  4. Test Adapter KNX v1.0.x
knx adapter
719 Beiträge 93 Kommentatoren 243.5k Aufrufe 85 Beobachtet
  • M Markus84
    Ich habe folgenden Fehler im Log:
    knx.0	2021-05-07 01:14:01.715	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342841712,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:13:58.573	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342838569,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:13:48.571	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342828568,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:13:39.064	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342819029,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:13:28.573	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342808567,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:13:18.568	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342798563,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:13:08.627	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342788585,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:12:58.565	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342778561,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:12:48.563	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342768559,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:12:38.562	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342758557,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:12:28.564	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342748557,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:12:18.559	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342738553,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    knx.0	2021-05-07 01:12:08.556	silly	(2133) States user redis pmessage knx.0.*/knx.0.info.connection:{"val":true,"ack":true,"ts":1620342728551,"q":0,"from":"system.adapter.knx.0","user":"system.user.admin","lc":1620342498948}
    Während der Fehler alle paar Sekunden einläuft kann ich weder an den Bus senden noch vom Bus empfangen. Dann geht es wieder für ein paar Minuten ohne Probleme und dann läuft wieder alle paar Sekunden dieser Fehler ein. Hat jemand eine Idee woran das liegen könnte?
    Edit: Es hat mit der Meldung im Log nichts zu tun. Ich habe leider auch so sporadische Aussetzer. Die frames pro Sekunde habe ich schon auf 30 gesetzt. Das hat leider nichts geändert.
    GarfonsoG Offline
    GarfonsoG Offline
    Garfonso
    schrieb am zuletzt editiert von Garfonso
    #459
    @markus84
    Da sind keine Fehler in deinem log? Du hast nur die höchste Logstufe an, wo jeder State-Änderung (es wir der connection state auf "true" gesetzt).
    //Edit; oh, hattest du schon gesehen. Merkwürdig ist, dass er connection immer wieder auf true setzt, das zeigt schon irgendwie nen Verbindungsproblem... grübel -> ne, ok, macht er bei mir auch alle paar Sekunden.
    Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
    Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
    • GarfonsoG Garfonso
      @markus84
      Markus84
      #460
      @garfonso Ich habe den Fehler gefunden. Ich schreibe einen ioBroker-Status bei einer Veränderung auf den Bus. Die Bus-Gruppenadresse hatte ich noch nicht mit irgendetwas verknüpft. Dies führt dazu, dass für ca. 1-3 Minuten weder etwas auf den Bus gesendet wird noch ankommt. Danach geht es wieder einwandfrei. Nachdem ich die betreffende Gruppenadresse mit einem Gerät verknüpft habe, ist das Problem weg.
      Ist es grundsätzlich möglich, dass Geräte bei einem Neustart den Status von ioBroker Datenpunkten auslesen können? Oder muss ich das einfach regelmäßig auf den Bus schreiben? Ich meine ich hätte hier im Forum mal etwas zu dem Thema gelesen, ich finde es aber einfach nicht mehr...
      GarfonsoG TheBamT 2 Antworten Letzte Antwort
      • M Markus84
        GarfonsoG Offline
        GarfonsoG Offline
        Garfonso
        #461
        @markus84 said in Test Adapter KNX v1.0.x:
        Dazu müsste der Adapter auf GroupValueRead Nachrichten reagieren (so denn das Gerät versucht den Status auszulesen, machen leider auch nicht alle). Laut chefkoch geht das irgendwie, ich habe es aber selber nie hinbekommen und wüsste erlich gesagt auch nicht wie...
        V 1 Antwort Letzte Antwort
        • M Markus84
          TheBamT Offline
          TheBamT Offline
          TheBam
          #462
          @markus84 sagte in Test Adapter KNX v1.0.x:
          Das geht du kannst mit einem blockly reagieren auf änderungen. Dann ändert sich der Zeit Stempel danach musst du dann einfach den Wert erneut auf den Bus senden.
          • TheBamT TheBam
            Markus84
            #463
            @thebam Danke! Das ist natürlich echt aufwändig. Ich glaube ich sende dann die meisten Sachen einfach zyklisch, werde aber bei einigen wichtigen Dingen mir die Arbeit machen und wirklich den Zeitstempel mit einem Blockly überwachen.
              V Offline
              V Offline
              Videonisse
              #464
              @garfonso sagte in Test Adapter KNX v1.0.x:
              So far I know, chefkoch responded in github that KNX Adapter can NOT respond to a GroupValueRead from the bus, as he hasn't yet found any way to solve this.
              I have an idea that maybe using a Device Dummy representing ioBroker in the ETS could help the Adapter to know which GAs with ETS Write flag that "belongs" to the ioBroker/KNX Adapter and that it should respond with a GroupValueRespond for those. Have you had any thoughts about this?
              ioBroker v3.3.18, Debian 10 Buster 64-bit (Vmware 6.5 VM), Node.js: v12.22.6, NPM: 6.14.15
              Most important Device Adapters: KNX, Trådfri, Homekit/Yahka
              GarfonsoG 1 Antwort Letzte Antwort
                killroy2
                #465
                ich habe aktuell ein Problem dass mein KNX Ethernet-Interface ab und am mal aussteigt. Zustände sind dann ich up-to-date und sollte bei Buswiederkehr aktualisiert werden. Dazu 2 Fragen:
                -wie erkenne ich einen Busausfall möglichst früh und zuverlässig?
                Es gibt ein info.connection Objekt, dass ist aber immer true. Derzeit Überwache ich den Ethernet ping.
                -Als Reaktion sollen wie bei einem Adapterneustart wichtige Messages neu angefragt werden. Wie bekomme ich das hin?
                Vielen Dank
                • V Videonisse
                  GarfonsoG Offline
                  GarfonsoG Offline
                  Garfonso
                  #466
                  @videonisse said in Test Adapter KNX v1.0.x:
                  This was proposed before. From what I know there has not been any development in that direction, though.
                  • K killroy2
                    Vielen Dank
                    GarfonsoG Offline
                    GarfonsoG Offline
                    Garfonso
                    #467
                    @killroy2 said in Test Adapter KNX v1.0.x:
                    Der Adapter fragt bei einem Neustart eigentlich alles per GroupValueRead ab, was er als StatusGA erkennt. Bei mir schickt der bestimmt ne Minute lang nur GroupValueRead raus (halt mit throtteling, damit das Interface nicht direkt abraucht) und hat dann nach den antworten den aktuellen stand.
                    -> falls das bei dir nicht passiert, ggf. nochmal die Flags im ETS und die Read/Write Flags der Objekte in ioBroker prüfen.
                    (Throtteling würde ich auch bei dir empfehlen mal anzugucken, wenn das Interface aussteigt -> in den Instanzoptionen die Anzahl Pakete (oder frames?) etwas runtersetzten, dann bremst der Adapter das raussenden).
                      killroy2
                      #468
                      @garfonso
                      Bei mir ist Pakete pro Sekunde auf 30 eingestellt.
                      Dass KNX auch bei niederer Last bei mir aussetzt hat denke ich nichts mit Iobroker zu tun, ich sehe dann in der ETS im Gruppenmonitor eine Meldung Verbindung verloren und kurz später Verbindung hergestellt. Ich habe das Ethernet Interface im Verdacht und werde mal austauschen. Bis dahin und auch generell versuche ich mein System robuster zu gestalten.
                      Nach Adapterneustart fragt er bei mir auch jede Menge ab. Genau das möchte ich selber triggern, geht das?
                        V Offline
                        V Offline
                        Videonisse
                        schrieb am zuletzt editiert von Videonisse
                        #469
                        @garfonso As you seem to be an experienced user of the adapter, could you verify that you really get all DPs updated when receiving GroupValueRespons after the start of the adapter? For me and some other users, some DPTs doesn't work 100%. For example DPT 5.001. I have not been able to get any help regarding this and I can't understand how it can be a problem just with my (and some other few users) installation.
                        The easiest way to reproduce the Issue:
                        • Switch a dimmer light off. Notice the dim value object (should be 0%)
                        • Turn off KNX Adapter instance
                        • Switch the dimmer light on
                        • Turn on KNX Adapter instance
                        • Notice the dim value object (should be anything else than 0%)
                        If your DP still shows 0% it would make it likely to be a general bug for all installations. If you get the correct %, I need to look into what's wrong with my ioBroker.
                        This is the Github issue: https://github.com/ioBroker/ioBroker.knx/issues/162#issuecomment-838082533
                        M GarfonsoG 2 Antworten Letzte Antwort
                        • V Videonisse
                          Markus84
                          #470
                          @videonisse I am not sure if it is in any way related to your problem, but I found out a couple of thinks that make the adapter unresponsive for a couple of minutes:
                          • Do not sent an empty string to an ASCII GA
                          • I changed the structure of a GA from Temperatur (Ist) to Temperatur-Ist. The former datapoint in ioBroker worked fine, the new datapoint was not working properly. After deleting all datapoints from knx.0. and reimporting the same ETS project file again the new dataipoints worked. Not sure what it causes it. The RAW values looked almost the same. Only one value was different, I think it was "ts".
                          • I write several information from ioBroker to GAs. The GAs only exist to show information on a MDT LED Display. When I physically disconnect the MDT LED and update one of these GAs, the adapter does not receive any GA changes for a couple of minutes.
                          @Garfonso Ich weiß du bist nicht der ursprüngliche Entwickler des Adapters, aber bist du der richtige Ansprechpartner für solche Bugmeldungen? Fehler eins habe ich auf Github gemeldet. Macht es Sinn die beiden anderen Punkte auch zu melden? Wird der Adapter durch den ursprünglichen Entwickler oder dich fortentwickelt?
                          • K killroy2
                            @garfonso
                            GarfonsoG Offline
                            GarfonsoG Offline
                            Garfonso
                            #471
                            Am einfachsten über Adapter-Neustart, wenn du merkst, dass das Interface weg war. Nicht? ;-)
                            Sonst kannst du die StatusGA so einstellen (ich meine read & write auf true -> siehe Readme des Adapters in der Tabelle), dass die bei einem write auf den State ein GroupValueRead an den Bus schicken und damit dann den Wert aktualisieren.
                            Ich habe bei mir ehrlich gesagt die meisten KNX Geräte so eingestellt, dass sie zyklisch ihren Status senden.
                            • V Videonisse
                              GarfonsoG Offline
                              GarfonsoG Offline
                              Garfonso
                              #472
                              @videonisse
                              I followed your steps and it works perfectly fine for me.
                              I can not guarantee that all states are updated, but whenever I checked, the state was updated during startup. If I watch the bus in ETS I also can see the adapter sending out a lot of GroupValueRead messages.
                              Do you generally see updates from the bus in the states? Are the action and status GAs linked in ioBroker?
                              • M Markus84
                                GarfonsoG Offline
                                GarfonsoG Offline
                                Garfonso
                                #473
                                Bitte auf jeden Fall github issues und möglichst mit allen Infos.
                                Ich habe bisher leider keine Zeit gefunden in den code zu gucken... aber wenn ich das mal schaffe, ist es auf Github am übersichtlichsten die Probleme abzuarbeiten.
                                  Markus84
                                  #474
                                  @garfonso said in Test Adapter KNX v1.0.x:
                                  Alles klar, mache ich!
                                    @videonisse
                                    V Offline
                                    V Offline
                                    Videonisse
                                    #475
                                    @videonisse
                                    Interesting!
                                    Yes. All Boolean values and for example, 0% with DPT 5.001 are updated correctly for me. But a value above 0% is not. (I assume you mean GroupValueRespons. With GroupValueWrite I don't have any problems.)
                                    ALL values are also visible in the log, but the above values are not stored in the states db.
                                    Yes, they are.
                                    I can't understand what can be wrong with my installation if the values are received correctly by the adapter but not written to the states db. Any ideas on how I can troubleshoot further?
                                    • V Videonisse
                                      @videonisse
                                      Interesting!
                                      Yes, they are.
                                      GarfonsoG Offline
                                      GarfonsoG Offline
                                      Garfonso
                                      #476
                                      @videonisse
                                      I'll try to have a look at the code in a debug environment some time.
                                        @videonisse
                                        Markus84
                                        #477
                                        Ich habe ein seltsames Problem: Ich versuche alle Rollos über ioBroker zu steuern. Etwa zwei Drittel funktioniert einwandfrei, das verbleibende Drittel funktioniert nicht. Ich kann leider nicht herausfinden woran es liegt. Hier die Gruppenadressen:
                                        Bei den GAs, bei denen kein letzter Wert steht funktioniert es nicht. Es wird anstatt eines GroupValueWrite ein GroupValueRead gesendet.
                                        Hier ein Beispiel eines Datenpunktes bei dem es funktioniert:
                                          "from": "system.adapter.knx.0",
                                          "user": "system.user.admin",
                                          "ts": 1621626475652,
                                          "common": {
                                            "name": "EG-Buero-Rollo-Fahren",
                                            "type": "boolean",
                                            "role": "",
                                            "max": true,
                                            "min": false
                                          "native": {
                                            "dpt": "DPT1.008",
                                            "address": "6/0/2",
                                            "addressRefId": "P-0C17-0_GA-1140",
                                            "statusGARefId": "",
                                            "actGARefId": "",
                                            "update": "",
                                            "objRef": "MD-2_M-6_MI-1_O-2-23_R-4",
                                            "devName": "M-0083_A-0128-43-7CBD",
                                            "devInst": "P-0C17-0_DI-24",
                                            "objectSize": ""
                                          "acl": {
                                            "object": 1636,
                                            "owner": "system.user.admin",
                                            "state": 1636
                                          "_id": "knx.0.Beschatten-1.Fahren.EG-Buero-Rollo-Fahren",
                                          "type": "state"
                                        Und hier ein Beispiel bei dem es nicht funktioniert:
                                          "_id": "knx.0.Beschatten-1.Fahren.OG-Ankleide-Rollo-Fahren",
                                          "type": "state",
                                          "common": {
                                            "name": "OG-Ankleide-Rollo-Fahren",
                                            "type": "boolean",
                                            "role": "value",
                                            "read": true,
                                            "write": true,
                                            "max": true,
                                            "min": false
                                          "native": {
                                            "dpt": "DPT1.008",
                                            "address": "6/0/16",
                                            "addressRefId": "P-0C17-0_GA-1154",
                                            "actGARefId": "",
                                            "update": "",
                                            "objRef": "O-5_R-11034",
                                            "devName": "M-0083_A-008A-27-4A49",
                                            "devInst": "P-0C17-0_DI-49",
                                            "objectSize": ""
                                          "ts": 1621626479292,
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                        Ich weiß leider nicht, wo ich den Fehler noch suchen soll. Hat jemand eine Idee?
                                        GarfonsoG V 2 Antworten Letzte Antwort
                                        • M Markus84
                                            "common": {
                                              "type": "boolean",
                                              "role": "",
                                              "max": true,
                                              "min": false
                                            "native": {
                                              "dpt": "DPT1.008",
                                              "address": "6/0/2",
                                              "actGARefId": "",
                                              "update": "",
                                              "objectSize": ""
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636
                                            "type": "state"
                                            "type": "state",
                                            "common": {
                                              "type": "boolean",
                                              "role": "value",
                                              "read": true,
                                              "write": true,
                                              "max": true,
                                              "min": false
                                            "native": {
                                              "dpt": "DPT1.008",
                                              "actGARefId": "",
                                              "update": "",
                                              "objectSize": ""
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                          GarfonsoG Offline
                                          GarfonsoG Offline
                                          Garfonso
                                          #478
                                          @markus84
                                          Ja, du musst read auf false setzen, siehe auch hier: https://github.com/ioBroker/ioBroker.knx#3-herausfinden-der-schalt--und-statusaddressen
                                          Da wird leider oft quatsch gesetzt, wenn es keine Zuordnung von SchaltGA und StatusGA gibt.. theoretisch sollte sich das an den Flags im KNX Projekt orientieren. Die kannst du ja mal vergleichen.
                                          V M 2 Antworten Letzte Antwort
