    6.5k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • s.bormannS s.bormann
    @kassmann sagte in Test Adapter iQontrol 1.8.x Vis:
    @s-bormann
    Die Safari Konsole überfordert mich 😬
    Ich hoffe, ich habe das Richtige erwischt 😁
    //Get Link of best fitting web-adapter
    console.log("getLink of best fitting web-adapter");
    getExtendableInstances(async function (result) {
    if (result) {
    //Detect connection over iobroker.net or iobroker.pro
    var isIobrokerPro = false;
    if (location.hostname.toLowerCase() == "iobroker.net" || location.hostname.toLowerCase() == "iobroker.pro"){ //Connection over iobroker.net or iobroker.pro
    console.log("Connection over iobroker.net or iobroker.pro detected...");
    isIobrokerPro = true;
      	//Find best fitting web-Adapter
      	var bestInstance = 0;
      	var goalSecure = (location.protocol == 'https:');
      	var goalSecureFound = false;
      	var goalSocketFound = false;
      	var goalForceWebSocketsFound = false;
      	for (i=0; i<result.length; i++){
      		if (result[i].native.secure == goalSecure){
      			if (!goalSecureFound) {
      				goalSecureFound = true;
      				bestInstance = i;
      			if (result[i].native.socketio == ""){
      				if (!goalSocketFound) {
      					goalSocketFound = true;
      					bestInstance = i;
      				if (result[i].native.forceWebSockets == false){
      					if(!goalForceWebSocketsFound){
      						goalForceWebSocketsFound = true;
      						bestInstance = i;
      	if (!(goalSocketFound && goalForceWebSocketsFound) && !isIobrokerPro){
      		console.log("Could not find any web-adapter with integrated socketIO and disabled Force Web-Sockets");
      		socketConnectionErrorMessages += "\n" + _("You need to activate integrated socket.IO and disable 'Force Web-Sockets' in web-adapter-settings!");
      	//Create Link from best fitting web-adapter
      	if (isIobrokerPro){ //Connection over iobroker.net or iobroker.pro - connect without ports!
      		link = location.protocol + "//" + location.hostname + "/iqontrol";
      		var connectionLink = location.protocol + "//"  + location.hostname;
      		var forceWebSocket = false;
      	} else { //Direct connection
      		link = (result[bestInstance].native.secure ? "https://" : "http://") + location.hostname + ":" + result[bestInstance].native.port + "/iqontrol";
      		var connectionLink = (result[bestInstance].native.secure ? "https://" : "http://") + location.hostname + ":" + result[bestInstance].native.port;
      		var forceWebSockets = result[bestInstance].native.forceWebSockets;
      	console.log("Got Link: " + link);
      	$('#mainLink').attr('href', link + "/index.html?namespace=" + adapter + "." + instance);
      	//Add Roles to dialogDeviceEditCommonRole-Selectbox
      	$('#dialogDeviceEditCommonRole').empty().append("<option disabled selected value>" + _("Select Role") + "</option>");
      	for (var element in iQontrolRoles){ $('#dialogDeviceEditCommonRole').append("<option value='" + element + "' data-icon='" + (iQontrolRoles[element].icon ? link + iQontrolRoles[element].icon : "") + "'>" + _(iQontrolRoles[element].name) + "</option>"); }
      	$('#dialogDeviceEditCommonRole').select();
      	//Signal to admin, that no changes yet
      	if(!newConfig) onChange(false);
      	//Create /usericons /usersymbols and /userwidgets
      	var createSpecialDirs = ["/usericons", "/usersymbols", "/userwidgets"];
      	for(i = 0; i < createSpecialDirs.length; i++){
      		var dirname = createSpecialDirs[i];
      		console.log("Check directory " + userfilesImagePath + dirname);
      		var result = await checkDirExistance(userfilesImagePath + dirname);
      		console.log(result);
      		if(!result) {
      			console.log("Creating directory " + userfilesImagePath + dirname);
      			await createDirAsync(userfilesImagePath + dirname);
      	//Get images
      	console.log("getImages");
      	getImages(async function(){
      		//Show Settings
      		console.log("All settings loaded. Adapter ready.");
      		$('.hideOnLoad').show();
      		$('.showOnLoad').hide();
      		loading = false;
      		//Reinitialize all the Materialize labels on the page if you are dynamically adding inputs:
      		if (M) M.updateTextFields();
      		//Get iobrokerObjects
      		getIobrokerObjects();
      		//If react, make some css adjustments
      		var toDo = function(){
      			if(iobrokerObjects["system.adapter.admin.0"]?.native?.react){
      				isReact = true;
      				var customCSS = "";
      				customCSS += ".table-values tr:nth-child(2n) { background-color: rgba(0,0,0,0.04) !important; }";
      				customCSS += ".table-values.highlight > tbody > tr:hover { background-color: rgba(0,0,0,0.08) !important; }";
      				customCSS += ".table-values.highlight > tbody > tr:nth-child(2n):hover { background-color: rgba(0,0,0,0.08) !important; }";
      				customCSS += ".table-values th { background-color: rgba(0,0,0,0.1) !important; color: #1d1d1d !important; }";
      				customCSS += ".title { background-color: #164477; }";
      				customCSS += ".m .tabs .tab a { color: rgba(0, 0, 0, 0.5); }";
      				customCSS += ".m .tabs .tab a:hover { color: rgba(0, 0, 0, 0.86); }";
      				customCSS += ".m .tabs .tab a.active { color: #164477; }";
      				customCSS += ".m .tabs .active { border-bottom: 2px solid #164477; }";
      				customCSS += ".m nav { background-color: #3399cc; }";
      				customCSS += ".m .btn { background-color: #e0e0e0; color: #000000; }";
      				customCSS += ".m .btn:hover { background-color: #d5d5d5; }";
      				customCSS += ".m .btn.disabled { background-color: rgba(0, 0, 0, 0.12) !important; color: rgba(0, 0, 0, 0.26) !important; }";
      				customCSS += ".m .btn-floating { background-color: transparent; box-shadow: none; color: #000000; }";
      				customCSS += ".m .btn-floating:hover { background-color: rgba(0,0,0,0.08); }";
      				customCSS += ".m .btn-floating.selectClear { background-color: #ffffff; }";
      				customCSS += ".m .btn-floating.selectClear:hover { background-color: #ebebeb; }";
      				customCSS += ".m .btn-floating i { color: #000000; transition: color 0.3s; }";
      				customCSS += ".m .btn-floating.red  { background-color: transparent !important; }";
      				customCSS += ".m .btn-floating.red:hover { background-color: red !important; }";
      				customCSS += ".m .btn-floating.red:hover i { color: #ffffff; }";
      				customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button { background-color: transparent; }";
      				customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button:hover { background-color: rgba(0,0,0,0.08); }";
      				customCSS += ".dialog-select-object-ids .material .main-toolbar-table .panel-button i { color: #757575; }";
      				customCSS += ".dialog-select-object-ids .objects-list-table { background-color: #ffffff; }";
      				customCSS += ".dialog-select-object-ids .objects-list-table thead { display: none; }";
      				customCSS += ".dialog-select-object-ids table.objects-list-table tr { border: none !important; }";
      				customCSS += ".dialog-select-object-ids table.objects-list-table tr:hover { background-color: #3399cc; outline: none; color: #ffffff; }";
      				customCSS += ".dialog-select-object-ids table.objects-list-table tr:hover .fancytree-title { color: #ffffff; }";
      				customCSS += ".dialog-select-object-ids table.objects-list-table tr.fancytree-active { background-color: #236b8e !important; outline: none !important; color: #ffffff !important; }";
      				customCSS += ".dialog-select-object-ids table.objects-list-table tr.fancytree-active .fancytree-title { color: #ffffff; }";
      				customCSS += ".dialog-select-object-ids table.objects-list-table td { border: none !important; }";
      				customCSS += ".m .dropdown-content li>span { color: rgba(0, 0, 0, 0.86); }";
      				customCSS += ".m .dropdown-content li>a { color: rgba(0, 0, 0, 0.86); }";
      				customCSS += ".m [type=checkbox].filled-in:checked+span:not(.lever):after { border: #164477; background-color: #164477; }";
      				addCustomCSS(customCSS, "reactCSS");
      				$('.table-button-add').addClass('grey lighten-2');
      				var selectIdImgPath = './fancytree/react/';
      				$('#fancytreeCSSLink').attr('href', './fancytree/react/ui.fancytree.min.css');
      				var warnIfLE = "5.0.8";
      			} else {
      				isReact = false;
      				var warnIfLE = "5.0.6";
      			//Warn if Admin-Version is too low
      			if(parseInt((iobrokerObjects && iobrokerObjects["system.adapter.admin"] && iobrokerObjects["system.adapter.admin"].common && iobrokerObjects["system.adapter.admin"].common.version || "0").split('.').join('')) <= warnIfLE.split('.').join('')) alert(_("Some operations are only supported by admin versions > %s. Please update your admin-adapter!", warnIfLE));
      		if(iobrokerObjectsReady) {
      			toDo();
      		} else {
      			iobrokerObjectsReadyFunctions.push(toDo);
      } else {
      	alert(_("Error: No web-adapter found!"));
    Hi, leider nur fast :)
    Ich benötige das, was im Fenster "Console" steht. Im "optimalfall" sollte da ein Fehler stehen mit einer Zeilennummer, z.B.
    index_m.js:12345 ERROR: irgendwas stimmt nicht
    Das bräuchte ich.
    kassmann
    #5277
    @s-bormann
    neuer Versuch 👽
    index_m.js:2128
    Jetzt besser?
    • P Offline
      Peter213
      #5278
      ich wollte gerade ein Grafana Dashboard als Link hinterlegen. In der Kachel kommt dann immer "hat eine Verbindung verweigert".
      Hat einer eine Idee was ich prüfen kann?
      Von allen anderen Geräten ist das Dashboard über den Link erreichbar.
      • P Peter213
        da_WoodyD Online
        da_WoodyD Online
        #5279
        @peter213 ich seh in den links was von proxmox. was versuchst du da?
        ein grafana link als widget und background URL sieht so aus.
        http://192.168.0.252:3000/d-solo/z8EAZn_Gk/heating?orgId=1&refresh=1m&theme=light&panelId=2
        z.b. temperatur und luftfeuchte:
        P 1 Antwort Letzte Antwort
        • da_WoodyD da_Woody
          Peter213
          #5280
          @da_woody mein Dashboard heißt Proxmox ;-)
          ich nutze diesen Link
          http://192.168.15.24:3000/d/kxQQuHRZk/proxmox?orgId=1&refresh=10s&kiosk=tv
          • P Peter213
            da_WoodyD Online
            da_WoodyD Online
            #5281
            @peter213 ah, ok! mehr war ja nicht zu sehn, drum die frage... ;)
            du hast als gerät externer link und bei url was eingetragen. background URL ist ja ok. versuchs mal als widget und ohne den URL eintrag.
            wenn das nicht geht, stimmt mit den berechtigungen etwas nicht. dazu hat @Dutchman ein gutes video auf YT.
              Peter213
              #5282
              @da_woody Ich habe es rausgefunden. Es gibt in Grafana einen Config Punkt das Embedding als iframe usw nicht erlaubt ist. Nachdem ich "allow_embedding=true" gesetzt habe gehts es.
              • P Peter213
                da_WoodyD Online
                da_WoodyD Online
                #5283
                @peter213 👍 genau das meinte ich mit berechtigungen. konnt mich aber nicht genau erinnern, was es in der config war.
                  Kueppert
                  #5284
                  Hallo zusammen, habe seit heute das folgende Problem, wenn ich iQontrol administrieren möchte:
                  Nen Upload, um das Problem zu beheben, hab ich schon versucht...Instanz neu gestartet auch...nix...
                  • K Kueppert
                    da_WoodyD Online
                    da_WoodyD Online
                    #5285
                    @kueppert hast admin höher als 5.0.15 installiert...
                    https://github.com/sbormann/ioBroker.iqontrol/issues/185
                    https://github.com/ioBroker/ioBroker.admin/issues/848
                    • K kassmann
                      @s-bormann
                      neuer Versuch 👽
                      index_m.js:2128
                      Jetzt besser?
                      s.bormannS Offline
                      s.bormannS Offline
                      s.bormann
                      #5286
                      @s-bormann
                      neuer Versuch 👽
                      index_m.js:2128
                      Jetzt besser?
                      Ging das ganze früher denn mal? Aktuell wird ja viel im Admin geschraubt und verändert, liegt es vielleicht daran?
                        s.bormannS Offline
                        s.bormannS Offline
                        s.bormann
                        #5287
                        @da_woody sagte in Test Adapter iQontrol 1.8.x Vis:
                        Laut Bluefox wird es mit der nächsten Admin-Version 5.0.21 wieder gehen.
                        F 1 Antwort Letzte Antwort
                          funboxbolzer
                          schrieb am zuletzt editiert von funboxbolzer
                          #5288
                          Edit:
                          habe es denke ich geschafft. Habe die Stream URL in Background URL eingefügt. Jetzt die nächste Frage.
                          Wie bekomme ich das Widget von der Größe angepasst, das meine komplettes Bild angezeigt wird.
                          Ich habe quasi scroll Balken nach Oben und zur Seite.
                          ich würde gerne einen webcam stream von meinem 3D Drucker integrieren.
                          Läuft über eine Stream URL. Wie kann ich das umsetzten?
                          Danke schon mal.
                          Gruß Klaus
                          da_WoodyD s.bormannS 2 Antworten Letzte Antwort
                          • F funboxbolzer
                            Edit:
                            Danke schon mal.
                            Gruß Klaus
                            da_WoodyD Online
                            da_WoodyD Online
                            #5289
                            @funboxbolzer ich habs als background html drinnen.
                            <html style="height: 100%;"><head><meta name="Ender" content="width=device-width, minimum-scale=0.1"></head><body style="margin: 0px; background: #424242; height: 100%"><img style="-webkit-user-select: none;max-width: 100%;margin: auto;" src="http://192.168.2.59/webcam/?action=stream"></body></html>
                            3ce8a175-7588-4fbd-86ff-cff8105705a5-grafik.png 313ee568-0dfd-4e1f-90ae-fb54c7dffa38-grafik.png
                              funboxbolzer
                              #5290
                              @da_woody
                              Besten dank. Dann werde ich das mal so testen.
                              Hast du repetear oder octoprint?
                              Ich nutze repetear. Wie verhält sich das mit dem stream, wenn du die visualisierung geschlossen hast? Dann ist der stream aus oder?
                              • F funboxbolzer
                                @da_woody
                                da_WoodyD Online
                                da_WoodyD Online
                                #5291
                                @funboxbolzer ich tu mit octoprint. der stream läuft im octoprint natürlich weiter. warum sollte der aufhören? solang der raspi strom hat, wird auch gestreamt. steuern tu ich sowieso über octoprint, in iQontrol ist nur für die übersicht.
                                  @s-bormann
                                  neuer Versuch 👽
                                  index_m.js:2128
                                  Jetzt besser?
                                  kassmann
                                  #5292
                                  @s-bormann
                                  Es ging immer und seit gestern, zumindest ist mir da aufgefallen, geht es auch wieder. 😊
                                    funboxbolzer
                                    #5293
                                    @da_woody Danke für die Info.
                                    Bedienen wollte ich auch nicht, ich hatte evtl. Bedenken, dass der Dauerstream den Raspberry mit der Zeit überfordern könnte.
                                    @s-bormann Ist eicht ein Tolles VIS. Danke dafür!!
                                    Gruß Klaus
                                    • F funboxbolzer
                                      Gruß Klaus
                                      da_WoodyD Online
                                      da_WoodyD Online
                                      #5294
                                      @funboxbolzer nun ja, der stream kommt ja vom raspi mit octoprint. der wird in der vis ja nur aufgerufen. sollte somit ioBroker nicht überlasten. oder seh ich da was falsch? kratz.gif
                                      • K kassmann
                                        @s-bormann
                                        s.bormannS Offline
                                        s.bormannS Offline
                                        s.bormann
                                        #5295
                                        @s-bormann
                                        Perfekt, war vielleicht im Rahmen der vielen Updates von ioBroker mal zwischendrin zerschossen.
                                        E 1 Antwort Letzte Antwort
                                        • F funboxbolzer
                                          Edit:
                                          Danke schon mal.
                                          Gruß Klaus
                                          s.bormannS Offline
                                          s.bormannS Offline
                                          s.bormann
                                          #5296
                                          @funboxbolzer sagte in Test Adapter iQontrol 1.8.x Vis:
                                          Edit:
                                          Danke schon mal.
                                          Gruß Klaus
                                          Schau mal in den Optionen, da gibt es einige Anpassungsmöglichkeiten:
