  4. IoBroker über ip:8081 nicht erreichber (Vis läuft jedoch)
34 Beiträge 8 Kommentatoren 37.1k Aufrufe
  • OstfrieseUnterwegsO Offline
    OstfrieseUnterwegs
    > pi@ioBroker-Pi:~ $ /opt/iobroker/iobroker-data/iobroker.json
    Da bist du auf dem Holzweg. In der Anleitung steht, Du kannst die Ports IN der Datei ändern.
    Also: sudo nano /opt/iobroker/iobroker-data/iobroker.json
    • L Offline
      lewanpl
      pi@ioBroker-Pi:~ $ sudo nano /opt/iobroker/iobroker-data/iobroker.json
      GNU nano 2.2.6 Datei: /opt/iobroker/iobroker-data/iobroker.json
      code im spoiler
      "system": {
      "memoryLimitMB": 0,
      "hostname": ""
      "network": {
      "IPv4": true,
      "IPv6": true,
      "bindAddress": null,
      "useSystemNpm": true
      "objects": {
      "type": "file",
      "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
      "host": "127.0.0.1",
      "port": 9001,
      "user": "",
      "pass": "",
      "noFileCache": false,
      "connectTimeout": 2000,
      "dataDir": "../../iobroker-data/"
      "states": {
      "type": "redis",
      "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
      "port": 6379,
      "options": {
      "auth_pass": null,
      "retry_max_delay": 15000
      "log": {
      "level": "info",
      "maxDays": 7,
      "noStdout": true,
      "transport": {
      "file1": {
      "type": "file",
      "enabled": true,
      "filename": "log/iobroker",
      "fileext": ".log",
      "maxsize": null,
      "maxFiles": null
      "syslog1": {
      "type": "syslog",
      "enabled": false,
      "host": "localhost",
      "host_comment": "The host running syslogd, defaults to localhost.",
      "port_comment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
      "protocol": "udp4",
      "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
      "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
      "facility_comment": "Syslog facility to use (Default: local0).",
      "localhost": "iobroker",
      "localhost_comment": "Host to indicate that log messages are coming from (Default: localhost).",
      "sysLogType_comment": "The type of the syslog protocol to use (Default: BSD).",
      [ 66 Zeilen gelesen ]
      ^G Hilfe ^O Speichern ^R Datei öffnen ^Y Seite zurück ^K Ausschneiden ^C Cursor
      ^X Beenden ^J Ausrichten ^W Wo ist ^V Seite vor ^U Ausschn. rückgängi^T Rechtschr.
      und das mit dem Holz ist bei mir und Linux standart. ich kenne mich echt überhaupt nicht damit aus. befolge nur Anleitungen ;)
      muss ich hier was ändern?
      ****Geändert:**** Code in Code-Tags ****Homoran (Admin)****
      • wendy2702W Offline
        wendy2702W Offline
        Hast du mal ins logfile von iobroker geschaut ob da etwas drin steht?
        Kenne leider nicht den genauen Ort auf einem PI aber würde so etwas vermuten:
        /home/pi/iobroker/log
        EDIT: gerade in einem anderen Thema gesehen, der Standart ordner auf dem PI ist wohl auch:
        cd /opt/iobroker
        da dann das File mit dem aktuellem Datum
        Auch mal````
        ps -ef |grep io
        Wenn du das logfile gefunden hast, vielleicht mal ein````
        tail -f <logfile-name></logfile-name>
        ````und in einer zweiten session den Admin Adapter stoppen und wieder starten.
        Bei mir sähe das loggen zum Beispiel so aus:
        cd /opt/iobroker/log
        tail -f iobroker.2017-01-24.log
        Das lässt sich dann mit "STRG C" später wieder beenden.
        • 0 Offline
          0 Offline
          0018
          Hast du schonmal geschaut ob der Admin Adapter überhaut aktiv ist?
          Schau mal hier:
          http://www.iobroker.net/?page_id=3928&lang=de
          Ich hatte schonmal der sich der Admin-Adapter nach einem Update disabled hat.
          Prüf mal bitte den Punkt "Prüfen ob Admin-Adapter läuft" in der Anleitung.
          cd /opt/iobroker
          iobroker list instances
          wenn der Admin disabled ist dann
           iobroker start admin
          mir hat das damals geholfen.
          mfg
          Mfg
          0018
          • L Offline
            lewanpl
            pi@ioBroker-Pi:~ $ cd /opt/iobroker
            pi@ioBroker-Pi:/opt/iobroker $ iobroker list instances
            system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.hm-rpc.0 : hm-rpc - enabled, port: 0
            system.adapter.hm-rega.0 : hm-rega - enabled
            system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.vis.0 : vis - enabled
            system.adapter.socketio.0 : socketio - enabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.javascript.0 : javascript - enabled
            system.adapter.vis-metro.0 : vis-metro - enabled
            system.adapter.vis-hqwidgets.0 : vis-hqwidgets - enabled
            system.adapter.fritzbox.0 : fritzbox - enabled
            system.adapter.hm-rpc.1 : hm-rpc - enabled, port: 0
            system.adapter.icons-ultimate-png.0 : icons-ultimate-png - enabled
            system.adapter.icons-icons8.0 : icons-icons8 - enabled
            system.adapter.admin.1 : admin - enabled, port: 8090, bind: 0.0.0.0, run as: admin
            der läuft
            jetzt probiere ich mal in die log zu schauen…
            • L Offline
              lewanpl
              @wendy2702:
              "Auch malps -ef |grep iound schauen welche prozesse laufen. `
              code im Spoiler
              pi@ioBroker-Pi:/opt/iobroker $ ps -ef |grep io
              root 9 2 0 Jan24 ? 00:00:00 [migration/0]
              root 10 2 0 Jan24 ? 00:00:00 [migration/1]
              root 14 2 0 Jan24 ? 00:00:00 [migration/2]
              root 18 2 0 Jan24 ? 00:00:00 [migration/3]
              root 28 2 0 Jan24 ? 00:00:00 [bioset]
              root 31 2 0 Jan24 ? 00:00:00 [rpciod]
              root 35 2 0 Jan24 ? 00:00:00 [nfsiod]
              root 46 2 0 Jan24 ? 00:00:00 [bioset]
              root 47 2 0 Jan24 ? 00:00:00 [bioset]
              root 48 2 0 Jan24 ? 00:00:00 [bioset]
              root 49 2 0 Jan24 ? 00:00:00 [bioset]
              root 50 2 0 Jan24 ? 00:00:00 [bioset]
              root 51 2 0 Jan24 ? 00:00:00 [bioset]
              root 52 2 0 Jan24 ? 00:00:00 [bioset]
              root 53 2 0 Jan24 ? 00:00:00 [bioset]
              root 54 2 0 Jan24 ? 00:00:00 [bioset]
              root 55 2 0 Jan24 ? 00:00:00 [bioset]
              root 56 2 0 Jan24 ? 00:00:00 [bioset]
              root 57 2 0 Jan24 ? 00:00:00 [bioset]
              root 58 2 0 Jan24 ? 00:00:00 [bioset]
              root 59 2 0 Jan24 ? 00:00:00 [bioset]
              root 60 2 0 Jan24 ? 00:00:00 [bioset]
              root 61 2 0 Jan24 ? 00:00:00 [bioset]
              root 62 2 0 Jan24 ? 00:00:00 [bioset]
              root 63 2 0 Jan24 ? 00:00:00 [bioset]
              root 64 2 0 Jan24 ? 00:00:00 [bioset]
              root 65 2 0 Jan24 ? 00:00:00 [bioset]
              root 66 2 0 Jan24 ? 00:00:00 [bioset]
              root 67 2 0 Jan24 ? 00:00:00 [bioset]
              root 68 2 0 Jan24 ? 00:00:00 [bioset]
              root 69 2 0 Jan24 ? 00:00:00 [bioset]
              root 75 2 0 Jan24 ? 00:00:00 [DWC Notificatio]
              root 82 2 0 Jan24 ? 00:00:00 [bioset]
              avahi 395 1 0 Jan24 ? 00:00:00 avahi-daemon: running [ioBroker-Pi.local]
              message+ 396 1 0 Jan24 ? 00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
              root 729 1 0 Jan24 ? 00:02:37 iobroker.js-controller
              root 739 729 0 Jan24 ? 00:06:58 io.admin.0
              root 758 729 0 Jan24 ? 00:05:34 io.admin.1
              root 768 729 0 Jan24 ? 00:03:19 io.hm-rpc.0
              root 778 729 0 Jan24 ? 00:01:43 io.hm-rega.0
              root 791 729 0 Jan24 ? 00:04:48 io.web.0
              root 811 729 0 Jan24 ? 00:00:49 io.socketio.0
              root 817 729 0 Jan24 ? 00:06:13 io.javascript.0
              root 823 729 0 Jan24 ? 00:00:51 io.fritzbox.0
              root 835 729 0 Jan24 ? 00:00:57 io.hm-rpc.1
              pi 2277 2238 0 08:56 pts/0 00:00:00 grep --color=auto io
              ich kann mit dem Inhalt leider nichts anfangen. ist da etwas verdächtiges?
              • L Offline
                lewanpl
                pi@ioBroker-Pi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
                2017-01-25 09:10:04.022  - info: host.ioBroker-Pi iobroker.js-controller version 0.12.2 js-controller starting
                2017-01-25 09:10:04.032  - info: host.ioBroker-Pi Copyright (c) 2014-2016 bluefox, hobbyquaker
                2017-01-25 09:10:04.034  - info: host.ioBroker-Pi hostname: ioBroker-Pi
                2017-01-25 09:10:04.036  - info: host.ioBroker-Pi ip addresses: 192.168.178.21 fe80::548e:671f:704b:bb69
                2017-01-25 09:10:04.266  - info: inMem-objects listening on port 9001
                2017-01-25 09:10:04.284  - error: Another instance is running or some application uses port!
                2017-01-25 09:10:04.285  - error: uncaught exception: listen EADDRINUSE :::9001
                2017-01-25 09:10:04.295  - info: iobroker _restart
                2017-01-25 09:10:04.329  - info: host.ioBroker-Pi InMemoryDB connected
                2017-01-25 09:10:04.341  - info: host.ioBroker-Pi 14 instances found
                host.ioBroker-Pi check instance "system.adapter.admin.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.hm-rpc.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.hm-rega.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.web.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.vis.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.socketio.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.javascript.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.vis-metro.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.vis-hqwidgets.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.fritzbox.0" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.hm-rpc.1" for host "ioBroker-Pi"
                host.ioBroker-Pi check instance "system.adapter.admin.1" for host "ioBroker-Pi"
                2017-01-25 09:10:04.357  - info: host.ioBroker-Pi starting 12 instances
                2017-01-25 09:10:04.386  - info: host.ioBroker-Pi States connected to redis 127.0.0.1:6379
                2017-01-25 09:10:04.424  - info: host.ioBroker-Pi instance system.adapter.admin.0 started with pid 2344
                2017-01-25 09:10:04.498  - info: host.ioBroker-Pi terminated
                2017-01-25 09:10:04.824  - info: iobroker Starting node restart.js
                2017-01-25 09:10:04.856  - info: iobroker exit 0
                Da fällt mir der error auf.
                muss das so, oder ist das ein fehler?
                • L Offline
                  lewanpl
                  @wendy2702:
                  bei mir leider so ohne erfolg:
                  pi@ioBroker-Pi:/opt/iobroker $ cd /opt/iobroker/log
                  pi@ioBroker-Pi:/opt/iobroker/log $ tail -f iobroker.2017.01.24.log
                  tail: „iobroker.2017.01.24.log“ kann nicht zum Lesen geöffnet werden: Datei oder Verzeichnis nicht gefunden
                  tail: Keine Dateien mehr übrig
                  • 0 Offline
                    0 Offline
                    0018
                    @lewanpl:
                    system.adapter.admin.1 : admin - enabled, port: 8090, bind: 0.0.0.0, run as: admin `
                    Hast du schonmal über Port 8090 versucht die Oberfläche zu erreichen?
                    Du hast auf jeden Fall zwei admin Instanzen am laufen.
                    Ob das so sein kann/ darf weiß ich leider nicht…..
                    und es muss so lauten:
                    nicht
                    mfg
                    Mfg
                    0018
                    • L Offline
                      lewanpl
                      @0018:
                      Ob das so sein kann/ darf weiß ich leider nicht….. `
                      Ja, leider ohne erfolg.
                      • L Offline
                        lewanpl
                        @0018:
                        nicht
                        mfg `
                        Danke ;)
                        pi@ioBroker-Pi:/opt/iobroker/log $ tail -f iobroker.2017-01-24.log
                        2017-01-24 21:01:22.040  - info: hm-rpc.0 setValue ["NEQ0751587:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:25.332  - info: hm-rpc.0 setValue ["NEQ0751260:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:25.833  - info: hm-rpc.0 setValue ["NEQ0751020:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:26.520  - info: hm-rpc.0 setValue ["NEQ0751192:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:37.477  - info: hm-rpc.0 setValue ["NEQ0751373:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:37.989  - info: hm-rpc.0 setValue ["NEQ0751407:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:38.458  - info: hm-rpc.0 setValue ["NEQ0751111:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:38.741  - info: hm-rpc.0 setValue ["NEQ0751425:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:39.055  - info: hm-rpc.0 setValue ["NEQ0751180:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2017-01-24 21:01:39.317  - info: hm-rpc.0 setValue ["NEQ0751406:1","LEVEL",{"explicitDouble":0}] FLOAT
                        • 0 Offline
                          0 Offline
                          0018
                          @lewanpl:
                          2017-01-25 09:10:04.285 - error: uncaught exception: listen EADDRINUSE :::9001 `
                          Da scheint es scheinbar eine Doppelbelegung eines Ports zu geben.
                          Gib mal folgendes ein und schau ob es eine doppelte Belegung für 8081 oder 8090 gibt.
                          sudo lsof -i -P | grep -i LISTEN
                          mfg
                          Mfg
                          0018
                          • BluefoxB Offline
                            BluefoxB Offline
                            @lewanpl:
                            muss das so, oder ist das ein fehler? `
                            Das ist definitiv ein Fehler. Und system kann nicht normal funktionieren.
                            Schreibe bitte:
                            sudo iobroker stop
                            iobroker setup custom
                            sudo iobroker start
                            Bei setup custom https://github.com/ioBroker/ioBroker/wi … tup-custom
                            drücke überall Enter und nur gegen
                            Port of objects DB(file), default[9001]: 10001
                            10001 schreibe.
                            • L Offline
                              lewanpl
                              @0018:
                              mfg `
                              pi@ioBroker-Pi:/opt/iobroker $ sudo lsof -i -P | grep -i LISTEN
                              sudo: lsof: Kommando nicht gefunden
                              geht nicht…
                              • BluefoxB Offline
                                BluefoxB Offline
                                @lewanpl:
                                @0018:
                                mfg `
                                geht nicht… `
                                sudo netstat -nab | grep 9001
                                  wendy2702W Offline
                                  @lewanpl:
                                  ich kann mit dem Inhalt leider nichts anfangen. ist da etwas verdächtiges? `
                                  So wie ich das sehe läuft der Admin adapter 2 mal.
                                  ich würde mal:
                                  iobroker stop
                                  machen.
                                  Dann mit dem ps -ef erneut schauen ob noch immer ein Admin Prozess läuft und den dann mit
                                  kill
                                  beenden.
                                  Oder hast du mit absicht zwei Admin laufen ?
                                  • L Offline
                                    lewanpl
                                    @Bluefox:
                                    sudo iobroker stop
                                    sudo iobroker start
                                    10001 schreibe. `
                                    habe ich gemacht…
                                    pi@ioBroker-Pi:/ $ sudo iobroker stop
                                    Stopping iobroker controller daemon...
                                    iobroker controller daemon stopped.
                                    Exit code for "killall.sh": 0
                                    pi@ioBroker-Pi:/ $ iobroker setup custom
                                    Type of objects DB [(f)ile, (c)ouch, (r)edis], default [file]:
                                    Host of objects DB(file), default[127.0.0.1]:
                                    Type of states DB [(f)file, (r)edis], default [undefined]:
                                    Host of states DB (undefined), default[127.0.0.1]:
                                    Port of states DB (undefined), default[undefined]:
                                    Data directory (file), default[../../../iobroker-data/]:
                                    Host name of this machine [ioBroker-Pi]:
                                    creating conf/iobroker.json
                                    readline.js:930
                                                throw err;
                                    Error: EACCES: permission denied, open '/opt/iobroker/iobroker-data/iobroker.json'
                                        at Error (native)
                                        at Object.fs.openSync (fs.js:549:18)
                                        at Object.fs.writeFileSync (fs.js:1156:15)
                                        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:496:56
                                        at Interface._onLine (readline.js:210:5)
                                        at Interface._line (readline.js:551:8)
                                        at Interface._ttyWrite (readline.js:828:14)
                                        at ReadStream.onkeypress (readline.js:107:10)
                                        at emitTwo (events.js:87:13)
                                        at ReadStream.emit (events.js:172:7)
                                    pi@ioBroker-Pi:/ $ sudo iobroker start
                                    Starting iobroker controller daemon...
                                    iobroker controller daemon started. PID: 2497
                                    Dann mach
                                    sudo iobroker setup custom
                                    • L Offline
                                      lewanpl
                                      @wendy2702:
                                      ich würde mal:
                                      iobroker stop
                                      machen.
                                      kill
                                      beenden.
                                      Oder hast du mit absicht zwei Admin laufen ? `
                                      ich habe den zweiten Admin nur angelegt um einen Versuch zu starten darüber auf den Iobroker zuzugreifen.
                                      Ich kann ihn wieder entfernen, jedoch nur mit einer genauen Anleitung ;)
                                      • L Offline
                                        lewanpl
                                        ` > Dann mach
                                        sudo iobroker setup custom `
                                        pi@ioBroker-Pi:/ $ sudo iobroker setup custom
                                        /opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136
                                                    throw new Error(msg.error);
                                        Error
                                            at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136:19)
                                            at ChildProcess.emit (events.js:172:7)
                                            at internal/child_process.js:696:12
                                            at nextTickCallbackWith0Args (node.js:420:9)
                                            at process._tickCallback (node.js:349:13)
                                        pi@ioBroker-Pi:/ $</anonymous>
                                        Jetzt will er nicht mehr starten…
                                        • 0 Offline
                                          0 Offline
                                          0018
                                          Neustart durchgeführt?
                                          Wie sieht es bei dir mit Backups aus? Nicht das am Ende alles tot ist und du mit leeren Händen da stehst….
                                          mfg
                                          Mfg
                                          0018
