  4. Alexa2 aktualisiert History nur noch unzuverlässig?
    6.7k
71 Beiträge 9 Kommentatoren 6.0k Aufrufe 9 Beobachtet
  • haselchenH haselchen
    Anscheinend auch wieder Einzelfallbezogen.
    Derartige Restarts habe ich nicht.
    Adapter läuft problemlos durch.
    @haselchen
    echad@chet:~ $ cat /opt/iobroker/log/iobroker.current.log | grep -i alexa2
    2021-05-31 00:09:09.101  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 00:23:40.715  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 01:09:14.212  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 02:09:30.082  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 03:09:48.971  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 03:44:12.706  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 04:44:29.352  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 05:44:46.248  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 06:45:01.860  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 07:42:50.346  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 07:53:55.990  - info: alexa2.0 (3059) Alexa-Push-Connection established. Disable Polling
    2021-05-31 08:13:56.030  - info: alexa2.0 (3059) Update cookie in adapter configuration ... restarting ...
    2021-05-31 08:13:56.098  - info: host.chet stopInstance system.adapter.alexa2.0 (force=false, process=true)
    2021-05-31 08:13:56.112  - info: host.chet stopInstance system.adapter.alexa2.0 send kill signal
    2021-05-31 08:13:56.113  - info: alexa2.0 (3059) Got terminate signal TERMINATE_YOURSELF
    2021-05-31 08:13:56.116  - info: alexa2.0 (3059) terminating
    2021-05-31 08:13:56.118  - info: alexa2.0 (3059) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-05-31 08:13:56.734  - info: host.chet instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-05-31 08:13:59.240  - info: host.chet instance system.adapter.alexa2.0 started with pid 31302
    2021-05-31 08:14:01.021  - info: alexa2.0 (31302) starting. Version 3.9.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.2.0, js-controller: 3.3.11
    2021-05-31 08:14:06.832  - info: alexa2.0 (31302) Alexa-Push-Connection established. Disable Polling
    2021-05-31 08:14:07.427  - info: alexa2.0 (31302) Unknown Device, but enabling commands, Try it and report back if commands work.
    2021-05-31 08:14:07.428  - info: alexa2.0 (31302) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
    2021-05-31 08:14:07.428  - info: alexa2.0 (31302)     Device-type:A1QKZ9D0IJY332 (AUDIBLE,MULTI_WAKEWORDS_SUPPORTED,PERSISTENT_CONNECTION,CHANGE_NAME,DREAM_TRAINING,VOLUME_SETTING,SUPPORTS_LOCALE,EARCONS,SUPPORTS_LOCALE_SWITCH,REMINDERS,SPEECH_RECOGNIZER_USS,SLEEP,SIRIUSXM,SET_LOCALE,SET_TIME_ZONE,APPLE_MUSIC,TIMERS_AND_ALARMS,AUDIO_PLAYER,MICROPHONE,TIDAL,TUNE_IN,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,KINDLE_BOOKS,CUSTOM_ALARM_TONE,ASCENDING_ALARM_VOLUME,I_HEART_RADIO,AMAZON_MUSIC,DEEZER,DEREGISTER_DEVICE,SOUND_SETTINGS,MUSIC_SKILL,GOLDFISH)
    2021-05-31 08:14:37.923  - info: alexa2.0 (31302) State value to set for "alexa2.0.Smart-Home-Devices.99dacfad-37ba-4085-9954-36b266e22da5.powerLevelType" has to be type "string" but received type "number"
    2021-05-31 08:14:40.305  - info: alexa2.0 (31302) Subscribing to states...
    2021-05-31 08:27:16.199  - info: alexa2.0 (31302) Alexa-Push-Connection established. Disable Polling
    2021-05-31 09:27:55.457  - info: alexa2.0 (31302) Alexa-Push-Connection established. Disable Polling
    2021-05-31 10:23:48.385  - info: alexa2.0 (31302) Alexa-Push-Connection established. Disable Polling
    2021-05-31 11:24:04.956  - info: alexa2.0 (31302) Alexa-Push-Connection established. Disable Polling
    2021-05-31 12:24:21.022  - info: alexa2.0 (31302) Alexa-Push-Connection established. Disable Polling
    echad@chet:~ $
      @haselchen
      echad@chet:~ $
      haselchenH Offline
      haselchenH Offline
      haselchen
      Den Cookie neu holen, dass ist ja okay.
      Aber vorher und danach die Neustarts.
      Mysteriös
      Hast Du Alexa geärgert? 😬
        Mysteriös
        @haselchen Cookie neuholen war heute ein manueller Restart. Aber was diese Zicke davor und danach treibt... Keine Ahnung.
          haselchenH Offline
          haselchenH Offline
          haselchen
          Du wirst schon Recht haben , Amazon fummelt wieder an irgendwelchen Komponenten rum.
          Ich behalte das für heute auch mal weiter im Blick.
            @padrino
            Wenn arbeitet Amazon wieder an irgendwas....ansonsten kannste versuchen den Haken zu setzen:
            padrinoP Offline
            padrinoP Offline
            padrino
            schrieb am zuletzt editiert von padrino
            @haselchen sagte in Alexa2 aktualisiert History nur noch unzuverlässig?:
            @padrino
            ![455031c5-50d8-4011-a9f6-4768a56f9b78-grafik.png(/assets/uploads/files/1622456334665-455031c5-50d8-4011-a9f6-4768a56f9b78-grafik.png)
            Hm, das hilft mir, glaub ich, nicht. ;)
            Ich trigger ja teils auf summary, aber wenn sich da nix ändert, obwohl es sollte, springt das Skript ja nicht an.
            • padrinoP padrino
              @padrino
              haselchenH Offline
              haselchenH Offline
              haselchen
              @padrino
              Haken ist also schon drin bei Dir. Okay.
              Joa, hab mal im Forum geschmökert, von diesem Phänomen sind vereinzelt immer nur welche betroffen. Immer ein Amazon Problem. Ergebnis: abwarten.
                @padrino
                Ich habe die Auffälligkeit, das der alexa2 seit dieser Nacht im Stundentakt neustartet. Komme aber gerade nicht an log ran. Ich denke Amazon schraubt da wieder im Hintergrund.
                Dr. BakteriusD Offline
                Dr. Bakterius
                @thomas-braun Ich habe die Einträge schon einige Tage gehäuft im Log (die von heute bisher):
                2021-06-01 06:19:13.195	info	Alexa-Push-Connection established. Disable Polling
                2021-06-01 05:47:12.005	info	Alexa-Push-Connection established. Disable Polling
                2021-06-01 04:46:57.647	info	Alexa-Push-Connection established. Disable Polling
                2021-06-01 03:46:41.582	info	Alexa-Push-Connection established. Disable Polling
                2021-06-01 02:46:25.928	info	Alexa-Push-Connection established. Disable Polling
                2021-06-01 01:46:12.076	info	Alexa-Push-Connection established. Disable Polling
                Sonst funktioniert aber alles. Nur kommt eine Sprachausgabe manchmal etwas verzögert oder muss ein Befehl doppelt gegeben werden seit zwei Tagen.
                haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @dr-bakterius
                  Kann ich vollauf bestätigen.
                  Permanent die gleichen Einträge.
                  Und Befehle werden erst nach dem 2-3 Mal sprechen ausgeführt.
                  alexa2.0	2021-06-01 15:45:41.545	info	(30166) Alexa-Push-Connection established. Disable Polling
                  @apollon77 any idea?
                    @dr-bakterius
                    Kann man fast die Uhr nach stellen. Immer nach einer Stunde wird die Verbindung neuaufgebaut.
                    • apollon77A Offline
                      Also diese websocket Verbindung hat ein Ping Pong und nur wenn das nicht klappt oder die Gegenseite die Verbindung schließt wird neu verbunden. Da fehlen dann kurze Zeiten die Push Infos.
                      Wenn es bei einem do regelmäßig kommt könnt ihr ja mal davor schauen ob schon was vorher nicht geht und wenn ja wieviel vorher ;-)
                      Ingo
                      • apollon77A apollon77
                        Ingo
                        @apollon77
                        Hier ist eigentlich alles sonst unauffällig. Ich hab aber für alexa2 jetzt mal log level auf debug gesetzt.
                          @apollon77
                          padrinoP Offline
                          padrinoP Offline
                          padrino
                          So, eben ging dann nix mehr, history wurde gar nicht mehr aktualisiert.
                          Das Problem, der Adapter konnte (auch nach mehrmaligem Neustart) den cookie nicht erneuern/speichern.
                          Manuell ging es zum Glück noch.
                          Danach hat auch der Neustart was gebracht. ;)
                          Etwas seltsam finde ich, dass im Log vor dem Hinweis af den manuellen Cookie erst mal ein "leerer error" protokolliert wurde.
                          2021-06-02 17:47:25.232 - error: alexa2.0 (27553) Error:
                          2021-06-02 17:47:25.233 - error: alexa2.0 (27553) Error: You can try to get the cookie manually by opening http://192.168.178.29:40269/ with your browser
                          • padrinoP padrino
                            Seit ein paar Tagen ist mir aufgefallen, dass Alexa bei individuellen Anfragen auf einmal gerne mal Stumm bleibt.
                            Hatte erst an das kürzliche Problem (mit Cookie) gedacht, dann ist mir aber aufgefallen, ist diesmal anders, diesmal wird history oft nicht aktualisiert.
                            Und da ich auf summary triggere...
                            Hat noch jemand das Problem?
                            @padrino sagte in Alexa2 aktualisiert History nur noch unzuverlässig?:
                            ...diesmal wird history oft nicht aktualisiert.
                            Ich habe erst letzte Woche mit Summary angefangen zu triggern. Ich muss oft Sätze zweimal sagen damit etwas passiert. Am Anfang dachte ich es liegt an mir und meiner Aussprache das im Summary etwas anderes ankommt. Somit lasse ich mir die letzten Tage jede Änderung per Telegramm senden. Und siehe da nicht jeder gesprochene Satz wird im Summary getriggert.
                            Die Routine die angelegt ist gibt aber die richtige Antwort zurück.
                              @brainbug Na wenn Ihr es nachstellen könnte: Adapter auf Debug Log und Log zeigen mit genauen Zeitlichen Infos wann etwas tat und wann nicht
                                @apollon77 so gerade gehabt und log kommt per Download in einer privaten Nachricht. Dauert aber noch...
                                • padrinoP padrino
                                  crunchipC Offline
                                  crunchipC Offline
                                  @padrino das hatte ich gestern auch
                                    Also ja, es wurde von Amazon wohl mal wieder ws gemacht. Habe später eine neue Alexa2 version
                                      Alexa2 3.9.1 kommt nach NPM bzw wäre GitHub ... wer mag zuerst testen? :-)
                                        @apollon77
                                        2021-06-04 16:11:40.540  - info: host.chet instance system.adapter.alexa2.0 started with pid 24868
                                        2021-06-04 16:11:42.470  - info: alexa2.0 (24868) starting. Version 3.9.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.2.0, js-controller: 3.3.11
                                        2021-06-04 16:11:47.662  - info: alexa2.0 (24868) Alexa-Push-Connection established. Disable Polling
                                        Läuft superstabil!!11!!!11 :-)
                                        crunchipC haselchenH 2 Antworten Letzte Antwort
                                          @apollon77
                                          crunchipC Offline
                                          crunchipC Offline
                                          @thomas-braun musst gleich wieder eins draufsetzen mit...node v16😜
