  4. Xiaomi Smartmi Air Humidifier2
121 Beiträge 23 Kommentatoren 24.4k Aufrufe 21 Beobachtet
  • P Pittini
    @maxim-777 Schau mal unter
    /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices
    ob dort die deerma.humidifier.jsq.js vorhanden ist, bzw. kopier die mal von da
    https://github.com/Pittini/iobroker-nodemihome/tree/main/DefinitionfilesForNode-Mihome
    dort rein. Dann JS Adapter neustarten und guggen obs dann geht. Wenn nicht, Log posten.
    Maxim-777
    schrieb am zuletzt editiert von Maxim-777
    #73
    @pittini Ich habe die Daten kopiert, danke @Thomas-Braun,
    leide bekomme ich folgende Fehler Log:
    javascript.0	2021-04-22 21:11:24.570	error	(1540) at Script.runInContext (vm.js:130:18)
    javascript.0	2021-04-22 21:11:24.570	error	(1540) at script.js.common.test:859:3
    javascript.0	2021-04-22 21:11:24.569	error	(1540) at script.js.common.test:66:1
    javascript.0	2021-04-22 21:11:24.569	error	(1540) at Init (script.js.common.test:587:12)
    javascript.0	2021-04-22 21:11:24.568	error	(1540) script.js.common.test: TypeError: Cannot read property 'miioProtocol' of undefined
    javascript.0	2021-04-22 21:11:24.566	info	(1540) script.js.common.test: registered 0 subscriptions and 0 schedules
    javascript.0	2021-04-22 21:11:24.563	info	(1540) script.js.common.test: Starting AllMyMi V.0.2.11
    javascript.0	2021-04-22 21:11:24.562	error	(1540) at Script.runInContext (vm.js:130:18)
    javascript.0	2021-04-22 21:11:24.562	error	(1540) at script.js.common.test:859:3
    javascript.0	2021-04-22 21:11:24.561	error	(1540) at script.js.common.test:3:16
    javascript.0	2021-04-22 21:11:24.561	error	(1540) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:397:36)
    javascript.0	2021-04-22 21:11:24.560	error	(1540) at require (internal/modules/cjs/helpers.js:74:18)
    javascript.0	2021-04-22 21:11:24.560	error	(1540) at Module.require (internal/modules/cjs/loader.js:887:19)
    javascript.0	2021-04-22 21:11:24.559	error	(1540) script.js.common.test: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../node-mihome'
    javascript.0	2021-04-22 21:11:24.477	info	(1540) Start javascript script.js.common.test
    • M Maxim-777
      #74
      @maxim-777 Hast du nodemi-home denn jetzt auch im javascript-Adapter eingetragen?
        Maxim-777
        #75
        @thomas-braun Ja, habe ich gemacht...
        • M Maxim-777
          #76
          @maxim-777
          Hier läuft's.
          Musst du @Pittini Mal fragen.
          • P Pittini
            Maxim-777
            #77
            @pittini Habe jetzt komplett neu raspi+ Iobroker installiert dann Javascript + im Javascript Adapter als Zusatzmodul eingetragen "node-mihome" und setObject zugelassen, dann Adapter gestartet LOG:
            javascript.0	2021-04-22 22:01:02.599	info	(12087) received all states
            javascript.0	2021-04-22 22:01:02.586	info	(12087) received all objects
            javascript.0	2021-04-22 22:01:02.310	info	(12087) requesting all objects
            javascript.0	2021-04-22 22:01:02.308	info	(12087) requesting all states
            javascript.0	2021-04-22 22:01:02.197	info	(12087) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
            host.raspberrypi	2021-04-22 22:00:59.620	info	instance system.adapter.javascript.0 started with pid 12087
            host.raspberrypi	2021-04-22 22:00:59.542	info	"system.adapter.javascript.0" enabled
            host.raspberrypi	2021-04-22 22:00:26.175	info	instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            javascript.0	2021-04-22 22:00:25.627	info	(12009) Terminated (NO_ERROR): Without reason
            javascript.0	2021-04-22 22:00:25.623	info	(12009) terminating
            javascript.0	2021-04-22 22:00:25.609	info	(12009) Got terminate signal TERMINATE_YOURSELF
            host.raspberrypi	2021-04-22 22:00:25.607	info	stopInstance system.adapter.javascript.0 send kill signal
            javascript.0	2021-04-22 22:00:25.588	info	(12009) Stop script script.js.Test
            host.raspberrypi	2021-04-22 22:00:25.587	info	stopInstance system.adapter.javascript.0 (force=false, process=true)
            host.raspberrypi	2021-04-22 22:00:25.585	info	"system.adapter.javascript.0" disabled
            javascript.0	2021-04-22 22:00:25.583	info	(12009) Adapter is disabled => stop
            javascript.0	2021-04-22 22:00:03.153	info	(12009) script.js.Test: Setting trigger #0 for deerma.humidifier.jsq
            javascript.0	2021-04-22 22:00:03.153	info	(12009) script.js.Test: Init Device# 0 - device="deerma.humidifier.jsq"
            javascript.0	2021-04-22 22:00:02.745	info	(12009) script.js.Test: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"239969578","address":"192.168.178.63","token":"47555d87e284070b8920da3b129e1ede","protocol":"local","re
            javascript.0	2021-04-22 22:00:02.741	info	(12009) script.js.Test: Now creating device for deerma.humidifier.jsq / 239969578 / 192.168.178.63 / 47555d87e284070b8920da3b129e1ede / 10000
            javascript.0	2021-04-22 22:00:02.712	info	(12009) script.js.Test: Device Mi Smart Antibacterial Humidifier is supported, creating DataPoints
            javascript.0	2021-04-22 22:00:02.711	info	(12009) script.js.Test: Now searching for supported Devices...
            javascript.0	2021-04-22 22:00:02.710	info	(12009) script.js.Test: RoboCop
            javascript.0	2021-04-22 22:00:02.709	info	(12009) script.js.Test: Mi Smart Antibacterial Humidifier
            javascript.0	2021-04-22 22:00:02.708	info	(12009) script.js.Test: Found 2 MiHome Devices, those are:
            javascript.0	2021-04-22 22:00:02.581	info	(12009) script.js.Test: Retrieving your in de registered MiHome Devices
            javascript.0	2021-04-22 21:59:59.885	info	(12009) script.js.Test: registered 0 subscriptions and 0 schedules
            javascript.0	2021-04-22 21:59:59.838	info	(12009) script.js.Test: Starting AllMyMi V.0.2.11
            javascript.0	2021-04-22 21:59:59.657	info	(12009) Start javascript script.js.Test
            javascript.0	2021-04-22 21:59:59.551	info	(12009) received all states
            javascript.0	2021-04-22 21:59:59.547	info	(12009) received all objects
            javascript.0	2021-04-22 21:59:59.285	info	(12009) requesting all objects
            javascript.0	2021-04-22 21:59:59.284	info	(12009) requesting all states
            javascript.0	2021-04-22 21:59:59.162	info	(12009) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
            host.raspberrypi	2021-04-22 21:59:56.524	info	instance system.adapter.javascript.0 started with pid 12009
            host.raspberrypi	2021-04-22 21:59:54.000	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            javascript.0	2021-04-22 21:59:53.443	info	(11958) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            javascript.0	2021-04-22 21:59:53.440	info	(11958) terminating
            Dann folgende Befehl ausgeführt:
            und danach Adapter neue gestartet, gleiche Fehler Log wie vorher :(
            P 1 Antwort Letzte Antwort
            • M Maxim-777
              Pittini
              #78
              @maxim-777 Hmm, die letzte Zeile aus dem Screenshot sagts, er findet node-mihome nicht. Sorry, das is Systemebene, wenn alles gemacht wurde wie Du sagst, weis ich auch nicht weiter, auffällig ist dass die meisten mit ähnlichen Problemen nen raspi verwenden. Ich hab aber keine Ahnung was da anders ist. Vielleicht haz @Dutchman ne Idee, ich muß passen an der Stelle, ich kanns auch nicht testen weil ich keinen raspi verwende.
              • P Pittini
                Maxim-777
                #79
                @pittini welche Betriebssystem verwendest du?
                • M Maxim-777
                  #80
                  @maxim-777
                  Hast du dieses Verzeichnis?
                  /opt/iobroker/node_modules/node-mihome
                    @maxim-777
                    Maxim-777
                    #81
                    @thomas-braun ich schaue abends nach... bin gerade bei der Arbeit
                    • M Maxim-777
                      #82
                      @maxim-777
                      Jedenfalls muss der iobroker-Adapter iobroker.mihome installiert sein.
                        @maxim-777
                        Maxim-777
                        #83
                        @thomas-braun du meinst diese Adapter?
                        • M Maxim-777
                          #84
                          @maxim-777 Ja. Auf den setzt das skript auf.
                          M 2 Antworten Letzte Antwort
                            Maxim-777
                            #85
                            @thomas-braun aha, den habe ich nicht installiert 😤 probiere ich abends. Danke für dein Tipp 🤝
                              Maxim-777
                              #86
                              @thomas-braun mal blöde frage: muss "Xiaomi MiHome Gateway" Adapter grün leuchten? Brauche ich dafür ein MiHome Gateway??
                              Nach den Installation "Xiaomi MiHome Gateway" Adapter habe ich folgende LOG (keine Fehler mehr, aber trotzdem keine werte):
                              javascript.0	2021-04-23 21:52:48.525	info	(8102) script.js.Test: Setting trigger #0 for deerma.humidifier.jsq
                              javascript.0	2021-04-23 21:52:48.524	info	(8102) script.js.Test: Init Device# 0 - device="deerma.humidifier.jsq"
                              javascript.0	2021-04-23 21:52:48.093	info	(8102) script.js.Test: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"239969578","address":"192.168.178.63","token":"47555d87e284070b8920da3b129e1ede","protocol":"local","refr
                              javascript.0	2021-04-23 21:52:48.089	info	(8102) script.js.Test: Now creating device for deerma.humidifier.jsq / 239969578 / 192.168.178.63 / 47555d87e284070b8920da3b129e1ede / 10000
                              javascript.0	2021-04-23 21:52:48.058	info	(8102) script.js.Test: Device Mi Smart Antibacterial Humidifier is supported, creating DataPoints
                              javascript.0	2021-04-23 21:52:48.057	info	(8102) script.js.Test: Now searching for supported Devices...
                              javascript.0	2021-04-23 21:52:48.056	info	(8102) script.js.Test: RoboCop
                              javascript.0	2021-04-23 21:52:48.054	info	(8102) script.js.Test: Mi Smart Antibacterial Humidifier
                              javascript.0	2021-04-23 21:52:48.053	info	(8102) script.js.Test: Found 2 MiHome Devices, those are:
                              javascript.0	2021-04-23 21:52:47.907	info	(8102) script.js.Test: Retrieving your in de registered MiHome Devices
                              javascript.0	2021-04-23 21:52:45.084	info	(8102) script.js.Test: registered 0 subscriptions and 0 schedules
                              javascript.0	2021-04-23 21:52:45.036	info	(8102) script.js.Test: Starting AllMyMi V.0.2.11
                              javascript.0	2021-04-23 21:52:44.865	info	(8102) Start javascript script.js.Test
                              javascript.0	2021-04-23 21:52:44.800	info	(8102) received all states
                              javascript.0	2021-04-23 21:52:44.795	info	(8102) received all objects
                              javascript.0	2021-04-23 21:52:44.523	info	(8102) requesting all objects
                              javascript.0	2021-04-23 21:52:44.521	info	(8102) requesting all states
                              javascript.0	2021-04-23 21:52:44.408	info	(8102) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
                              host.raspberrypi	2021-04-23 21:52:41.793	info	instance system.adapter.javascript.0 started with pid 8102
                              host.raspberrypi	2021-04-23 20:52:39.294	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              javascript.0	2021-04-23 20:52:38.693	info	(7866) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              javascript.0	2021-04-23 20:52:38.691	info	(7866) terminating
                              javascript.0	2021-04-23 20:52:38.677	info	(7866) Stop script script.js.Test
                              • M Maxim-777
                                #87
                                @maxim-777
                                Ich habe beides. Also ein Gateway und einen grün leuchtenden Adapter.
                                Ich weiß aber nicht wie weit die Unterstützung durch das Skript für die Hardware gehen sollte.
                                  @maxim-777
                                  Maxim-777
                                  #88
                                  @thomas-braun ach... dann geht es ohne Gateway wahrscheinlich nicht
                                  Thomas BraunT P 2 Antworten Letzte Antwort
                                  • M Maxim-777
                                    #89
                                    @maxim-777 Das kann ich dir nicht sagen.
                                    Wobei das Gateway eigentlich nur für Zigbee-Komponenten erforderlich sein sollte. Die Wifi-Geräte kommen ja darüber in das Netz.
                                    • M Maxim-777
                                      Pittini
                                      #90
                                      @maxim-777 sagte in Xiaomi Smartmi Air Humidifier2:
                                      Weder braucht man ein Gateway, noch den MiHome Adapter. Das Skript setzt viel früher an, und meldet sich selber an der Cloud an, bzw. die node-mihome, daran liegts nicht das is mal sicher.
                                        Maxim-777
                                        #91
                                        @pittini Guten Abend,
                                        hab gerade noch mal "node-mihome" installiert, jetzt bekomme ich keine Fehler in log, aber immer noch keine Werte in Datenpunkte, mal ne Idee?
                                        javascript.0	2021-04-25 21:41:19.221	info	(1688) script.js.Test: Setting trigger #0 for deerma.humidifier.jsq
                                        javascript.0	2021-04-25 21:41:19.220	info	(1688) script.js.Test: Init Device# 0 - device="deerma.humidifier.jsq"
                                        javascript.0	2021-04-25 21:41:18.837	info	(1688) script.js.Test: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"239969578","address":"192.168.178.63","token":"eb8d9d423828ac5240b14c348142c5ff","protocol":"local","refr
                                        javascript.0	2021-04-25 21:41:18.834	info	(1688) script.js.Test: Now creating device for deerma.humidifier.jsq / 239969578 / 192.168.178.63 / eb8d9d423828ac5240b14c348142c5ff / 10000
                                        javascript.0	2021-04-25 21:41:18.805	info	(1688) script.js.Test: Device Mi Smart Antibacterial Humidifier is supported, creating DataPoints
                                        javascript.0	2021-04-25 21:41:18.805	info	(1688) script.js.Test: Now searching for supported Devices...
                                        javascript.0	2021-04-25 21:41:18.804	info	(1688) script.js.Test: RoboCop
                                        javascript.0	2021-04-25 21:41:18.803	info	(1688) script.js.Test: Mi Smart Antibacterial Humidifier
                                        javascript.0	2021-04-25 21:41:18.801	info	(1688) script.js.Test: Found 2 MiHome Devices, those are:
                                        javascript.0	2021-04-25 21:41:18.645	info	(1688) script.js.Test: Retrieving your in de registered MiHome Devices
                                        javascript.0	2021-04-25 21:41:15.918	info	(1688) script.js.Test: registered 0 subscriptions and 0 schedules
                                        javascript.0	2021-04-25 21:41:15.871	info	(1688) script.js.Test: Starting AllMyMi V.0.2.11
                                        javascript.0	2021-04-25 21:41:15.597	info	(1688) Start javascript script.js.Test
                                        javascript.0	2021-04-25 21:41:15.533	info	(1688) received all states
                                        javascript.0	2021-04-25 21:41:15.529	info	(1688) received all objects
                                        javascript.0	2021-04-25 21:41:15.252	info	(1688) requesting all objects
                                        javascript.0	2021-04-25 21:41:15.250	info	(1688) requesting all states
                                        javascript.0	2021-04-25 21:41:15.137	info	(1688) starting. Version 5.1.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
                                        host.raspberrypi	2021-04-25 20:41:12.283	info	instance system.adapter.javascript.0 started with pid 1688
                                        host.raspberrypi	2021-04-25 20:41:09.856	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        javascript.0	2021-04-25 20:41:09.252	info	(1537) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        javascript.0	2021-04-25 20:41:09.249	info	(1537) terminating
                                        javascript.0	2021-04-25 20:41:09.243	info	(1537) Stop script script.js.Test
                                        • M Maxim-777
                                          Pittini
                                          #92
                                          @maxim-777 Wenn Du node-mihome neuinstallierst, must Du die deerma.humidifier.jsq.js aus meinem Git Verzeichnis da wieder reinkopieren.
