Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread)
@s-bormann
Die Safari Konsole überfordert mich
Ich hoffe, ich habe das Richtige erwischt
//Get Link of best fitting web-adapter console.log("getLink of best fitting web-adapter"); getExtendableInstances(async function (result) { if (result) { //Detect connection over iobroker.net or iobroker.pro var isIobrokerPro = false; if (location.hostname.toLowerCase() == "iobroker.net" || location.hostname.toLowerCase() == "iobroker.pro"){ //Connection over iobroker.net or iobroker.pro console.log("Connection over iobroker.net or iobroker.pro detected..."); isIobrokerPro = true; } //Find best fitting web-Adapter var bestInstance = 0; var goalSecure = (location.protocol == 'https:'); var goalSecureFound = false; var goalSocketFound = false; var goalForceWebSocketsFound = false; for (i=0; i<result.length; i++){ if (result[i].native.secure == goalSecure){ if (!goalSecureFound) { goalSecureFound = true; bestInstance = i; } if (result[i].native.socketio == ""){ if (!goalSocketFound) { goalSocketFound = true; bestInstance = i; } if (result[i].native.forceWebSockets == false){ if(!goalForceWebSocketsFound){ goalForceWebSocketsFound = true; bestInstance = i; } } } } } if (!(goalSocketFound && goalForceWebSocketsFound) && !isIobrokerPro){ console.log("Could not find any web-adapter with integrated socketIO and disabled Force Web-Sockets"); socketConnectionErrorMessages += "\n" + _("You need to activate integrated socket.IO and disable 'Force Web-Sockets' in web-adapter-settings!"); } //Create Link from best fitting web-adapter if (isIobrokerPro){ //Connection over iobroker.net or iobroker.pro - connect without ports! link = location.protocol + "//" + location.hostname + "/iqontrol"; var connectionLink = location.protocol + "//" + location.hostname; var forceWebSocket = false; } else { //Direct connection link = (result[bestInstance].native.secure ? "https://" : "http://") + location.hostname + ":" + result[bestInstance].native.port + "/iqontrol"; var connectionLink = (result[bestInstance].native.secure ? "https://" : "http://") + location.hostname + ":" + result[bestInstance].native.port; var forceWebSockets = result[bestInstance].native.forceWebSockets; } console.log("Got Link: " + link); $('#mainLink').attr('href', link + "/index.html?namespace=" + adapter + "." + instance); //Add Roles to dialogDeviceEditCommonRole-Selectbox $('#dialogDeviceEditCommonRole').empty().append("<option disabled selected value>" + _("Select Role") + "</option>"); for (var element in iQontrolRoles){ $('#dialogDeviceEditCommonRole').append("<option value='" + element + "' data-icon='" + (iQontrolRoles[element].icon ? link + iQontrolRoles[element].icon : "") + "'>" + _(iQontrolRoles[element].name) + "</option>"); } $('#dialogDeviceEditCommonRole').select(); //Signal to admin, that no changes yet if(!newConfig) onChange(false); //Create /usericons /usersymbols and /userwidgets var createSpecialDirs = ["/usericons", "/usersymbols", "/userwidgets"]; for(i = 0; i < createSpecialDirs.length; i++){ var dirname = createSpecialDirs[i]; console.log("Check directory " + userfilesImagePath + dirname); var result = await checkDirExistance(userfilesImagePath + dirname); console.log(result); if(!result) { console.log("Creating directory " + userfilesImagePath + dirname); await createDirAsync(userfilesImagePath + dirname); } }; //Get images console.log("getImages"); getImages(async function(){ //Show Settings console.log("All settings loaded. Adapter ready."); $('.hideOnLoad').show(); $('.showOnLoad').hide(); loading = false; //Reinitialize all the Materialize labels on the page if you are dynamically adding inputs: if (M) M.updateTextFields(); //Get iobrokerObjects getIobrokerObjects(); //If react, make some css adjustments var toDo = function(){ if(iobrokerObjects["system.adapter.admin.0"]?.native?.react){ isReact = true; var customCSS = ""; customCSS += ".table-values tr:nth-child(2n) { background-color: rgba(0,0,0,0.04) !important; }"; customCSS += ".table-values.highlight > tbody > tr:hover { background-color: rgba(0,0,0,0.08) !important; }"; customCSS += ".table-values.highlight > tbody > tr:nth-child(2n):hover { background-color: rgba(0,0,0,0.08) !important; }"; customCSS += ".table-values th { background-color: rgba(0,0,0,0.1) !important; color: #1d1d1d !important; }"; customCSS += ".title { background-color: #164477; }"; customCSS += ".m .tabs .tab a { color: rgba(0, 0, 0, 0.5); }"; customCSS += ".m .tabs .tab a:hover { color: rgba(0, 0, 0, 0.86); }"; customCSS += ".m .tabs .tab a.active { color: #164477; }"; customCSS += ".m .tabs .active { border-bottom: 2px solid #164477; }"; customCSS += ".m nav { background-color: #3399cc; }"; customCSS += ".m .btn { background-color: #e0e0e0; color: #000000; }"; customCSS += ".m .btn:hover { background-color: #d5d5d5; }"; customCSS += ".m .btn.disabled { background-color: rgba(0, 0, 0, 0.12) !important; color: rgba(0, 0, 0, 0.26) !important; }"; customCSS += ".m .btn-floating { background-color: transparent; box-shadow: none; color: #000000; }"; customCSS += ".m .btn-floating:hover { background-color: rgba(0,0,0,0.08); }"; customCSS += ".m .btn-floating.selectClear { background-color: #ffffff; }"; customCSS += ".m .btn-floating.selectClear:hover { background-color: #ebebeb; }"; customCSS += ".m .btn-floating i { color: #000000; transition: color 0.3s; }"; customCSS += ".m .btn-floating.red { background-color: transparent !important; }"; customCSS += ".m .btn-floating.red:hover { background-color: red !important; }"; customCSS += ".m .btn-floating.red:hover i { color: #ffffff; }"; customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button { background-color: transparent; }"; customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button:hover { background-color: rgba(0,0,0,0.08); }"; customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button i { color: #757575; }"; customCSS += ".dialog-select-object-ids .objects-list-table { background-color: #ffffff; }"; customCSS += ".dialog-select-object-ids .objects-list-table thead { display: none; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr { border: none !important; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr:hover { background-color: #3399cc; outline: none; color: #ffffff; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr:hover .fancytree-title { color: #ffffff; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr.fancytree-active { background-color: #236b8e !important; outline: none !important; color: #ffffff !important; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr.fancytree-active .fancytree-title { color: #ffffff; }"; customCSS += ".dialog-select-object-ids table.objects-list-table td { border: none !important; }"; customCSS += ".m .dropdown-content li>span { color: rgba(0, 0, 0, 0.86); }"; customCSS += ".m .dropdown-content li>a { color: rgba(0, 0, 0, 0.86); }"; customCSS += ".m [type=checkbox].filled-in:checked+span:not(.lever):after { border: #164477; background-color: #164477; }"; addCustomCSS(customCSS, "reactCSS"); $('.table-button-add').addClass('grey lighten-2'); var selectIdImgPath = './fancytree/react/'; $('#fancytreeCSSLink').attr('href', './fancytree/react/ui.fancytree.min.css'); var warnIfLE = "5.0.8"; } else { isReact = false; var warnIfLE = "5.0.6"; } //Warn if Admin-Version is too low if(parseInt((iobrokerObjects && iobrokerObjects["system.adapter.admin"] && iobrokerObjects["system.adapter.admin"].common && iobrokerObjects["system.adapter.admin"].common.version || "0").split('.').join('')) <= warnIfLE.split('.').join('')) alert(_("Some operations are only supported by admin versions > %s. Please update your admin-adapter!", warnIfLE)); } if(iobrokerObjectsReady) { toDo(); } else { iobrokerObjectsReadyFunctions.push(toDo); } }); } else { alert(_("Error: No web-adapter found!")); } });@kassmann sagte in Test Adapter iQontrol 1.8.x Vis:
@s-bormann
if (result) {
}//Find best fitting web-Adapter var bestInstance = 0; var goalSecure = (location.protocol == 'https:'); var goalSecureFound = false; var goalSocketFound = false; var goalForceWebSocketsFound = false; for (i=0; i<result.length; i++){ if (result[i].native.secure == goalSecure){ if (!goalSecureFound) { goalSecureFound = true; bestInstance = i; } if (result[i].native.socketio == ""){ if (!goalSocketFound) { goalSocketFound = true; bestInstance = i; } if (result[i].native.forceWebSockets == false){ if(!goalForceWebSocketsFound){ goalForceWebSocketsFound = true; bestInstance = i; } } } } } if (!(goalSocketFound && goalForceWebSocketsFound) && !isIobrokerPro){ console.log("Could not find any web-adapter with integrated socketIO and disabled Force Web-Sockets"); socketConnectionErrorMessages += "\n" + _("You need to activate integrated socket.IO and disable 'Force Web-Sockets' in web-adapter-settings!"); } //Create Link from best fitting web-adapter if (isIobrokerPro){ //Connection over iobroker.net or iobroker.pro - connect without ports! link = location.protocol + "//" + location.hostname + "/iqontrol"; var connectionLink = location.protocol + "//" + location.hostname; var forceWebSocket = false; } else { //Direct connection link = (result[bestInstance].native.secure ? "https://" : "http://") + location.hostname + ":" + result[bestInstance].native.port + "/iqontrol"; var connectionLink = (result[bestInstance].native.secure ? "https://" : "http://") + location.hostname + ":" + result[bestInstance].native.port; var forceWebSockets = result[bestInstance].native.forceWebSockets; } console.log("Got Link: " + link); $('#mainLink').attr('href', link + "/index.html?namespace=" + adapter + "." + instance); //Add Roles to dialogDeviceEditCommonRole-Selectbox $('#dialogDeviceEditCommonRole').empty().append("<option disabled selected value>" + _("Select Role") + "</option>"); for (var element in iQontrolRoles){ $('#dialogDeviceEditCommonRole').append("<option value='" + element + "' data-icon='" + (iQontrolRoles[element].icon ? link + iQontrolRoles[element].icon : "") + "'>" + _(iQontrolRoles[element].name) + "</option>"); } $('#dialogDeviceEditCommonRole').select(); //Signal to admin, that no changes yet if(!newConfig) onChange(false); //Create /usericons /usersymbols and /userwidgets var createSpecialDirs = ["/usericons", "/usersymbols", "/userwidgets"]; for(i = 0; i < createSpecialDirs.length; i++){ var dirname = createSpecialDirs[i]; console.log("Check directory " + userfilesImagePath + dirname); var result = await checkDirExistance(userfilesImagePath + dirname); console.log(result); if(!result) { console.log("Creating directory " + userfilesImagePath + dirname); await createDirAsync(userfilesImagePath + dirname); } }; //Get images console.log("getImages"); getImages(async function(){ //Show Settings console.log("All settings loaded. Adapter ready."); $('.hideOnLoad').show(); $('.showOnLoad').hide(); loading = false; //Reinitialize all the Materialize labels on the page if you are dynamically adding inputs: if (M) M.updateTextFields(); //Get iobrokerObjects getIobrokerObjects(); //If react, make some css adjustments var toDo = function(){ if(iobrokerObjects["system.adapter.admin.0"]?.native?.react){ isReact = true; var customCSS = ""; customCSS += ".table-values tr:nth-child(2n) { background-color: rgba(0,0,0,0.04) !important; }"; customCSS += ".table-values.highlight > tbody > tr:hover { background-color: rgba(0,0,0,0.08) !important; }"; customCSS += ".table-values.highlight > tbody > tr:nth-child(2n):hover { background-color: rgba(0,0,0,0.08) !important; }"; customCSS += ".table-values th { background-color: rgba(0,0,0,0.1) !important; color: #1d1d1d !important; }"; customCSS += ".title { background-color: #164477; }"; customCSS += ".m .tabs .tab a { color: rgba(0, 0, 0, 0.5); }"; customCSS += ".m .tabs .tab a:hover { color: rgba(0, 0, 0, 0.86); }"; customCSS += ".m .tabs .tab a.active { color: #164477; }"; customCSS += ".m .tabs .active { border-bottom: 2px solid #164477; }"; customCSS += ".m nav { background-color: #3399cc; }"; customCSS += ".m .btn { background-color: #e0e0e0; color: #000000; }"; customCSS += ".m .btn:hover { background-color: #d5d5d5; }"; customCSS += ".m .btn.disabled { background-color: rgba(0, 0, 0, 0.12) !important; color: rgba(0, 0, 0, 0.26) !important; }"; customCSS += ".m .btn-floating { background-color: transparent; box-shadow: none; color: #000000; }"; customCSS += ".m .btn-floating:hover { background-color: rgba(0,0,0,0.08); }"; customCSS += ".m .btn-floating.selectClear { background-color: #ffffff; }"; customCSS += ".m .btn-floating.selectClear:hover { background-color: #ebebeb; }"; customCSS += ".m .btn-floating i { color: #000000; transition: color 0.3s; }"; customCSS += ".m .btn-floating.red { background-color: transparent !important; }"; customCSS += ".m .btn-floating.red:hover { background-color: red !important; }"; customCSS += ".m .btn-floating.red:hover i { color: #ffffff; }"; customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button { background-color: transparent; }"; customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button:hover { background-color: rgba(0,0,0,0.08); }"; customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button i { color: #757575; }"; customCSS += ".dialog-select-object-ids .objects-list-table { background-color: #ffffff; }"; customCSS += ".dialog-select-object-ids .objects-list-table thead { display: none; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr { border: none !important; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr:hover { background-color: #3399cc; outline: none; color: #ffffff; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr:hover .fancytree-title { color: #ffffff; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr.fancytree-active { background-color: #236b8e !important; outline: none !important; color: #ffffff !important; }"; customCSS += ".dialog-select-object-ids table.objects-list-table tr.fancytree-active .fancytree-title { color: #ffffff; }"; customCSS += ".dialog-select-object-ids table.objects-list-table td { border: none !important; }"; customCSS += ".m .dropdown-content li>span { color: rgba(0, 0, 0, 0.86); }"; customCSS += ".m .dropdown-content li>a { color: rgba(0, 0, 0, 0.86); }"; customCSS += ".m [type=checkbox].filled-in:checked+span:not(.lever):after { border: #164477; background-color: #164477; }"; addCustomCSS(customCSS, "reactCSS"); $('.table-button-add').addClass('grey lighten-2'); var selectIdImgPath = './fancytree/react/'; $('#fancytreeCSSLink').attr('href', './fancytree/react/ui.fancytree.min.css'); var warnIfLE = "5.0.8"; } else { isReact = false; var warnIfLE = "5.0.6"; } //Warn if Admin-Version is too low if(parseInt((iobrokerObjects && iobrokerObjects["system.adapter.admin"] && iobrokerObjects["system.adapter.admin"].common && iobrokerObjects["system.adapter.admin"].common.version || "0").split('.').join('')) <= warnIfLE.split('.').join('')) alert(_("Some operations are only supported by admin versions > %s. Please update your admin-adapter!", warnIfLE)); } if(iobrokerObjectsReady) { toDo(); } else { iobrokerObjectsReadyFunctions.push(toDo); } }); } else { alert(_("Error: No web-adapter found!")); }});
Hi, leider nur fast :)
Ich benötige das, was im Fenster "Console" steht. Im "optimalfall" sollte da ein Fehler stehen mit einer Zeilennummer, z.B.
index_m.js:12345 ERROR: irgendwas stimmt nicht
Das bräuchte ich. -
@s-bormann
if (result) {
Das bräuchte ich. -
ich wollte gerade ein Grafana Dashboard als Link hinterlegen. In der Kachel kommt dann immer "hat eine Verbindung verweigert".
Hat einer eine Idee was ich prüfen kann?
Von allen anderen Geräten ist das Dashboard über den Link erreichbar.
@peter213 ich seh in den links was von proxmox. was versuchst du da?
ein grafana link als widget und background URL sieht so aus.
http://192.168.0.252:3000/d-solo/z8EAZn_Gk/heating?orgId=1&refresh=1m&theme=light&panelId=2
z.b. temperatur und luftfeuchte:
@da_woody mein Dashboard heißt Proxmox ;-)
ich nutze diesen Link
http://192.168.15.24:3000/d/kxQQuHRZk/proxmox?orgId=1&refresh=10s&kiosk=tv@peter213 ah, ok! mehr war ja nicht zu sehn, drum die frage... ;)
du hast als gerät externer link und bei url was eingetragen. background URL ist ja ok. versuchs mal als widget und ohne den URL eintrag.
wenn das nicht geht, stimmt mit den berechtigungen etwas nicht. dazu hat @Dutchman ein gutes video auf YT. -
@da_woody Ich habe es rausgefunden. Es gibt in Grafana einen Config Punkt das Embedding als iframe usw nicht erlaubt ist. Nachdem ich "allow_embedding=true" gesetzt habe gehts es.
Hallo zusammen, habe seit heute das folgende Problem, wenn ich iQontrol administrieren möchte:
Nen Upload, um das Problem zu beheben, hab ich schon versucht...Instanz neu gestartet auch...nix...@kueppert hast admin höher als 5.0.15 installiert...
https://github.com/sbormann/ioBroker.iqontrol/issues/185
https://github.com/ioBroker/ioBroker.admin/issues/848 -
@s-bormann
neuer Versuch
index_m.js:2128
Jetzt besser?
Ging das ganze früher denn mal? Aktuell wird ja viel im Admin geschraubt und verändert, liegt es vielleicht daran?
https://github.com/ioBroker/ioBroker.admin/issues/848@da_woody sagte in Test Adapter iQontrol 1.8.x Vis:
https://github.com/ioBroker/ioBroker.admin/issues/848Laut Bluefox wird es mit der nächsten Admin-Version 5.0.21 wieder gehen.
Edit:
habe es denke ich geschafft. Habe die Stream URL in Background URL eingefügt. Jetzt die nächste Frage.
Wie bekomme ich das Widget von der Größe angepasst, das meine komplettes Bild angezeigt wird.
Ich habe quasi scroll Balken nach Oben und zur Seite.Hallo zusammen,
ich würde gerne einen webcam stream von meinem 3D Drucker integrieren.
Läuft über eine Stream URL. Wie kann ich das umsetzten?Danke schon mal.
Gruß Klaus -
Edit:
Gruß Klaus@funboxbolzer ich habs als background html drinnen.
<html style="height: 100%;"><head><meta name="Ender" content="width=device-width, minimum-scale=0.1"></head><body style="margin: 0px; background: #424242; height: 100%"><img style="-webkit-user-select: none;max-width: 100%;margin: auto;" src="http://192.168.2.59/webcam/?action=stream"></body></html>
@da_woody
Besten dank. Dann werde ich das mal so testen.Hast du repetear oder octoprint?
Ich nutze repetear. Wie verhält sich das mit dem stream, wenn du die visualisierung geschlossen hast? Dann ist der stream aus oder? -
@da_woody
Ich nutze repetear. Wie verhält sich das mit dem stream, wenn du die visualisierung geschlossen hast? Dann ist der stream aus oder?@funboxbolzer ich tu mit octoprint. der stream läuft im octoprint natürlich weiter. warum sollte der aufhören? solang der raspi strom hat, wird auch gestreamt. steuern tu ich sowieso über octoprint, in iQontrol ist nur für die übersicht.
@s-bormann
neuer Versuch
index_m.js:2128
Jetzt besser?
@da_woody Danke für die Info.
Bedienen wollte ich auch nicht, ich hatte evtl. Bedenken, dass der Dauerstream den Raspberry mit der Zeit überfordern könnte.@s-bormann Ist eicht ein Tolles VIS. Danke dafür!!
Gruß Klaus
Gruß Klaus
@funboxbolzer nun ja, der stream kommt ja vom raspi mit octoprint. der wird in der vis ja nur aufgerufen. sollte somit ioBroker nicht überlasten. oder seh ich da was falsch?
@s-bormann
Es ging immer und seit gestern, zumindest ist mir da aufgefallen, geht es auch wieder.
@s-bormann
Perfekt, war vielleicht im Rahmen der vielen Updates von ioBroker mal zwischendrin zerschossen.
genau das meinte ich mit berechtigungen. konnt mich aber nicht genau erinnern, was es in der config war.
