  4. js-controller 3.3 jetzt im Beta
791 Beiträge 75 Kommentatoren 318.9k Aufrufe 56 Beobachtet
  • D doerk32
    @ilovegym
    hier ist der inhalt der log Datei
    pi@iobroker:~ $ cat /home/iobroker/.npm/_logs/2021-05-07T06_29_23_039Z-debug.log
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/local/bin/node',
    1 verbose cli   '/usr/local/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.js-controller@3.3.8',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--unsafe-perm',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.12
    3 info using node@v14.16.1
    4 verbose npm-session 4a7a39f3ae2b2553
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 569ms (from cache)
    8 silly pacote version manifest for iobroker.js-controller@3.3.8 fetched in 692ms
    9 timing stage:loadCurrentTree Completed in 14929ms
    10 silly install loadIdealTree
    11 silly install cloneCurrentTreeToIdealTree
    12 timing stage:loadIdealTree:cloneCurrentTree Completed in 132ms
    13 silly install loadShrinkwrap
    14 timing stage:loadIdealTree:loadShrinkwrap Completed in 3228ms
    15 silly install loadAllDepsIntoIdealTree
    16 silly resolveWithNewModule iobroker.js-controller@3.3.8 checking installable status
    17 silly removeObsoleteDep removing iobroker.js-controller@3.2.16 from the tree as its been replaced by a newer version or is no longer required
    18 silly removeObsoleteDep removing @iobroker/db-objects-file@1.1.4 from the tree as its been replaced by a newer version or is no longer required
    19 silly removeObsoleteDep removing @iobroker/db-base@1.1.4 from the tree as its been replaced by a newer version or is no longer required
    20 silly removeObsoleteDep removing deep-clone@3.0.3 from the tree as its been replaced by a newer version or is no longer required
    21 silly removeObsoleteDep removing fs-extra@9.1.0 from the tree as its been replaced by a newer version or is no longer required
    22 silly removeObsoleteDep removing jsonfile@6.1.0 from the tree as its been replaced by a newer version or is no longer required
    23 silly removeObsoleteDep removing universalify@2.0.0 from the tree as its been replaced by a newer version or is no longer required
    24 silly removeObsoleteDep removing node.extend@2.0.2 from the tree as its been replaced by a newer version or is no longer required
    25 silly removeObsoleteDep removing is@3.3.0 from the tree as its been replaced by a newer version or is no longer required
    26 silly removeObsoleteDep removing respjs@4.2.0 from the tree as its been replaced by a newer version or is no longer required
    27 silly removeObsoleteDep removing @iobroker/db-objects-redis@1.1.4 from the tree as its been replaced by a newer version or is no longer required
    28 silly removeObsoleteDep removing ioredis@4.27.2 from the tree as its been replaced by a newer version or is no longer required
    29 silly removeObsoleteDep removing cluster-key-slot@1.1.0 from the tree as its been replaced by a newer version or is no longer required
    30 silly removeObsoleteDep removing debug@4.3.1 from the tree as its been replaced by a newer version or is no longer required
    31 silly removeObsoleteDep removing ms@2.1.2 from the tree as its been replaced by a newer version or is no longer required
    32 silly removeObsoleteDep removing denque@1.5.0 from the tree as its been replaced by a newer version or is no longer required
    33 silly removeObsoleteDep removing lodash.defaults@4.2.0 from the tree as its been replaced by a newer version or is no longer required
    34 silly removeObsoleteDep removing lodash.flatten@4.4.0 from the tree as its been replaced by a newer version or is no longer required
    35 silly removeObsoleteDep removing p-map@2.1.0 from the tree as its been replaced by a newer version or is no longer required
    36 silly removeObsoleteDep removing redis-commands@1.7.0 from the tree as its been replaced by a newer version or is no longer required
    37 silly removeObsoleteDep removing redis-errors@1.2.0 from the tree as its been replaced by a newer version or is no longer required
    38 silly removeObsoleteDep removing redis-parser@3.0.0 from the tree as its been replaced by a newer version or is no longer required
    39 silly removeObsoleteDep removing standard-as-callback@2.1.0 from the tree as its been replaced by a newer version or is no longer required
    40 silly removeObsoleteDep removing fs-extra@9.1.0 from the tree as its been replaced by a newer version or is no longer required
    41 silly removeObsoleteDep removing jsonfile@6.1.0 from the tree as its been replaced by a newer version or is no longer required
    42 silly removeObsoleteDep removing universalify@2.0.0 from the tree as its been replaced by a newer version or is no longer required
    43 silly removeObsoleteDep removing @iobroker/db-states-file@1.1.4 from the tree as its been replaced by a newer version or is no longer required
    44 silly removeObsoleteDep removing @iobroker/db-states-redis@1.1.4 from the tree as its been replaced by a newer version or is no longer required
    45 silly removeObsoleteDep removing @iobroker/plugin-base@1.2.1 from the tree as its been replaced by a newer version or is no longer required
    46 silly removeObsoleteDep removing @iobroker/plugin-sentry@1.1.10 from the tree as its been replaced by a newer version or is no longer required
    47 silly removeObsoleteDep removing @sentry/integrations@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    48 silly removeObsoleteDep removing @sentry/types@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    49 silly removeObsoleteDep removing @sentry/utils@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    50 silly removeObsoleteDep removing tslib@1.14.1 from the tree as its been replaced by a newer version or is no longer required
    51 silly removeObsoleteDep removing localforage@1.9.0 from the tree as its been replaced by a newer version or is no longer required
    52 silly removeObsoleteDep removing lie@3.1.1 from the tree as its been replaced by a newer version or is no longer required
    53 silly removeObsoleteDep removing immediate@3.0.6 from the tree as its been replaced by a newer version or is no longer required
    54 silly removeObsoleteDep removing @sentry/node@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    55 silly removeObsoleteDep removing @sentry/core@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    56 silly removeObsoleteDep removing @sentry/hub@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    57 silly removeObsoleteDep removing @sentry/minimal@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    58 silly removeObsoleteDep removing @sentry/tracing@6.3.5 from the tree as its been replaced by a newer version or is no longer required
    59 silly removeObsoleteDep removing cookie@0.4.1 from the tree as its been replaced by a newer version or is no longer required
    60 silly removeObsoleteDep removing https-proxy-agent@5.0.0 from the tree as its been replaced by a newer version or is no longer required
    61 silly removeObsoleteDep removing debug@4.3.1 from the tree as its been replaced by a newer version or is no longer required
    62 silly removeObsoleteDep removing ms@2.1.2 from the tree as its been replaced by a newer version or is no longer required
    63 silly removeObsoleteDep removing lru_map@0.3.3 from the tree as its been replaced by a newer version or is no longer required
    64 silly removeObsoleteDep removing source-map-support@0.5.19 from the tree as its been replaced by a newer version or is no longer required
    65 silly removeObsoleteDep removing buffer-from@1.1.1 from the tree as its been replaced by a newer version or is no longer required
    66 silly removeObsoleteDep removing source-map@0.6.1 from the tree as its been replaced by a newer version or is no longer required
    67 silly removeObsoleteDep removing chokidar@3.5.1 from the tree as its been replaced by a newer version or is no longer required
    68 silly removeObsoleteDep removing anymatch@3.1.2 from the tree as its been replaced by a newer version or is no longer required
    69 silly removeObsoleteDep removing normalize-path@3.0.0 from the tree as its been replaced by a newer version or is no longer required
    70 silly removeObsoleteDep removing picomatch@2.2.3 from the tree as its been replaced by a newer version or is no longer required
    71 silly removeObsoleteDep removing braces@3.0.2 from the tree as its been replaced by a newer version or is no longer required
    72 silly removeObsoleteDep removing fill-range@7.0.1 from the tree as its been replaced by a newer version or is no longer required
    73 silly removeObsoleteDep removing to-regex-range@5.0.1 from the tree as its been replaced by a newer version or is no longer required
    74 silly removeObsoleteDep removing is-number@7.0.0 from the tree as its been replaced by a newer version or is no longer required
    75 silly removeObsoleteDep removing glob-parent@5.1.2 from the tree as its been replaced by a newer version or is no longer required
    76 silly removeObsoleteDep removing is-glob@4.0.1 from the tree as its been replaced by a newer version or is no longer required
    77 silly removeObsoleteDep removing is-extglob@2.1.1 from the tree as its been replaced by a newer version or is no longer required
    78 silly removeObsoleteDep removing is-binary-path@2.1.0 from the tree as its been replaced by a newer version or is no longer required
    79 silly removeObsoleteDep removing binary-extensions@2.2.0 from the tree as its been replaced by a newer version or is no longer required
    80 silly removeObsoleteDep removing readdirp@3.5.0 from the tree as its been replaced by a newer version or is no longer required
    81 silly removeObsoleteDep removing daemonize2@0.4.2 from the tree as its been replaced by a newer version or is no longer required
    82 silly removeObsoleteDep removing debug@4.3.1 from the tree as its been replaced by a newer version or is no longer required
    83 silly removeObsoleteDep removing ms@2.1.2 from the tree as its been replaced by a newer version or is no longer required
    84 silly removeObsoleteDep removing decache@4.6.0 from the tree as its been replaced by a newer version or is no longer required
    85 silly removeObsoleteDep removing callsite@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    86 silly removeObsoleteDep removing diskusage@1.1.3 from the tree as its been replaced by a newer version or is no longer required
    87 silly removeObsoleteDep removing es6-promise@4.2.8 from the tree as its been replaced by a newer version or is no longer required
    88 silly removeObsoleteDep removing event-stream@4.0.1 from the tree as its been replaced by a newer version or is no longer required
    89 silly removeObsoleteDep removing duplexer@0.1.2 from the tree as its been replaced by a newer version or is no longer required
    90 silly removeObsoleteDep removing from@0.1.7 from the tree as its been replaced by a newer version or is no longer required
    91 silly removeObsoleteDep removing map-stream@0.0.7 from the tree as its been replaced by a newer version or is no longer required
    92 silly removeObsoleteDep removing pause-stream@0.0.11 from the tree as its been replaced by a newer version or is no longer required
    93 silly removeObsoleteDep removing through@2.3.8 from the tree as its been replaced by a newer version or is no longer required
    94 silly removeObsoleteDep removing split@1.0.1 from the tree as its been replaced by a newer version or is no longer required
    95 silly removeObsoleteDep removing stream-combiner@0.2.2 from the tree as its been replaced by a newer version or is no longer required
    96 silly removeObsoleteDep removing fs-extra@9.1.0 from the tree as its been replaced by a newer version or is no longer required
    97 silly removeObsoleteDep removing jsonfile@6.1.0 from the tree as its been replaced by a newer version or is no longer required
    98 silly removeObsoleteDep removing universalify@2.0.0 from the tree as its been replaced by a newer version or is no longer required
    99 silly removeObsoleteDep removing greenlock@4.0.4 from the tree as its been replaced by a newer version or is no longer required
    100 silly removeObsoleteDep removing @greenlock/manager@3.1.0 from the tree as its been replaced by a newer version or is no longer required
    101 silly removeObsoleteDep removing greenlock-manager-fs@3.1.1 from the tree as its been replaced by a newer version or is no longer required
    102 silly removeObsoleteDep removing @root/mkdirp@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    103 silly removeObsoleteDep removing safe-replace@1.1.0 from the tree as its been replaced by a newer version or is no longer required
    104 silly removeObsoleteDep removing @root/acme@3.1.0 from the tree as its been replaced by a newer version or is no longer required
    105 silly removeObsoleteDep removing @root/csr@0.8.1 from the tree as its been replaced by a newer version or is no longer required
    106 silly removeObsoleteDep removing @root/asn1@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    107 silly removeObsoleteDep removing @root/encoding@1.0.1 from the tree as its been replaced by a newer version or is no longer required
    108 silly removeObsoleteDep removing @root/pem@1.0.4 from the tree as its been replaced by a newer version or is no longer required
    109 silly removeObsoleteDep removing @root/x509@0.7.2 from the tree as its been replaced by a newer version or is no longer required
    110 silly removeObsoleteDep removing @root/keypairs@0.10.1 from the tree as its been replaced by a newer version or is no longer required
    111 silly removeObsoleteDep removing @root/request@1.7.0 from the tree as its been replaced by a newer version or is no longer required
    112 silly removeObsoleteDep removing @root/greenlock@4.0.5 from the tree as its been replaced by a newer version or is no longer required
    113 silly removeObsoleteDep removing @root/keypairs@0.10.1 from the tree as its been replaced by a newer version or is no longer required
    114 silly removeObsoleteDep removing acme-http-01-standalone@3.0.5 from the tree as its been replaced by a newer version or is no longer required
    115 silly removeObsoleteDep removing cert-info@1.5.1 from the tree as its been replaced by a newer version or is no longer required
    116 silly removeObsoleteDep removing greenlock-store-fs@3.2.2 from the tree as its been replaced by a newer version or is no longer required
    117 silly removeObsoleteDep removing @root/keypairs@0.9.0 from the tree as its been replaced by a newer version or is no longer required
    118 silly removeObsoleteDep removing greenlock-express@4.0.3 from the tree as its been replaced by a newer version or is no longer required
    119 silly removeObsoleteDep removing @root/greenlock-express@4.0.4 from the tree as its been replaced by a newer version or is no longer required
    120 silly removeObsoleteDep removing redirect-https@1.3.1 from the tree as its been replaced by a newer version or is no longer required
    121 silly removeObsoleteDep removing jsonwebtoken@8.5.1 from the tree as its been replaced by a newer version or is no longer required
    122 silly removeObsoleteDep removing jws@3.2.2 from the tree as its been replaced by a newer version or is no longer required
    123 silly removeObsoleteDep removing jwa@1.4.1 from the tree as its been replaced by a newer version or is no longer required
    124 silly removeObsoleteDep removing lodash.includes@4.3.0 from the tree as its been replaced by a newer version or is no longer required
    125 silly removeObsoleteDep removing lodash.isboolean@3.0.3 from the tree as its been replaced by a newer version or is no longer required
    126 silly removeObsoleteDep removing lodash.isinteger@4.0.4 from the tree as its been replaced by a newer version or is no longer required
    127 silly removeObsoleteDep removing lodash.isnumber@3.0.3 from the tree as its been replaced by a newer version or is no longer required
    128 silly removeObsoleteDep removing lodash.isplainobject@4.0.6 from the tree as its been replaced by a newer version or is no longer required
    129 silly removeObsoleteDep removing lodash.isstring@4.0.1 from the tree as its been replaced by a newer version or is no longer required
    130 silly removeObsoleteDep removing lodash.once@4.1.1 from the tree as its been replaced by a newer version or is no longer required
    131 silly removeObsoleteDep removing ms@2.1.3 from the tree as its been replaced by a newer version or is no longer required
    132 silly removeObsoleteDep removing semver@5.7.1 from the tree as its been replaced by a newer version or is no longer required
    133 silly removeObsoleteDep removing jszip@3.6.0 from the tree as its been replaced by a newer version or is no longer required
    134 silly removeObsoleteDep removing lie@3.3.0 from the tree as its been replaced by a newer version or is no longer required
    135 silly removeObsoleteDep removing pako@1.0.11 from the tree as its been replaced by a newer version or is no longer required
    136 silly removeObsoleteDep removing readable-stream@2.3.7 from the tree as its been replaced by a newer version or is no longer required
    137 silly removeObsoleteDep removing isarray@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    138 silly removeObsoleteDep removing string_decoder@1.1.1 from the tree as its been replaced by a newer version or is no longer required
    139 silly removeObsoleteDep removing set-immediate-shim@1.0.1 from the tree as its been replaced by a newer version or is no longer required
    140 silly removeObsoleteDep removing le-acme-core@2.1.4 from the tree as its been replaced by a newer version or is no longer required
    141 silly removeObsoleteDep removing rsa-compat@1.9.4 from the tree as its been replaced by a newer version or is no longer required
    142 silly removeObsoleteDep removing keypairs@1.2.14 from the tree as its been replaced by a newer version or is no longer required
    143 silly removeObsoleteDep removing eckles@1.4.1 from the tree as its been replaced by a newer version or is no longer required
    144 silly removeObsoleteDep removing rasha@1.2.5 from the tree as its been replaced by a newer version or is no longer required
    145 silly removeObsoleteDep removing node-forge@0.7.6 from the tree as its been replaced by a newer version or is no longer required
    146 silly removeObsoleteDep removing ursa-optional@0.9.10 from the tree as its been replaced by a newer version or is no longer required
    147 silly removeObsoleteDep removing le-challenge-fs@2.0.9 from the tree as its been replaced by a newer version or is no longer required
    148 silly removeObsoleteDep removing le-sni-auto@2.1.9 from the tree as its been replaced by a newer version or is no longer required
    149 silly removeObsoleteDep removing loadavg-windows@1.1.1 from the tree as its been replaced by a newer version or is no longer required
    150 silly removeObsoleteDep removing weak-daemon@1.0.3 from the tree as its been replaced by a newer version or is no longer required
    151 silly removeObsoleteDep removing mime@2.5.2 from the tree as its been replaced by a newer version or is no longer required
    152 silly removeObsoleteDep removing ncp@2.0.0 from the tree as its been replaced by a newer version or is no longer required
    153 silly removeObsoleteDep removing node-schedule@1.3.3 from the tree as its been replaced by a newer version or is no longer required
    154 silly removeObsoleteDep removing cron-parser@2.18.0 from the tree as its been replaced by a newer version or is no longer required
    155 silly removeObsoleteDep removing moment-timezone@0.5.33 from the tree as its been replaced by a newer version or is no longer required
    156 silly removeObsoleteDep removing moment@2.29.1 from the tree as its been replaced by a newer version or is no longer required
    157 silly removeObsoleteDep removing pidusage@2.0.21 from the tree as its been replaced by a newer version or is no longer required
    158 silly removeObsoleteDep removing safe-buffer@5.2.1 from the tree as its been replaced by a newer version or is no longer required
    159 silly removeObsoleteDep removing promisify-child-process@4.1.1 from the tree as its been replaced by a newer version or is no longer required
    160 silly removeObsoleteDep removing prompt@1.1.0 from the tree as its been replaced by a newer version or is no longer required
    161 silly removeObsoleteDep removing colors@1.4.0 from the tree as its been replaced by a newer version or is no longer required
    162 silly removeObsoleteDep removing read@1.0.7 from the tree as its been replaced by a newer version or is no longer required
    163 silly removeObsoleteDep removing mute-stream@0.0.8 from the tree as its been replaced by a newer version or is no longer required
    164 silly removeObsoleteDep removing revalidator@0.1.8 from the tree as its been replaced by a newer version or is no longer required
    165 silly removeObsoleteDep removing utile@0.3.0 from the tree as its been replaced by a newer version or is no longer required
    166 silly removeObsoleteDep removing async@0.9.2 from the tree as its been replaced by a newer version or is no longer required
    167 silly removeObsoleteDep removing deep-equal@0.2.2 from the tree as its been replaced by a newer version or is no longer required
    168 silly removeObsoleteDep removing i@0.3.6 from the tree as its been replaced by a newer version or is no longer required
    169 silly removeObsoleteDep removing mkdirp@0.5.5 from the tree as its been replaced by a newer version or is no longer required
    170 silly removeObsoleteDep removing ncp@1.0.1 from the tree as its been replaced by a newer version or is no longer required
    171 silly removeObsoleteDep removing rimraf@2.7.1 from the tree as its been replaced by a newer version or is no longer required
    172 silly removeObsoleteDep removing glob@7.1.6 from the tree as its been replaced by a newer version or is no longer required
    173 silly removeObsoleteDep removing fs.realpath@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    174 silly removeObsoleteDep removing inflight@1.0.6 from the tree as its been replaced by a newer version or is no longer required
    175 silly removeObsoleteDep removing path-is-absolute@1.0.1 from the tree as its been replaced by a newer version or is no longer required
    176 silly removeObsoleteDep removing winston@2.4.5 from the tree as its been replaced by a newer version or is no longer required
    177 silly removeObsoleteDep removing async@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    178 silly removeObsoleteDep removing colors@1.0.3 from the tree as its been replaced by a newer version or is no longer required
    179 silly removeObsoleteDep removing cycle@1.0.3 from the tree as its been replaced by a newer version or is no longer required
    180 silly removeObsoleteDep removing eyes@0.1.8 from the tree as its been replaced by a newer version or is no longer required
    181 silly removeObsoleteDep removing stack-trace@0.0.10 from the tree as its been replaced by a newer version or is no longer required
    182 silly removeObsoleteDep removing readline-sync@1.4.10 from the tree as its been replaced by a newer version or is no longer required
    183 silly removeObsoleteDep removing tar@6.1.0 from the tree as its been replaced by a newer version or is no longer required
    184 silly removeObsoleteDep removing chownr@2.0.0 from the tree as its been replaced by a newer version or is no longer required
    185 silly removeObsoleteDep removing fs-minipass@2.1.0 from the tree as its been replaced by a newer version or is no longer required
    186 silly removeObsoleteDep removing minipass@3.1.3 from the tree as its been replaced by a newer version or is no longer required
    187 silly removeObsoleteDep removing minizlib@2.1.2 from the tree as its been replaced by a newer version or is no longer required
    188 silly removeObsoleteDep removing mkdirp@1.0.4 from the tree as its been replaced by a newer version or is no longer required
    189 silly removeObsoleteDep removing winston@3.3.3 from the tree as its been replaced by a newer version or is no longer required
    190 silly removeObsoleteDep removing @dabh/diagnostics@2.0.2 from the tree as its been replaced by a newer version or is no longer required
    191 silly removeObsoleteDep removing colorspace@1.1.2 from the tree as its been replaced by a newer version or is no longer required
    192 silly removeObsoleteDep removing color@3.0.0 from the tree as its been replaced by a newer version or is no longer required
    193 silly removeObsoleteDep removing color-convert@1.9.3 from the tree as its been replaced by a newer version or is no longer required
    194 silly removeObsoleteDep removing color-name@1.1.3 from the tree as its been replaced by a newer version or is no longer required
    195 silly removeObsoleteDep removing color-string@1.5.5 from the tree as its been replaced by a newer version or is no longer required
    196 silly removeObsoleteDep removing simple-swizzle@0.2.2 from the tree as its been replaced by a newer version or is no longer required
    197 silly removeObsoleteDep removing is-arrayish@0.3.2 from the tree as its been replaced by a newer version or is no longer required
    198 silly removeObsoleteDep removing text-hex@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    199 silly removeObsoleteDep removing enabled@2.0.0 from the tree as its been replaced by a newer version or is no longer required
    200 silly removeObsoleteDep removing kuler@2.0.0 from the tree as its been replaced by a newer version or is no longer required
    201 silly removeObsoleteDep removing async@3.2.0 from the tree as its been replaced by a newer version or is no longer required
    202 silly removeObsoleteDep removing logform@2.2.0 from the tree as its been replaced by a newer version or is no longer required
    203 silly removeObsoleteDep removing fast-safe-stringify@2.0.7 from the tree as its been replaced by a newer version or is no longer required
    204 silly removeObsoleteDep removing fecha@4.2.1 from the tree as its been replaced by a newer version or is no longer required
    205 silly removeObsoleteDep removing ms@2.1.3 from the tree as its been replaced by a newer version or is no longer required
    206 silly removeObsoleteDep removing triple-beam@1.3.0 from the tree as its been replaced by a newer version or is no longer required
    207 silly removeObsoleteDep removing one-time@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    208 silly removeObsoleteDep removing fn.name@1.1.0 from the tree as its been replaced by a newer version or is no longer required
    209 silly removeObsoleteDep removing readable-stream@3.6.0 from the tree as its been replaced by a newer version or is no longer required
    210 silly removeObsoleteDep removing string_decoder@1.3.0 from the tree as its been replaced by a newer version or is no longer required
    211 silly removeObsoleteDep removing safe-buffer@5.2.1 from the tree as its been replaced by a newer version or is no longer required
    212 silly removeObsoleteDep removing winston-transport@4.4.0 from the tree as its been replaced by a newer version or is no longer required
    213 silly removeObsoleteDep removing readable-stream@2.3.7 from the tree as its been replaced by a newer version or is no longer required
    214 silly removeObsoleteDep removing isarray@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    215 silly removeObsoleteDep removing string_decoder@1.1.1 from the tree as its been replaced by a newer version or is no longer required
    216 silly removeObsoleteDep removing winston-daily-rotate-file@4.5.4 from the tree as its been replaced by a newer version or is no longer required
    217 silly removeObsoleteDep removing file-stream-rotator@0.5.7 from the tree as its been replaced by a newer version or is no longer required
    218 silly removeObsoleteDep removing object-hash@2.1.1 from the tree as its been replaced by a newer version or is no longer required
    219 silly removeObsoleteDep removing winston-transport@4.4.0 from the tree as its been replaced by a newer version or is no longer required
    220 silly removeObsoleteDep removing readable-stream@2.3.7 from the tree as its been replaced by a newer version or is no longer required
    221 silly removeObsoleteDep removing isarray@1.0.0 from the tree as its been replaced by a newer version or is no longer required
    222 silly removeObsoleteDep removing string_decoder@1.1.1 from the tree as its been replaced by a newer version or is no longer required
    223 silly removeObsoleteDep removing winston-seq-updated@1.0.4 from the tree as its been replaced by a newer version or is no longer required
    224 silly removeObsoleteDep removing seq-logging@0.4.6 from the tree as its been replaced by a newer version or is no longer required
    225 silly removeObsoleteDep removing winston-syslog@2.4.4 from the tree as its been replaced by a newer version or is no longer required
    226 silly removeObsoleteDep removing glossy@0.1.7 from the tree as its been replaced by a newer version or is no longer required
    227 silly removeObsoleteDep removing unix-dgram@2.0.3 from the tree as its been replaced by a newer version or is no longer required
    228 silly removeObsoleteDep removing yargs@16.2.0 from the tree as its been replaced by a newer version or is no longer required
    229 silly removeObsoleteDep removing cliui@7.0.4 from the tree as its been replaced by a newer version or is no longer required
    230 silly removeObsoleteDep removing string-width@4.2.2 from the tree as its been replaced by a newer version or is no longer required
    231 silly removeObsoleteDep removing emoji-regex@8.0.0 from the tree as its been replaced by a newer version or is no longer required
    232 silly removeObsoleteDep removing is-fullwidth-code-point@3.0.0 from the tree as its been replaced by a newer version or is no longer required
    233 silly removeObsoleteDep removing strip-ansi@6.0.0 from the tree as its been replaced by a newer version or is no longer required
    234 silly removeObsoleteDep removing ansi-regex@5.0.0 from the tree as its been replaced by a newer version or is no longer required
    235 silly removeObsoleteDep removing wrap-ansi@7.0.0 from the tree as its been replaced by a newer version or is no longer required
    236 silly removeObsoleteDep removing ansi-styles@4.3.0 from the tree as its been replaced by a newer version or is no longer required
    237 silly removeObsoleteDep removing color-convert@2.0.1 from the tree as its been replaced by a newer version or is no longer required
    238 silly removeObsoleteDep removing color-name@1.1.4 from the tree as its been replaced by a newer version or is no longer required
    239 silly removeObsoleteDep removing escalade@3.1.1 from the tree as its been replaced by a newer version or is no longer required
    240 silly removeObsoleteDep removing get-caller-file@2.0.5 from the tree as its been replaced by a newer version or is no longer required
    241 silly removeObsoleteDep removing require-directory@2.1.1 from the tree as its been replaced by a newer version or is no longer required
    242 silly removeObsoleteDep removing y18n@5.0.8 from the tree as its been replaced by a newer version or is no longer required
    243 silly removeObsoleteDep removing yargs-parser@20.2.7 from the tree as its been replaced by a newer version or is no longer required
    244 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fdb-objects-jsonl 915ms (from cache)
    245 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fdb-objects-redis 919ms (from cache)
    246 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fdb-objects-file 945ms (from cache)
    247 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fdb-states-jsonl 922ms (from cache)
    248 http fetch GET 304 https://registry.npmjs.org/chokidar 901ms (from cache)
    249 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fdb-states-redis 944ms (from cache)
    250 silly pacote range manifest for @iobroker/db-objects-jsonl@~1.2.3 fetched in 988ms
    251 silly resolveWithNewModule @iobroker/db-objects-jsonl@1.2.3 checking installable status
    252 http fetch GET 304 https://registry.npmjs.org/daemonize2 935ms (from cache)
    253 silly pacote range manifest for @iobroker/db-objects-redis@~1.2.3 fetched in 1000ms
    254 silly resolveWithNewModule @iobroker/db-objects-redis@1.2.3 checking installable status
    255 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fdb-states-file 1010ms (from cache)
    256 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fplugin-sentry 980ms (from cache)
    257 silly pacote range manifest for @iobroker/db-objects-file@~1.2.3 fetched in 1046ms
    258 silly resolveWithNewModule @iobroker/db-objects-file@1.2.3 checking installable status
    259 silly pacote range manifest for @iobroker/db-states-jsonl@~1.2.3 fetched in 1020ms
    260 silly resolveWithNewModule @iobroker/db-states-jsonl@1.2.3 checking installable status
    261 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fplugin-base 1018ms (from cache)
    262 silly pacote range manifest for chokidar@^3.5.1 fetched in 1009ms
    263 silly resolveWithNewModule chokidar@3.5.1 checking installable status
    264 silly pacote range manifest for @iobroker/db-states-redis@~1.2.3 fetched in 1045ms
    265 silly resolveWithNewModule @iobroker/db-states-redis@1.2.3 checking installable status
    266 silly pacote range manifest for daemonize2@^0.4.2 fetched in 1091ms
    267 silly resolveWithNewModule daemonize2@0.4.2 checking installable status
    268 silly pacote range manifest for @iobroker/db-states-file@~1.2.3 fetched in 1218ms
    269 silly resolveWithNewModule @iobroker/db-states-file@1.2.3 checking installable status
    270 silly pacote range manifest for @iobroker/plugin-sentry@~1.1.10 fetched in 1191ms
    271 silly resolveWithNewModule @iobroker/plugin-sentry@1.1.10 checking installable status
    272 silly pacote range manifest for @iobroker/plugin-base@~1.2.1 fetched in 1241ms
    273 silly resolveWithNewModule @iobroker/plugin-base@1.2.1 checking installable status
    274 http fetch GET 304 https://registry.npmjs.org/decache 754ms (from cache)
    275 http fetch GET 304 https://registry.npmjs.org/deep-clone 735ms (from cache)
    276 http fetch GET 304 https://registry.npmjs.org/debug 787ms (from cache)
    277 http fetch GET 304 https://registry.npmjs.org/esbuild-register 727ms (from cache)
    278 http fetch GET 304 https://registry.npmjs.org/event-stream 720ms (from cache)
    279 silly pacote range manifest for decache@^4.6.0 fetched in 798ms
    280 silly resolveWithNewModule decache@4.6.0 checking installable status
    281 http fetch GET 304 https://registry.npmjs.org/jszip 576ms (from cache)
    282 http fetch GET 304 https://registry.npmjs.org/jsonwebtoken 583ms (from cache)
    283 http fetch GET 304 https://registry.npmjs.org/fs-extra 674ms (from cache)
    284 silly pacote range manifest for debug@^4.3.1 fetched in 861ms
    285 silly resolveWithNewModule debug@4.3.1 checking installable status
    286 silly pacote range manifest for deep-clone@^3.0.3 fetched in 819ms
    287 silly resolveWithNewModule deep-clone@3.0.3 checking installable status
    288 silly pacote range manifest for esbuild-register@^2.5.0 fetched in 802ms
    289 silly resolveWithNewModule esbuild-register@2.5.0 checking installable status
    290 silly pacote range manifest for event-stream@^4.0.1 fetched in 811ms
    291 silly resolveWithNewModule event-stream@4.0.1 checking installable status
    292 http fetch GET 304 https://registry.npmjs.org/loadavg-windows 581ms (from cache)
    293 http fetch GET 304 https://registry.npmjs.org/esbuild 884ms (from cache)
    294 silly pacote range manifest for jszip@^3.6.0 fetched in 703ms
    295 silly resolveWithNewModule jszip@3.6.0 checking installable status
    296 silly pacote range manifest for jsonwebtoken@^8.5.1 fetched in 727ms
    297 silly resolveWithNewModule jsonwebtoken@8.5.1 checking installable status
    298 silly pacote range manifest for fs-extra@^9.1.0 fetched in 844ms
    299 silly resolveWithNewModule fs-extra@9.1.0 checking installable status
    300 silly pacote range manifest for loadavg-windows@^1.1.1 fetched in 733ms
    301 silly resolveWithNewModule loadavg-windows@1.1.1 checking installable status
    302 silly pacote range manifest for esbuild@^0.11.18 fetched in 1087ms
    303 silly resolveWithNewModule esbuild@0.11.19 checking installable status
    304 http fetch GET 304 https://registry.npmjs.org/mime 761ms (from cache)
    305 http fetch GET 304 https://registry.npmjs.org/ncp 727ms (from cache)
    306 http fetch GET 304 https://registry.npmjs.org/pidusage 725ms (from cache)
    307 http fetch GET 304 https://registry.npmjs.org/node.extend 739ms (from cache)
    308 http fetch GET 304 https://registry.npmjs.org/promisify-child-process 729ms (from cache)
    309 http fetch GET 304 https://registry.npmjs.org/prompt 689ms (from cache)
    310 silly pacote range manifest for mime@^2.5.2 fetched in 811ms
    311 silly resolveWithNewModule mime@2.5.2 checking installable status
    312 silly pacote range manifest for pidusage@^2.0.21 fetched in 783ms
    313 silly resolveWithNewModule pidusage@2.0.21 checking installable status
    314 http fetch GET 304 https://registry.npmjs.org/readline-sync 674ms (from cache)
    315 silly pacote range manifest for node.extend@^2.0.2 fetched in 802ms
    316 silly resolveWithNewModule node.extend@2.0.2 checking installable status
    317 silly pacote range manifest for ncp@^2.0.0 fetched in 820ms
    318 silly resolveWithNewModule ncp@2.0.0 checking installable status
    319 silly pacote range manifest for promisify-child-process@^4.1.1 fetched in 807ms
    320 silly resolveWithNewModule promisify-child-process@4.1.1 checking installable status
    321 silly pacote range manifest for prompt@^1.1.0 fetched in 777ms
    322 silly resolveWithNewModule prompt@1.1.0 checking installable status
    323 http fetch GET 304 https://registry.npmjs.org/tar 731ms (from cache)
    324 http fetch GET 304 https://registry.npmjs.org/winston 669ms (from cache)
    325 silly pacote range manifest for readline-sync@^1.4.10 fetched in 774ms
    326 silly resolveWithNewModule readline-sync@1.4.10 checking installable status
    327 http fetch GET 304 https://registry.npmjs.org/winston-daily-rotate-file 600ms (from cache)
    328 silly pacote range manifest for tar@^6.1.0 fetched in 843ms
    329 silly resolveWithNewModule tar@6.1.0 checking installable status
    330 silly pacote range manifest for winston@^3.3.3 fetched in 782ms
    331 silly resolveWithNewModule winston@3.3.3 checking installable status
    332 silly pacote range manifest for winston-daily-rotate-file@^4.5.3 fetched in 697ms
    333 silly resolveWithNewModule winston-daily-rotate-file@4.5.4 checking installable status
    334 http fetch GET 304 https://registry.npmjs.org/diskusage 501ms (from cache)
    335 http fetch GET 304 https://registry.npmjs.org/le-acme-core 455ms (from cache)
    336 http fetch GET 304 https://registry.npmjs.org/le-challenge-fs 454ms (from cache)
    337 http fetch GET 304 https://registry.npmjs.org/greenlock-express 476ms (from cache)
    338 http fetch GET 304 https://registry.npmjs.org/yargs 544ms (from cache)
    339 http fetch GET 304 https://registry.npmjs.org/greenlock 552ms (from cache)
    340 http fetch GET 304 https://registry.npmjs.org/le-sni-auto 461ms (from cache)
    341 silly pacote range manifest for diskusage@^1.1.3 fetched in 595ms
    342 silly resolveWithNewModule diskusage@1.1.3 checking installable status
    343 silly pacote range manifest for le-acme-core@^2.1.4 fetched in 551ms
    344 silly resolveWithNewModule le-acme-core@2.1.4 checking installable status
    345 silly pacote range manifest for le-challenge-fs@^2.0.9 fetched in 543ms
    346 silly resolveWithNewModule le-challenge-fs@2.0.9 checking installable status
    347 silly pacote range manifest for greenlock-express@^4.0.3 fetched in 564ms
    348 silly resolveWithNewModule greenlock-express@4.0.3 checking installable status
    349 http fetch GET 304 https://registry.npmjs.org/winston-syslog 410ms (from cache)
    350 silly pacote range manifest for yargs@^16.2.0 fetched in 629ms
    351 silly resolveWithNewModule yargs@16.2.0 checking installable status
    352 http fetch GET 304 https://registry.npmjs.org/winston-seq-updated 422ms (from cache)
    353 silly pacote range manifest for greenlock@^4.0.4 fetched in 615ms
    354 silly resolveWithNewModule greenlock@4.0.4 checking installable status
    355 silly pacote range manifest for le-sni-auto@^2.1.9 fetched in 512ms
    356 silly resolveWithNewModule le-sni-auto@2.1.9 checking installable status
    357 silly pacote range manifest for winston-seq-updated@^1.0.4 fetched in 443ms
    358 silly resolveWithNewModule winston-seq-updated@1.0.4 checking installable status
    359 silly pacote range manifest for winston-syslog@^2.4.4 fetched in 445ms
    360 silly resolveWithNewModule winston-syslog@2.4.4 checking installable status
    361 silly pacote range manifest for fs-extra@^9.1.0 fetched in 17ms
    362 silly resolveWithNewModule fs-extra@9.1.0 checking installable status
    363 http fetch GET 304 https://registry.npmjs.org/@iobroker%2fdb-base 184ms (from cache)
    364 silly pacote version manifest for @iobroker/db-base@1.2.3 fetched in 194ms
    365 silly resolveWithNewModule @iobroker/db-base@1.2.3 checking installable status
    366 silly pacote range manifest for fs-extra@^9.1.0 fetched in 10ms
    367 silly resolveWithNewModule fs-extra@9.1.0 checking installable status
    368 http fetch GET 304 https://registry.npmjs.org/respjs 104ms (from cache)
    369 silly pacote range manifest for respjs@^4.2.0 fetched in 115ms
    370 silly resolveWithNewModule respjs@4.2.0 checking installable status
    371 http fetch GET 304 https://registry.npmjs.org/universalify 161ms (from cache)
    372 http fetch GET 304 https://registry.npmjs.org/jsonfile 170ms (from cache)
    373 silly pacote range manifest for universalify@^2.0.0 fetched in 176ms
    374 silly resolveWithNewModule universalify@2.0.0 checking installable status
    375 silly pacote range manifest for jsonfile@^6.0.1 fetched in 183ms
    376 silly resolveWithNewModule jsonfile@6.1.0 checking installable status
    377 http fetch GET 304 https://registry.npmjs.org/is 83ms (from cache)
    378 silly pacote range manifest for is@^3.2.1 fetched in 94ms
    379 silly resolveWithNewModule is@3.3.0 checking installable status
    380 http fetch GET 304 https://registry.npmjs.org/ioredis 131ms (from cache)
    381 silly pacote range manifest for ioredis@^4.27.1 fetched in 160ms
    382 silly resolveWithNewModule ioredis@4.27.2 checking installable status
    383 silly pacote range manifest for debug@^4.3.1 fetched in 69ms
    384 silly resolveWithNewModule debug@4.3.1 checking installable status
    385 http fetch GET 304 https://registry.npmjs.org/cluster-key-slot 395ms (from cache)
    386 http fetch GET 304 https://registry.npmjs.org/denque 399ms (from cache)
    387 http fetch GET 304 https://registry.npmjs.org/lodash.defaults 403ms (from cache)
    388 http fetch GET 304 https://registry.npmjs.org/lodash.flatten 404ms (from cache)
    389 http fetch GET 304 https://registry.npmjs.org/redis-commands 402ms (from cache)
    390 http fetch GET 304 https://registry.npmjs.org/redis-errors 408ms (from cache)
    391 http fetch GET 304 https://registry.npmjs.org/redis-parser 413ms (from cache)
    392 http fetch GET 304 https://registry.npmjs.org/standard-as-callback 414ms (from cache)
    393 silly pacote range manifest for cluster-key-slot@^1.1.0 fetched in 434ms
    394 silly resolveWithNewModule cluster-key-slot@1.1.0 checking installable status
    395 silly pacote range manifest for denque@^1.1.0 fetched in 440ms
    396 silly resolveWithNewModule denque@1.5.0 checking installable status
    397 silly pacote range manifest for lodash.defaults@^4.2.0 fetched in 444ms
    398 silly resolveWithNewModule lodash.defaults@4.2.0 checking installable status
    399 silly pacote version manifest for redis-commands@1.7.0 fetched in 441ms
    400 silly resolveWithNewModule redis-commands@1.7.0 checking installable status
    401 http fetch GET 304 https://registry.npmjs.org/p-map 447ms (from cache)
    402 silly pacote range manifest for lodash.flatten@^4.4.0 fetched in 452ms
    403 silly resolveWithNewModule lodash.flatten@4.4.0 checking installable status
    404 silly pacote range manifest for redis-errors@^1.2.0 fetched in 453ms
    405 silly resolveWithNewModule redis-errors@1.2.0 checking installable status
    406 silly pacote range manifest for redis-parser@^3.0.0 fetched in 462ms
    407 silly resolveWithNewModule redis-parser@3.0.0 checking installable status
    408 silly pacote range manifest for standard-as-callback@^2.1.0 fetched in 475ms
    409 silly resolveWithNewModule standard-as-callback@2.1.0 checking installable status
    410 silly pacote range manifest for p-map@^2.1.0 fetched in 492ms
    411 silly resolveWithNewModule p-map@2.1.0 checking installable status
    412 http fetch GET 304 https://registry.npmjs.org/ms 270ms (from cache)
    413 silly pacote version manifest for ms@2.1.2 fetched in 289ms
    414 silly resolveWithNewModule ms@2.1.2 checking installable status
    415 silly pacote range manifest for jsonfile@^6.0.1 fetched in 6ms
    416 silly resolveWithNewModule jsonfile@6.1.0 checking installable status
    417 silly pacote range manifest for universalify@^2.0.0 fetched in 9ms
    418 silly resolveWithNewModule universalify@2.0.0 checking installable status
    419 silly pacote range manifest for fs-extra@^9.1.0 fetched in 10ms
    420 silly resolveWithNewModule fs-extra@9.1.0 checking installable status
    421 http fetch GET 304 https://registry.npmjs.org/@alcalzone%2fjsonl-db 174ms (from cache)
    422 silly pacote range manifest for @alcalzone/jsonl-db@^1.2.4 fetched in 185ms
    423 silly resolveWithNewModule @alcalzone/jsonl-db@1.2.4 checking installable status
    424 silly pacote range manifest for fs-extra@^9.1.0 fetched in 15ms
    425 silly resolveWithNewModule fs-extra@9.1.0 checking installable status
    426 http fetch GET 304 https://registry.npmjs.org/alcalzone-shared 118ms (from cache)
    427 silly pacote range manifest for alcalzone-shared@^3.0.2 fetched in 133ms
    428 silly resolveWithNewModule alcalzone-shared@3.0.4 checking installable status
    429 silly pacote range manifest for debug@^4.3.1 fetched in 10ms
    430 silly resolveWithNewModule debug@4.3.1 checking installable status
    431 silly pacote version manifest for ms@2.1.2 fetched in 5ms
    432 silly resolveWithNewModule ms@2.1.2 checking installable status
    433 silly pacote range manifest for jsonfile@^6.0.1 fetched in 7ms
    434 silly resolveWithNewModule jsonfile@6.1.0 checking installable status
    435 silly pacote range manifest for universalify@^2.0.0 fetched in 10ms
    436 silly resolveWithNewModule universalify@2.0.0 checking installable status
    437 silly pacote range manifest for jsonfile@^6.0.1 fetched in 5ms
    438 silly resolveWithNewModule jsonfile@6.1.0 checking installable status
    439 silly pacote range manifest for universalify@^2.0.0 fetched in 8ms
    440 silly resolveWithNewModule universalify@2.0.0 checking installable status
    441 http fetch GET 304 https://registry.npmjs.org/@sentry%2fnode 216ms (from cache)
    442 silly pacote range manifest for @sentry/node@^6.1.0 fetched in 274ms
    443 silly resolveWithNewModule @sentry/node@6.3.5 checking installable status
    444 http fetch GET 304 https://registry.npmjs.org/source-map-support 292ms (from cache)
    445 silly pacote range manifest for source-map-support@^0.5.19 fetched in 309ms
    446 silly resolveWithNewModule source-map-support@0.5.19 checking installable status
    447 http fetch GET 304 https://registry.npmjs.org/@sentry%2fintegrations 323ms (from cache)
    448 silly pacote range manifest for @sentry/integrations@^6.1.0 fetched in 346ms
    449 silly resolveWithNewModule @sentry/integrations@6.3.5 checking installable status
    450 http fetch GET 200 https://registry.npmjs.org/tslib 245ms
    451 http fetch GET 304 https://registry.npmjs.org/localforage 265ms (from cache)
    452 silly pacote range manifest for tslib@^1.9.3 fetched in 274ms
    453 silly resolveWithNewModule tslib@1.14.1 checking installable status
    454 http fetch GET 304 https://registry.npmjs.org/@sentry%2futils 289ms (from cache)
    455 http fetch GET 304 https://registry.npmjs.org/@sentry%2ftypes 312ms (from cache)
    456 silly pacote range manifest for localforage@^1.8.1 fetched in 346ms
    457 silly resolveWithNewModule localforage@1.9.0 checking installable status
    458 silly pacote version manifest for @sentry/utils@6.3.5 fetched in 361ms
    459 silly resolveWithNewModule @sentry/utils@6.3.5 checking installable status
    460 silly pacote version manifest for @sentry/types@6.3.5 fetched in 370ms
    461 silly resolveWithNewModule @sentry/types@6.3.5 checking installable status
    462 http fetch GET 304 https://registry.npmjs.org/lie 124ms (from cache)
    463 silly pacote version manifest for lie@3.1.1 fetched in 151ms
    464 silly resolveWithNewModule lie@3.1.1 checking installable status
    465 http fetch GET 200 https://registry.npmjs.org/immediate 82ms
    466 silly pacote range manifest for immediate@~3.0.5 fetched in 93ms
    467 silly resolveWithNewModule immediate@3.0.6 checking installable status
    468 http fetch GET 304 https://registry.npmjs.org/lru_map 325ms (from cache)
    469 http fetch GET 304 https://registry.npmjs.org/cookie 345ms (from cache)
    470 silly pacote range manifest for lru_map@^0.3.3 fetched in 345ms
    471 silly resolveWithNewModule lru_map@0.3.3 checking installable status
    472 http fetch GET 304 https://registry.npmjs.org/https-proxy-agent 356ms (from cache)
    473 http fetch GET 304 https://registry.npmjs.org/@sentry%2fhub 374ms (from cache)
    474 silly fetchPackageMetaData error for @sentry/hub@6.3.5 Unexpected end of JSON input while parsing near '...,"@sentry/utils":"6.3'
    475 silly pacote range manifest for cookie@^0.4.1 fetched in 396ms
    476 silly resolveWithNewModule cookie@0.4.1 checking installable status
    477 http fetch GET 304 https://registry.npmjs.org/@sentry%2ftracing 403ms (from cache)
    478 silly pacote range manifest for https-proxy-agent@^5.0.0 fetched in 409ms
    479 silly resolveWithNewModule https-proxy-agent@5.0.0 checking installable status
    480 silly pacote version manifest for @sentry/tracing@6.3.5 fetched in 422ms
    481 silly resolveWithNewModule @sentry/tracing@6.3.5 checking installable status
    482 http fetch GET 304 https://registry.npmjs.org/@sentry%2fcore 885ms (from cache)
    483 silly pacote version manifest for @sentry/core@6.3.5 fetched in 907ms
    484 silly resolveWithNewModule @sentry/core@6.3.5 checking installable status
    485 timing stage:rollbackFailedOptional Completed in 2ms
    486 timing stage:runTopLevelLifecycles Completed in 26032ms
    487 silly saveTree iobroker.inst@3.0.0
    487 silly saveTree ├─┬ iobroker.admin@5.0.15
    487 silly saveTree │ ├─┬ @iobroker/adapter-core@2.4.0
    487 silly saveTree │ │ └─┬ @types/iobroker@3.2.9
    487 silly saveTree │ │   └── @types/node@15.0.2
    487 silly saveTree │ ├─┬ body-parser@1.19.0
    487 silly saveTree │ │ ├── bytes@3.1.0
    487 silly saveTree │ │ ├── content-type@1.0.4
    487 silly saveTree │ │ ├─┬ debug@2.6.9
    487 silly saveTree │ │ │ └── ms@2.0.0
    487 silly saveTree │ │ ├── depd@1.1.2
    487 silly saveTree │ │ ├─┬ http-errors@1.7.2
    487 silly saveTree │ │ │ ├── inherits@2.0.3
    487 silly saveTree │ │ │ ├── setprototypeof@1.1.1
    487 silly saveTree │ │ │ ├── statuses@1.5.0
    487 silly saveTree │ │ │ └── toidentifier@1.0.0
    487 silly saveTree │ │ ├─┬ iconv-lite@0.4.24
    487 silly saveTree │ │ │ └── safer-buffer@2.1.2
    487 silly saveTree │ │ ├─┬ on-finished@2.3.0
    487 silly saveTree │ │ │ └── ee-first@1.1.1
    487 silly saveTree │ │ ├── qs@6.7.0
    487 silly saveTree │ │ ├─┬ raw-body@2.4.0
    487 silly saveTree │ │ │ └── unpipe@1.0.0
    487 silly saveTree │ │ └─┬ type-is@1.6.18
    487 silly saveTree │ │   ├── media-typer@0.3.0
    487 silly saveTree │ │   └─┬ mime-types@2.1.30
    487 silly saveTree │ │     └── mime-db@1.47.0
    487 silly saveTree │ ├── connect-flash@0.1.1
    487 silly saveTree │ ├─┬ cookie-parser@1.4.5
    487 silly saveTree │ │ ├── cookie-signature@1.0.6
    487 silly saveTree │ │ └── cookie@0.4.0
    487 silly saveTree │ ├─┬ express-fileupload@1.2.1
    487 silly saveTree │ │ └─┬ busboy@0.3.1
    487 silly saveTree │ │   └─┬ dicer@0.3.0
    487 silly saveTree │ │     └── streamsearch@0.1.2
    487 silly saveTree │ ├─┬ express-session@1.17.1
    487 silly saveTree │ │ ├── depd@2.0.0
    487 silly saveTree │ │ ├── on-headers@1.0.2
    487 silly saveTree │ │ ├── parseurl@1.3.3
    487 silly saveTree │ │ ├── safe-buffer@5.2.0
    487 silly saveTree │ │ └─┬ uid-safe@2.1.5
    487 silly saveTree │ │   └── random-bytes@1.0.0
    487 silly saveTree │ ├─┬ express@4.17.1
    487 silly saveTree │ │ ├─┬ accepts@1.3.7
    487 silly saveTree │ │ │ └── negotiator@0.6.2
    487 silly saveTree │ │ ├── array-flatten@1.1.1
    487 silly saveTree │ │ ├─┬ content-disposition@0.5.3
    487 silly saveTree │ │ │ └── safe-buffer@5.1.2
    487 silly saveTree │ │ ├── encodeurl@1.0.2
    487 silly saveTree │ │ ├── escape-html@1.0.3
    487 silly saveTree │ │ ├── etag@1.8.1
    487 silly saveTree │ │ ├── finalhandler@1.1.2
    487 silly saveTree │ │ ├── fresh@0.5.2
    487 silly saveTree │ │ ├── merge-descriptors@1.0.1
    487 silly saveTree │ │ ├── methods@1.1.2
    487 silly saveTree │ │ ├── path-to-regexp@0.1.7
    487 silly saveTree │ │ ├─┬ proxy-addr@2.0.6
    487 silly saveTree │ │ │ ├── forwarded@0.1.2
    487 silly saveTree │ │ │ └── ipaddr.js@1.9.1
    487 silly saveTree │ │ ├── range-parser@1.2.1
    487 silly saveTree │ │ ├── safe-buffer@5.1.2
    487 silly saveTree │ │ ├─┬ send@0.17.1
    487 silly saveTree │ │ │ ├── destroy@1.0.4
    487 silly saveTree │ │ │ ├── mime@1.6.0
    487 silly saveTree │ │ │ └── ms@2.1.1
    487 silly saveTree │ │ ├── serve-static@1.14.1
    487 silly saveTree │ │ ├── utils-merge@1.0.1
    487 silly saveTree │ │ └── vary@1.1.2
    487 silly saveTree │ ├─┬ passport-local@1.0.0
    487 silly saveTree │ │ └── passport-strategy@1.0.0
    487 silly saveTree │ ├─┬ passport.socketio@3.7.0
    487 silly saveTree │ │ └── xtend@4.0.2
    487 silly saveTree │ ├─┬ passport@0.4.1
    487 silly saveTree │ │ └── pause@0.0.1
    487 silly saveTree │ ├─┬ request@2.88.2
    487 silly saveTree │ │ ├── aws-sign2@0.7.0
    487 silly saveTree │ │ ├── aws4@1.11.0
    487 silly saveTree │ │ ├── caseless@0.12.0
    487 silly saveTree │ │ ├─┬ combined-stream@1.0.8
    487 silly saveTree │ │ │ └── delayed-stream@1.0.0
    487 silly saveTree │ │ ├── extend@3.0.2
    487 silly saveTree │ │ ├── forever-agent@0.6.1
    487 silly saveTree │ │ ├─┬ form-data@2.3.3
    487 silly saveTree │ │ │ └── asynckit@0.4.0
    487 silly saveTree │ │ ├─┬ har-validator@5.1.5
    487 silly saveTree │ │ │ ├─┬ ajv@6.12.6
    487 silly saveTree │ │ │ │ ├── fast-deep-equal@3.1.3
    487 silly saveTree │ │ │ │ ├── fast-json-stable-stringify@2.1.0
    487 silly saveTree │ │ │ │ ├── json-schema-traverse@0.4.1
    487 silly saveTree │ │ │ │ └─┬ uri-js@4.4.1
    487 silly saveTree │ │ │ │   └── punycode@2.1.1
    487 silly saveTree │ │ │ └── har-schema@2.0.0
    487 silly saveTree │ │ ├─┬ http-signature@1.2.0
    487 silly saveTree │ │ │ ├── assert-plus@1.0.0
    487 silly saveTree │ │ │ ├─┬ jsprim@1.4.1
    487 silly saveTree │ │ │ │ ├── extsprintf@1.3.0
    487 silly saveTree │ │ │ │ ├── json-schema@0.2.3
    487 silly saveTree │ │ │ │ └─┬ verror@1.10.0
    487 silly saveTree │ │ │ │   └── core-util-is@1.0.2
    487 silly saveTree │ │ │ └─┬ sshpk@1.16.1
    487 silly saveTree │ │ │   ├── asn1@0.2.4
    487 silly saveTree │ │ │   ├─┬ bcrypt-pbkdf@1.0.2
    487 silly saveTree │ │ │   │ └── tweetnacl@0.14.5
    487 silly saveTree │ │ │   ├── dashdash@1.14.1
    487 silly saveTree │ │ │   ├─┬ ecc-jsbn@0.1.2
    487 silly saveTree │ │ │   │ └── jsbn@0.1.1
    487 silly saveTree │ │ │   ├── getpass@0.1.7
    487 silly saveTree │ │ │   ├── jsbn@0.1.1
    487 silly saveTree │ │ │   └── tweetnacl@0.14.5
    487 silly saveTree │ │ ├── is-typedarray@1.0.0
    487 silly saveTree │ │ ├── isstream@0.1.2
    487 silly saveTree │ │ ├── json-stringify-safe@5.0.1
    487 silly saveTree │ │ ├── oauth-sign@0.9.0
    487 silly saveTree │ │ ├── performance-now@2.1.0
    487 silly saveTree │ │ ├── qs@6.5.2
    487 silly saveTree │ │ ├─┬ tough-cookie@2.5.0
    487 silly saveTree │ │ │ └── psl@1.8.0
    487 silly saveTree │ │ ├── tunnel-agent@0.6.0
    487 silly saveTree │ │ └── uuid@3.4.0
    487 silly saveTree │ ├─┬ semver@7.3.5
    487 silly saveTree │ │ └─┬ lru-cache@6.0.0
    487 silly saveTree │ │   └── yallist@4.0.0
    487 silly saveTree │ └── ws@7.4.5
    487 silly saveTree ├─┬ iobroker.backitup@2.1.6
    487 silly saveTree │ ├─┬ axios@0.21.1
    487 silly saveTree │ │ └── follow-redirects@1.14.0
    487 silly saveTree │ ├─┬ dropbox-v2-api@2.4.38
    487 silly saveTree │ │ └─┬ request@2.88.0
    487 silly saveTree │ │   └─┬ tough-cookie@2.4.3
    487 silly saveTree │ │     └── punycode@1.4.1
    487 silly saveTree │ ├─┬ fs-extra@9.1.0
    487 silly saveTree │ │ ├── at-least-node@1.0.0
    487 silly saveTree │ │ ├── graceful-fs@4.2.6
    487 silly saveTree │ │ ├─┬ jsonfile@6.1.0
    487 silly saveTree │ │ │ └── universalify@2.0.0
    487 silly saveTree │ │ └── universalify@2.0.0
    487 silly saveTree │ ├─┬ ftp@0.3.10
    487 silly saveTree │ │ ├─┬ readable-stream@1.1.14
    487 silly saveTree │ │ │ ├── isarray@0.0.1
    487 silly saveTree │ │ │ └── string_decoder@0.10.31
    487 silly saveTree │ │ └── xregexp@2.0.0
    487 silly saveTree │ ├─┬ google-auth-library@7.0.4
    487 silly saveTree │ │ ├── arrify@2.0.1
    487 silly saveTree │ │ ├── base64-js@1.5.1
    487 silly saveTree │ │ ├── ecdsa-sig-formatter@1.0.11
    487 silly saveTree │ │ ├── fast-text-encoding@1.0.3
    487 silly saveTree │ │ ├─┬ gaxios@4.2.1
    487 silly saveTree │ │ │ ├─┬ abort-controller@3.0.0
    487 silly saveTree │ │ │ │ └── event-target-shim@5.0.1
    487 silly saveTree │ │ │ ├─┬ https-proxy-agent@5.0.0
    487 silly saveTree │ │ │ │ ├─┬ agent-base@6.0.2
    487 silly saveTree │ │ │ │ │ └─┬ debug@4.3.1
    487 silly saveTree │ │ │ │ │   └── ms@2.1.2
    487 silly saveTree │ │ │ │ └─┬ debug@4.3.1
    487 silly saveTree │ │ │ │   └── ms@2.1.2
    487 silly saveTree │ │ │ ├── is-stream@2.0.0
    487 silly saveTree │ │ │ └── node-fetch@2.6.1
    487 silly saveTree │ │ ├─┬ gcp-metadata@4.2.1
    487 silly saveTree │ │ │ └─┬ json-bigint@1.0.0
    487 silly saveTree │ │ │   └── bignumber.js@9.0.1
    487 silly saveTree │ │ ├─┬ gtoken@5.2.1
    487 silly saveTree │ │ │ ├─┬ google-p12-pem@3.0.3
    487 silly saveTree │ │ │ │ └── node-forge@0.10.0
    487 silly saveTree │ │ │ └─┬ jws@4.0.0
    487 silly saveTree │ │ │   └─┬ jwa@2.0.0
    487 silly saveTree │ │ │     └── buffer-equal-constant-time@1.0.1
    487 silly saveTree │ │ └── jws@4.0.0
    487 silly saveTree │ ├─┬ googleapis@73.0.0
    487 silly saveTree │ │ └─┬ googleapis-common@5.0.2
    487 silly saveTree │ │   ├─┬ qs@6.10.1
    487 silly saveTree │ │   │ └─┬ side-channel@1.0.4
    487 silly saveTree │ │   │   ├─┬ call-bind@1.0.2
    487 silly saveTree │ │   │   │ ├── function-bind@1.1.1
    487 silly saveTree │ │   │   │ └─┬ get-intrinsic@1.1.1
    487 silly saveTree │ │   │   │   ├── has-symbols@1.0.2
    487 silly saveTree │ │   │   │   └── has@1.0.3
    487 silly saveTree │ │   │   ├── get-intrinsic@1.1.1
    487 silly saveTree │ │   │   └── object-inspect@1.10.2
    487 silly saveTree │ │   ├── url-template@2.0.8
    487 silly saveTree │ │   └── uuid@8.3.2
    487 silly saveTree │ ├─┬ node-schedule@2.0.0
    487 silly saveTree │ │ ├─┬ cron-parser@3.5.0
    487 silly saveTree │ │ │ ├─┬ is-nan@1.3.2
    487 silly saveTree │ │ │ │ └─┬ define-properties@1.1.3
    487 silly saveTree │ │ │ │   └── object-keys@1.1.1
    487 silly saveTree │ │ │ └── luxon@1.26.0
    487 silly saveTree │ │ ├── long-timeout@0.1.1
    487 silly saveTree │ │ └── sorted-array-functions@1.3.0
    487 silly saveTree │ ├── node-wol@0.1.1
    487 silly saveTree │ ├─┬ tar-fs@2.1.1
    487 silly saveTree │ │ ├── chownr@1.1.4
    487 silly saveTree │ │ ├── mkdirp-classic@0.5.3
    487 silly saveTree │ │ ├─┬ pump@3.0.0
    487 silly saveTree │ │ │ ├─┬ end-of-stream@1.4.4
    487 silly saveTree │ │ │ │ └─┬ once@1.4.0
    487 silly saveTree │ │ │ │   └── wrappy@1.0.2
    487 silly saveTree │ │ │ └── once@1.4.0
    487 silly saveTree │ │ └─┬ tar-stream@2.2.0
    487 silly saveTree │ │   ├─┬ bl@4.1.0
    487 silly saveTree │ │   │ ├─┬ buffer@5.7.1
    487 silly saveTree │ │   │ │ └── ieee754@1.2.1
    487 silly saveTree │ │   │ ├── inherits@2.0.4
    487 silly saveTree │ │   │ └─┬ readable-stream@3.6.0
    487 silly saveTree │ │   │   ├─┬ string_decoder@1.3.0
    487 silly saveTree │ │   │   │ └── safe-buffer@5.2.1
    487 silly saveTree │ │   │   └── util-deprecate@1.0.2
    487 silly saveTree │ │   ├── fs-constants@1.0.0
    487 silly saveTree │ │   └── readable-stream@3.6.0
    487 silly saveTree │ └─┬ webdav@4.3.0
    487 silly saveTree │   ├── axios@0.21.1
    487 silly saveTree │   ├── base-64@1.0.0
    487 silly saveTree │   ├── fast-xml-parser@3.19.0
    487 silly saveTree │   ├── he@1.2.0
    487 silly saveTree │   ├── hot-patcher@0.5.0
    487 silly saveTree │   ├── layerr@0.1.2
    487 silly saveTree │   ├─┬ md5@2.3.0
    487 silly saveTree │   │ ├── charenc@0.0.2
    487 silly saveTree │   │ ├── crypt@0.0.2
    487 silly saveTree │   │ └── is-buffer@1.1.6
    487 silly saveTree │   ├─┬ minimatch@3.0.4
    487 silly saveTree │   │ └─┬ brace-expansion@1.1.11
    487 silly saveTree │   │   ├── balanced-match@1.0.2
    487 silly saveTree │   │   └── concat-map@0.0.1
    487 silly saveTree │   ├── nested-property@4.0.0
    487 silly saveTree │   ├── path-posix@1.0.0
    487 silly saveTree │   ├── url-join@4.0.1
    487 silly saveTree │   └─┬ url-parse@1.5.1
    487 silly saveTree │     ├── querystringify@2.2.0
    487 silly saveTree │     └── requires-port@1.0.0
    487 silly saveTree ├─┬ iobroker.discovery@2.6.3
    487 silly saveTree │ ├─┬ mdns-discovery@0.2.6
    487 silly saveTree │ │ ├─┬ debug@2.2.0
    487 silly saveTree │ │ │ └── ms@0.7.1
    487 silly saveTree │ │ ├── dgram@1.0.1
    487 silly saveTree │ │ └─┬ dns-packet@1.3.1
    487 silly saveTree │ │   └── ip@1.1.5
    487 silly saveTree │ ├── netmask@1.0.6
    487 silly saveTree │ ├── node-mndp@0.0.3
    487 silly saveTree │ ├─┬ node-ssdp@4.0.1
    487 silly saveTree │ │ ├─┬ async@2.6.3
    487 silly saveTree │ │ │ └── lodash@4.17.21
    487 silly saveTree │ │ ├── bluebird@3.7.2
    487 silly saveTree │ │ └─┬ debug@3.2.7
    487 silly saveTree │ │   └── ms@2.1.3
    487 silly saveTree │ └─┬ serialport@9.0.7
    487 silly saveTree │   ├─┬ @serialport/binding-mock@9.0.7
    487 silly saveTree │   │ ├─┬ @serialport/binding-abstract@9.0.7
    487 silly saveTree │   │ │ └─┬ debug@4.3.1
    487 silly saveTree │   │ │   └── ms@2.1.2
    487 silly saveTree │   │ └─┬ debug@4.3.1
    487 silly saveTree │   │   └── ms@2.1.2
    487 silly saveTree │   ├─┬ @serialport/bindings@9.0.7
    487 silly saveTree │   │ ├─┬ @serialport/parser-readline@9.0.7
    487 silly saveTree │   │ │ └── @serialport/parser-delimiter@9.0.7
    487 silly saveTree │   │ ├─┬ bindings@1.5.0
    487 silly saveTree │   │ │ └── file-uri-to-path@1.0.0
    487 silly saveTree │   │ ├─┬ debug@4.3.1
    487 silly saveTree │   │ ├── nan@2.14.2
    487 silly saveTree │   │ └─┬ prebuild-install@6.1.2
    487 silly saveTree │   │   ├── detect-libc@1.0.3
    487 silly saveTree │   │   ├── expand-template@2.0.3
    487 silly saveTree │   │   ├── github-from-package@0.0.0
    487 silly saveTree │   │   ├── minimist@1.2.5
    487 silly saveTree │   │   ├── napi-build-utils@1.0.2
    487 silly saveTree │   │   ├─┬ node-abi@2.26.0
    487 silly saveTree │   │   │ └── semver@5.7.1
    487 silly saveTree │   │   ├── noop-logger@0.1.1
    487 silly saveTree │   │   ├─┬ npmlog@4.1.2
    487 silly saveTree │   │   │ ├─┬ are-we-there-yet@1.1.5
    487 silly saveTree │   │   │ │ ├── delegates@1.0.0
    487 silly saveTree │   │   │ │ └─┬ readable-stream@2.3.7
    487 silly saveTree │   │   │ │   ├── isarray@1.0.0
    487 silly saveTree │   │   │ │   ├── process-nextick-args@2.0.1
    487 silly saveTree │   │   │ │   └── string_decoder@1.1.1
    487 silly saveTree │   │   │ ├── console-control-strings@1.1.0
    487 silly saveTree │   │   │ ├─┬ gauge@2.7.4
    487 silly saveTree │   │   │ │ ├── aproba@1.2.0
    487 silly saveTree │   │   │ │ ├── has-unicode@2.0.1
    487 silly saveTree │   │   │ │ ├── object-assign@4.1.1
    487 silly saveTree │   │   │ │ ├── signal-exit@3.0.3
    487 silly saveTree │   │   │ │ ├─┬ string-width@1.0.2
    487 silly saveTree │   │   │ │ │ ├── code-point-at@1.1.0
    487 silly saveTree │   │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
    487 silly saveTree │   │   │ │ │ │ └── number-is-nan@1.0.1
    487 silly saveTree │   │   │ │ │ └─┬ strip-ansi@3.0.1
    487 silly saveTree │   │   │ │ │   └── ansi-regex@2.1.1
    487 silly saveTree │   │   │ │ ├── strip-ansi@3.0.1
    487 silly saveTree │   │   │ │ └── wide-align@1.1.3
    487 silly saveTree │   │   │ └── set-blocking@2.0.0
    487 silly saveTree │   │   ├─┬ rc@1.2.8
    487 silly saveTree │   │   │ ├── deep-extend@0.6.0
    487 silly saveTree │   │   │ ├── ini@1.3.8
    487 silly saveTree │   │   │ └── strip-json-comments@2.0.1
    487 silly saveTree │   │   └─┬ simple-get@3.1.0
    487 silly saveTree │   │     ├─┬ decompress-response@4.2.1
    487 silly saveTree │   │     │ └── mimic-response@2.1.0
    487 silly saveTree │   │     └── simple-concat@1.0.1
    487 silly saveTree │   ├── @serialport/parser-byte-length@9.0.7
    487 silly saveTree │   ├── @serialport/parser-cctalk@9.0.7
    487 silly saveTree │   ├── @serialport/parser-delimiter@9.0.7
    487 silly saveTree │   ├── @serialport/parser-inter-byte-timeout@9.0.7
    487 silly saveTree │   ├── @serialport/parser-readline@9.0.7
    487 silly saveTree │   ├── @serialport/parser-ready@9.0.7
    487 silly saveTree │   ├── @serialport/parser-regex@9.0.7
    487 silly saveTree │   ├─┬ @serialport/stream@9.0.7
    487 silly saveTree │   └─┬ debug@4.3.1
    487 silly saveTree │     └── ms@2.1.2
    487 silly saveTree ├─┬ iobroker.info@1.7.15
    487 silly saveTree │ ├── jshashes@1.0.8
    487 silly saveTree │ └── systeminformation@4.34.23
    487 silly saveTree └─┬ iobroker.js-controller@3.3.8
    487 silly saveTree   ├─┬ @iobroker/db-objects-file@1.2.3
    487 silly saveTree   │ ├─┬ @iobroker/db-base@1.2.3
    487 silly saveTree   │ │ ├── deep-clone@3.0.3
    487 silly saveTree   │ │ ├─┬ fs-extra@9.1.0
    487 silly saveTree   │ │ │ ├─┬ jsonfile@6.1.0
    487 silly saveTree   │ │ │ │ └── universalify@2.0.0
    487 silly saveTree   │ │ ├─┬ node.extend@2.0.2
    487 silly saveTree   │ │ │ └── is@3.3.0
    487 silly saveTree   │ │ └── respjs@4.2.0
    487 silly saveTree   │ ├─┬ @iobroker/db-objects-redis@1.2.3
    487 silly saveTree   │ │ └─┬ ioredis@4.27.2
    487 silly saveTree   │ │   ├── cluster-key-slot@1.1.0
    487 silly saveTree   │ │   ├── denque@1.5.0
    487 silly saveTree   │ │   ├── lodash.defaults@4.2.0
    487 silly saveTree   │ │   ├── lodash.flatten@4.4.0
    487 silly saveTree   │ │   ├── p-map@2.1.0
    487 silly saveTree   │ │   ├── redis-commands@1.7.0
    487 silly saveTree   │ │   ├── redis-errors@1.2.0
    487 silly saveTree   │ │   ├── redis-parser@3.0.0
    487 silly saveTree   │ │   └── standard-as-callback@2.1.0
    487 silly saveTree   │ ├── deep-clone@3.0.3
    487 silly saveTree   │ └── node.extend@2.0.2
    487 silly saveTree   ├─┬ @iobroker/db-objects-jsonl@1.2.3
    487 silly saveTree   │ ├─┬ @alcalzone/jsonl-db@1.2.4
    487 silly saveTree   │ │ ├─┬ alcalzone-shared@3.0.4
    487 silly saveTree   │ │ └─┬ fs-extra@9.1.0
    487 silly saveTree   │ └─┬ fs-extra@9.1.0
    487 silly saveTree   │   ├─┬ jsonfile@6.1.0
    487 silly saveTree   │   └── universalify@2.0.0
    487 silly saveTree   ├── @iobroker/db-objects-redis@1.2.3
    487 silly saveTree   ├─┬ @iobroker/db-states-file@1.2.3
    487 silly saveTree   │ └── @iobroker/db-states-redis@1.2.3
    487 silly saveTree   ├── @iobroker/db-states-jsonl@1.2.3
    487 silly saveTree   ├── @iobroker/db-states-redis@1.2.3
    487 silly saveTree   ├── @iobroker/plugin-base@1.2.1
    487 silly saveTree   ├─┬ @iobroker/plugin-sentry@1.1.10
    487 silly saveTree   │ ├─┬ @sentry/integrations@6.3.5
    487 silly saveTree   │ │ ├── @sentry/types@6.3.5
    487 silly saveTree   │ │ ├─┬ @sentry/utils@6.3.5
    487 silly saveTree   │ │ │ └── tslib@1.14.1
    487 silly saveTree   │ │ ├─┬ localforage@1.9.0
    487 silly saveTree   │ │ │ └─┬ lie@3.1.1
    487 silly saveTree   │ │ │   └── immediate@3.0.6
    487 silly saveTree   │ │ └── tslib@1.14.1
    487 silly saveTree   │ ├─┬ @sentry/node@6.3.5
    487 silly saveTree   │ │ ├── @sentry/core@6.3.5
    487 silly saveTree   │ │ ├── @sentry/tracing@6.3.5
    487 silly saveTree   │ │ ├── cookie@0.4.1
    487 silly saveTree   │ │ ├── https-proxy-agent@5.0.0
    487 silly saveTree   │ │ └── lru_map@0.3.3
    487 silly saveTree   │ └── source-map-support@0.5.19
    487 silly saveTree   ├── chokidar@3.5.1
    487 silly saveTree   ├── daemonize2@0.4.2
    487 silly saveTree   ├── debug@4.3.1
    487 silly saveTree   ├── decache@4.6.0
    487 silly saveTree   ├── deep-clone@3.0.3
    487 silly saveTree   ├── diskusage@1.1.3
    487 silly saveTree   ├─┬ esbuild-register@2.5.0
    487 silly saveTree   │ └── esbuild@0.11.19
    487 silly saveTree   ├── esbuild@0.11.19
    487 silly saveTree   ├── event-stream@4.0.1
    487 silly saveTree   ├── fs-extra@9.1.0
    487 silly saveTree   ├── greenlock-express@4.0.3
    487 silly saveTree   ├── greenlock@4.0.4
    487 silly saveTree   ├── jsonwebtoken@8.5.1
    487 silly saveTree   ├── jszip@3.6.0
    487 silly saveTree   ├── le-acme-core@2.1.4
    487 silly saveTree   ├── le-challenge-fs@2.0.9
    487 silly saveTree   ├── le-sni-auto@2.1.9
    487 silly saveTree   ├── loadavg-windows@1.1.1
    487 silly saveTree   ├── mime@2.5.2
    487 silly saveTree   ├── ncp@2.0.0
    487 silly saveTree   ├── node.extend@2.0.2
    487 silly saveTree   ├── pidusage@2.0.21
    487 silly saveTree   ├── promisify-child-process@4.1.1
    487 silly saveTree   ├── prompt@1.1.0
    487 silly saveTree   ├── readline-sync@1.4.10
    487 silly saveTree   ├── tar@6.1.0
    487 silly saveTree   ├── winston-daily-rotate-file@4.5.4
    487 silly saveTree   ├── winston-seq-updated@1.0.4
    487 silly saveTree   ├── winston-syslog@2.4.4
    487 silly saveTree   ├── winston@3.3.3
    487 silly saveTree   └── yargs@16.2.0
    488 verbose stack SyntaxError: Unexpected end of JSON input while parsing near '...,"@sentry/utils":"6.3'
    488 verbose stack     at JSON.parse (<anonymous>)
    488 verbose stack     at parseJson (/usr/local/lib/node_modules/npm/node_modules/json-parse-better-errors/index.js:7:17)
    488 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/node-fetch-npm/src/body.js:96:50
    488 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:93:5)
    489 verbose cwd /opt/iobroker
    490 verbose Linux 5.10.17-v7+
    491 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller@3.3.8" "--loglevel" "error" "--unsafe-perm" "--prefix" "/opt/iobroker"
    492 verbose node v14.16.1
    493 verbose npm  v6.14.12
    494 error Unexpected end of JSON input while parsing near '...,"@sentry/utils":"6.3'
    495 verbose exit [ 1, true ]
    pi@iobroker:~ $
    sorry jetzt ist Die Log Datei vollständig.
    Thomas BraunT
    Thomas BraunT
    #215
    @doerk32 sagte in js-controller 3.3 jetzt im Latest:
    /usr/local/bin/node',        /usr/local/bin/npm',
    NodeJS falsch installiert. In meiner Signatur steht wie man es richtig macht.
    Erst wenn das sauber ist lohnt es sich zu schauen warum das JSON kaputt ist. Und wo man eine Kopie herbekommt.
      @karel-puhli sagte in js-controller 3.3 jetzt im Latest:
      Allerdings würde ich schon gerne wissen, was los ist.
      Dann solltest du die Ankündigung zu einer neuen Beta-Version auch lesen. Da steht drin was los ist und was zu tun ist.
      Karel PuhliK
      Karel PuhliK
      Karel Puhli
      #216
      Beta... da sagst du was. Hatte versehentlich noch den Verwahrungsort Beta. Habe ich wohl vergessen wieder umzustellen. Dachte, ich lade mir stable herunter.
      Dann lasse ich alles so, es sind ja nur infos im log. Ansonsten funktioniert ja alles. Oder siehst du das anders?
      • Karel PuhliK Karel Puhli
        Thomas BraunT
        Thomas BraunT
        #217
        @karel-puhli
        Stell den Verwahrort auf Stable um. Dann wächst sich das mit der Zeit (wenn die Versionsnummer aus Stable die jetzige Beta-Versionsnummer überholt) aus. Oder installier die Stable halt jetzt gleich, wenn die Meldungen 'nerven'.
        Karel PuhliK 1 Antwort Letzte Antwort
        • foxriver76F foxriver76
          @foxthefox sagte in js-controller 3.3 jetzt im Latest:
          State value to set for "fritzdect.0.DECT_grp5665DB-3A12B8E79.endperiod" has to be type "number" but received type "string"
          Bin mir ziemlich sicher, dass da noch der Wurm drin ist bei dir. Das casten als String müsste auf jeden Fall einen String zurückgeben und der controller checkt ja nur mit typeof und typeof String(new Date()) ist string.
          Grundsätzlich würde ich allerdings empfehlen für role: 'date' common.type: 'number' zu wählen und das Datum als number zu speichern. Dies lässt sich in Skripten leichter weiterverarbeiten und Admin stellt es auch korrekt als Timestamp dar, da er die role Angabe nutzt.
          F
          F
          foxthefox
          #218
          @foxriver76 sagte in js-controller 3.3 jetzt im Latest:
          Ich denke es ist auch in ein String umgewandelt, zumindest besagt das der letzte Teil der Fehlermeldung.
          Für mich ist nur komisch warum bei type="string" der Checker eine "number" erwartet.
          Ich stelle es gern auf number um, dann gibt es in den Objekten eine kryptische Millisekunden Angabe und das wars. Ist nicht Anwenderfreundlich, aber löst das Problem höchstwahrscheinlich.
          Und es gibt dann GitHub-issues, daß das so nicht bleiben kann. :-(
          Oder habe ich es falsch verstanden und vis und admin können aus Millisekunden einen lesbaren String erzeugen?
          Adapterüberblick: Profil Github;
          Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
          Ein Aufruf: video
          • F foxthefox
            foxriver76F
            foxriver76F
            foxriver76
            #219
            @foxthefox bei dem state wo er meckert sagt e tja er möchte Number aber bekommt String deshalb passt da was nicht, weil du laut oben type String in der Definition hast, deshalb meine ich da ist der Wurm drin.
            Ja wandelt number automatisch in menschenlesbares Datum um , wenn role date ist.
            Videotutorials & mehr
              @karel-puhli
              Karel PuhliK
              Karel PuhliK
              Karel Puhli
              #220
              @thomas-braun Danke Dir! 👍
              • F foxthefox
                @apollon77
                irgendwie schaffe ich es nicht die Meldung wegzubekommen.
                Habe nun die Zeiten mit
                		common: {
                			type: 'string',
                			read: true,
                			write: false,
                			role: 'date',
                			desc: name
                definiert, also String.
                beim Schreiben der Werte sieht es so aus:
                				const convTime = new Date(value * 1000);
                				await this.setStateAsync('DECT_' + ain + '.' + key, {
                					val: String(convTime),
                					ack: true
                bekomme aber immer noch
                was kann ich machen, damit IOB keine Zahl erwartet?
                Bzw. was soll ich am Code ändern?
                Klaus
                foxriver76F
                foxriver76F
                foxriver76
                schrieb am zuletzt editiert von foxriver76
                #221
                  	common: {
                  		type: 'string',
                  		read: true,
                  		write: false,
                  		role: 'date',
                  		desc: name
                Also nochmal weil ich es im Post davor evtl. etwas verwirrend vom Handy getippt habe. Hier oben ist deine Objektdefinition die angeblich zum State fritzdect.0.DECT_grp5665DB-3A12B8E79.endperiod gehört. Hier wird definiert, dass der Typ string ist.
                Hier steht aber, dass das Objekt als Typ number definiert wurde, er aber einen String erhalten hat. Also passt die Objektdefinition (die oben in diesem Post) nicht zum Objekt, dessen State hier beschrieben wird.
                • D doerk32
                  leider brachte dies keine Besserung
                  pi@iobroker:~ $ iobroker stop
                  pi@iobroker:~ $
                  pi@iobroker:~ $ iobroker update
                  Used repository: beta
                  hash unchanged, use cached sources
                  update done
                  Adapter    "accuweather"   : 1.1.5
                  Adapter    "adb"           : 0.0.5
                  Adapter    "admin"         : 5.0.15   , installed 5.0.15
                  Adapter    "alarm"         : 2.0.0
                  Adapter    "alexa2"        : 3.8.2    , installed 3.8.2
                  Adapter    "alias-manager" : 1.2.0
                  Adapter    "alpha2"        : 1.0.0
                  Adapter    "amazon-dash"   : 1.1.0
                  Adapter    "artnet"        : 1.2.2
                  Adapter    "asterisk"      : 1.0.6
                  Adapter    "asuswrt"       : 1.0.1
                  Adapter    "b-control-em"  : 0.2.1
                  Adapter    "backitup"      : 2.1.6    , installed 2.1.6
                  Adapter    "beckhoff"      : 1.4.0
                  Adapter    "benq"          : 0.2.5
                  Adapter    "binance"       : 1.1.3
                  Adapter    "ble"           : 0.12.0
                  Adapter    "blink4home"    : 0.1.1
                  Adapter    "bmw"           : 1.4.0
                  Adapter    "boblight"      : 0.0.1
                  Adapter    "bosesoundtouch": 0.9.3
                  Adapter    "botvac"        : 1.0.0
                  Adapter    "bring"         : 1.7.7
                  Adapter    "broadlink2"    : 2.1.5
                  Adapter    "bsblan"        : 0.2.2
                  Adapter    "bshb"          : 0.1.13
                  Adapter    "bydbatt"       : 1.0.4
                  Adapter    "calendar"      : 1.2.0
                  Adapter    "cameras"       : 0.1.3
                  Adapter    "canbus"        : 1.1.4
                  Adapter    "cec2"          : 0.1.0
                  Adapter    "chromecast"    : 2.3.1
                  Adapter    "cloud"         : 4.0.10
                  Adapter    "comfoair"      : 1.1.3
                  Adapter    "contact"       : 1.1.3
                  Adapter    "contactid"     : 1.0.2
                  Adapter    "coronavirus-statistics": 0.7.0-4
                  Adapter    "corrently"     : 0.0.2
                  Adapter    "countdown"     : 1.1.0
                  Adapter    "cul"           : 1.3.5
                  Adapter    "daikin"        : 1.3.0
                  Adapter    "daswetter"     : 3.0.6
                  Adapter    "deconz"        : 1.3.14
                  Adapter    "denon"         : 1.10.6
                  Adapter    "device-reminder": 1.2.1
                  Adapter    "devices"       : 0.3.16
                  Adapter    "digitalstrom"  : 2.2.0
                  Adapter    "discovergy"    : 0.5.7
                  Adapter    "discovery"     : 2.6.3    , installed 2.6.3
                  Adapter    "divera247"     : 0.1.2
                  Adapter    "doorbird"      : 0.1.5
                  Adapter    "doorio"        : 1.1.4
                  Adapter    "ds18b20"       : 1.4.1
                  Adapter    "dwd"           : 2.7.5
                  Adapter    "dysonairpurifier": 0.8.2
                  Adapter    "easee"         : 1.0.1
                  Adapter    "ebus"          : 2.2.5
                  Adapter    "echarts"       : 0.4.14
                  Adapter    "ecovacs-deebot": 1.1.1
                  Adapter    "egigeozone"    : 0.1.2
                  Adapter    "ekey"          : 1.1.0
                  Adapter    "email"         : 1.0.9
                  Adapter    "emby"          : 1.0.2
                  Adapter    "energymanager" : 1.2.3
                  Adapter    "enet"          : 1.0.1
                  Adapter    "epson_ecotank_et_2750": 0.0.5
                  Adapter    "epson_stylus_px830": 0.2.1
                  Adapter    "esphome"       : 0.2.1-1
                  Adapter    "eventlist"     : 0.4.2
                  Adapter    "exchangerates" : 0.0.14
                  Adapter    "fahrplan"      : 1.0.7
                  Adapter    "fakeroku"      : 0.2.1
                  Adapter    "fb-checkpresence": 1.1.0
                  Adapter    "feiertage"     : 1.0.19
                  Adapter    "fhem"          : 1.6.0
                  Adapter    "find-my-iphone": 0.2.17
                  Adapter    "firetv"        : 1.0.0
                  Adapter    "fitbit-api"    : 0.1.1
                  Adapter    "flot"          : 1.10.6
                  Adapter    "followthesun"  : 0.3.3
                  Adapter    "foobar2000"    : 2.0.4
                  Adapter    "fritzbox"      : 0.2.1
                  Adapter    "fritzdect"     : 2.1.12
                  Adapter    "fronius"       : 1.1.3
                  Adapter    "frontier_silicon": 0.0.10
                  Adapter    "fuelpricemonitor": 0.2.5
                  Adapter    "fullcalendar"  : 1.1.0
                  Adapter    "fullybrowser"  : 2.0.8
                  Adapter    "g-homa"        : 0.5.3
                  Adapter    "geofency"      : 1.0.3
                  Adapter    "go-e"          : 1.0.2
                  Adapter    "googleauth"    : 0.3.2
                  Adapter    "growatt"       : 1.0.1
                  Adapter    "gruenbeck"     : 0.0.29
                  Adapter    "haassohn"      : 1.0.3
                  Adapter    "habpanel"      : 0.4.3
                  Adapter    "haier"         : 1.0.4
                  Adapter    "ham"           : 4.0.1
                  Adapter    "ham-wemo"      : 1.1.1
                  Adapter    "harmony"       : 1.2.2
                  Adapter    "hass"          : 1.0.0
                  Adapter    "hass-mqtt"     : 0.0.7
                  Adapter    "heatingcontrol": 2.3.2
                  Adapter    "heos"          : 1.8.0
                  Adapter    "heytech"       : 1.0.1
                  Adapter    "hid"           : 0.1.17
                  Adapter    "hilink"        : 0.2.7
                  Adapter    "history"       : 1.9.13
                  Adapter    "hm-rega"       : 3.0.24   , installed 3.0.24
                  Adapter    "hm-rpc"        : 1.14.37  , installed 1.14.37
                  Adapter    "hmip"          : 1.11.0
                  Adapter    "hombot"        : 0.1.3
                  Adapter    "homeconnect"   : 0.0.32
                  Adapter    "homee"         : 1.1.1
                  Adapter    "homepilot"     : 1.1.4
                  Adapter    "hp-ilo"        : 1.0.6
                  Adapter    "hs100"         : 2.0.3
                  Adapter    "hue"           : 3.5.14
                  Adapter    "hue-extended"  : 2.0.0
                  Adapter    "hyperion"      : 0.0.9
                  Adapter    "hyperion_ng"   : 0.1.19
                  Adapter    "i2c"           : 1.2.0
                  Adapter    "ical"          : 1.9.3
                  Adapter    "icons-addictive-flavour-png": 0.1.0
                  Adapter    "icons-fatcow-hosting": 0.1.0
                  Adapter    "icons-icons8"  : 0.0.1
                  Adapter    "icons-material-png": 0.1.0
                  Adapter    "icons-material-svg": 0.1.0
                  Adapter    "icons-mfd-png" : 1.0.2
                  Adapter    "icons-mfd-svg" : 1.0.2
                  Adapter    "icons-open-icon-library-png": 0.1.2
                  Adapter    "icons-ultimate-png": 1.0.1
                  Adapter    "influxdb"      : 1.9.5
                  Adapter    "info"          : 1.7.15   , installed 1.7.15
                  Adapter    "innogy-smarthome": 0.3.6
                  Adapter    "intesishome"   : 0.1.2
                  Adapter    "iogo"          : 0.6.6
                  Adapter    "iot"           : 1.8.16   , installed 1.8.16
                  Adapter    "iqontrol"      : 1.8.0
                  Adapter    "jarvis"        : 2.2.0
                  Adapter    "javascript"    : 5.1.3
                  Adapter    "jeelink"       : 0.1.3
                  Controller "js-controller" : 3.3.8    , installed 3.2.16 [Updateable]
                  Adapter    "judoisoft"     : 1.0.8
                  Adapter    "kecontact"     : 1.1.2
                  Adapter    "klf200"        : 1.0.1
                  Adapter    "km200"         : 2.0.3
                  Adapter    "knmi-weather"  : 1.0.0
                  Adapter    "knx"           : 1.0.45
                  Adapter    "kodi"          : 2.0.7
                  Adapter    "kostal-piko-ba": 1.1.6
                  Adapter    "kress"         : 2.5.5
                  Adapter    "lametric"      : 1.3.0
                  Adapter    "landroid"      : 1.0.3
                  Adapter    "lcn"           : 1.0.2
                  Adapter    "legrand-ecocompteur": 1.0.0
                  Adapter    "letrika_comgw" : 0.0.5
                  Adapter    "lg-ess-home"   : 0.0.10
                  Adapter    "lgtv"          : 1.1.10
                  Adapter    "lgtv-rs"       : 0.1.1
                  Adapter    "lgtv11"        : 1.0.5
                  Adapter    "lifx"          : 0.1.1
                  Adapter    "lightify"      : 0.2.16
                  Adapter    "link"          : 0.5.10
                  Adapter    "linkeddevices" : 1.4.3
                  Adapter    "linktap"       : 0.1.8
                  Adapter    "linux-control" : 1.1.2
                  Adapter    "logparser"     : 1.1.0
                  Adapter    "lovelace"      : 1.5.0
                  Adapter    "loxone"        : 2.1.0
                  Adapter    "luftdaten"     : 1.0.3
                  Adapter    "lupusec"       : 1.3.4
                  Adapter    "luxtronik1"    : 0.3.0
                  Adapter    "material"      : 0.13.9
                  Adapter    "maxcube"       : 1.0.3
                  Adapter    "maxcul"        : 1.3.1
                  Adapter    "mbus"          : 2.3.4
                  Adapter    "mclighting"    : 0.1.2
                  Adapter    "megad"         : 1.2.1
                  Adapter    "megadd"        : 0.2.0
                  Adapter    "megaesp"       : 0.1.0
                  Adapter    "melcloud"      : 1.1.2
                  Adapter    "mercedesme"    : 0.0.51
                  Adapter    "mercury"       : 0.1.5
                  Adapter    "meross"        : 1.6.1
                  Adapter    "meteoalarm"    : 1.1.5
                  Adapter    "midea"         : 0.0.6
                  Adapter    "miele"         : 0.1.5
                  Adapter    "mielecloudservice": 4.0.21
                  Adapter    "mihome"        : 1.3.7
                  Adapter    "mihome-airpurifier": 0.1.8
                  Adapter    "mihome-lamp"   : 1.1.0
                  Adapter    "mihome-plug"   : 0.2.1
                  Adapter    "mihome-vacuum" : 3.1.4
                  Adapter    "miio"          : 0.0.13
                  Adapter    "mikrotik"      : 1.0.16
                  Adapter    "milight"       : 0.3.6
                  Adapter    "milight-smart-light": 1.2.0
                  Adapter    "minuvis"       : 1.4.0
                  Adapter    "mobile"        : 1.0.1
                  Adapter    "modbus"        : 3.3.0
                  Adapter    "moma"          : 1.2.8
                  Adapter    "mpd"           : 1.0.6
                  Adapter    "mqtt"          : 2.3.5
                  Adapter    "mqtt-client"   : 1.3.2
                  Adapter    "multicast"     : 0.1.6
                  Adapter    "musiccast"     : 0.1.5
                  Adapter    "mydlink"       : 1.1.7
                  Adapter    "myq"           : 0.1.1
                  Adapter    "mysensors"     : 2.0.1
                  Adapter    "mystrom"       : 0.0.3
                  Adapter    "mytime"        : 0.6.1
                  Adapter    "myvbus"        : 0.1.0
                  Adapter    "nanoleaf-lightpanels": 1.2.0
                  Adapter    "net-tools"     : 0.1.5
                  Adapter    "netatmo"       : 1.3.3
                  Adapter    "netatmo-crawler": 0.4.1
                  Adapter    "nibeuplink"    : 0.4.0
                  Adapter    "nina"          : 0.0.24
                  Adapter    "node-red"      : 2.3.0
                  Adapter    "noolitef"      : 0.0.2
                  Adapter    "nuki"          : 1.4.3
                  Adapter    "nuki-extended" : 2.3.0
                  Adapter    "nut"           : 1.4.3
                  Adapter    "octoprint"     : 1.1.0
                  Adapter    "odl"           : 1.1.4
                  Adapter    "oilfox"        : 2.1.0
                  Adapter    "omnicomm-lls"  : 0.0.7
                  Adapter    "omron-fins"    : 0.0.2
                  Adapter    "onkyo"         : 2.0.5
                  Adapter    "onvif"         : 0.4.4
                  Adapter    "openhab"       : 1.1.0
                  Adapter    "openligadb"    : 1.2.0
                  Adapter    "opentherm"     : 0.1.9
                  Adapter    "openweathermap": 0.1.0
                  Adapter    "opi"           : 0.1.1
                  Adapter    "oppoplayer"    : 0.2.4
                  Adapter    "owfs"          : 0.6.4
                  Adapter    "owntracks"     : 1.0.0
                  Adapter    "palazzetti"    : 0.0.6
                  Adapter    "panasonic-viera": 1.0.2
                  Adapter    "parser"        : 1.0.7
                  Adapter    "paw"           : 0.3.2
                  Adapter    "pegelalarm"    : 1.2.0
                  Adapter    "phantomjs"     : 1.1.2
                  Adapter    "philips-air"   : 0.1.0
                  Adapter    "pi-hole"       : 1.3.1
                  Adapter    "piface"        : 1.0.0
                  Adapter    "pimatic"       : 0.3.0
                  Adapter    "ping"          : 1.4.12
                  Adapter    "places"        : 1.0.0
                  Adapter    "plenticore"    : 2.1.9
                  Adapter    "plex"          : 0.9.1
                  Adapter    "plexconnect"   : 0.0.7
                  Adapter    "pollenflug"    : 1.0.6
                  Adapter    "procon-ip"     : 1.0.2
                  Adapter    "proxmox"       : 1.3.2
                  Adapter    "proxy"         : 1.2.2
                  Adapter    "pushbullet"    : 0.0.11
                  Adapter    "pushover"      : 2.0.3
                  Adapter    "pushsafer"     : 1.0.3
                  Adapter    "radar2"        : 2.0.1
                  Adapter    "radiohead"     : 1.1.1
                  Adapter    "rainbird"      : 0.2.2
                  Adapter    "rflink"        : 2.1.6
                  Adapter    "rickshaw"      : 1.0.0
                  Adapter    "ring"          : 1.2.1
                  Adapter    "roadtraffic"   : 0.2.0
                  Adapter    "robonect"      : 0.1.4
                  Adapter    "roomba"        : 1.1.1
                  Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
                  Adapter    "rssfeed"       : 0.0.30
                  Adapter    "s7"            : 1.2.5
                  Adapter    "sainlogic"     : 0.6.1
                  Adapter    "samsung"       : 0.2.9
                  Adapter    "sanext"        : 0.0.5
                  Adapter    "sayit"         : 1.12.2
                  Adapter    "sbfspot"       : 4.0.5
                  Adapter    "scenes"        : 2.3.6
                  Adapter    "schoolfree"    : 0.7.0
                  Adapter    "schwoerer-ventcube": 1.4.0
                  Adapter    "senec"         : 1.1.1
                  Adapter    "seq"           : 0.2.10
                  Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                  Adapter    "shuttercontrol": 1.2.0
                  Adapter    "sia"           : 1.0.4
                  Adapter    "siegenia"      : 1.1.0
                  Adapter    "simple-api"    : 2.5.3    , installed 2.5.3
                  Adapter    "slideshow"     : 0.1.4
                  Adapter    "sma-em"        : 0.6.3
                  Adapter    "smappee"       : 0.2.4
                  Adapter    "smartcontrol"  : 1.2.1
                  Adapter    "smartgarden"   : 1.0.4
                  Adapter    "smartmeter"    : 3.2.0
                  Adapter    "snips"         : 1.5.1
                  Adapter    "snmp"          : 0.5.0
                  Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                  Adapter    "solarlog"      : 2.1.1
                  Adapter    "solarviewdatareader": 1.0.1
                  Adapter    "solarwetter"   : 1.0.0
                  Adapter    "sonnen"        : 1.7.3
                  Adapter    "sonoff"        : 2.4.0
                  Adapter    "sonos"         : 2.1.1
                  Adapter    "sonus"         : 0.1.1
                  Adapter    "sony-bravia"   : 1.0.3
                  Adapter    "sourceanalytix": 0.4.8
                  Adapter    "spotify-premium": 1.0.0
                  Adapter    "sprinklecontrol": 0.1.4
                  Adapter    "sql"           : 1.15.7
                  Adapter    "squeezebox"    : 1.0.0
                  Adapter    "squeezeboxrpc" : 1.3.4
                  Adapter    "starline"      : 1.1.3
                  Adapter    "statistics"    : 1.0.4
                  Adapter    "stiebel-isg"   : 1.6.1
                  Adapter    "stockmarket"   : 0.0.2
                  Adapter    "sunnyportal"   : 0.1.5
                  Adapter    "sureflap"      : 1.0.5
                  Adapter    "swiss-weather-api": 0.3.2
                  Adapter    "synology"      : 1.0.0
                  Adapter    "systeminfo"    : 0.3.1
                  Adapter    "tado"          : 0.2.6
                  Adapter    "tahoma"        : 0.3.3
                  Adapter    "tankerkoenig"  : 2.0.11
                  Adapter    "telegram"      : 1.8.1
                  Adapter    "terminal"      : 0.1.2
                  Adapter    "tesla-motors"  : 0.4.2
                  Adapter    "text2command"  : 2.0.7
                  Adapter    "tileboard"     : 0.3.1
                  Adapter    "time-switch"   : 2.2.1
                  Adapter    "tinker"        : 1.1.0
                  Adapter    "tino"          : 1.0.0
                  Adapter    "tinyrx4"       : 1.0.0
                  Adapter    "todoist2"      : 0.8.6
                  Adapter    "tr-064"        : 4.2.12
                  Adapter    "traccar"       : 0.0.8
                  Adapter    "tradfri"       : 2.7.2
                  Adapter    "trashschedule" : 1.1.3
                  Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                  Adapter    "tuya"          : 3.6.1
                  Adapter    "tvprogram"     : 1.0.0
                  Adapter    "tvspielfilm"   : 2.0.2
                  Adapter    "twinkly"       : 0.1.8
                  Adapter    "unifi"         : 0.5.8
                  Adapter    "unifi-protect" : 0.0.12
                  Adapter    "upnp"          : 1.0.17
                  Adapter    "vaillant"      : 0.0.11
                  Adapter    "valloxmv"      : 1.1.2
                  Adapter    "valuetrackerovertime": 0.6.0
                  Adapter    "vcard"         : 0.0.9
                  Adapter    "vedirect"      : 0.1.2
                  Adapter    "velux"         : 0.0.7
                  Adapter    "viessmann"     : 1.3.3
                  Adapter    "viessmannapi"  : 1.3.2
                  Adapter    "virtualpowermeter": 1.4.2
                  Adapter    "vis"           : 1.3.9
                  Adapter    "vis-3dmodel"   : 0.0.10
                  Adapter    "vis-bars"      : 0.1.4
                  Adapter    "vis-canvas-gauges": 0.1.5
                  Adapter    "vis-colorpicker": 1.2.0
                  Adapter    "vis-fancyswitch": 1.1.0
                  Adapter    "vis-google-fonts": 0.1.0
                  Adapter    "vis-history"   : 1.0.0
                  Adapter    "vis-hqwidgets" : 1.1.7
                  Adapter    "vis-icontwo"   : 0.66.0
                  Adapter    "vis-inventwo"  : 2.9.7
                  Adapter    "vis-jqui-mfd"  : 1.0.12
                  Adapter    "vis-justgage"  : 1.0.2
                  Adapter    "vis-keyboard"  : 0.0.2
                  Adapter    "vis-lcars"     : 1.0.4
                  Adapter    "vis-map"       : 1.0.4
                  Adapter    "vis-material"  : 0.1.3
                  Adapter    "vis-material-advanced": 1.7.0
                  Adapter    "vis-material-webfont": 0.0.3
                  Adapter    "vis-materialdesign": 0.5.5
                  Adapter    "vis-metro"     : 1.1.2
                  Adapter    "vis-players"   : 0.1.6
                  Adapter    "vis-plumb"     : 1.0.2
                  Adapter    "vis-rgraph"    : 0.0.2
                  Adapter    "vis-timeandweather": 1.1.7
                  Adapter    "vis-weather"   : 2.5.3
                  Adapter    "vodafone-speedtest": 0.0.6
                  Adapter    "volumio"       : 0.1.2
                  Adapter    "volvo"         : 0.0.3
                  Adapter    "vr200"         : 1.0.0
                  Adapter    "vw-connect"    : 0.0.33
                  Adapter    "weatherflow_udp": 0.0.15
                  Adapter    "weatherunderground": 3.3.0
                  Adapter    "web"           : 3.4.1    , installed 3.4.1
                  Adapter    "web-speedy"    : 0.2.0
                  Adapter    "weblogin"      : 0.1.1
                  Adapter    "weishaupt-wem" : 0.0.9
                  Adapter    "whatsapp-cmb"  : 0.1.6
                  Adapter    "wiffi-wz"      : 2.2.0
                  Adapter    "wifilight"     : 1.1.0
                  Adapter    "windows-control": 0.1.5
                  Adapter    "wlanthermo-nano": 0.1.1
                  Adapter    "wled"          : 0.5.6
                  Adapter    "wm-bus"        : 0.3.1
                  Adapter    "wolf"          : 1.2.1
                  Adapter    "worx"          : 1.3.0
                  Adapter    "xbox"          : 0.7.7
                  Adapter    "xs1"           : 1.0.2
                  Adapter    "yahka"         : 0.13.1
                  Adapter    "yamaha"        : 0.4.0
                  Adapter    "yeelight-2"    : 1.0.3
                  Adapter    "youtube"       : 1.1.0
                  Adapter    "yr"            : 2.0.3
                  Adapter    "zigbee"        : 1.5.5
                  Adapter    "zoneminder"    : 0.3.3
                  Adapter    "zont"          : 0.5.4
                  Adapter    "zwave2"        : 1.10.0
                  pi@iobroker:~ $
                  pi@iobroker:~ $ iobroker upgrade self
                  Update js-controller from @3.2.16 to @3.3.8
                  NPM version: 6.14.12
                  npm install iobroker.js-controller@3.3.8 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                  npm ERR! Unexpected end of JSON input while parsing near '...,"@sentry/utils":"6.3'
                  npm ERR!     /home/iobroker/.npm/_logs/2021-05-07T06_29_23_039Z-debug.log
                  Starting node restart.js
                  pi@iobroker:~ $
                  pi@iobroker:~ $ iobroker start
                  leider weiß ich nicht, wie ich die log atei angezeigt bekomme
                  apollon77A
                  apollon77A
                  #222
                  @doerk32 Schau mal ob du eine package-lock.json in deinem /opt/iobroker verzeichnis hast ... benenn die mal um bzw move die mal weg. Gehts dann? Aber wenn ja dann hat es das File corrupted ... also Filesystem prüfen!
                  • F foxthefox
                    @apollon77
                    		common: {
                    			type: 'string',
                    			read: true,
                    			write: false,
                    			role: 'date',
                    			desc: name
                    					ack: true
                    Klaus
                    apollon77A
                    apollon77A
                    #223
                    @foxthefox WIe schreibst Du denn das Objekt? setObjectNotExists? Dann wird ja deine neue definition nicht übernommen weil Objekt schon da ist. Objekte bzw Instanz löschen, nach neu Schreiben sollten Sie da sein
                    • H
                      H
                      heinzie
                      #224
                      ich habe im Log diverse Fehlermeldungen, kann mir da jemand weiterhelfen
                      2021-05-04 13:53:57.006  - error: javascript.0 (664) Error in callback: TypeError: Cannot read property 'common' of null
                      2021-05-04 13:53:57.006  - error: javascript.0 (664)     at script.js.common.Ping:136:74
                      2021-05-04 13:53:57.006  - error: javascript.0 (664)     at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:801:29)
                      2021-05-04 13:53:57.006  - error: javascript.0 (664)     at writeHTML (script.js.common.Ping:132:41)
                      2021-05-04 13:53:57.006  - error: javascript.0 (664)     at Object.<anonymous> (script.js.common.Ping:191:2)
                      2021-05-04 13:53:57.006  - error: javascript.0 (664)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1301:34)
                      2021-05-04 13:53:57.007  - error: javascript.0 (664)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
                      2021-05-04 13:53:57.007  - error: javascript.0 (664)     at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11
                      2021-05-04 13:53:57.007  - error: javascript.0 (664)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7)
                      2021-05-04 13:53:57.007  - error: javascript.0 (664)     at listOnTimeout (internal/timers.js:554:17)
                      2021-05-04 13:53:57.007  - error: javascript.0 (664)     at processTimers (internal/timers.js:497:7)
                      • H heinzie
                        apollon77A
                        apollon77A
                        #225
                        @heinzie Ist entweder was in deinem Skript oder im javascript Adapter. Andere Baustelle. Bitte eigenen Thread oder Issue im Javascript adapter
                        • apollon77A apollon77
                          ChaotC
                          ChaotC
                          Chaot
                          #226
                          @apollon77
                          Ich habe jetzt über die Konsole mehrere Updates gemacht die plötztlich erschienen sind.
                          Hat alles auch geklappt bis auf eine Fehlermeldung:
                          host.ioBroker-Server
                          2021-05-08 11:19:10.209	error	Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker/iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json.new'. Try direct write as fallback
                          Hast du eine Idee wo ich suchen könnte?
                          Thomas BraunT foxriver76F apollon77A 3 Antworten Letzte Antwort
                          • ChaotC Chaot
                            @apollon77
                            Thomas BraunT
                            Thomas BraunT
                            #227
                            @chaot sagte in js-controller 3.3 jetzt im Latest:
                            Den Fehler hatte ich auch schon:
                            https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host/96
                            • ChaotC Chaot
                              @apollon77
                              foxriver76F
                              foxriver76F
                              foxriver76
                              #228
                              @chaot Kam davor noch eine Error-Meldung?
                                ChaotC
                                ChaotC
                                Chaot
                                #229
                                @foxriver76 Nö - Einzig und einsam diese Meldung.
                                Und auch nur ein einziges mal als ich die Updates gemacht habe.
                                apollon77A foxriver76F 2 Antworten Letzte Antwort
                                • ChaotC Chaot
                                  apollon77A
                                  apollon77A
                                  #230
                                  @chaot Welcher js-controller? 3.3.8?
                                  • ChaotC Chaot
                                    foxriver76F
                                    foxriver76F
                                    foxriver76
                                    #231
                                    @chaot mit Updates sind lediglich Adapter her meint oder auch Controller? Mit der aktuellen Version hatten wir gehofft, dass es nicht mehr vorkommt.
                                      ChaotC
                                      ChaotC
                                      Chaot
                                      #232
                                      @foxriver76
                                      @apollon77
                                      Controller Version 3.3.8.
                                      War aber schon vorher auf dieser Version.
                                      Bei den Updates wurden nur Adapter (incl. Admin von 5.0.15 auf 5.0.18) abgearbeitet.
                                      Da es über Nacht mehrere Adapter waren habe ich das bei gestoppten ioBroker über die Konsole ausgeführt. Das schien mir bequemer und schneller.
                                      • ChaotC Chaot
                                        @apollon77
                                        apollon77A
                                        apollon77A
                                        #233
                                        @chaot wie hast Du denn die updates gemacht?
                                        • iobroker lief oder nicht?
                                        • nacheinander mit einzelnenbefehlen? massenupdate?
                                        Mehr infos bitte :-)
                                        Und am besten auch das vollständigere Log
                                          F
                                          F
                                          foxthefox
                                          #234
                                          @apollon77
                                          Das war genau der springende Punkt. Gemäß dem allgemeinen Regeln habe ich ......NotExists" verwendet und klar, damit wird nichts neu angelegt.
                                          Hätte man auch drauf kommen können, aber manchmal steht man auf dem Schlauch.
                                          SUPER. Danke.
                                          Klaus
                                          Ein Aufruf: video
                                          83.8k
