  4. Adapter: ioBroker.unifi
unifi
1.0k Beiträge 172 Kommentatoren 530.3k Aufrufe 93 Beobachtet
    Seit ein paar Tagen startet der Adapter (Ver. 0.5.8) nach einem Stopp-Backup und Restart von ioBroker in Proxmox nicht mehr automatisch. Im log steht dies:
    host.iobroker	2021-03-31 02:54:21.093	warn	Do not restart adapter system.adapter.unifi.0 because restart loop detected
    host.iobroker	2021-03-31 02:54:21.093	info	Restart adapter system.adapter.unifi.0 because enabled
    host.iobroker	2021-03-31 02:54:21.093	error	instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker	2021-03-31 02:54:21.092	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)
    host.iobroker	2021-03-31 02:54:21.092	error	Caught by controller[1]: Error: connect EHOSTUNREACH x.x.x.x:8443
    host.iobroker	2021-03-31 02:54:21.092	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
    unifi.0	2021-03-31 02:54:20.337	error	(5813) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:54:20.337	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)
    unifi.0	2021-03-31 02:54:20.337	error	(5813) Error: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:54:20.337	error	(5813) unhandled promise rejection: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:54:20.336	error	(5813) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker	2021-03-31 02:54:15.681	info	instance system.adapter.unifi.0 started with pid 5813
    host.iobroker	2021-03-31 02:53:45.657	info	Restart adapter system.adapter.unifi.0 because enabled
    host.iobroker	2021-03-31 02:53:45.656	error	instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker	2021-03-31 02:53:45.656	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)
    host.iobroker	2021-03-31 02:53:45.656	error	Caught by controller[1]: Error: connect EHOSTUNREACH x.x.x.x:8443
    host.iobroker	2021-03-31 02:53:45.655	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
    unifi.0	2021-03-31 02:53:44.912	error	(5714) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:53:44.912	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)
    unifi.0	2021-03-31 02:53:44.912	error	(5714) Error: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:53:44.912	error	(5714) unhandled promise rejection: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:53:44.910	error	(5714) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker	2021-03-31 02:53:40.353	info	instance system.adapter.unifi.0 started with pid 5714
    host.iobroker	2021-03-31 02:53:10.335	info	Restart adapter system.adapter.unifi.0 because enabled
    host.iobroker	2021-03-31 02:53:10.329	error	instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker	2021-03-31 02:53:10.328	error	Caught by controller[0]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)
    host.iobroker	2021-03-31 02:53:10.328	error	Caught by controller[0]: Error: connect EHOSTUNREACH x.x.x.x:8443
    host.iobroker	2021-03-31 02:53:10.319	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
    unifi.0	2021-03-31 02:53:09.315	error	(1544) Exception-Code: EHOSTUNREACH: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:53:09.315	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)
    unifi.0	2021-03-31 02:53:09.315	error	(1544) Error: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:53:09.315	error	(1544) unhandled promise rejection: connect EHOSTUNREACH x.x.x.x:8443
    unifi.0	2021-03-31 02:53:09.281	error	(1544) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker	2021-03-31 02:34:07.018	info	instance system.adapter.unifi.0 started with pid 1544
    Offenbar startet der Adapter nicht wegen vorangegangenen Fehlstarts. Stoße ich den Start über die Instanz manuell an, funktioniert es wieder.
    Kennt jemand dieses Phänomen und weiß Abhilfe?
    Meister MopperM Online
    Meister Mopper
    #607
    Der Adapter kommt offenbar noch nicht mit node.js 14.x zurecht ¯(ツ)/¯
    Nachdem ich zurück auf den 12.22.1 gewechselt habe, funktioniert der automatische Adapterstart wieder.
    Proxmox und HA ...
    • D dos1973
      ich hab da mal etwas gebastelt... :-)
      der DP für das 5Ghz Netz (rote obere) ist neu und braucht erst noch ein paar Stunden.
      Was ich überhaupt nicht ausfindig machen kann (oder bin zu doof das zu rechnen )sind ganzen Bits & Bytes :-(
      und wenn jemand weiß wie ich Sekunden -> Tage &. Stunden darstellen kann, wäre ich auch sehr dankbar.
      zB. 455009 (sekunden) sind 5Tage, xStunden und xMinuten
      I Offline
      I Offline
      Idefix01
      #608
      @dos1973
      kannst du eventuell das Widget für die Wlan Auslastung zur Verfügung stellen?
      • I Idefix01
        @dos1973
        dos1973
        #609
        @idefix01
        was genau meinst du?
        I 1 Antwort Letzte Antwort
        • D dos1973
          @idefix01
          I Offline
          I Offline
          Idefix01
          #610
          @dos1973
          das meine ich
          • I Idefix01
            @dos1973
            das meine ich
            dos1973
            #611
            @idefix01
            unifi.txt
            ich nutze das schon lange nicht mehr...
            ich habe noch eine version des damaligen vis gefunden. Schau mal ob dir das weiterhilft.
            • D dos1973
              @idefix01
              unifi.txt
              I Offline
              I Offline
              Idefix01
              #612
              @dos1973
              danke, aber leider ist es nicht das, muss ich mal selber versuchen zu basteln
              • W Offline
                W Offline
                WeiserWolf
                #613
                Ich werde bald Wahnsinnig mit diesem Adapter :)
                Ich bekomme ihn einfach nicht ans laufen.
                Der Status ist immer gelb weil die Verbindung zum UniFi fehlt.
                Folgende Error-Meldung bekomme ich im Log:
                (12110) fetchSites: Returned data is not in valid format
                Ich benutze ein USG-Pro-4, CloudKey 2 und 3 UAP-AC-PRO.
                Die UnFi Geräte sind auf den aktuellen Firmwareständen.
                Ich habe die lokale IP-Adresse des Cloudkey im Adapter eingetragen und den Port leer gelassen (Alternativ auch 8443 aber das Ergebnis ist leider dasgleiche). Den Benutzernamen und das Passwort habe ich aus den Einstellungen für den SSH Zugriff des Controllers genommen. Ich kriege es einfach nicht auf die Reihe 😢
                Hat jemand eine Idee?
                F 1 Antwort Letzte Antwort
                • W WeiserWolf
                  Frank579
                  #614
                  @weiserwolf
                  Du musst nicht den sah Zugang nehmen sondern den für die web Oberfläche ... Dann sollte es gehen
                  W 1 Antwort Letzte Antwort
                  • F Frank579
                    @weiserwolf
                    W Offline
                    W Offline
                    WeiserWolf
                    #615
                    @frank579 Danke für den Hinweis. Habe ich soeben getestet und siehe da: Mein Docker rauscht Performance-mäßig ins Bodenlose 100% Auslastung... hat sich aber nach einiger Zeit gefangen und läuft nun stabil. Vielen Dank.
                    Ausprobiert hatte ich die Logindaten vorher aber schonmal, aber wahrscheinlich hatte ich da noch den Port eingetragen.
                    • W WeiserWolf
                      timbo
                      #616
                      Mein Adapter läuft soweit, ich würde gern den internen Wifi Traffic dem Traffic der Fritzbox gegenüber stellen, gibt es eine Datenpunkt der den Traffic RX/TX ausgibt? Meinetwegen auch pro AP, das kann ich ja auch selber zusammenzählen.
                      Gruß Timo
                      • T timbo
                        Gruß Timo
                        Meister Mopper
                        #617
                        @timbo sagte in Adapter: ioBroker.unifi:
                        Reicht denn diese Ausgabe nicht?
                        Proxmox und HA ...
                          timbo
                          #618
                          @meister-mopper danke, werde mir die Datenpunkte mal genauer ansehen und schauen ob man da was sinnvolles draus basteln kann :)
                          • Hant0rH Offline
                            Hant0rH Offline
                            Hant0r
                            #619
                            Moin zusammen,
                            ich steuere mit dem Unifi Adapter die Anwesenheit bei uns im Haus.
                            Dafür schaue ich, ob unsere Handys im WLAN "online" sind und wenn keiner mehr online ist, sind wir abwesend.
                            Das hat eine Zeit lange auch gut funktioniert.
                            Mittlerweile kommt es aber ca. ein Mal die Std (kann auch öfters sein) vor, dass unsere Handys fast zeitgleich (seltsam!) einen kurzen Resync mit dem Wlan zu machen scheinen. Auf dem Handy selber sind wir die ganze Zeit mit dem Wlan verbunden, aber der Adapter sagt, dass wir offline sind.
                            Das dauert dann natürlich die Zeit, bis der Adapter sich wieder aktualisiert (default 60 Sekunden).
                            Heißt, wir sind für ca. eine Minute abwesend.
                            Leider kam es nun schon des öfteres vor, dass genau in diese Minute irgendwelche Automatismen gegriffen haben, weil wir ja "nicht da" waren. Rolladen runter oder dergelichen.
                            Habt ihr auch schon solch ein Verhalten festgestellt und habt ihr vielleicht eine Lösung dafür?
                            HiltexH crunchipC 2 Antworten Letzte Antwort
                            • Hant0rH Hant0r
                              Moin zusammen,
                              HiltexH Offline
                              HiltexH Offline
                              Hiltex
                              #620
                              @hant0r mit solchen Ereignissen muss man immer rechnen. Die beste Lösung ist meiner Ansicht nach einfach mal den online-Status in History zu tracken und das dann in Flot grafisch darstellen zu lassen.
                              Wenn du zu dem Schluss kommst, dass es immer nur eine kurze Zeit (60 Sekunden) ist, dann einfach alle entsprechenden Aktionen um 120 Sekunden zu verzögern.
                              Was man auch beachten sollte: vielleicht bist du mal alleine zuhause und installierst ein Update oder startest dein Handy neu. Dann ist auch niemand online…
                              In Summe handhabe ich das übrigens so, dass die Rolläden erst runter gehen, wenn ich mindestens eine Stunde weg bin, es draußen dunkel ist und es mindestens 21:00 Uhr (wochentags) oder 22:30 Uhr (am Wochenende) ist. Kann ja auch mal sein, dass du Sonntag Abend was kochst und keine Eier mehr hast. Dann gehst du 5 Minuten zum Nachbarn rüber und willst bestimmt nicht, dass die Hütte dunkel ist.
                              Blog: indibit.de
                              • Hant0rH Hant0r
                                Moin zusammen,
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #621
                                @hant0r sagte in Adapter: ioBroker.unifi:
                                das kann aber auch wieder einem Update seitens Handy geschuldet sein, möglicherweise wurde die ein oder andere Einstellung zurückgesetzt/überschrieben. Da ich z.b. weder ein Update seitens Unifi noch am Adapter gemacht habe, jedoch mittlerweile auch feststellen musste, das mein Handy des öfteren mal als offline angezeigt wird, wenn es unbenutzt auf dem Schreibtisch liegt, nachdem ich die neusten Update's drauf gespielt hatte. Das zweite Handy( ohne Update) immer noch zuverlässig ohne dieses Problem funktioniert.
                                des weiteren hängt das auch zusammen, ob ein Wechsel von AP zu AP oder ein Wechsel 5/2,4 Netz stattfindet.
                                dafür ist nicht die 60 sec Aktualisierung des Adapters zuständig, sondern bei Clients die Offset für is_online Einstellung. Bei mir (90 sec)
                                Um eine Anwesenheitskontrolle korrekt zu handhaben, wäre eine richtige Herangehensweise, es nicht nur von einer Bedingung abhängig zu machen.
                                Hant0rH 1 Antwort Letzte Antwort
                                  saeft_2003
                                  #622
                                  Ich wollte hier mal in die Runde fragen gibt es eine Möglichkeit über iobroker einen AP neustarten zu lassen?
                                  • S saeft_2003
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    schrieb am zuletzt editiert von Chaot
                                    #623
                                    @saeft_2003 Per unifi Adapter nicht. Einzig was mir so als Quick'n'dirty Variante einfallen würde wäre den POE Adapter kurz stromlos zu schalten.
                                    Gerade noch gefunden:
                                    https://gist.github.com/sjwilliams/2ab579cd4d96129f73bc34e181bc9ea4
                                    vielleicht hilft dir das weiter
                                    • ChaotC Chaot
                                      saeft_2003
                                      #624
                                      @chaot
                                      An das quick and dirty habe ich auch schon gedacht. Das mit dem Skript muss ich mir heute Abend mal genauer anschauen, schon mal vielen Dank soweit...
                                        Hant0rH Offline
                                        Hant0rH Offline
                                        Hant0r
                                        #625
                                        @crunchip Danke dir für den Tipp mit dem Offset für is_online" - Probiere es mal aus. Stand bei mir auf 30 :(
                                        Prinziepiell gebe ich dir Recht mit deien Vermutungen.
                                        Da es öfters Zeitgleich auf zwei Handys (ein Android und ein iPhone) passiert, finde ich das schon setlsam.
                                        @Hiltex
                                        Ich führe eigentlich keine Aktionen aus, sobald wir "abwesend" sind - ok doch, alle Sonos lautsprecher gehen aus ^^
                                        Rolladen werden zu einer bestimmten Zeit hoch und runtergefahren. Wenn wir nicht da sind, fahren bestimmte Rolladen direkt mit hoch statt noch unten zu bleiben oder andersrum fahren Rollladen direkt runter statt noch oben zu bleiben.
                                        Blöd ist dann nur, wenn Murphy's law zuschlägt und genau in diesem Moment das Handyproblem auftritt, man "nicht da" ist und im Schlaftimmer die Rolladen hochfahren :D
                                        • Hant0rH Hant0r
                                          @Hiltex
                                          HiltexH Offline
                                          HiltexH Offline
                                          Hiltex
                                          #626
                                          @hant0r ich kann dir da nur empfehlen, eine Verzögerung einzubauen, dass nicht geguckt wird, ob du in diesem Moment online oder offline bist, sondern über einen bestimmten Zeitraum. Glaub mir, das gibt weniger Spezialeffekte 😉
                                          Blog: indibit.de
