24 ? 00:00:00 [bioset]
    root 58 2 0 Jan24 ? 00:00:00 [bioset]
    root 59 2 0 Jan24 ? 00:00:00 [bioset]
    root 60 2 0 Jan24 ? 00:00:00 [bioset]
    root 61 2 0 Jan24 ? 00:00:00 [bioset]
    root 62 2 0 Jan24 ? 00:00:00 [bioset]
    root 63 2 0 Jan24 ? 00:00:00 [bioset]
    root 64 2 0 Jan24 ? 00:00:00 [bioset]
    root 65 2 0 Jan24 ? 00:00:00 [bioset]
    root 66 2 0 Jan24 ? 00:00:00 [bioset]
    root 67 2 0 Jan24 ? 00:00:00 [bioset]
    root 68 2 0 Jan24 ? 00:00:00 [bioset]
    root 69 2 0 Jan24 ? 00:00:00 [bioset]
    root 75 2 0 Jan24 ? 00:00:00 [DWC Notificatio]
    root 82 2 0 Jan24 ? 00:00:00 [bioset]
    avahi 395 1 0 Jan24 ? 00:00:00 avahi-daemon: running [ioBroker-Pi.local]
    message+ 396 1 0 Jan24 ? 00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
    root 729 1 0 Jan24 ? 00:02:37 iobroker.js-controller
    root 739 729 0 Jan24 ? 00:06:58 io.admin.0
    root 758 729 0 Jan24 ? 00:05:34 io.admin.1
    root 768 729 0 Jan24 ? 00:03:19 io.hm-rpc.0
    root 778 729 0 Jan24 ? 00:01:43 io.hm-rega.0
    root 791 729 0 Jan24 ? 00:04:48 io.web.0
    root 811 729 0 Jan24 ? 00:00:49 io.socketio.0
    root 817 729 0 Jan24 ? 00:06:13 io.javascript.0
    root 823 729 0 Jan24 ? 00:00:51 io.fritzbox.0
    root 835 729 0 Jan24 ? 00:00:57 io.hm-rpc.1
    pi 2277 2238 0 08:56 pts/0 00:00:00 grep --color=auto io
    ich kann mit dem Inhalt leider nichts anfangen. ist da etwas verdächtiges?
    • L Offline
      lewanpl
      pi@ioBroker-Pi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
      2017-01-25 09:10:04.022  - info: host.ioBroker-Pi iobroker.js-controller version 0.12.2 js-controller starting
      2017-01-25 09:10:04.032  - info: host.ioBroker-Pi Copyright (c) 2014-2016 bluefox, hobbyquaker
      2017-01-25 09:10:04.034  - info: host.ioBroker-Pi hostname: ioBroker-Pi
      2017-01-25 09:10:04.036  - info: host.ioBroker-Pi ip addresses: 192.168.178.21 fe80::548e:671f:704b:bb69
      2017-01-25 09:10:04.266  - info: inMem-objects listening on port 9001
      2017-01-25 09:10:04.284  - error: Another instance is running or some application uses port!
      2017-01-25 09:10:04.285  - error: uncaught exception: listen EADDRINUSE :::9001
      2017-01-25 09:10:04.295  - info: iobroker _restart
      2017-01-25 09:10:04.329  - info: host.ioBroker-Pi InMemoryDB connected
      2017-01-25 09:10:04.341  - info: host.ioBroker-Pi 14 instances found
      host.ioBroker-Pi check instance "system.adapter.admin.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.hm-rpc.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.hm-rega.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.web.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.vis.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.socketio.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.javascript.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.vis-metro.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.vis-hqwidgets.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.fritzbox.0" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.hm-rpc.1" for host "ioBroker-Pi"
      host.ioBroker-Pi check instance "system.adapter.admin.1" for host "ioBroker-Pi"
      2017-01-25 09:10:04.357  - info: host.ioBroker-Pi starting 12 instances
      2017-01-25 09:10:04.386  - info: host.ioBroker-Pi States connected to redis 127.0.0.1:6379
      2017-01-25 09:10:04.424  - info: host.ioBroker-Pi instance system.adapter.admin.0 started with pid 2344
      2017-01-25 09:10:04.498  - info: host.ioBroker-Pi terminated
      2017-01-25 09:10:04.824  - info: iobroker Starting node restart.js
      2017-01-25 09:10:04.856  - info: iobroker exit 0
      Da fällt mir der error auf.
      muss das so, oder ist das ein fehler?
      • L Offline
        lewanpl
        @wendy2702:
        Bei mir sähe das loggen zum Beispiel so aus:
        cd /opt/iobroker/log
        tail -f iobroker.2017-01-24.log
        bei mir leider so ohne erfolg:
        pi@ioBroker-Pi:/opt/iobroker $ cd /opt/iobroker/log
        pi@ioBroker-Pi:/opt/iobroker/log $ tail -f iobroker.2017.01.24.log
        tail: „iobroker.2017.01.24.log“ kann nicht zum Lesen geöffnet werden: Datei oder Verzeichnis nicht gefunden
        tail: Keine Dateien mehr übrig
        • 0 Offline
          0 Offline
          0018
          @lewanpl:
          system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1 : admin - enabled, port: 8090, bind: 0.0.0.0, run as: admin `
          Hast du schonmal über Port 8090 versucht die Oberfläche zu erreichen?
          Du hast auf jeden Fall zwei admin Instanzen am laufen.
          Ob das so sein kann/ darf weiß ich leider nicht…..
          und es muss so lauten:
          nicht
          mfg
          Mfg
          0018
          • L Offline
            lewanpl
            @0018:
            Ob das so sein kann/ darf weiß ich leider nicht….. `
            Ja, leider ohne erfolg.
            • L Offline
              lewanpl
              @0018:
              nicht
              mfg `
              Danke ;)
              pi@ioBroker-Pi:/opt/iobroker/log $ tail -f iobroker.2017-01-24.log
              2017-01-24 21:01:22.040  - info: hm-rpc.0 setValue ["NEQ0751587:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:25.332  - info: hm-rpc.0 setValue ["NEQ0751260:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:25.833  - info: hm-rpc.0 setValue ["NEQ0751020:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:26.520  - info: hm-rpc.0 setValue ["NEQ0751192:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:37.477  - info: hm-rpc.0 setValue ["NEQ0751373:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:37.989  - info: hm-rpc.0 setValue ["NEQ0751407:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:38.458  - info: hm-rpc.0 setValue ["NEQ0751111:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:38.741  - info: hm-rpc.0 setValue ["NEQ0751425:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:39.055  - info: hm-rpc.0 setValue ["NEQ0751180:1","LEVEL",{"explicitDouble":0}] FLOAT
              2017-01-24 21:01:39.317  - info: hm-rpc.0 setValue ["NEQ0751406:1","LEVEL",{"explicitDouble":0}] FLOAT
              • 0 Offline
                0 Offline
                0018
                @lewanpl:
                2017-01-25 09:10:04.285 - error: uncaught exception: listen EADDRINUSE :::9001 `
                Da scheint es scheinbar eine Doppelbelegung eines Ports zu geben.
                Gib mal folgendes ein und schau ob es eine doppelte Belegung für 8081 oder 8090 gibt.
                sudo lsof -i -P | grep -i LISTEN
                mfg
                Mfg
                0018
                • BluefoxB Offline
                  BluefoxB Offline
                  @lewanpl:
                  muss das so, oder ist das ein fehler? `
                  Das ist definitiv ein Fehler. Und system kann nicht normal funktionieren.
                  Schreibe bitte:
                  sudo iobroker stop
                  iobroker setup custom
                  sudo iobroker start
                  Bei setup custom https://github.com/ioBroker/ioBroker/wi … tup-custom
                  drücke überall Enter und nur gegen
                  Port of objects DB(file), default[9001]: 10001
                  10001 schreibe.
                  • L Offline
                    lewanpl
                    @0018:
                    mfg `
                    pi@ioBroker-Pi:/opt/iobroker $ sudo lsof -i -P | grep -i LISTEN
                    sudo: lsof: Kommando nicht gefunden
                    geht nicht…
                    • BluefoxB Offline
                      BluefoxB Offline
                      @lewanpl:
                      @0018:
                      mfg `
                      geht nicht… `
                      sudo netstat -nab | grep 9001
                      • wendy2702W Offline
                        wendy2702W Offline
                        @lewanpl:
                        ich kann mit dem Inhalt leider nichts anfangen. ist da etwas verdächtiges? `
                        So wie ich das sehe läuft der Admin adapter 2 mal.
                        ich würde mal:
                        iobroker stop
                        machen.
                        Dann mit dem ps -ef erneut schauen ob noch immer ein Admin Prozess läuft und den dann mit
                        kill
                        beenden.
                        Oder hast du mit absicht zwei Admin laufen ?
                        • L Offline
                          lewanpl
                          @Bluefox:
                          sudo iobroker stop
                          sudo iobroker start
                          10001 schreibe. `
                          habe ich gemacht…
                          pi@ioBroker-Pi:/ $ sudo iobroker stop
                          Stopping iobroker controller daemon...
                          iobroker controller daemon stopped.
                          Exit code for "killall.sh": 0
                          pi@ioBroker-Pi:/ $ iobroker setup custom
                          Type of objects DB [(f)ile, (c)ouch, (r)edis], default [file]:
                          Host of objects DB(file), default[127.0.0.1]:
                          Type of states DB [(f)file, (r)edis], default [undefined]:
                          Host of states DB (undefined), default[127.0.0.1]:
                          Port of states DB (undefined), default[undefined]:
                          Data directory (file), default[../../../iobroker-data/]:
                          Host name of this machine [ioBroker-Pi]:
                          creating conf/iobroker.json
                          readline.js:930
                                      throw err;
                          Error: EACCES: permission denied, open '/opt/iobroker/iobroker-data/iobroker.json'
                              at Error (native)
                              at Object.fs.openSync (fs.js:549:18)
                              at Object.fs.writeFileSync (fs.js:1156:15)
                              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:496:56
                              at Interface._onLine (readline.js:210:5)
                              at Interface._line (readline.js:551:8)
                              at Interface._ttyWrite (readline.js:828:14)
                              at ReadStream.onkeypress (readline.js:107:10)
                              at emitTwo (events.js:87:13)
                              at ReadStream.emit (events.js:172:7)
                          pi@ioBroker-Pi:/ $ sudo iobroker start
                          Starting iobroker controller daemon...
                          iobroker controller daemon started. PID: 2497
                          Dann mach
                          sudo iobroker setup custom
                          • L Offline
                            lewanpl
                            @wendy2702:
                            ich würde mal:
                            iobroker stop
                            machen.
                            kill
                            beenden.
                            Oder hast du mit absicht zwei Admin laufen ? `
                            ich habe den zweiten Admin nur angelegt um einen Versuch zu starten darüber auf den Iobroker zuzugreifen.
                            Ich kann ihn wieder entfernen, jedoch nur mit einer genauen Anleitung ;)
                            • L Offline
                              lewanpl
                              ` > Dann mach
                              sudo iobroker setup custom `
                              pi@ioBroker-Pi:/ $ sudo iobroker setup custom
                              /opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136
                                          throw new Error(msg.error);
                              Error
                                  at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136:19)
                                  at ChildProcess.emit (events.js:172:7)
                                  at internal/child_process.js:696:12
                                  at nextTickCallbackWith0Args (node.js:420:9)
                                  at process._tickCallback (node.js:349:13)
                              pi@ioBroker-Pi:/ $</anonymous>
                              Jetzt will er nicht mehr starten…
                              • 0 Offline
                                0 Offline
                                0018
                                Neustart durchgeführt?
                                Wie sieht es bei dir mit Backups aus? Nicht das am Ende alles tot ist und du mit leeren Händen da stehst….
                                mfg
                                Mfg
                                0018
                                • L Offline
                                  lewanpl
                                  Neustart habe ich durchgeführt, ohne erfolg.
                                  Ein funktionierendes Backup habe ich, aber ich habe die Befürchtung dass der Fehler früher oder später wieder auftaucht.
                                    Der admin nutzt ein anderes webinterface als vis.
                                    Daher kann es ohne weiteres vorkommen, dass eins von beiden noch funktioniert, wenn das andere Teil ausgefallen ist.
                                    Eine Checkliste zum testen gibt es hier
                                    http://www.iobroker.net/?page_id=3928&lang=de
                                    Was läuft sonst noch auf dem Raspi?
                                    • L Offline
                                      lewanpl
                                      die Checkliste habe ich schon durch.
                                      es scheint der Fehler mit der doppelten Belegung der Ports zu sein.
                                      Aber beim versuch das zu ändern, ist jetzt wohl mehr kaputt.
                                      Auf dem Raspi ist nur Iobroiker mit vis.
                                      Ich werde jetzt aber mein Backup draufspielen…
                                      • N Offline
                                        N Offline
                                        Nippy
                                        Hast es mal mit einem Portscanner versucht?
                                        Unter eingegebener IP werden die Offene (HTTP) Ports angezeigt.
                                          @lewanpl:
                                          es scheint der Fehler mit der doppelten Belegung der Ports zu sein. `
                                          Da gehe ich auch von aus.
                                          @lewanpl:
                                          Auf dem Raspi ist nur Iobroiker mit vis. `
                                          Dann sollte der port 8081 nicht doppelt vergeben sein.
                                          Außer du hast den admin zweimal installiert, oder im web adapter den port geändert
                                          @lewanpl:
                                          die Checkliste habe ich schon durch `
                                          Was hat denn dies gebracht?
                                          netstat -n -a -p TCP
