  4. Test js-controller 0.15.1
36 Beiträge 15 Kommentatoren 6.0k Aufrufe
  • eric2905E
    eric2905E
    eric2905
    Hier mal einen ganzen Block (ab der Meldung):
    `2017-01-20 21:25:05.104  - ^[[32minfo^[[39m: admin.0 Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 60 (in last second 0)
    2017-01-20 21:25:18.304  - ^[[32minfo^[[39m: admin.0 Subscribe on all states again
    2017-01-20 21:25:18.801  - ^[[32minfo^[[39m: admin.0 received all states
    2017-01-20 21:25:18.816  - ^[[31merror^[[39m: admin.0 uncaught exception: Cannot read property 'val' of null
    2017-01-20 21:25:18.820  - ^[[31merror^[[39m: admin.0 TypeError: Cannot read property 'val' of null
        at /opt/iobroker/node_modules/iobroker.admin/admin.js:700:128
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3337:61
        at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:305:49)
        at normal_reply (/opt/iobroker/node_modules/redis/index.js:714:21)
        at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:816:9)
        at JavascriptRedisParser.Parser.returnReply (/opt/iobroker/node_modules/redis/index.js:188:18)
        at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:415:12)
        at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:267:27)
        at emitOne (events.js:77:13)
        at Socket.emit (events.js:169:7)
    2017-01-20 21:25:18.820  - ^[[32minfo^[[39m: admin.0 terminating http server on port 8081
    2017-01-20 21:25:18.845  - ^[[31merror^[[39m: host.iobroker instance system.adapter.admin.0 terminated with code 0 (OK)
    2017-01-20 21:25:18.850  - ^[[32minfo^[[39m: hm-rpc.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.855  - ^[[32minfo^[[39m: fritzbox.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.855  - ^[[32minfo^[[39m: sonos.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.856  - ^[[32minfo^[[39m: pushover.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.856  - ^[[32minfo^[[39m: simple-api.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.857  - ^[[32minfo^[[39m: web.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.857  - ^[[32minfo^[[39m: node-red.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.858  - ^[[32minfo^[[39m: node-red.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.858  - ^[[32minfo^[[39m: socketio.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.859  - ^[[32minfo^[[39m: text2command.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.859  - ^[[32minfo^[[39m: sayit.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.860  - ^[[32minfo^[[39m: botvac.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.860  - ^[[32minfo^[[39m: hm-rpc.1 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.861  - ^[[32minfo^[[39m: harmony.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.862  - ^[[32minfo^[[39m: pushover.1 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.862  - ^[[32minfo^[[39m: cloud.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.866  - ^[[32minfo^[[39m: sql.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.864  - ^[[32minfo^[[39m: tankerkoenig.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.869  - ^[[32minfo^[[39m: javascript.0 system.adapter.admin.0: logging false
    2017-01-20 21:25:18.846  - ^[[32minfo^[[39m: host.iobroker Restart adapter system.adapter.admin.0 because enabled
    2017-01-20 21:25:18.853  - ^[[32minfo^[[39m: hm-rega.0 system.adapter.admin.0: logging false[/code]</anonymous>`
    Gruß,
    Eric
    • G
      G
      gst666
      Bei mir tritt leider auch der Fehler "Zu viele Ereignisse" auf.
      Wahrscheinlich ist die Meldung zutreffend. Der Philips Hue Adapter verursacht bei mir viele Meldungen (zwei Adapter rund 70 Leuchtmittel). Stoppen dieser Adapter führt zum Erfolg. Auch der neue unifi Adapter geizt nicht mit Meldungen. Auf meinem Rechner ist das Limit von 180 Events/3 sec sicherlich nicht nötig. Vielleicht sollte man im admin Adapter das Limit einstellen können. Auf kleineren Maschinen wie raspi wird er sicherlich Sinn machen.
      • BluefoxB
        Ja. 180 ist schon zu wenig. Aber irgendwann ist auf jeder Machine Schluss.
        Bitte bis zu nächster Version diese Zeile auf z.B 1000 anpassen:
        https://github.com/ioBroker/ioBroker.ad … min.js#L40
        value:         60,
        Bis dorthin überlege ich wie es besser zu machen ist.
        • BluefoxB
          @eric2905:
          Gruß,
          Eric
          Danke. Konnte ich fixen.
          • G
            G
            gst666
            Umsetzung hat geholfen. Spannend ist, ob Du eine Möglichkeit findest, die Zahl der max Events dynamisch ermitteln kannst? Evt. ist es interessant zu ermitteln, wie lange eine Subscription benötigt, um auf ein Event zu reagieren. Andererseits frage ich mich auch, ob wirklich so vile Events abgesetzt werden müssen. Beispielsweise treten bei dem unifi Adapter/genauso hue-Apdater häufig keine Änderungen auf. Wäre es nicht sinnvoll die Adapter-Entwickler zu animieren, die Zahl der Events auf die notwendigen zu beschränken? Dass dürfte das System insgesamt entlasten.
            • H
              H
              Heinzelmaennchen
              Hi Bluefox,
              nur mal damit ichs verstehe. Für was steht denn dieser Wert? Denn ich konnte bisher zumindest keine negativen Erscheinungen feststellen. Und mein System haut wahrscheinlich ziemlich viele Events raus. Zumindest mehr, als der Browser (im selben Netz) unter dem Reiter Events flüssig darstellen kann.
              Oder stehen diese Events für etwas anderes?
              Vielleicht könnte man ja so etwas wie einen Eventzähler(Tacho?) in den Admin einbauen. So in der Art wie beim Log wenn ich dieses anhalte, nur eben dauernd. Als Pulsanzeige quasi.
              Das wäre möglicherweise auch ein ziemlich guter Performancemesser für die unterschiedlichen Hardwareplattformen.
              Bis 100 Transaktionen reicht ein Raspi.
              Ab dann bis 500 wäre ein Raspi3 nötig.
              und ab diesem Wert braucht es schnellere Prozessoren/mehr Ram etc.
              Vielleicht ließe sich so eine ungefähre Kalkulation für den benötigten Rechner im Vorfeld einer Installation ermitteln.
              Ist nur so ne Idee.
              Bernhard
              Bernhard
              263 Kanäle in 91 Geräten
              3x Sonos Play:1, 1x Sonos:Amp, 1x Sonos Playbar
              4x Hue E27, 21xHue GU10, 1x Lightify RGB Stripe, 1x Lightify E27 TW
              • HomoranH
                Hallo Bernhard,
                @Heinzelmaennchen:
                Das wäre möglicherweise auch ein ziemlich guter Performancemesser für die unterschiedlichen Hardwareplattformen. `
                Ich verstehe leider nicht alles in diesem Thread, aber wenn das so ist, wie du es (nachvollziehbar) beschreibst, fände ich so eine Kennzahl wirklich brauchbar.
                • BluefoxB
                  @Heinzelmaennchen:
                  Hi Bluefox,
                  Ist nur so ne Idee.
                  Bernhard `
                  Es geht um Browser. Wie viele events kann ein Browser verarbeiten.
                  So ein Pulsmessung ist interessant. :D
                  • M
                    M
                    Marcolotti
                    Bei mir läuft der 15.3 ohne die Meldung. Wenn man sich die Ereignisse anschaut, dann ist der Philips Hue Adapter wirklich spitzenreiter.
                    @gst666 > zwei Adapter rund 70 Leuchtmittel Hast du deine ganze Straße damit ausgestattet? :lol: :shock:
                    CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
                    • BluefoxB
                      In der nächsten js-controller Version kommen die States, die input/output rates zeigen.
                      Man kann damit die Übeltäter erkennen. :)
                      • P
                        P
                        Pman
                        @Marcolotti:
                        Bei mir läuft der 15.3 ohne die Meldung. Wenn man sich die Ereignisse anschaut, dann ist der Philips Hue Adapter wirklich spitzenreiter. `
                        Leider funktioniert die Hue Api ja nur mit Polling, dabei werden dann alle paar Sekunden alle Leuchten abgerufen und die Datenkpunkte gespeichert. Möglicherweise ist es auch hier sinnvoll nur tatsächlich geänderte Datenpunkte auch zu schreiben, ich gucke mir das mal an sobald ich Zeit dazu habe. Es hilft natürlich auch die Polling-Abstände in den Adapteroptionen zu verlängern.
                        • jens.mausJ
                          jens.mausJ
                          jens.maus
                          @Marcolotti:
                          Ich denke es ist sicherlich nicht spezifisch bzgl des Philips Hue Adapters. Ich wage auch mal einfach die These aufzustellen das es auch vmtl daran liegt das viele Adapter (wenn nicht sogar die meisten) PullAdapter sind. D.h. Sie holen regelmäßig ihre werte ab und melden die dann per adapter.setState() egal ob die werte sich geändert haben oder nicht. Und so kommt ws das eben z.b. Der Hue Adapter auf einmal recht viele state änderungen publisht und das macht dann hin/wieder recht hohe state peaks. Helfen würde hierbei IMHO wenn Bluefox dem adapter.setState() wie hier besprochen (http://forum.iobroker.net/viewtopic.php?f=24&t=4868) eine möglichkeit verpassen würde die werte nur zu setzen/publishen wenn sich die werte auch geändert haben. IMHO wäre es ggf auch testweise mal interessant per default die adapter.setState() funktion sich so verhalten zu lassen und nur adapter die eben nicht in regelmäßigen Abständen werte abholen sondern diese aktiv geliefert bekommen sollten setState dann mit einer force option aufrufen. iMHO sollte sich somit das state change augkommen radikal reduzieren lassen.
                          RaspberryMatic @ PromoxVE mit ~190 HomeMatic Geräten + ioBroker – GitHub – GitHub Sponsors / PayPal
                          • jens.mausJ
                            jens.mausJ
                            jens.maus
                            @Pman:
                            Leider funktioniert die Hue Api ja nur mit Polling, dabei werden dann alle paar Sekunden alle Leuchten abgerufen und die Datenkpunkte gespeichert. Möglicherweise ist es auch hier sinnvoll nur tatsächlich geänderte Datenpunkte auch zu schreiben, ich gucke mir das mal an sobald ich Zeit dazu habe. Es hilft natürlich auch die Polling-Abstände in den Adapteroptionen zu verlängern. `
                            Wenn du dir das anschaust dann magst du vielleicht mal einen Blick auf folgende Funktion werfen die ich von Bluefox erhalten/angepasst habe und die bis er ggf adapter.setState() angepasst hat so ein setState nur bei wertänderung implementiert:
                            https://github.com/jens-maus/ioBroker.u … in.js#L192
                            Funktioniert in meinem ioBroker.unifi adapter sehr gut.
                            • BluefoxB
                              @jens.maus:
                              @Marcolotti:
                              Ich denke es ist sicherlich nicht spezifisch bzgl des Philips Hue Adapters. Ich wage auch mal einfach die These aufzustellen das es auch vmtl daran liegt das viele Adapter (wenn nicht sogar die meisten) PullAdapter sind. D.h. Sie holen regelmäßig ihre werte ab und melden die dann per adapter.setState() egal ob die werte sich geändert haben oder nicht. Und so kommt ws das eben z.b. Der Hue Adapter auf einmal recht viele state änderungen publisht und das macht dann hin/wieder recht hohe state peaks. Helfen würde hierbei IMHO wenn Bluefox dem adapter.setState() wie hier besprochen (http://forum.iobroker.net/viewtopic.php?f=24&t=4868) eine möglichkeit verpassen würde die werte nur zu setzen/publishen wenn sich die werte auch geändert haben. IMHO wäre es ggf auch testweise mal interessant per default die adapter.setState() funktion sich so verhalten zu lassen und nur adapter die eben nicht in regelmäßigen Abständen werte abholen sondern diese aktiv geliefert bekommen sollten setState dann mit einer force option aufrufen. iMHO sollte sich somit das state change augkommen radikal reduzieren lassen. `
                              setStateIfChanged Funktion wird nicht besonders helfen, sogar die Sache verschlimmern.
                              Man muss erst den Wert lesen und dann updaten. Das sind 2 requests über Netz. (Im iobroker läuft doch alles über sockets). Wenn man einfach schreibt, dann ist das nur ein request.
                              Natürlich danach bekommen history und Co und admin die Werte, aber besser ist natürlich im Adapter zu prüfen.
                              HueLampen sind vermutlich boolean, und wenn sogar dimmer, dann pro Wert 8 Bytes.
                              Wenn 100 Lampen sind es 800 Bytes. Ein Adapter braucht aber 20 MB Minimum. 1kb ist im Vergleich nichts.
                              • ruhr70R
                                ruhr70R
                                ruhr70
                                Update auf 0.15.3 hat nicht funktioniert. ioBroker startet nicht mehr.
                                Fehlermeldung:
                                root@ubuntu1604server:/opt/iobroker# iobroker upgrade self
                                npm install iobroker.js-controller --production --prefix "/opt/iobroker" (System call)
                                module.js:327
                                throw err;
                                ! Error: Cannot find module './lib/encoding'
                                at Function.Module._resolveFilename (module.js:325:15)
                                at Function.Module._load (module.js:276:25)
                                at Module.require (module.js:353:17)
                                at require (internal/module.js:12:17)
                                at loadModule (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/negotiator/index.js:108:16)
                                at Negotiator.encodings (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/negotiator/index.js:56:28)
                                at Accepts.encoding.Accepts.encodings (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/index.js:136:26)
                                at XHR.Polling.doWrite (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/lib/transports/polling.js:301:36)
                                at XHR.Polling.write (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/lib/transports/polling.js:266:8)
                                at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/lib/transports/polling.js:251:10
                                npm 2.1.5.11
                                node 4.7.2
                                Ubuntu 16.04
                                [EDIT]
                                Oben die Meldung bezog sich darauf, welche Meldung nach der "normalen" Update-Reihenfolge kam.
                                Nach der Neuinstallation des js-controllers funktioniert es.
                                • BluefoxB
                                  @Pman:
                                  Da ich dort am besten alles testen kann habe ich mein Produktivsystem (nach einem Backup :lol: ) auf die git Version von js-controller, admin, vis und web geupdated.
                                  Bisher läuft fast alles rund, keine Probleme beim Updaten (alles über shell) und beim Starten danach.
                                  Eine Sache ist mir aber aufgefallen, ich kann aber nicht sagen ob es am Update liegt, weil ich es vorher nicht getestet habe:
                                  Wenn ich Web/Vis mit https und auth absichere, kann ich nur noch mit dem Standard-Admin User auf die Views zugreifen. Ein zweiter User, welcher auch in der Admin-Gruppe ist, kann zwar edit.html nutzen, aber index.html bleibt bei "Lade Werte…" hängen. In der Browserkonsole kommt dies hier:
                                  conn.js:266 2017-01-20T11:18:03.426Z Connected => authenticate
                                  conn.js:281 2017-01-20T11:18:03.561Z Authenticated: true
                                  vis.js:3202 Request 0 states.
                                  Mit dem Standard-Admin User:
                                  conn.js:266 2017-01-20T11:20:29.266Z Connected => authenticate
                                  conn.js:281 2017-01-20T11:20:29.382Z Authenticated: true
                                  vis.js:3219 Create inner vis object harmony.0.Wohnzimmer_Hub.TV.Exit
                                  vis.js:3219 Create inner vis object harmony.0.Wohnzimmer_Hub.TV.Return
                                  vis.js:3219 Create inner vis object harmony.0.Wohnzimmer_Hub.TV.Select
                                  vis.js:2796 [1484911229917] Request 115 states.
                                  Bitte checken was für eine iobroker.socketio Version installiert. Sollte 1.7.4 sein.
                                  /opt/iobroker/node_modules/iobroker.socketio
                                  und
                                  /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio
                                  • P
                                    P
                                    Pman
                                    @Bluefox:
                                    und
                                    /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio `
                                    Der Fix dafür war mein letzter Pull-Request:
                                    https://github.com/ioBroker/ioBroker.js … r/pull/129
                                    84.2k
