  4. ZigBee neue Version 1.5.x
    6.5k
579 Beiträge 72 Kommentatoren 188.3k Aufrufe 74 Beobachtet
    anno171986
    #358
    Hallo ich habe leider auch mit dem Zigbee Adapter 1.5.6 Probleme, hier das Log dazu:
    host.raspberrypi	2021-06-03 23:51:58.771	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi	2021-06-03 23:51:58.770	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-06-03 23:51:58.770	error	Caught by controller[0]: }
    host.raspberrypi	2021-06-03 23:51:58.770	error	Caught by controller[0]: ]
    host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
    host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js',
    host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js',
    host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js',
    host.raspberrypi	2021-06-03 23:51:58.768	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/danfoss.js',
    host.raspberrypi	2021-06-03 23:51:58.768	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/index.js',
    host.raspberrypi	2021-06-03 23:51:58.768	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/ledvance.js',
    host.raspberrypi	2021-06-03 23:51:58.767	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js',
    host.raspberrypi	2021-06-03 23:51:58.767	error	Caught by controller[0]: requireStack: [
    host.raspberrypi	2021-06-03 23:51:58.767	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) {
    host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-06-03 23:51:58.765	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-06-03 23:51:58.765	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js:5:15)
    host.raspberrypi	2021-06-03 23:51:58.765	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
    host.raspberrypi	2021-06-03 23:51:58.763	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js
    host.raspberrypi	2021-06-03 23:51:58.763	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js
    host.raspberrypi	2021-06-03 23:51:58.763	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/index.js
    host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/danfoss.js
    host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/index.js
    host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/ledvance.js
    host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js
    host.raspberrypi	2021-06-03 23:51:58.761	error	Caught by controller[0]: Require stack:
    host.raspberrypi	2021-06-03 23:51:58.761	error	Caught by controller[0]: Error: Cannot find module 'buffer-crc32'
    host.raspberrypi	2021-06-03 23:51:58.761	error	Caught by controller[0]: ^
    host.raspberrypi	2021-06-03 23:51:58.760	error	Caught by controller[0]: throw err;
    host.raspberrypi	2021-06-03 23:51:58.760	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
    host.raspberrypi	2021-06-03 23:51:56.709	info	instance system.adapter.zigbee.0 started with pid 3229
    RPi 3
    Zigbee 1.5.6
    CC2538 Stick
    Hat jemand einen Tipp?
    • A anno171986
      RPi 3
      Zigbee 1.5.6
      CC2538 Stick
      arteckA Offline
      arteckA Offline
      arteck
      #359
      @anno171986 bei dir scheint der adapter nicht richtig installier zu sein..
      installier nochmal drüber von GIT https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
      @bjoern77
      adapter stopp
      dann
      rm /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
      adapter starten
      A Bjoern77B 2 Antworten Letzte Antwort
      • arteckA arteck
        @bjoern77
        adapter stopp
        dann
        adapter starten
        anno171986
        #360
        @arteck said in ZigBee neue Version 1.5.x:
        Ich habe schon folgendes gemacht:
        @mr-x said in ZigBee neue Version 1.5.x:
        @arteck sagte in ZigBee neue Version 1.5.x:
        @Mr-X
        bevor du anfängst was wild auszuprobieren
        adapter stoppen DEN RICHTIGEN
        console auf AUF DEM RICHTIGEN HOST AUF
        rm -R /opt/iobroker/node_modules/zigbee-herdsman
        rm -R /opt/iobroker/node_modules/zigbee-herdsman-converter
        rm -R /opt/iobroker/node_modules/@serialport
        rm -R /opt/iobroker/node_modules/iobroker.zigbee
        dann von GIT ... AUF DEM RICHTIGEN HOST installieren https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
        nix löschen... nix deinstallieren... nur das machen was da oben steht
        Hey, sorry, soll ich das ganze auf dem Master machen, oder auf dem Slave, wo Zigbee nicht mehr tut?
        Bei
        hat er einen Fehler ausgegeben, dass er das modul nicht entfernen kann, da nicht gefunden (oder so).
        Bevor ich das (über GIT installiert) gemacht habe, gab es einen ähnlichen Fehler, jedoch war dort der Fehler dass ein "Serial" (oder so ähnlich) nicht gefunden werden konnte.
        Soll ich es einfach nochmal probieren?
        • A anno171986
          @Mr-X
          Bei
          arteckA Offline
          arteckA Offline
          arteck
          #361
          @anno171986 ich kann dir nicht folgen .. aber ja
          • ? Offline
            #362
            Hallo zusammen, ich habe gestern das Update von 1.4.4 auf 1.5.6 gemacht. Soweit ist erstmal alles in Ordnung. Das einzige was jetzt gar nicht mehr funktioniert ist der Firmware aktualisieren Button. Wenn ich diesen drücke, passiert garnichts. Ich habe verschiedene Browser ausprobiert. Ich habe mir das Log angeschaut und habe keine Warnungen oder Error Einträge. Ist da was bekannt? Gerne stelle ich weitere Infos zur Verfügung. Was wird gebraucht?
            Mfg
            David
            arteckA mickymM 2 Antworten Letzte Antwort
              Mfg
              David
              arteckA Offline
              arteckA Offline
              arteck
              #363
              @david83 doch ... schau im LOG..da wird der start des checks Protokolliert
              • arteckA arteck
                anno171986
                #364
                @arteck Ich habe gestern auch von Version 1.4.4 auf 1.5.6 geupdated. Dann kam ein Fehlerbild, was ähnlich dem ist, was ich oben gepostet habe, jedoch war dort von einem "serialport" Modul (oder so ähnlich die Rede, welches nicht gefunden wurde.
                Nach dem ich etwas gesucht habe, hatte ich dieses Thema hier gefunden und habe dann folgendes gemacht:
                iobroker stoppen
                Bei
                kam der Fehler dass er diesen nicht entfernen konnte, da nicht vorhanden.
                Danach von den Adapter von GIT installiert installieren https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                iobroker starten
                Das ist der aktuelle Stand und ich bekomme folgenden Fehler:
                Ich probiere heute Abend dann nochmal folgendes:
                iobroker stoppen
                iobroker starten
                • A anno171986
                  iobroker stoppen
                  Bei
                  iobroker starten
                  iobroker stoppen
                  iobroker starten
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #365
                  @anno171986 sagte in ZigBee neue Version 1.5.x:
                  hier fehlt ein Buchstabe am ende.. mein Fehler
                  rm -R /opt/iobroker/node_modules/zigbee-herdsman-converters
                  ALSO SO MUSS DAS
                  E A 2 Antworten Letzte Antwort
                  • arteckA arteck
                    ALSO SO MUSS DAS
                    eMd
                    #366
                    @arteck
                    Benutzt du immernoch das zigbee Modul aus deiner Signatur? Hast du damit keine Probleme in 1.5.6?
                    MfG
                    eMd
                    Master: Intel NUC 16GB/500GB
                    Slave: Raspberry Pi 3 + Homematicmodul
                    Shelly, Google Home, Zigbee Aqara, Sonoff
                    Meine VIS: https://youtu.be/JMYr2KYlpME
                    • E eMd
                      @arteck
                      MfG
                      eMd
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #367
                      @emd ich habe mehrere Coordinatoren.. auch zum testen..sowie unterschiedliche Hardware (pi,vm,rock64) und Betriebsysteme
                        Mfg
                        David
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #368
                        @david83 hast Du auch die Kacheln umgedreht? Das Ergebnis des OTA Firmware Checks siehst Du auf der Rückseite (früher Vorderseite)
                        • arteckA arteck
                          ALSO SO MUSS DAS
                          anno171986
                          #369
                          ALSO SO MUSS DAS
                          Nach dem ersten Befehl kommt jetzt folgende Frage:
                          rm: in schreibgeschütztes Verzeichnis '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build' absteigen?
                          • A anno171986
                            ALSO SO MUSS DAS
                            msauer
                            #370
                            @anno171986 sudo davor..dann sollte es gehen
                            Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
                            • M msauer
                              anno171986
                              #371
                              @msauer said in ZigBee neue Version 1.5.x:
                              Das hat geklappt, jetzt kommt
                              pi@raspberrypi:~ $ sudo rm -R /opt/iobroker/node_modules/@serialport
                              rm: das Entfernen von '/opt/iobroker/node_modules/@serialport' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                              • A anno171986
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #372
                                @anno171986
                                Dann ist schon alles gut - das Verzeichnis ist weg.
                                A.
                                • AsgothianA Asgothian
                                  @anno171986
                                  A.
                                  anno171986
                                  #373
                                  @asgothian said in ZigBee neue Version 1.5.x:
                                  @anno171986
                                  A.
                                  Ok. Ich habe jetzt alle 4 Zeilen ausgeführt und den iobroker wieder gestartet. Wenn ich jetzt bei Instanzen gucke, ist da immer noch ein "zigbee.0", ist das richtig so? Habe ich das nicht gerade über die Konsole deinstalliert? Auch unter Adapter steht bei Zigbee "Installierte Version: 1.5.6" und "Installierte Instanzen: 1"
                                  • A anno171986
                                    @anno171986
                                    A.
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #374
                                    @anno171986 na klar ist die noch da.. aber wird nicht laufen.... da der sourcecode dazu fehlt..den hast du gerade hintenrum gelöscht
                                    also musst du neu über GIT installieren..
                                    • arteckA arteck
                                      anno171986
                                      schrieb am zuletzt editiert von anno171986
                                      #375
                                      Installation lief erfolgreich durch. Jetzt ist der Adapter schon mal gelb und nicht mehr rot. "Verbunden mit zigbee: falsch", die anderen beiden sind wahr.
                                      zigbee.0	2021-06-04 12:03:38.064	error	(16566) Error herdsman start
                                      zigbee.0	2021-06-04 12:03:38.063	error	(16566) Failed to start Zigbee
                                      zigbee.0	2021-06-04 12:03:38.061	error	(16566) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                      • L Offline
                                        luie
                                        schrieb am zuletzt editiert von luie
                                        #376
                                        Der Link auf die Modelnummer in beiden Kacheln ist fehlerhaft.
                                        Richtig ist Link Text
                                        Und
                                        betrifft das nur den Link in der Geräteinformation. Der richtige Link.
                                        debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
                                        • mickymM mickym
                                          #377
                                          @mickym said in ZigBee neue Version 1.5.x:
                                          Das war die Lösung, so einfach... Dankeschön!
