  4. [gelöst]: Easymeter bzw. Smart Grid Hub über Javascript auslesen (JSON)
27 Beiträge 6 Kommentatoren 5.4k Aufrufe
  • paul53P Offline
    Vorschlag (URL anpassen !):
    // Easymeter auslesen
    var request = require('request');
    var pfad = "Easymeter.";
    var idpower       = pfad + "Leistung";
    var idheute       = pfad + "Ertrag-heute";
    var idgestern     = pfad + "Ertrag-gestern";
    var url = 'http://192.168.2.8/json.txt?LogName=xxx&LogPSWD=xxx';
     createState(idpower, 0, {
        desc: 'Momentanleistung',
        type: 'number',
        role: 'value',
        unit: 'W'
    createState(idheute, 0, {
        desc: 'Ertrag Tag',
        type: 'number',
        role: 'value',
        unit: 'kWh'
    createState(idgestern, 0, {
        desc: 'Ertrag Vortag',
        type: 'number',
        role: 'value',
        unit: 'kWh'
    function main() {
        request(url, function (err, state, body) {
            if(!err && state.statusCode == 200) {
                var values = JSON.parse(body)['billingData:'].values;
                log("Momentanleistung: " + values[2].value,"info");
                log("Ertrag Tag: "       + values[9].value,"info");
                log("Ertrag Vortag: "    + values[10].value,"info");
                setState(idpower  , values[2].value);
                setState(idheute  , values[9].value);
                setState(idgestern, values[10].value);
            } else {
                log("Fehler: " + err + " bei Abfrage von: " + url, "warn");
    schedule("*/10 * * * *", main); // alle 10 Minuten die Werte abfragen
    // Beim Skriptstart die Werte abfragen
    setTimeout(main,500);
    EDIT: Änderung billingData –> billingData:
      moebius
      Mein Vorschlag mit node-red
      [{"id":"7a597ace.f170e4","type":"debug","z":"93e48696.f68df8","name":"","active":true,"console":"false","complete":"true","x":1251,"y":225,"wires":[]},{"id":"125b9ea.0eb4161","type":"inject","z":"93e48696.f68df8","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":96,"y":50,"wires":[["75cd084a.68c538"]]},{"id":"8a0eb211.ba2a4","type":"json","z":"93e48696.f68df8","name":"","x":420,"y":114,"wires":[["1e3d4d89.714152"]]},{"id":"1e3d4d89.714152","type":"change","z":"93e48696.f68df8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.billingData:.values","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":587,"y":151,"wires":[["daac6ae9.37e7e8"]]},{"id":"daac6ae9.37e7e8","type":"split","z":"93e48696.f68df8","name":"","splt":"\\n","x":739,"y":206,"wires":[["17fba018.d0f18"]]},{"id":"cac2d016.c7dc6","type":"change","z":"93e48696.f68df8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1070,"y":324,"wires":[["7a597ace.f170e4"]]},{"id":"17fba018.d0f18","type":"switch","z":"93e48696.f68df8","name":"","property":"payload.obis","propertyType":"msg","rules":[{"t":"eq","v":"0101020800FF","vt":"str"}],"checkall":"true","outputs":1,"x":866,"y":276,"wires":[["cac2d016.c7dc6"]]},{"id":"75cd084a.68c538","type":"http request","z":"93e48696.f68df8","name":"","method":"GET","ret":"txt","url":"http://192.168.2.8/json.txt?LogName=xxx&LogPSWD=xxx","tls":"","x":247,"y":92,"wires":[["8a0eb211.ba2a4"]]}]
      ````Der flow extrahiert als Beispiel den Wert für orbis 0101020800FF. Vorteil: kein Zugriff über Array und 90% weniger zu schreiben :)
      • apollon77A Online
        apollon77A Online
        Hey,
        ich baue gerade einen Adapter der solche Werte per Seriell/IR ausliesst und so. Geht bei mir mit SML (mein eHz-Stromzähler9 und auch bei meiner Fernwärmestation (dort per D0).
        Wenn das fertig ist wäre es denke ich auch eine Idee das Format von Eurem Zähler dort mit einzubauen.
        nach aktueller Idee (weil ich den Adapter schon generisch halten will) wären die Datenpunkte aber die verwendeten OBIS-Nummern (also das "1.8.1") … aber wenn man ja weiss was was ist dann ist das ja benutzbar.
        Macht das Sinn?
        Ingo F
        • apollon77A Online
          apollon77A Online
          PS: Welche anderen Formate sind denn per HTTP noch erreichbar? SML auch? Dann wäre es noch einfacher weil ich das schon parsen kann.
          Habt Ihr mal ne Doku?
          • I Offline
            I Offline
            ichderarnd
            Es geht um dieses Gerät:
            http://www.efr.de/fileadmin/content/dow … NEU_DE.pdf
            Die Beschreibung der Schnittstelle finde ich grade nicht auf dem EFR Server. Sie liegt aber z.B. hier:
            http://www.sev-soemmerda.de/de/Strom/Sm … id-Hub.pdf
            Was anderes als JSON per http geht meines Wissens nicht. Klappt aber gut!
            Ich hatte ebenfalls daran gedacht, daraus einen Adapter zu bauen. Habe mich in die Adapter-Entwicklung aber bisher noch nicht eingelesen. Würde also noch etwas dauern.
            Viele Grüße
            arndl
            • apollon77A Online
              apollon77A Online
              Ich schaue mal rein
              • apollon77A Online
                apollon77A Online
                Laut Produktinformationen hat das Ding auch IR … Da kommt binärkodiertes SML raus ... Das kann ich schon direkt :-)
                Aber ich schaue mal das ich in meinen Adapter auch ne URL Option einbaue wo man dieses Format parsen kann, Am Ende bauen die nur SML in ein JSON um ...
                • I Offline
                  I Offline
                  ichderarnd
                  Stimmt… SML ist in den technischen Daten mit aufgeführt. Bisher sagt mir das Protokoll allerdings nichts.
                  Ob das Gerät das über Ethernet spricht? Für SML scheint das Übertragungsmedium nicht festgelegt zu sein.
                  Den "Parser" für das EFR JSON Format habe ich ja weiter oben gepostet. Der funktioniert so, wie er da steht.
                  arndl
                  • apollon77A Online
                    apollon77A Online
                    Das Parsen des JSON ist nicht das Thema :-)
                    Also am Ende ist der Smart Grid Hub nur ein Aufsatz auf den Easymeter-Zähler und holt dort per SML die Daten alle paar Sekunden ab und bereitet diese auf und stellt Sie zur Verfügung.
                    Wird in der ersten version mit drin sein …
                      MIKAMI
                      Hallo Zusammen,
                      vielen Dank für die schnelle Hilfe und konstruktiven Vorschläge. Das Script von Arndl funktioniert und ließt auf jedenfall schon mal einige Werte aus dem Easymeter aus. Das Script von paul53 ist einfacher (da natürlich weniger Werte) scheint aber irgendwie nicht zu funktionieren. Es kommt zu folgender Fehlermeldung:
                      javascript.0 2017-01-17 19:52:04.579 info terminating
                      javascript.0 2017-01-17 19:52:04.569 error at emitNone (events.js:72:20)
                      javascript.0 2017-01-17 19:52:04.569 error at IncomingMessage.g (events.js:260:16)
                      javascript.0 2017-01-17 19:52:04.569 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1001:12)
                      javascript.0 2017-01-17 19:52:04.569 error at Request.emit (events.js:169:7)
                      javascript.0 2017-01-17 19:52:04.569 error at emitOne (events.js:77:13)
                      javascript.0 2017-01-17 19:52:04.569 error at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1081:10)
                      javascript.0 2017-01-17 19:52:04.569 error at Request.emit (events.js:172:7)
                      javascript.0 2017-01-17 19:52:04.569 error at emitTwo (events.js:87:13)
                      javascript.0 2017-01-17 19:52:04.569 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
                      javascript.0 2017-01-17 19:52:04.569 error at Request._callback (script.js.Scripte.Easymeter:38:54)
                      javascript.0 2017-01-17 19:52:04.569 error TypeError: Cannot read property 'values' of undefined
                      javascript.0 2017-01-17 19:52:04.555 error uncaught exception: Cannot read property 'values' of undefined
                      javascript.0 2017-01-17 19:52:03.900 info script.js.Scripte.Easymeter: registered 0 subscriptions and 1 schedule
                      Falls es zu den Logs noch eine Vorschlag zur Abhilfe gibt gerne, ansonsten werde ich mal versuchen am Wochenende das Script von arndl auf meine Bedürfnisse zu reduzieren (das sollte ja kein Problem sein)
                      Danke auch an moebius. An node-red habe ich mich allerdings bis jetzt noch nicht rangewagt (kommt sicherlich noch…)
                      Vielen Dank
                      Michael
                      • paul53P Offline
                        Ich hatte das Skript nachträglich korrigiert (Zeile 3):
                        Ist das in Deinem Skript enthalten ?
                          MIKAMI
                          Ja, die Codezeile ist im Script enthalten…
                          • paul53P Offline
                            Dann versuch das mal:
                                type: 'number',
                                role: 'value',
                                unit: 'W'
                                desc: 'Ertrag Tag',
                                type: 'number',
                                role: 'value',
                                unit: 'kWh'
                                type: 'number',
                                role: 'value',
                                unit: 'kWh'
                            function main() {
                                        var result;
                                        try{
                                            result = JSON.parse(body);
                                            log('JSON response: ' + JSON.stringify(result, null, 2), 'debug');
                                        } catch (e) {
                                            log('JSON parse error:' + e, 'error');
                                        if (result) {
                                            var values = result.billingData.values;
                                    } else {
                            • blauholstenB Offline
                              blauholsten
                              @paul53:
                              Ist das in Deinem Skript enthalten ? `
                              Kann es sein das durch das asyncrone verhalten von "request" das Object noch nicht geladen ist?
                              - Alarm Adapter
                                blauholsten
                                Kannst ja mal das probieren…
                                    type: 'number',
                                    role: 'value',
                                    unit: 'W'
                                    desc: 'Ertrag Tag',
                                    type: 'number',
                                    role: 'value',
                                    unit: 'kWh'
                                    type: 'number',
                                    role: 'value',
                                    unit: 'kWh'
                                function write(values){
                                function main() {
                                            try{
                                                var values = JSON.parse(body).billingData.values;
                                                setTimout(function(){
                                                write(values)},100);
                                            catch(e){
                                                log(e + "parsen fehlgeschlagen");
                                        } else {
                                - Alarm Adapter
                                  MIKAMI
                                  Hallo Zusammen,
                                  danke für die Rückmeldungen. Das Script von blauholsten bringt leider ebenfalls einen Fehler:
                                  javascript.0 2017-01-18 19:20:00.568 info javascript.0 script.js.Scripte.Easymeter_1: TypeError: Cannot read property 'values' of undefinedparsen fehlgeschlagen
                                  javascript.0 2017-01-18 19:18:42.130 info script.js.Scripte.Easymeter_1: TypeError: Cannot read property 'values' of undefinedparsen fehlgeschlagen
                                  Das aktualisierte Script von paul53 bringt folgende Logeinträge
                                  javascript.0 2017-01-18 19:35:12.595 info terminating
                                  javascript.0 2017-01-18 19:35:12.579 error at emitNone (events.js:72:20)
                                  javascript.0 2017-01-18 19:35:12.579 error at IncomingMessage.g (events.js:260:16)
                                  javascript.0 2017-01-18 19:35:12.579 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1001:12)
                                  javascript.0 2017-01-18 19:35:12.579 error at Request.emit (events.js:169:7)
                                  javascript.0 2017-01-18 19:35:12.579 error at emitOne (events.js:77:13)
                                  javascript.0 2017-01-18 19:35:12.579 error at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1081:10)
                                  javascript.0 2017-01-18 19:35:12.579 error at Request.emit (events.js:172:7)
                                  javascript.0 2017-01-18 19:35:12.579 error at emitTwo (events.js:87:13)
                                  javascript.0 2017-01-18 19:35:12.579 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
                                  javascript.0 2017-01-18 19:35:12.579 error at Request._callback (script.js.Scripte.Easymeter_1_2:45:48)
                                  javascript.0 2017-01-18 19:35:12.579 error TypeError: Cannot read property 'values' of undefined
                                  javascript.0 2017-01-18 19:35:12.565 error uncaught exception: Cannot read property 'values' of undefined
                                  Mach ich evt. selbst einen Fehler? Für das Verständnis kann mir evt. mal jemand erklären wie ich hier auf die values [2],[9] und [10] im Script komme wenn im JSON Output die gewünschten Werte an einer anderen Stelle stehen? Warum ist im JSON Output der Wert meistens "value" nur einmal "values" und im Script "values* .value Ist evt. da der Fehler oder liegt es an meinen Nichtwissen bezüglich Javascript und JSON :?
                                  Danke und Gruß
                                  Michael
                                    blauholsten
                                    EDIT: Blödsinniger Post :oops:
                                    - Alarm Adapter
                                    • paul53P Offline
                                      Füge mal vor oder nach
                                      var result;
                                      ein und poste das Ergebnis:
                                      log('body: ' + body);
                                      • I Offline
                                        I Offline
                                        ichderarnd
                                        @MIKAMI:
                                        Danke und Gruß
                                        Michael
                                        Hallo Michael,
                                        guck Dir mal die Zeile:
                                        var billingData = result["billingData:"];
                                        aus meinem Code weiter oben im Post an. EFR hat da leider einen Doppelpunkt in das "billingData" gebastelt…
                                        Wenn Du es so löst, sollte es auch mit den anderen Beispielen klappen.
                                        Viele Grüße
                                        arndl `
                                        • paul53P Offline
                                          @arndl:
                                          EFR hat da leider einen Doppelpunkt in das "billingData" gebastelt… `
                                          Stimmt, habe ich glatt übersehen :? Dann muss die Zeile
                                          geändert werden in
                                                          var values = result["billingData:"].values;
